MIKROE-2218
MIKROE-2218
    MIKRO
    6LOWPAN T CLICK
MIKROE-2218 数据手册
CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 Radio • IEEE 802.15.4 compliant DSSS baseband modem with 250 kbps data rate • Excellent receiver sensitivity (-98 dBm) • Programmable output power up to +5 dBm • RF frequency range 2394-2507 MHz • Suitable for systems targeting compliance with worldwide radio frequency regulations: ETSI EN 300 328 and EN 300 440 class 2 (Europe), FCC CFR47 Part 15 (US) and ARIB STD-T66 (Japan) APPLICATIONS • IEEE 802.15.4 systems • ZigBee® systems • Industrial monitoring and control • Home and building automation • Automatic Meter Reading • Low-power wireless sensor networks • Set-top boxes and remote controls • Consumer electronics KEY FEATURES • State-of-the-art selectivity/co-existence Adjacent channel rejection: 49 dB Alternate channel rejection: 54 dB • Excellent link budget (103dB) 400 m Line-of-sight range • Extended temp range (-40 to +125°C) • Wide supply range: 1.8 V – 3.8 V • Extensive IEEE 802.15.4 MAC hardware support to offload the microcontroller • AES-128 security module • CC2420 interface compatibility mode Microcontroller Support Digital RSSI/LQI support Automatic clear channel assessment for CSMA/CA • Automatic CRC • 768 bytes RAM for flexible buffering and security processing • Fully supported MAC security • 4 wire SPI • 6 configurable IO pins • Interrupt generator • Frame filtering and processing engine • Random number generator • • Low Power RX (receiving frame, -50 dBm) 18.5 mA TX 33.6 mA @ +5 dBm TX 25.8 mA @ 0 dBm 0 16K+15 16K 16 bytes key E C bytes ciphertext A+F+C-1 C bytes plaintext 16N+15 16 bytes counter E+C+[NaN,3,7,15] [0,4,8,16] bytes encrypted MIC E+C E+C-1 A+F A+F-1 A CTR F bytes plaintext 16N+15 16N 16 bytes counter 16K+15 16K 16 bytes key Figure 37: Advanced security instructions 26.6 CTR / UCTR The CTR instruction will perform counter mode encryption on a configurable number C of plaintext bytes. It outputs C ciphertext bytes. The 2 least significant bytes of the counter are incremented after each 16 byte block of plaintext has been processed. 96 WWW.TI.COM CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 If the last block of plaintext is not 16 bytes long, only the required number of bits (from the MSB end) from the encryption is used in the XOR operation. The UCTR instruction performs counter mode decryption and is absolutely identical to the CTR instruction because counter mode encryption and decryption are symmetrical operations. 26.7 CBC-MAC The CBC-MAC instruction performs authentication. Note that if M[1:0]=0 no authentication code is output. For other values of M[1:0] the number of authentication bytes that are output is 2M[1:0]+1. If M[2]=0 the plaintext data is prefixed with the value of C expanded to 8 bits by concatenation of a 0 at the MSB end. 26.8 CCM / UCCM The CCM instruction uses both CBC-MAC and CTR to perform both authentication and encryption. It supports the CCM* mode of operation as specified in IEEE 802.14.5-2006 [2]. The authentication (CBC-MAC) part calculates a Message Integrity Code (MIC) over the address range A to A+F+C-1. The resulting MIC is encrypted with CTR mode encryption using the counter value with index 0. The encryption (CTR) part encrypts the address range A+F to A+F+C-1 using CTR mode encryption and counter values with index 1 and up, and thus generates C bytes of ciphertext. The output which is the concatenation of the ciphertext and the encrypted MIC is written to memory starting at address E. The UCCM instruction decrypts the ciphertext in the address range A+F to A+F+C-1 using CTR mode decryption. A MIC is then generated in the same way as for the CCM instruction, and compared to the MIC in the input data. The result of the MIC comparison is stored in the DPUSTAT register. 26.8.1 Inputs to the CCM and UCCM Instructions The input parameters to the CCM and UCCM instructions are described in detail in Figure 38 and Figure 39 with notes on how they related to the terminology used in the IEEE 802.15.4 specifications. WWW.TI.COM 97 CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 Figure 38: Details of the input parameters to the CCM instruction. Figure 39: Details of the input parameters to the UCCM instruction. 26.9 Examples from IEEE802.15.4-2006 This section contains a detailed step-by-step guide to reproducing the CCM* examples given in annex C of IEEE802.15.4-2006 [2]. The addresses that are used in these examples are chosen at random. Other addresses can be used as well. Note that all the parameters to the instructions in the examples use hex notation, and that section 13.3 describes the exact bit order that is required for the SPI communication. 98 WWW.TI.COM CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 26.9.1 Authentication Only Using CCM* This example uses a MAC beacon frame and demonstrates how to apply authentication using the CCM/UCCM instructions. //Write frame data to RAM //Start at address 0x200 MEMWR(A={02 00} D={08 d0 84 21 43 01 00 00 00 00 48 de ac 02 05 00 00 00 55 cf 00 00 51 52 53 54}) //Write key to RAM in reverse byte order //Start at address 0x230 MEMWR(A={02 30} D={cf ce cd cc cb ca c9 c8 c7 c6 c5 c4 c3 c2 c1 c0}) //Write concatenation of flags, nonce and counter to RAM in reversed byte order //Start at address 0x240 MEMWR(A={02 40} D={00 00 02 05 00 00 00 01 00 00 00 00 48 de ac 09}) //Do CCM operation with high priority //Append the output to the frame data (by setting the output address E to 0x000) CCM(P={01} K={23} C={00} N={24} A={200} E={000} F={1a} M={02}) The expected output from the CCM instruction is {22 3B C1 EC 84 1A B5 53}. To verify the authentication code in the receiver, the following steps are required. It is assumed that frame data is already present in RAM from address 0x200. //Write key to RAM in reverse byte order //Start at address 0x230 MEMWR(A={02 30} D={cf ce cd cc cb ca c9 c8 c7 c6 c5 c4 c3 c2 c1 c0}) //Write concatenation of flags, nonce and counter to RAM in reversed byte order //Start at address 0x240 MEMWR(a={02 40} D={00 00 02 05 00 00 00 01 00 00 00 00 48 de ac 09}) //Do UCCM operation with low priority UCCM(P={00} K={23} C={00} N={24} A={200} E={2c0} F={1a} M={02}) //Read DPUSTAT register at address 0x02C to check whether the authentication passed or not REGRD(A={2c}) 26.9.2 Encryption Only Using CCM* This example uses a MAC data frame and demonstrates how to apply encryption/decryption of the payload using the CCM/UCCM instructions. //Write frame data to RAM //Start at address 0x200 MEMWR(A={02 00} D={69 dc 84 21 43 02 00 00 00 00 48 de ac 01 00 00 00 00 48 de ac 04 05 00 00 00 61 62 63 64}) //Write key to RAM in reverse byte order //Start at address 0x230 MEMWR(A={02 30} D={cf ce cd cc cb ca c9 c8 c7 c6 c5 c4 c3 c2 c1 c0}) //Write concatenation of flags, nonce and counter to RAM in reversed byte order //Starting at address 0x240 MEMWR(A={02 40} D={00 00 04 05 00 00 00 01 00 00 00 00 48 de ac 01}) //Do CCM instruction. CCM(P={01} K={23} C={04} N={24} A={200} E={2c0} F={1a} M={00}) The expected output from the CCM instruction is {D4 3E 02 2B}. To decrypt the frame in the receiver, the following steps are required. It is assumed that the packed data is already present in RAM from address 0x200. //Write key to RAM in reverse byte order //Start at address 0x230 MEMWR(A={02 30} D={cf ce cd cc cb ca