AS229701TN2SA
AS229701TN2SA
    KHATOD
    透镜 白色 胶合剂
AS229701TN2SA 数据手册
180° 15 0° 0° 15 TECHNICAL DEPT. Lenses Test Report 0° 12 12 0° AS229701TN2SA - Counterbeam optic for tunnel entrance lighting - 55° Max cd 90° 90° 60 ° 60 ° 30 30 ° ° 0° Self-adhesive Fixing • • • • • Material = PMMA HT Angle 55° max Candela Full angle at 50% from maximum: ~ 100°x120° Full angle at 10% from maximum: ~ 130°x140° The light spots here represented refer to tests carried out with 1 LED 5.0x5.0mm and ~ 605 Lumen www.khatod.com technical@khatod.com Page 3 - November 2021 TECHNICAL DEPT. Lenses Test Report ETIPLLSA2039 - Fixing Adhesive Tape Technical Drawing 3 High Strength Double Coated Tape with Adhesive 300LSE 9474LE • 9495LE Technical Data Product Description 3M™ High Strength Double Coated Tape with Adhesive 300LSE 9474LE • 9495LE Typical Physical Properties and Performance Characteristics November, 2008 3M™ Double Coated Tapes with 3M™ Adhesive 300LSE provides high bond strength to most surfaces, including many low surface energy plastics such as polypropylene and powder coated paints. The acrylic adhesive also provides excellent adhesion to surfaces contaminated lightly with oil typically used with machine parts. Note: The following technical information and data should be considered representative or typical only and should not be used for specification purposes. Product Number 3M™ Double Coated Tapes 9474LE, 9495LE Adhesion to stainless steel ASTM D3330 - 180 degree 2 mil polyester as backing - 72 hour RT 100 (113) / 105 (119) Adhesion to stainless steel ASTM D3330 - 90 degree 2 mil al foil - 15 minute RT Construction Product Number 3M™ Double Coated Tape 9474LE 3M™ Double Coated Tape 9495LE Total Tape Thickness (w/o liner) 0.0067" (0.17mm) 0.0067" (0.17mm) Faceside1 Adhesive Type/ Thickness Carrier Type/ Thickness Backside2 Adhesive Type/ Thickness Liner Caliper3 0.0028" Clear Polyester 0.0034" Faceside Liner/ 0.0042" (0.071mm) 0.0005" (0.086mm) Tan, 58# (0.11mm)/ (0.013mm) Polycoated Kraft, 0.0042" no print (0.11mm) Backside liner/ Tan, 58#, Polycoated Kraft, “3M 300LSE” 0.0028" Clear Polyester 0.0034" Tan, 58#, 0.0042" (0.071mm) 0.0005" (0.086mm) Polycoated Kraft, (0.11mm) (0.013mm) “3M 300LSE” Note 1: Faceside (FS) adhesive is on the interior of the roll, exposed when unwound. Note 2: Backside (BS) adhesive is on the exterior of the roll, exposed when liner is removed. Note 3: The caliper listed is based on a calculation from manufacturing controlled adhesive coat weights using a density of 1.012 g/cc. Oz/in (N/100 mm) Faceside / Backside 70 (79) / 80 (90) - 72 hour RT Liner Color, Type, Print Oz/in (N/100 mm) Faceside / Backside 85 (96) / 100 (113) - 72 hour 158°F (70°C) 106 (119) / 130 (147) Adhesion to other surfaces ASTM D3330 - 90 degree, 2 mil al foil, 72 hour RT Oz/in (N/100 mm) Faceside / Backside ABS 100 (124) / 90 (102) Polypropylene 90 (102) / 80 (90) Polycarbonate 150 (169) / 140 (158) Glass 90 (102) / 100 (113) Shear Strength - ASTM D3654 Modified – (.5 inch2 sample size) 1000 grams at 72°F (22°C) >10,000 minutes 500 grams at 158°F (70°C) >10,000 minutes Relative High Temperature Operating Ranges: Long Term (days, weeks) 200°F (93°C) Short Term (minutes, hours) 300°F (149°C) Relative Solvent Resistance: www.khatod.com technical@khatod.com Very Good Page 8 - November 2021 TECHNICAL DEPT. Lenses Test Report Assembly Specifications AS229701TNxSA Self-Adhesive Tape Self-Adhesive Tape Press down Heat Sink Circuit Board AS229704TNx Heat Sink 1 Screw M3: Maximum tightening torque ~ 0.4/0.6 Nm Circuit Board 2 Pre-fractured for customized modules www.khatod.com technical@khatod.com Page 9 - November 2021 TECHNICAL DEPT. Lenses Test Report Application Examples www.khatod.com technical@khatod.com Page 10 - November 2021 TECHNICAL DEPT. Lenses Test Report Thermal shock resistance level Initial Visual Inspection Visual inspection to check the lens integrity before the test The part resulted physically intact. The reference