CT-G Series Specification
Compact Non-contact Infrared Thermometer
Temperature Range, Field-of-View
Dimensions / Pins and Wiring colors
unit: mm
CT - □G
Temp. code
Measurement range
FOV (field of view)
100
-20℃ … 100℃
7.16°
e.g. Model CT-100G has a 7.16° field of view and provides Object
The shield wire is connected to the GND wire.
temperatures of -20…100℃.
Product Specifications
If not otherwise noted, 25℃ ambient temperature, 5V supply voltage were applied.
Parameter
min
Typ
Max
Unit
Supply voltage
4.75
5
12
V
Supply current
15
mA
No.
Wire Color
Description
1
Red
VDD (5V)
2
Yellow or Black
Ground
3
White
RS485 D-
4
Blue or Green
RS485 D+
5
None
None
Calculate Field of View
The FOV determines the size of the infrared measurement area
Spectral range
Operating temperature
8
14
-20
70
10
Hz
IR refresh rate
10
Response time
1
Hz
Object 20~41℃
±0.3
else(0~20, 41~100℃)
±1
0.01
according to the distance.
unit: mm
Angle
FOV
7.16°
Accuracy
Resolution digital
Emission coefficient
0.1
Standard start-up time
Stabilization time
0.99
1.0
1
2
sec
1
Ø12 ⅹ55mm(long)
Thread mounting
M12 ⅹ 1mm pitch
Cable length
about 1m (39.37 inch)
Weight with cable
36g
Cable interface
molex 5264-05
protocol
Relative humidity
any given distance from the sensing head and assumes 50% energy.
min
Dimensions
Communication interface/
2 ⅹ tan( 7.16° 2) ⅹ distance(mm) + 6.65 (mm)
The optical chart below indicates the nominal target spot diameter at
Accessories
nut
(assembled to the body.)
Protective cap
RS-485/ Modbus-RTU
(Remove when using)
2 pcs
1 pc
95% Max. non-condensing
*: Accuracy is only effective if the object is fully covered by the
Molex 5267-05A-X
1 pc
sensor's FOV and applicable to stable temperature conditions.
Page 1 of 3
1.0.0
Modbus-RTU Register Table
- BaudRate: 19,200 bps(fixed), data bit: 8, stop bit: 1, parity: none, flow control: none.
Address
Length
- R = Read
Description
- W = Write (single write)
R/W
Dec
Hex
(short)
40,000
0x9C40
1
Device ID (1 ~ 200), Modbus broadcast not supported.
R/W
40,001
0x9C41
1
Emissivity (10~100. default : 99) (*)
R/W
40,002
0x9C42
1
Object temperature
R
40,003
0x9C43
1
Ambient temperature
R
*: “99” means emissivity “0.99”. To adjust the emissivity to 0.98, write 98 not 0.98.
Support Modbus function codes
- Read Holding Registers 03 (0x03)
- Write Single Register: 06 (0x06)
Object Temperature: To, Ambient Temperature: Ta
To is the object temperature derived from thermopile and ambient sensor outputs.
Ta stands for ambient temperature.
0x3BFB(read data) = 15,355(dec) → 15,355 * 0.02 - 273.15 = 33.95℃
0x3365(read data) → 13,157(dec) → 13,157 * 0.02 - 273.15 = -10.01℃
Output Data limit (object temperature): -19.99℃ … 105.01℃
Request & Response timing
- Request cycle: ≥100ms
- First data request time after Power-on: ≥ 1 sec
- Timeout: ≥ 25ms
Request cycle
≥100ms
5~15 ms
Response delay
Request
Response: ≤10ms
Note. If there is an error in the request sequence (including crc), there is no response data.
Products handling precaution
※ When it comes to dust removal by air, the best method is to use a blower, and to avoid using compressed air.
※ Do not press the lens with your hands or any other object.
※ Do not scratch the lens surface with sharp objects.
※ Voluntary disassembly and modification of the product is prohibited.
※ Avoid direct sunlight, chemical substance, heat or fire.
※ Water resistance is not guaranteed.
Page 2 of 3
1.0.0
PC Software
The program runs in the Windows 10 environment.
It is not guaranteed to be used on other OS.
For more information, refer to the Test Board manual.
https://www.diwellshop.com/web/en/CT-G/CT-G_Testboard_en.pdf
Additional information
Manufacturer: DIWELL Electronics Co., Ltd. (South Korea)
Technical support: mailto:expoeb2@diwell.com, mailto:dsjeong@diwell.com
Revision history
Version
Date(Y,M,D)
1.0.0
2022. 5. 9.
Page 3 of 3
Description
First version is released
1.0.0
很抱歉,暂时无法提供与“CT-100G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1875.648541+243.63723
- 5+1754.689225+227.92523
- 10+1709.5923510+222.06738
- 25+1655.5906125+215.05282
- 50+1618.6214850+210.25072