c9 c8 c7 c6 c5 c4 c3 c2 c1 c0}) //Write concatenation of flags, nonce and counter to RAM in reversed byte order //Starting at address 0x240 MEMWR(A={02 40} D={00 00 04 05 00 00 00 01 00 00 00 00 48 de ac 01}) //Decrypt the frame data and put the plaintext at address 0x2C0. UCCM(P={01} K={23} C={04} N={24} A={200} E={2c0} F={1a} M={00}) The expected output from the CCM instruction is {61 62 63 64}. WWW.TI.COM 99 CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 26.9.3 Combination of Encryption and Authentication Using CCM* This example uses a MAC command frame and demonstrates how to apply both encryption/decryption and authentication using the CCM/UCCM instructions. //Write frame data to RAM //Start at address 0x200 MEMWR(A={02 00} D={2b dc 84 21 43 02 00 00 00 00 48 de ac ff ff 01 00 00 00 00 48 de ac 06 05 00 00 00 01 CE}) //Write key to RAM in reverse byte order //Start at address 0x230 MEMWR(A={02 30} D={cf ce cd cc cb ca c9 c8 c7 c6 c5 c4 c3 c2 c1 c0}) //Write concatenation of flags, nonce and counter to RAM in reversed byte order //Starting at address 0x240 MEMWR(A={02 40} D={00 00 06 05 00 00 00 01 00 00 00 00 48 de ac 09}) //Do CCM instruction. //Replace the last byte in the plaintext frame with the cipehertext and encrypted MIC by setting the output address E to 0x000. CCM(P={01} K={23} C={01} N={24} A={200} E={000} F={1d} M={02}) The expected output from the CCM instruction is {D8 4F DE 52 90 61 F9 C6 F1}. To decrypt the frame in the receiver, the following steps are required. It is assumed that the packed data is already present in RAM from address 0x200. //Write key to RAM in reverse byte order //Start at address 0x230 MEMWR(A={02 30} D={cf ce cd cc cb ca c9 c8 c7 c6 c5 c4 c3 c2 c1 c0}) //Write concatenation of flags, nonce and counter to RAM in reversed byte order //Starting at address 0x240 MEMWR(A={02 40} D={00 00 06 05 00 00 00 01 00 00 00 00 48 de ac 09}) //Decrypt the frame data and authenticate the MIC. Note that the output address E is set to 0x000. UCCM(P={01} K={23} C={01} N={24} A={200} E={000} F={1d} M={02}) //Read DPUSTAT register at address 0x02C to check whether the authentication passed or not REGRD(A={2c}) The expected plaintext output from the UCCM instruction is {CE}. 100 WWW.TI.COM CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 27 Packet Sniffing Packet sniffing is a non-intrusive way of observing data that is either being transmitted or received by CC2520. The packet sniffer outputs a clock and a data signal which should be sampled on the rising edges of the clock. The two packet sniffer signals are observable as GPIO outputs. For accurate time stamping, the SFD signal should also be output. Because CC2520 only supports a data rate of 250kbps, the packet sniffer clock frequency is 250 kHz. The data is output serially with the MSB of each byte first, which is opposite of the actual RF transmission, but more convenient when processing the data. It is possible to use an SPI slave to receive the data stream. When sniffing frames in TX mode, the data that is read from the TX FIFO by the modulator is the same data that is output by the packet sniffer. However, if automatic CRC generation is enabled, the packet sniffer will NOT output these 2 bytes. Instead, it will replace the CRC bytes with 0x8080. This value can never occur as the last two bytes of a received frame (when automatic CRC checking is enabled), and thus it provides a way for the receiver of the sniffed data to separate frames that were transmitted by the CC2520 and frames that were received by the CC2520. When sniffing frames in RX mode, the data that is written to the RX FIFO by the demodulator is the same data that is output by the packet sniffer. In other words, the last two bytes are either the received CRC value or the CRC OK/RSSI/correlation/SRCRESINDEX value that may automatically replace the CRC value, depending on configuration settings. Note that in order to observe the packet sniffing data on GPIO pins, the packet sniffer module must be enabled in the MDMTEST1 register, and the correct GPIO configuration must be written to any of the GPIOn registers. WWW.TI.COM 101 CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 28 Registers The table below shows the memory mapping for the configuration registers in CC2520. The FREG registers are accessible with the REGRD and REGWR instructions. Registers in address space 0x000 to 0x01F (marked with gray) are also accessible with the BSET and BCLR instructions. The SREG registers are only accessible with the MEMRD and MEMWR instructions. Please also refer to Figure 11: CC2520 memory map for information on the rest of the address range. Table 20: Register overview Address (hex) +0x000 +0x001 +0x002 +0x003 FREG registers 0x000 FRMFILT0 FRMFILT1 SRCMATCH 0x004 SRCSHORTEN0 SRCSHORTEN1 SRCSHORTEN2 0x008 SRCEXTEN0 SRCEXTEN1 SRCEXTEN2 0x00C FRMCTRL0 FRMCTRL1 RXENABLE0 0x010 EXCFLAG0 EXCFLAG1 EXCFLAG2 0x014 EXCMASKA0 EXCMASKA1 EXCMASKA2 0x018 EXCMASKB0 EXCMASKB1 EXCMASKB2 0x01C EXCBINDX0 EXCBINDX1 EXCBINDY0 EXCBINDY1 0x020 GPIOCTRL0 GPIOCTRL1 GPIOCTRL2 GPIOCTRL3 0x024 GPIOCTRL4 GPIOCTRL5 GPIOPOLARITY 0x028 GPIOCTRL DPUCON 0x02C DPUSTAT FREQCTRL FREQTUNE 0x030 TXPOWER TXCTRL FSMSTAT0 FSMSTAT1 0x034 FIFOPCTRL FSMCTRL CCACTRL0 CCACTRL1 0x038 RSSI RSSISTAT 0x03C RXFIRST RXFIFOCNT TXFIFOCNT 0x040 CHIPID VERSION 0x044 EXTCLOCK MDMCTRL0 0x048 FREQEST RXCTRL 0x04C FSCTRL FSCAL0 FSCAL1 0x050 FSCAL2 FSCAL3 AGCCTRL0 AGCCTRL1 0x054 AGCCTRL2 AGCCTRL3 ADCTEST0 ADCTEST1 0x058 ADCTEST2 MDMTEST0 MDMTEST1 0x05C DACTEST0 DACTEST1 ATEST DACTEST2 0x060 PTEST0 PTEST1 RESERVED RXENABLE1 SREG registers MDMCTRL1 0x064-0x077 0x078 0x07C DPUBIST ACTBIST RAMBIST NOTE: When accessing unmapped addresses a MEMADDR_ERROR exception will be generated. This is valid for address space from 0x064 to 0x079 and addresses above 0x07F. Other unmapped addresses like i.e. 0x003 will not generate a MEMADDR_ERROR. 102 WWW.TI.COM CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 28.1 Register Settings Update This section contains a summary of the register settings that need to be updated from their default value. Note that these values must be written every time CC2520 has been in LPM2 and is being brought back to active mode. Table 21: Registers that need update from their default value Register name Address (hex) New value (hex) Description TXPOWER 030 32 Set 0 dBm output power. Use only the values listed in Table 17 in this register. CCACTRL0 036 F8 Raises the CCA threshold from about -108dBm to about 84 dBm input level. MDMCTRL0 046 85 Makes sync word detection less likely by requiring two zero symbols before the sync word. MDMCTRL1 047 14 Make it more likely to detect sync by removing the requirement that both symbols in the SFD must have a correlation value above the correlation threshold, and make sync word detection less likely by raising the correlation threshold. RXCTRL 04A 3F Adjust currents in RX related analog modules. FSCTRL 04C 5A Adjust currents in synthesizer. FSCAL1 04F 2B Adjust currents in VCO. AGCCTRL1 053 11 Adjust target value for AGC control loop. ADCTEST0 056 10 Tune ADC performance. ADCTEST1 057 0E Tune ADC performance. ADCTEST2 058 03 Tune ADC performance. 