temperature of the component under test is 105° C. Photo: the lens in the climatic chamber. Temperature stress in the climatic chamber Temperature detected on the part by IR thermal camera Final Visual Inspection After testing, an expective view is made with positive result (view photo) In the picture: the lens in the climatic chamber after testing. Based on the testing result, AS229701TNxSA test specimens provided to overcome the thermal stress test up to 105°C without any physical deterioration of the material. www.khatod.com technical@khatod.com Page 11 - November 2021 TECHNICAL DEPT. Lenses Test Report Packaging AS229701TNxSA Item Quantity Total Lens Size (L*W*H) G.W. Trays 76 pcs per Tray 76 pcs 50*32 cm 0.8 Kg Outer Box 11 Trays per Outer Box 836 pcs 50*32*38 cm 13.8 Kg 836 Lenses / 11 Trays 11 Trays / Outer Box www.khatod.com technical@khatod.com Page 12 - November 2021 TECHNICAL DEPT. Lenses Test Report Materials Material PMMA HT AS2297xxTNx Temperature resistance: long-term exposure AS2297xxTNx Temperature resistance: short-term exposure Top -40°...110°C -40°...105°C up to + 110 °C Notes: • The optical values shown are the result of optical simulations carried out with LIGHTOOLS, ASAP and ZEMAX software systems. The optical simulations are carried out on the basis of the typical values provided in the LED manufacturers’ official datasheets. The photometric analysis has been carried out on physical samples. Use and Maintenance • • • DO NOT HANDLE OR INSTALL LENSES WITHOUT WEARING GLOVES, SKIN OILS MAY DAMAGE LENS OR LIGHT TRANSMISSION; CLEAN LENSES WITH MILD SOAP AND WATER AND A SOFT CLOTH; DO NOT USE ANY COMMERCIAL CLEANING SOLVENTS ON LENSES. Disclaimer Please note that flow lines and weld lines on the external surfaces of the lenses are acceptable if the optical performance of the lens is within the specifications. Should you require further information, please contact Khatod for advice. All lens testing must be subject to identical conditions as Khatod test condition. Khatod Optoelectronic, Milan, Italy, manufactures lenses for LEDs. Any other use of the lens shall void our liability and warranty. The lenses are an inert component to be used in the manufacture of various products. Our warranty and liability are limited only to the manufacture of the lens. You may not modify, copy, distribute reproduce, license or alter the lens and related materials of Khatod. Khatod does not warrant against damages or defects arising out of the use or misuse of the products; against defects or damage arising from improper installation, or against defects in the product or in its components. No warranty of any kind, expressed or implied, is made regarding the safety of the products. The entire risk as to the quality or performance of the product is with the buyer. In no event shall Khatod be liable for any direct, indirect, punitive, incidental, special, consequential damages, or any damages whatsoever arising out of or connected with the use or misuse of the product. Khatod shall not have any obligation with respect to the product or any part thereof, whether based on contract, tort, strict liability or otherwise. Buyer assumes all risks and liability from use of the product. The laws of Milan, Italy govern this product warranty and liability and you hereby consent to the exclusive jurisdiction and venue of courts in Milan, Italy in all disputes arising out of or relating to the use of this product. Production, marketing, distribution, sale of these products as well as their possible modifications and variations are only exclusive right of Khatod Optoelectronic. No company can perform any of these actions without written permission released by Khatod Optoelectronic. The information contained in this document is proprietary of Khatod Optoelectronic and may change without notice. REPRODUCTION PROHIBITED. www.khatod.com technical@khatod.com Page 14 - November 2021
AS229701TN2SA 价格&库存
很抱歉,暂时无法提供与“AS229701TN2SA”相匹配的价格&库存,您可以联系我们找货