28.2 Register Access Modes The “Mode” columns in the tables below show what kind of accesses that are allowed for each bit. Table 22 shows the meaning of the different alternatives. Table 22: Register bits access modes Mode Description R Read W Write R0 Read constant zero R1 Read constant one W1 Only possible to write one W0 Only possible to write zero R* The value read is not the actual register value, but rather the value seen by the module. This is typically used where a configuration value may be generated automatically (through calibration, dynamic control etc.) or manually overridden with a register value. An example structure is shown below for the AGCCTRL2 register. WWW.TI.COM 103 CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 read_data write_data AGCCTRL2 register LNA_CURRENT_OE rf_input LNA 1 AGC module 0 Figure 40: Example hardware structure for the R* register access mode. 104 WWW.TI.COM CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 28.3 Register Descriptions The heading for each register is built up according to the following pattern: , A , R , FRMFILT0, A 0x000, R 0x0D, Frame filtering Bit no. Bit mnemonic Reset value Mode Description 7 RESERVED 0 R/W Reserved. Always write ‘0’ 6:4 FCF_RESERVED_MASK[2:0] 000 R/W Used for filtering on the reserved part of the frame control field (FCF). FCF_RESERVED_MASK[2:0] is AND'ed with FCF[9:7]. If the result is non-zero, and frame filtering is enabled, the frame is rejected. 3:2 MAX_FRAME_VERSION[1:0] 11 R/W Used for filtering on the frame version field of the frame control field (FCF). If FCF[13:12] (the frame version subfield) is higher than MAX_FRAME_VERSION[1:0], and frame filtering is enabled, the frame is rejected. 1 PAN_COORDINATOR 0 R/W Should be set high when the device is a PAN coordinator, to accept frames with no destination address (as specified in section 7.5.6.2 in 802.15.4(b)) 0 - Device is not PAN coordinator 1 - Device is PAN coordinator 0 FRAME_FILTER_EN 1 R/W Enables frame filtering. When this bit is set, CC2520 will perform frame filtering as specified in section 7.5.6.2 of 802.15.4(b), third filtering level. FRMFILT0[6:1] and FRMFILT1[7:1] together with the local address information, define the behavior of the filtering algorithm. 0 - Frame filtering off. (FRMFILT0[6:1], FRMFILT1[7:1] and SRCMATCH[2:0] are don't care). 1 - Frame filtering on. WWW.TI.COM 105 CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 FRMFILT1, A 0x001, R 0x78, Frame filtering Bit no. Bit mnemonic Reset value Mode Description 7 ACCEPT_FT_4TO7_RESERVED 0 R/W Defines whether reserved frames are accepted or not. Reserved frames have frame type = (100, 101, 110, 111). 0 - Reject 1 - Accept 6 ACCEPT_FT_3_MAC_CMD 1 R/W Defines whether MAC command frames are accepted or not. MAC command frames have frame type = 011. 0 - Reject 1 - Accept 5 ACCEPT_FT_2_ACK 1 R/W Defines whether acknowledgment frames are accepted or not. Acknowledgement frames have frame type = 010. 0 - Reject 1 - Accept 4 ACCEPT_FT_1_DATA 1 R/W Defines whether data frames are accepted or not. Data frames have frame type = 001. 0 - Reject 1 - Accept. 3 ACCEPT_FT_0_BEACON 1 R/W Defines whether beacon frames are accepted or not. Beacon frames have frame type = 000 0 - Reject 1 - Accept 2:1 MODIFY_FT_FILTER[1:0] 00 R/W These bits are used to modify the frame type field of a received frame before frame type filtering is performed. The modification does not influence the frame that is written to the RX FIFO. 00 : Leave as it is 01 : Invert MSB 10 : Set MSB to ‘0’ 11 : Set MSB to ‘1’ 0 106 RESERVED 0 R/W Reserved. Always write ‘0’ WWW.TI.COM CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 SRCMATCH, A 0x002, R 0x07, Source address matching and pending bits Bit no. Bit mnemonic Reset value Mode Description 7:3 RESERVED[4:0] 0x00 R/W Reserved. Always write ‘0’ 2 PEND_DATAREQ_ONLY 1 R/W When this bit is set, the AUTOPEND function also requires that the received frame is a "DATA REQUEST" MAC command frame. 1 AUTOPEND 1 R/W Automatic acknowledgment pending flag enable. Upon reception of a frame, the pending bit in the (possibly) returned acknowledgment will be set automatically, given that: - FRMFILT0.FRAME_FILTER_EN is set. - SRCMATCH.SRC_MATCH_EN is set. - SRCMATCH.AUTOPEND is set. - The received frame matches the current SRCMATCH.PEND_DATAREQ_ONLY setting. - The received source address matches at least one source match table entry, which is enabled in both SHORT_ADDR_EN and SHORT_PEND_EN or EXT_ADDR_EN and EXT_PEND_EN. Note: Details for SHORT_PEND_EN and EXT_PEND_EN is found in memory map description. 0 SRC_MATCH_EN 1 R/W Source address matching enable (This bit is “don’t care” if FRMFILT0.FRAME_FILTER_EN = 0) SRCSHORTEN0, A 0x004, R 0x00, Short address matching Bit no. Bit mnemonic Reset value Mode Description 7:0 SHORT_ADDR_EN[7:0] 0x00 R/W The 7:0 part of the 24-bit word SHORT_ADDR_EN that enables / disables source address matching for each of the 24 short address table entries. Optional safety feature: To ensure that an entry in the source matching table is not used while it is being updated, set the corresponding SHORT_ADDR_EN bit to 0 while updating. SRCSHORTEN1, A 0x005, R 0x00, Short address matching Bit no. Bit mnemonic Reset value Mode Description 7:0 SHORT_ADDR_EN[15:8] 0x00 R/W The 15:8 part of the 24-bit word SHORT_ADDR_EN See description of SRCSHORTEN0. SRCSHORTEN2, A 0x006, R 0x00, Short address matching Bit no. Bit mnemonic Reset value Mode Description 7:0 SHORT_ADDR_EN[23:16] 0x00 R/W The 23:16 part of the 24-bit word SHORT_ADDR_EN See description of SRCSHORTEN0. WWW.TI.COM 107 CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 SRCEXTEN0, A 0x008, R 0x00, Extended address matching Bit no. Bit mnemonic Reset value Mode Description 7:0 EXT_ADDR_EN[7:0] 0x00 R/W RO The 7:0 part of the 24-bit word EXT_ADDR_EN that enables / disables source address matching for each of the 12 extended address table entries. Write access: Extended address enable for table entry n (0 to 7) is mapped to EXT_ADDR_EN[2n]. All EXT_ADDR_EN[2n + 1] bits are read only and don’t care when written to. Read access: Extended address enable for table entry n (0 to 7) is mapped to both EXT_ADDR_EN[2n] and EXT_ADDR_EN[2n+1]. Optional safety feature: To ensure that an entry in the source matching table is not used while it is being updated, set the corresponding EXT_ADDR_EN bit to 0 while updating. SRCEXTEN1, A 0x009, R 0x00, Extended address matching Bit no. Bit mnemonic Reset value Mode Description 7:0 EXT_ADDR_EN[15:8] 0x00 R/W The 15:8 part of the 24-bit word EXT_ADDR_EN See description of SRCEXTEN0. SRCEXTEN2, A 0x00A, R 0x00, Extended address matching Bit no. Bit mnemonic Reset value Mode Description 7:0 EXT_ADDR_EN[23:16] 0x00 R/W The 23:16 part of the 24-bit word EXT_ADDR_EN See description of SRCEXTEN0. 108 WWW.TI.COM CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 FRMCTRL0, A 0x00C, R 0x40, Frame handling Bit no. Bit mnemonic Reset value Mode Description 7 APPEND_DATA_MODE 0 R/W When AUTOCRC = 0:Don’t care When AUTOCRC = 1: 0: RSSI + The crc_ok bit and the 7 bit correlation value is appended at the end of each received frame 1: RSSI + The crc_ok bit and the 7 bit SRCRESINDEX is appended at the end of each received frame. See Table 15 for details. 6 AUTOCRC 1 R/W In TX: 1: A CRC-16 (ITU-T) is generated in hardware and appended to the transmitted frame. There is no need to write the two last bytes to TXBUF. 0: No CRC-16 is appended to the frame. The two last bytes of the frame must be generated manually and written to TXBUF (if not, TX_UNDERFLOW will occur). In RX 1: The CRC-16 is checked in hardware, and replaced in the RX FIFO by a 16-bit status word which contains a CRC OK bit. The status word is controllable through APPEND_DATA_MODE 0: The last two bytes of the frame (crc-16 field) are stored in the RXFIFO. The CRC check (if any) must be done manually. Note that this setting does not influence acknowledgment transmission (including AUTOACK) 5 AUTOACK 0 R/W Defines whether CC2520 automatically transmits acknowledge frames or not. When autoack is enabled, all frames that are accepted by address filtering, have the acknowledge request flag set and have a valid CRC, are automatically acknowledged 12 symbol periods after being received. 0 - Autoack disabled 1 - Autoack enabled 4 ENERGY_SCAN 0 R/W Defines whether the RSSI register contains the most recent signal strength or the peak signal strength since the energy scan was enabled. 0 - Most recent signal strength 1 - Peak signal strength 3:2 RX_MODE[1:0] 00 R/W Set RX modes 00: Normal operation, use RXFIFO. 01: Reserved 10: RXFIFO looping ignore overflow in RXFIFO, infinite reception. 11: Same as normal operation except that symbol search is disabled. Can be used for RSSI or CCA measurements when it is undesired to find symbol. 1:0 TX_MODE[1:0] 00 R/W Set test modes for TX 00: Normal operation, transmit TXFIFO 01: Reserved. Should not be used. 10: TXFIFO looping ignore underflow in TXFIFO and read cyclic, infinite transmission. 11: Send pseudo random data from CRC, infinite transmission. WWW.TI.COM 109 CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 FRMCTRL1, A 0x00D, R 0x01, Frame handling Bit no. Bit mnemonic Reset value Mode Description 7:3 RESERVED 0x00 R0 Read as zero 2 PENDING_OR 0 R/W Defines whether the pending data bit in outgoing acknowledgment frames are always set to ‘1’ or controlled by the main FSM and the address filtering. 0 - Pending data bit is controlled by main FSM and address filtering 1 - Pending data bit is always ‘1’. 1 IGNORE_TX_UNDERF 0 R/W Defines whether TX underflow should be ignored or not. 0 - Normal TX operation. TX underflow is detected and TX is aborted if underflow occurs 1 - Ignore TX underflow. Transmit the number of bytes given by the length field. 0 SET_RXENMASK_ON_TX 1 R/W Defines whether STXON will set bit 14 in the RXENABLE register or leave it unchanged. 0: Do not affect RXENABLE. 1: Set bit 14 in RXENABLE. Used for backwards compatibility with CC2420. 110 WWW.TI.COM CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 RXENABLE0, A 0x00E, R 0x00, RX enabling Bit no. Bit mnemonic Reset value Mode Description 7:0 RXENMASK[7:0] 0x00 R/W LSB part of the 16 bit word RXENMASK RXENABLE enables the receiver. A non-zero value in this register will cause the main FSM to enable the receiver when in idle, after transmission and after acknowledgement transmission. The following strobes can modify RXENMASK: SRXON: Set bit 15 in RXENMASK STXON: Set bit 14 in RXENMASK if SET_RXENMASK_ON_TX = ‘1’ SRFOFF: Clears all bits in RXENMASK The following instructions modifies RXENMASK: RXMASKAND : Performs a bitwise AND between RXENMASK and the 16 bit parameter given with the instruction RXMASKOR : Performs a bitwise OR between RXENMASK and the 16 bit parameter given with the instruction RXENABLE can also be written and is bit accessible. BSET and BCLR set and clear any of the 16 bits in RXENMASK. SRXMASKBITSET and SRXMASKBITCLR will set and clear bit 13 in RXENMASK. There are several sources which might try to modify RXENMASK simultaneously. To handle the case of simultaneous access to RXENMASK from different sources the following rules apply: - If two sources are not in conflict (they modify different parts of the register) both their requests to modify RXENMASK will be processed. -Data bus has priority over all sources (BSET, BCLR, REGWR, MEMWR) Strobes which modify RXENMASK are prioritized as following: 1 SRFOFF 2 SXTON 3 SRXON 4 RXMASKOR 5 RXMASKAND 6 SRXMASKBITSET 7 SRXMASKBITCLR RXENABLE1, A 0x00F, R 0x00, RX enabling Bit no. Bit mnemonic Reset value Mode Description 7:0 RXENMASK[15:8] 0x00 R/W MSB part of the 16 bit word RXENMASK Se description of RXENABLE0. WWW.TI.COM 111 CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 EXCFLAG0, A 0x010, R 0x00, Exception flags Bit no. Bit mnemonic Reset value Mode Description 7:0 EXCFLAG[7:0] 0x00 R/W0 Exception pending bits for exceptions 7 to 0. Whenever an exception occurs this bit will be set by hardware. Only software can clear this bit. EXCFKLAG is write zero only and attempts to write ‘1’ to any bits in EXFLAG will not result in a register change. 1: This exception has occurred and not yet cleared. 0: This exception has not yet occurred or has been cleared by software. Bit no Exception 0 RF_IDLE 1 TX_FRM_DONE 2 TX_ACK_DONE 3 TX_UNDERFLOW 4 TX_OVERFLOW 5 RX_UNDERFLOW 6 RX_OVERFLOW 7 RXENABLE_ZERO EXCFLAG1, A 0x011, R 0x00, Exception flags Bit no. Bit mnemonic Reset value Mode Description 7:0 EXCFLAG[15:8] 0x00 R/W0 Exception pending bits for exceptions 15 to 8. See description above. 112 Bit no Exception 8 RX_FRM_DONE 9 RX_FRM_ACCEPTED 10 SRC_MATCH_DONE 11 SRC_MATCH_FOUND 12 FIFOP 13 SFD 14 DPU_DONE_L 15 DPU_DONE_H WWW.TI.COM CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 EXCFLAG2, A 0x012, R 0x00, Exception flags Bit no. Bit mnemonic Reset value Mode Description 7:0 EXCFLAG[23:16] 0x00 R/W0 Exception pending bits for exceptions 23 to 16. See description above. Bit no Exception 16 MEMADDR_ERROR 17 USAGE_ERROR 18 OPERAND_ERROR 19 SPI_ERROR 20 RF_NO_LOCK 21 RX_FRM_ABORTED 22 RXBUFMOV_TIMEOUT 23 UNUSED EXCMASKA0, A 0x014, R 0x00, Exception masking channel A Bit no. Bit mnemonic Reset value Mode Description 7:0 EXCMASKA[7:0] 0x00 R/W The 7:0 part of 24 bit word EXCMASKA Mask exceptions for channel A. If channel A is selected as output configuration for a pin, an exception indication will be generated on that pin when a selected exception occurs. If the complementary channel is selected, then an exception will be indicated when a masked exception occurs. For each bit: 1: Selected 0: Masked EXCMASKA1, A 0x015, R 0x00, Exception masking channel A Bit no. Bit mnemonic Reset value Mode Description 7:0 EXCMASKA[15:8] 0x00 R/W The 15:8 part of 24 bit word EXCMASKA See description of EXCMASKA0. EXCMASKA2, A 0x016, R 0x00, Exception masking channel A Bit no. Bit mnemonic Reset value Mode Description 7:0 EXCMASKA[23:16] 0x00 R/W The 23:16 part of 24 bit word EXCMASKA See description of EXCMASKA0. WWW.TI.COM 113 CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 EXCMASKB0, A 0x018, R 0x00, Exception masking channel B Bit no. Bit mnemonic Reset value Mode Description 7:0 EXCMASKB[7:0] 0x00 R/W The 7:0 part of 24 bit word EXCMASKB Mask exceptions for channel B. If channel B is selected as output configuration for a pin, an exception indication will be generated on that pin when a selected exception occurs. If the complementary channel is selected, then an exception will be indicated when a masked exception occurs. For each bit: 1: Selected 0: Masked EXCMASKB1, A 0x019, R 0x00, Exception masking channel B Bit no. Bit mnemonic Reset value Mode Description 7:0 EXCMASKB[15:8] 0x00 R/W The 15:8 part of 24 bit word EXCMASKB See description of EXCMASKB0. EXCMASKB2, A 0x01A, R 0x00, Exception masking channel B Bit no. Bit mnemonic Reset value Mode Description 7:0 EXCMASKB[23:16] 0x00 R/W The 23:16 part of 24 bit word EXCMASKB See description of EXCMASKB0. EXCBINDX0, A 0x01C, R 0x00, Exception binding channel X Bit no. Bit mnemonic Reset value Mode Description 7:4 RESERVED 0x0 R0 Read as zero 3:0 INSTRUCTIONX 0x0 R/W Instruction for channel X Instruction number to bind to exception. See documentation for GPIO configuration for list over possible instructions that can be bound. EXCBINDX1, A 0x01D, R 0x12, Exception binding channel X Bit no. Bit mnemonic Reset value Mode Description 7 BINDX_EN 0 R/W Defines whether exception binding for channel X is enabled or not. 0 - Binding disabled. 1 -: Binding enabled. Whenever the exception given by EXCEPTIONX occurs the instruction given by INSTRUCTIONX is executed. 6:5 RESERVED 00 R0 Read as zero 4:0 EXCEPTIONX 0x12 R/W Exception for channel X Exception number to bind to an instruction. Se table in Exception overview for valid configurations 114 WWW.TI.COM CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 EXCBINDY0, A 0x01E, R 0x00, Exception binding channel Y Bit no. Bit mnemonic Reset value Mode Description 7:4 RESERVED 0x0 R0 Read as zero 3:0 INSTRUCTIONY 0x0 R/W Instruction for channel Y Instruction number to bind to exception. See documentation for GPIO configuration for list over possible instructions that can be bound. EXCBINDY1, A 0x01F, R 0x12, Exception binding channel Y Bit no. Bit mnemonic Reset value Mode Description 7 BINDY_EN 0 R/W Defines whether exception binding for channel Y is enabled or not. 0: Binding disabled. 1: Binding enabled. Whenever the exception given by EXCEPTIONY occurs the instruction given by INSTRUCTIONY is executed. 6:5 RESERVED 0 R0 Read as zero 4:0 EXCEPTIONY 0x12 R/W Exception for channel Y Exception number to bind to an instruction. Se table in Exception overview for valid configurations GPIOCTRL0, A 0x020, R 0x00, Control GPIO0 Bit no. Bit mnemonic Reset value Mode Description 7 IN0 0 R/W Defines whether GPIO0 is an input or output. Must be set as input when using analog test functionality. 0 - GPIO0 is output 1 - GPIO0 is input 6:0 CTRL0 0x00 R/W GPIO0 Configuration When output: mux selector. See GPIO description for table over all possible signals that can be set as output to the pin. When input: 4 LSBs chose one of 16 instructions to be triggered on the active edge of this GPIO input line. Values above 0x0F have no effect. GPIOCTRL1, A 0x021, R 0x27, Control GPIO1 Bit no. Bit mnemonic Reset value Mode Description 7 IN1 0 R/W Defines whether GPIO1 is an input or output. Must be set as input when using analog test functionality. 0 - GPIO1 is output 1 - GPIO1 is input 6:0 CTRL1 0x27 R/W GPIO1 configuration. For details, see GPIOCTRL0 register WWW.TI.COM 115 CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 GPIOCTRL2, A 0x022, R 0x28, Control GPIO2 Bit no. Bit mnemonic Reset value Mode Description 7 IN2 0 R/W Defines whether GPIO2 is an input or output. 0 - GPIO2 is output 1 - GPIO2 is input 6:0 CTRL2 0x28 R/W GPIO2 configuration For details, see GPIOCTRL0 register GPIOCTRL3, A 0x023, R 0x29, Control GPIO3 Bit no. Bit mnemonic Reset value Mode Description 7 IN3 0 R/W Defines whether GPIO3 is an input or output. 0 - GPIO3 is output 1 - GPIO3 is input 6:0 CTRL3 0x29 R/W GPIO3 configuration. For details, see GPIOCTRL0 register GPIOCTRL4, A 0x024, R 0x2A, Control GPIO4 Bit no. Bit mnemonic Reset value Mode Description 7 IN4 0 R/W Defines whether GPIO4 is an input or output. 0 - GPIO4 is output 1 - GPIO4 is input 6:0 CTRL4 0x2A R/W GPIO4 configuration. For details, see GPIOCTRL0 register GPIOCTRL5, A 0x025, R 0x90, Control GPIO5 Bit no. Bit mnemonic Reset value Mode Description 7 IN5 1 R/W Defines whether GPIO5 is an input or output. 0 - GPIO5 is output 1 - GPIO5 is input 6:0 CTRL5 0x10 R/W GPIO5 configuration For details, see GPIOCTRL0 register GPIOPOLARITY, A 0x026, R 0x3F, Polarity control for GPIO pins Bit no. Bit mnemonic Reset value Mode Description 7:6 RESERVED 00 R0 Read as zero 5:0 POLARITY 0x3F R/W Selects output polarity or input edge of GPIO pins. 0 - Negative polarity. Level indication is active low. When input, falling edge is active. 1 - Positive polarity. Level indication is active high. When input, rising edge is active. 116 WWW.TI.COM CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 GPIOCTRL, A 0x028, R 0x00, Other GPIO options Bit no. Bit mnemonic Reset value Mode Description 7 SC 0 R/W Select extra drive strength for pads. 0 - No extra drive 1 - Extra drive 6 GPIO_ACTRL 0 R/W 5:0 GPIO_PUE 0x00 R/W Controls analog functionality for GPIO[1:0]. When set both GPIO pin 0 and 1 will be set to analog pads. 0 - Disable analog pads 1 - Enable analog pads Set pull up enable individually on GPIO pads 0 through 5 Pull up is 20 kohm +/- 15% 0 - Pull up disabled 1 - Pull up enabled DPUCON, A 0x02A, R 0x01, Timeout control for DPU Bit no. Bit mnemonic Reset value Mode Description 7:1 RESERVED 0x00 R0 Read as zero 0 RXTIMEOUT 1 R/W Defines whether the RXBUFMOV instruction will time out after 32 us or immediately when the RXFIFO is empty. When the 32 us timeout is enabled, the RXBUFMOV instruction can be run with a higher number of bytes than the number of bytes currently stored in RXFIFO since one byte is received every 32us. 0 - Immediate time out 1 - 32us time out DPUSTAT, A 0x02C, R 0x00, DPU status register Bit no. Bit mnemonic Reset value Mode Description 7:4 RESERVED 0000 R0 Read as 0 3 AUTHSTAT_H 0 R Authentication status, high priority Updated when a high priority UCBCMAC or UCCM instruction completes and keep result until a new instruction completes. Reports the result of the last run authentication operation. 0: Authentication check failed. 1: Authentication check passed or no authentication check was performed. 2 AUTHSTAT_L 0 R Authentication status, low priority Updated when a low priority UCBCMAC or UCCM instruction completes and keep result until a new instruction completes. Reports the result of the last run authentication operation. 0: Authentication check failed. 1: Authentication check passed or no authentication check was performed. 1 DPUH_ACTIVE 0 R High Priority Active 0: No high priority DPU instruction is currently active. 1: A high priority DPU instruction is currently active. 0 DPUL_ACTIVE 0 R Low Priority Active 0: No low priority DPU instruction is currently active. 1: A low priority DPU instruction is currently active. WWW.TI.COM 117 CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 FREQCTRL, A 0x02E, R 0x0B, Controls the RF frequency Bit no. Bit mnemonic Reset value Mode Description 7 RESERVED 0 R0 Read as zero 6:0 FREQ[6:0] 0x0B R/W Frequency control word. f RF = f LO = (2394 + FREQ [6 : 0]) MHz (2405 MHz) The frequency word in freq[6:0] is an offset value from 2394. The device supports the frequency range from 2394MHz to 2507MHz. The usable settings for freq[6:0] is consequently 0 to 113. Settings outside this (114-127) will give a frequency of 2507MHz. IEEE802.15.4-2006 specifies a frequency range from 2405MHz to 2480MHz with 16 channels 5 MHz apart. The channels are numbered 11 through 26. For an IEEE802.15.4-2006 compliant system, the only valid settings are thus freq[6:0] = 11 + 5(channel number - 11) FREQTUNE, A 0x02F, R 0x0F, Crystal oscillator frequency tuning Bit no. Bit mnemonic Reset value Mode Description 7:4 RESERVED 0x0 R0 Read as zero 3:0 XOSC32M_TUNE[3:0] 0xF R/W Tune crystal oscillator The default setting “1111” will leave the XOSC not tuned. Changing setting from default will switch in extra capacitance to the oscillator, effectively lowering the XOSC frequency. Hence higher setting gives higher frequency. TXPOWER, A 0x030, R 0x06, Controls the output power Bit no. Bit mnemonic Reset value Mode Description 7:0 PA_POWER [7:0] 0x06 R/W PA power control. Use only the values listed in in this register. NOTE This value should be updated to one of the values listed in Table 17 before going to TX. FSMSTAT0, A 0x032, R 0x00, Radio status register Bit no. Bit mnemonic Reset value Mode Description 7 CAL_DONE 0 R Note that this signal can not be used as a “calibration completed” signal. It will only be high for a very brief period of time (one 32 MHz clock cycle) when the calibration module is ready to be turned off (which does not necessarily mean that the calibration has completed) and is thus difficult to capture with a register read over the SPI. This signal should not be documented in the datasheet. Falling edges on CAL_RUNNING should be used in stead. 6 CAL_RUNNING 0 R Frequency synth calibration status. 0 - Calibration done or not started 1 - Calibration in progress. 5:0 FSM_FFCTRL_STATE[5:0] - R Gives the current state of the FIFO and Frame Control (FFCTRL) finite state machine. 118 WWW.TI.COM CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 FSMSTAT1, A 0x033, R 0x00, Radio status register Bit no. Bit mnemonic Reset value Mode Description 7 FIFO 0 R FIFO is high whenever there is data in the RXFIFO. Low during RXFIFO overflow 6 FIFOP 0 R FIFOP is set high when there are more than FIFOP_THR bytes of data in the RXFIFO that has passed frame filtering. FIFOP is set high when there is at least one complete frame in the RXFIFO. FIFOP is set low again when a byte is read from the RXFIFO and this leaves less than FIFOP_THR bytes in the FIFO. FIFOP is high during RXFIFO overflow 5 SFD 0 R In TX: 0: When a complete frame with SFD has been sent or no SFD has been sent 1: SFD has been sent In RX: 0: When a complete frame has been received or no SFD has been received 1: SFD has been received 4 CCA 0 R Clear channel assessment. Dependent on CCA_MODE settings. See CCACTRL1 for details. 3 SAMPLED_CCA 0 R Contains a sampled value of the CCA. The value is updated whenever a SSAMPLECCA or STXONCCA strobe is issued 2 LOCK_STATUS 0 R '1' when PLL is in lock, otherwise '0'. 1 TX_ACTIVE 0 R Status signal, active when FFCTRL is in one of the transmit states 0 RX_ACTIVE 0 R Status signal, active when FFCTRL is in one of the receive states FIFOPCTRL, A 0x034, R 0x40, FIFOP threshold Bit no. Bit mnemonic Reset value Mode Description 7 RESERVED 0 R0 Read as zero 6:0 FIFOP_THR[6:0] 0x40 R/W Threshold used when generating FIFOP signal FSMCTRL, A 0x035, R 0x01, FSM options Bit no. Bit mnemonic Reset value Mode Description 7:2 RESERVED 0x00 R0 Read as zero 1 SLOTTED_ACK 0 R/W Controls timing of transmission of acknowledge frames 0: The acknowledge frame will be sent 12 symbol periods after the end of the received frame which requests the aknowledge. 1: The acknowledge frame will be sent at the first backoff slot boundary more than 12 symbol periods after the end of the received frame which requests the aknowledge 0 RX2RX_TIME_OFF 1 R/W Defines whether or not a 12 symbol time out should be used after frame reception has ended. 0 - No time out. 1 - 12 symbol period time out. WWW.TI.COM 119 CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 CCACTRL0, A 0x036, R 0xE0, CCA threshold Bit no. Bit mnemonic Reset value Mode Description 7:0 CCA_THR[7:0] 0xE0 R/W Clear Channel Assessment threshold value, signed 2’s complement number for comparison with the RSSI. The unit is 1 dB, offset is about 76dBm. The CCA signal goes high when the received signal is below this value. The CCA signal is available on the CCA pin and in FSMSTAT1 register. Note that the value should never be set lower than CCA_HYST128 in order to avoid erroneous behavior of the CCA signal. NOTE The reset value translates to an input level of approximately -32 – 76 = -108 dBm, which is well below the sensitivity limit. That means the CCA signal will never indicate a clear channel. This register should be updated to 0xF8, which translates to an input level of about -8 - 76 = -84dBm. CCACTRL1, A 0x037, R 0x1A, Other CCA options Bit no. Bit mnemonic Reset value Mode Description 7:5 RESERVED 000 R0 Read as zero 4:3 CCA_MODE[1:0] 11 R/W 00 : CCA always set to ‘1’ 01 : CCA = ‘1’ when RSSI < CCA_THR-CCA_HYST, CCA = ‘0’ when RSSI >= CCA_THR 10 : CCA = ‘1’ when not receiving a frame, else CCA = ‘0’ 11 : CCA = ‘1’ when RSSI < CCA_THR-CCA_HYST and not receiving a frame, CCA=0 when RSSI >= CCA_THR or receiving a frame 2:0 CCA_HYST[2:0] 010 R/W Sets the level of CCA hysteresis. Unsigned values given in dB. RSSI, A 0x038, R 0x80, RSSI status register Bit no. Bit mnemonic Reset value Mode Description 7:0 RSSI_VAL[7:0] 0x80 R RSSI estimate on a logarithmic scale, signed number on 2’s complement. Unit is 1 dB, offset is TBD [depends on the absolute gain of the RX chain, including external components, and should be measured]. The RSSI value is averaged over 8 symbol periods. The RSSI_VALID status bit should be checked before reading RSSI_VAL the first time. The reset value of –128 also indicates that the RSSI value is invalid. RSSISTAT, A 0x039, R 0x00, RSSI valid status register Bit no. Bit mnemonic Reset value Mode Description 7:1 RESERVED 0000 000 R0 Read as zero 0 RSSI_VALID 0 R RSSI value is valid. Occurs eight symbol periods after entering RX 120 WWW.TI.COM CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 RXFIRST, A 0x03C, R 0x00, First byte in RXFIFO Bit no. Bit mnemonic Reset value Mode Description 7:0 DATA[7:0] 0x00 R First byte of the RXFIFO. Note: Reading this register will not modify the contents of the FIFO. RXFIFOCNT, A 0x03E, R 0x00, Number of bytes in RXFIFO Bit no. Bit mnemonic Reset value Mode Description 7:0 RXFIFOCNT[7:0] 0x00 R Number of bytes in the RXFIFO. Unsigned integer. TXFIFOCNT, A 0x03F, R 0x00, Number of bytes in TXFIFO Bit no. Bit mnemonic Reset value Mode Description 7:0 TXFIFOCNT[7:0] 0x00 R Number of bytes in the TXFIFO. Unsigned integer. CHIPID, A 0x040, R 0x84, Chip ID Bit no. Bit mnemonic Reset value Mode Description 7:0 CHIPID[7:0] 0x84 R Chip ID number. 0x84 = CC2520 VERSION, A 0x042, R 0x00, Chip version number Bit no. Bit mnemonic Reset value Mode Description 7:0 VERSION[7:0] 0x00 R Chip version. Unsigned integer. WWW.TI.COM 121 CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 EXTCLOCK, A 0x044, R 0x20, Controls clock output Bit no. Bit mnemonic Reset value Mode Description 7:6 RESERVED 00 R0 Read as zero 5 EXTCLOCK_EN 1 RW Defines whether the clock generator module for the external clock is enabled or not. Note that a GPIO pin must be configured as output and Clock must be selected in one of the GPIOCTRLn registers to get the clock at the selected pin. 1 - Clock running 0 - Clock off 4:0 122 EXT_FREQ 0x00 RW Frequency setting of external clock. Changes of frequencies are glitch free and have 50/50 duty cycle. I.e. a change of frequency will not have effect before a complete period of the current clock setting is finished. Setting Div. factor Frequency [MHz] 00000 32 1,00 00001 31 1,03 00010 30 1,07 00011 29 1,10 00100 28 1,14 00101 27 1,19 00110 26 1,23 00111 25 1,28 01000 24 1,33 01001 23 1,39 01010 22 1,45 01011 21 1,52 01100 20 1,60 01101 19 1,68 01110 18 1,78 01111 17 1,88 10000 16 2,00 10001 15 2,13 10010 14 2,29 10011 13 2,46 10100 12 2,67 10101 11 2,91 10110 10 3,20 10111 9 3,56 11000 8 4,00 11001 7 4,57 11010 6 5,33 11011 5 6,40 11100 4 8,00 11101 3 10,67 11110 2 16,00 11111 2 16,00 WWW.TI.COM CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 MDMCTRL0, A 0x046, R 0x45, Controls modem Bit no. Bit mnemonic Reset value Mode Description 7:6 DEM_NUM_ZEROS[1:0] 01 R/W Sets how many zero symbols have to be detected before the sync word when searching for sync. Note that only one is required to have a correlation value above the correlation threshold set in MDMCTRL1 register. 00 : reserved 01 : 1 zero symbols 10 : 2 zero symbols 11 : 3 zero symbols NOTE This value should be updated to “10” before attempting RX. Testing has shown that the reset value causes too many false frames to be received. 5 DEMOD_AVG_MODE 0 R/W Defines the behavior or the frequency offset averaging filter. 0 - Lock average level after preamble match. Restart frequency offset calibration when searching for the next frame. 1 - Continuously update average level. 4:1 PREAMBLE_LENGTH [3:0] 0010 R/W The number of preamble bytes (2 zero-symbols) to be sent in TX mode prior to the SFD, encoded in steps of 2. The reset value of 2 is compliant with IEEE 802.15.4 0000 - 2 leading zero bytes 0001 - 3 leading zero bytes 0010 - 4 leading zero bytes … 1111 - 17 leading zero bytes 0 TX_FILTER 1 R/W Defines what kind of TX filter that is used. The normal TX filter is as defined by the IEEE802.15.4 standard. Extra filtering may be applied in order to lower the out of band emissions. 0 - Normal TX filtering 1 - Enable extra filtering MDMCTRL1, A 0x047, R 0x2E, Controls modem Bit no. Bit mnemonic Reset value Mode Description 7:6 RESERVED 00 R0 Read as zero 5 CORR_THR_SFD 1 R/W Defines requirements for SFD detection: 0 - The correlation value of one of the zero symbols of the preamble must be above the correlation threshold. 1 - The correlation value of one zero symbol of the preamble and both symbols in the SFD must be above the correlation threshold. NOTE This value should be changed to ‘0’ before attempting RX. This will give the best trade off between good sensitivity and few false SFD detections. 4:0 CORR_THR[4:0] 0x0E R/W Demodulator correlator threshold value, required before SFD search. Threshold value adjusts how the receiver synchronizes to data from the radio. If threshold is set too low sync can more easily be found on noise. If set too high the sensitivity will be reduced but sync will not likely be found on noise. I combination with DEM_NUM_ZEROS the system can be tuned so sensitivity is high with less synch found on noise. NOTE This value should be changed to 0x14 before attempting RX. Testing has shown that too many false frames are received if the reset value is used. WWW.TI.COM 123 CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 FREQEST, A 0x048, R 0x00, Estimated RF frequency offset. Bit no. Bit mnemonic Reset value Mode Description 7:0 FREQEST[7:0] 0x00 R Signed 2’s complement value. Contains an estimate of the frequency offset between carrier and the receiver LO. The offset frequency is FREQESTx7800 Hz. DEM_AVG_MODE controls when this estimate is updated. If DEM_AVG_MODE = 0 it is updated until sync is found. Then the frequency offset estimate is frozen until the end of the received frame. If DEM_AVG_MODE = 1 it is updated as long as the demodulator is enabled. MDMTEST1, A 0x05B, R 0x08, Test register for modem Bit no. Bit mnemonic Reset value Mode Description 7:4 RESERVED 0000 R0 Read as zero 3 RESERVED 1 R/W Do not write. 2 RFC_SNIFF_EN 0 R/W 0 - Packet sniffer module disabled 1 - Packet sniffer module enabled. The received and transmitted data can be observed on GPIO pins. 1 MODULATION_MODE 0 R/W Set one of two RF modulation modes for RX / TX 0 - IEEE 802.15.4 compliant mode 1 - Reversed phase, non-IEEE compliant 0 124 RESERVED 0 R/W Do not write. WWW.TI.COM CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 The following registers in the address range 0x04A to 0x07F are for performance tuning and test purposes and should generally not be written. The registers that require updates to give the performance described in this datasheet are listed in Table 21: Registers that need update from their default value. RXCTRL, A 0x04A, R 0x29, Test/tuning of RX modules FSCTRL, A 0x04C, R 0x55, Test/tuning of synthesizer FSCAL0, A 0x04E, R 0x24, Test/tuning of synthesizer FSCAL1, A 0x04F, R 0x29, Test/tuning of VCO FSCAL2, A 0x050, R 0x20, Test/tuning of VCO FSCAL3, A 0x051, R 0x2A, Test/tuning of VCO AGCCTRL0, A 0x052, R 0x5F, Test/tuning of AGC AGCCTRL1, A 0x053, R 0x0E, Test/tuning of AGC AGCCTRL2, A 0x054, R 0x00, Test/tuning of LNA AGCCTRL3, A 0x055, R 0x2E, Test/tuning of AGC and AAF ADCTEST0, A 0x056, R 0x66, Test/tuning of ADC ADCTEST1, A 0x057, R 0x0A, Test/tuning of ADC ADCTEST2, A 0x058, R 0x05, Test/tuning of ADC MDMTEST0, A 0x05A, R 0x05, Test/tuning of modem DACTEST0, A 0x05C, R 0x00, Test/tuning of DAC DACTEST1, A 0x05D, R 0x00, Test/tuning of DAC ATEST, A 0x05E, R 0x00, Controls analog test mode DACTEST2, A 0x05F, R 0x00, Test/tuning of DAC PTEST0, A 0x060, R 0x00, Test/tuning of power down signals PTEST1, A 0x061, R 0x00, Test/tuning of power down signals RESERVED, A 0x062, R 0x00, Not currently in use DPUBIST, A 0x07A, R 0x00, Test/tuning of DPU ROM ACTBIST, A 0x07C, R 0x00, Test/tuning of ACT ROM RAMBIST, A 0x07E, R 0x02, Test/tuning of RAM WWW.TI.COM 125 CC2520 DATASHEET 2.4 GHZ IEEE 802.15.4/ZIGBEE® RF TRANSCEIVER SWRS068 – DECEMBER 2007 29 Datasheet Revision History Literature Number Release Date Comments SWRS068 2007-12-20 Initial release NOTE: Page and figure numbers refer to the respective document revision. 126 WWW.TI.COM PACKAGE OPTION ADDENDUM www.ti.com 15-Nov-2014 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) Op Temp (°C) Device Marking (4/5) CC2520RHDR ACTIVE VQFN RHD 28 3000 Green (RoHS & no Sb/Br) CU NIPDAU | Call TI Level-3-260C-168 HR -40 to 125 CC2520 CC2520RHDRG4 ACTIVE VQFN RHD 28 3000 Green (RoHS & no Sb/Br) Call TI Level-3-260C-168 HR -40 to 125 CC2520 CC2520RHDT ACTIVE VQFN RHD 28 250 Green (RoHS & no Sb/Br) CU NIPDAU | Call TI Level-3-260C-168 HR -40 to 125 CC2520 CC2520RHDTG4 ACTIVE VQFN RHD 28 250 Green (RoHS & no Sb/Br) Call TI Level-3-260C-168 HR -40 to 125 CC2520 (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) Eco Plan - The planned eco-friendly classification: Pb-Free (RoHS), Pb-Free (RoHS Exempt), or Green (RoHS & no Sb/Br) - please check http://www.ti.com/productcontent for the latest availability information and additional product content details. TBD: The Pb-Free/Green conversion plan has not been defined. Pb-Free (RoHS): TI's terms "Lead-Free" or "Pb-Free" mean semiconductor products that are compatible with the current RoHS requirements for all 6 substances, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, TI Pb-Free products are suitable for use in specified lead-free processes. Pb-Free (RoHS Exempt): This component has a RoHS exemption for either 1) lead-based flip-chip solder bumps used between the die and package, or 2) lead-based die adhesive used between the die and leadframe. The component is otherwise considered Pb-Free (RoHS compatible) as defined above. Green (RoHS & no Sb/Br): TI defines "Green" to mean Pb-Free (RoHS compatible), and free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) (3) MSL, Peak Temp. - The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications, and peak solder temperature. (4) There may be additional marking, which relates to the logo, the lot trace code information, or the environmental category on the device. (5) Multiple Device Markings will be inside parentheses. Only one Device Marking contained in parentheses and separated by a "~" will appear on a device. If a line is indented then it is a continuation of the previous line and the two combined represent the entire Device Marking for that device. (6) Lead/Ball Finish - Orderable Devices may have multiple material finish options. Finish options are separated by a vertical ruled line. Lead/Ball Finish values may wrap to two lines if the finish value exceeds the maximum column width. Addendum-Page 1 Samples PACKAGE OPTION ADDENDUM www.ti.com 15-Nov-2014 Important Information and Disclaimer:The information provided on this page represents TI's knowledge and belief as of the date that it is provided. TI bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. TI has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. TI and TI suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. In no event shall TI's liability arising out of such information exceed the total purchase price of the TI part(s) at issue in this document sold by TI to Customer on an annual basis. Addendum-Page 2 PACKAGE MATERIALS INFORMATION www.ti.com 21-Mar-2013 TAPE AND REEL INFORMATION *All dimensions are nominal Device Package Package Pins Type Drawing SPQ Reel Reel A0 Diameter Width (mm) (mm) W1 (mm) B0 (mm) K0 (mm) P1 (mm) W Pin1 (mm) Quadrant CC2520RHDR VQFN RHD 28 3000 330.0 12.4 5.3 5.3 1.5 8.0 12.0 Q2 CC2520RHDT VQFN RHD 28 250 180.0 12.4 5.3 5.3 1.5 8.0 12.0 Q2 Pack Materials-Page 1 PACKAGE MATERIALS INFORMATION www.ti.com 21-Mar-2013 *All dimensions are nominal Device Package Type Package Drawing Pins SPQ Length (mm) Width (mm) Height (mm) CC2520RHDR VQFN RHD 28 3000 338.1 338.1 20.6 CC2520RHDT VQFN RHD 28 250 210.0 185.0 35.0 Pack Materials-Page 2 IMPORTANT NOTICE Texas Instruments Incorporated and its subsidiaries (TI) reserve the right to make corrections, enhancements, improvements and other changes to its semiconductor products and services per JESD46, latest issue, and to discontinue any product or service per JESD48, latest issue. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All semiconductor products (also referred to herein as “components”) are sold subject to TI’s terms and conditions of sale supplied at the time of order acknowledgment. TI warrants performance of its components to the specifications applicable at the time of sale, in accordance with the warranty in TI’s terms and conditions of sale of semiconductor products. Testing and other quality control techniques are used to the extent TI deems necessary to support this warranty. Except where mandated by applicable law, testing of all parameters of each component is not necessarily performed. TI assumes no liability for applications assistance or the design of Buyers’ products. Buyers are responsible for their products and applications using TI components. To minimize the risks associated with Buyers’ products and applications, Buyers should provide adequate design and operating safeguards. TI does not warrant or represent that any license, either express or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right relating to any combination, machine, or process in which TI components or services are used. Information published by TI regarding third-party products or services does not constitute a license to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from TI under the patents or other intellectual property of TI. Reproduction of significant portions of TI information in TI data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. TI is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. Resale of TI components or services with statements different from or beyond the parameters stated by TI for that component or service voids all express and any implied warranties for the associated TI component or service and is an unfair and deceptive business practice. TI is not responsible or liable for any such statements. Buyer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements concerning its products, and any use of TI components in its applications, notwithstanding any applications-related information or support that may be provided by TI. Buyer represents and agrees that it has all the necessary expertise to create and implement safeguards which anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause harm and take appropriate remedial actions. Buyer will fully indemnify TI and its representatives against any damages arising out of the use of any TI components in safety-critical applications. In some cases, TI components may be promoted specifically to facilitate safety-related applications. With such components, TI’s goal is to help enable customers to design and create their own end-product solutions that meet applicable functional safety standards and requirements. Nonetheless, such components are subject to these terms. No TI components are authorized for use in FDA Class III (or similar life-critical medical equipment) unless authorized officers of the parties have executed a special agreement specifically governing such use. Only those TI components which TI has specifically designated as military grade or “enhanced plastic” are designed and intended for use in military/aerospace applications or environments. Buyer acknowledges and agrees that any military or aerospace use of TI components which have not been so designated is solely at the Buyer's risk, and that Buyer is solely responsible for compliance with all legal and regulatory requirements in connection with such use. TI has specifically designated certain components as meeting ISO/TS16949 requirements, mainly for automotive use. In any case of use of non-designated products, TI will not be responsible for any failure to meet ISO/TS16949. Products Applications Audio www.ti.com/audio Automotive and Transportation www.ti.com/automotive Amplifiers amplifier.ti.com Communications and Telecom www.ti.com/communications Data Converters dataconverter.ti.com Computers and Peripherals www.ti.com/computers DLP® Products www.dlp.com Consumer Electronics www.ti.com/consumer-apps DSP dsp.ti.com Energy and Lighting www.ti.com/energy Clocks and Timers www.ti.com/clocks Industrial www.ti.com/industrial Interface interface.ti.com Medical www.ti.com/medical Logic logic.ti.com Security www.ti.com/security Power Mgmt power.ti.com Space, Avionics and Defense www.ti.com/space-avionics-defense Microcontrollers microcontroller.ti.com Video and Imaging www.ti.com/video RFID www.ti-rfid.com OMAP Applications Processors www.ti.com/omap TI E2E Community e2e.ti.com Wireless Connectivity www.ti.com/wirelessconnectivity Mailing Address: Texas Instruments, Post Office Box 655303, Dallas, Texas 75265 Copyright © 2014, Texas Instruments Incorporated
MIKROE-2218 价格&库存
很抱歉,暂时无法提供与“MIKROE-2218”相匹配的价格&库存,您可以联系我们找货
MIKROE-2218
  • 1+90.433011+11.75200
库存:1
MIKROE-2218
  • 1+264.625001+33.70340
