MIKROE-2550
MIKROE-2550
    MIKRO
    MS5525DSO-SB001GS 压力 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-2550 数据手册
MS5525DSO (Digital Small Outline) SPECIFICATIONS Integrated Digital Pressure Sensor (24-bit ∆Σ ADC) Fast Conversion Down to 1 ms Low Power, 1 µA (standby < 0.15 µA) Supply Voltage: 1.8 to 3.6V Pressure Range: 1 to 30 PSI I2C and SPI Interface The MS5525DSO is a new generation of Digital Small Outline pressure sensors from MEAS with SPI and I 2C bus interface designed for high volume OEM users. The sensor module includes a pressure sensor and an ultra low power 24-bit ∆Σ ADC with internal factory calibrated coefficients. It provides a 24-bit digital pressure and temperature value and different operation modes that allow the user to optimize for conversion speed and current consumption. The MS5525DSO can be interfaced to virtually any microcontroller. The communication protocol is simple, without the need of programming internal registers in the device. This new sensor module generation is based on leading MEMS technology and latest benefits from TE proven experience and know-how in high volume manufacturing of pressure modules, which have been widely used for over a decade. The rugged engineered thermoplastic transducer is available in single and dual port configurations, and can measure absolute, gauge, compound, and differential pressure from 1 to 30psi. SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 1 MS5525DSO (Digital Small Outline) FEATURES Small Outline IC Package Barbed Pressure Ports Low Power, High Resolution ADC Digital Pressure and Temperature Outputs APPLICATIONS Factory Automation Altitude and Airspeed Measurements Medical Instruments Leak Detection STANDARD RANGES (PSI) FS Pressure 1 2 5 15 30 Absolute DB, DH,FT DB, DH,FT Gauge DB, SB, ST, DH,FT DB, SB, ST, DH,FT DB, SB, ST, DH,FT DB, SB, ST, DH,FT DB, SB, ST, DH,FT Differential DB, SB,ST, DH DB, SB,ST, DH DB, SB,ST ,DH DB, DH DB, DH See Package Configurations: DB= Dual Barb, DH= Dual Hole, SB=Single Barb, ST=Single Tube, FT=Front Side Tube SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 2 MS5525DSO (Digital Small Outline) ABSOLUTE MAXIMUM RATING Parameter Supply Voltage Storage Temperature Overpressure Burst Pressure ESD Solder Temperature Conditions TA = 25°C TA = 25 °C, both Ports TA = 25 °C, Port 1 HBM Min -0.3 -40 Max 3.6 125 60 -4 +4 250°C, 5 sec max. Unit V °C psi psi kV Symbol/Notes VDD See Table 1 EN 61000-4-2 Table 1- BURST PRESSURE BY RANGE AND PORT DESIGNATION. Range 001 002 005 015 030 Port 1 10 20 50 120 120 Port 2 10 20 15 60 120 Unit psi psi psi psi psi ENVIRONMENTAL SPECIFICATIONS Parameter Mechanical Shock Mechanical Vibration Thermal Shock Life MTTF Conditions Mil Spec 202F, Method 213B, Condition C, 3 Drops Mil Spec 202F, Method 214A, Condition 1E, 1Hr Each Axis 100 Cycles over Storage Temperature, 30 minute dwell 1 Million FS Cycles >10Yrs, 70 ºC, 1 Million Pressure Cycles, 120%FS Pressure SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 3 MS5525DSO (Digital Small Outline) PERFORMANCE SPECIFICATIONS Supply Voltage1 3.0 Vdc Reference Temperature: 25°C (unless otherwise specified) PARAMETERS MIN Operating Voltage 1.8 TYP MAX ADC 24 Pressure Accuracy See Table 2 Below Total Error Band (TEB) UNITS NOTES 3.6 -2.5 2.5 bits %FS 2,5 %FS 3 Temperature Accuracy (Reference Temperature) ±1.5 ºC 4,5 Temperature Accuracy ±2.5 ºC 4,5 See OSR Table Below mA Supply Current Compensated Temperature Operating Temperature 0 85 -40 +125 Conversion Time Weight Media ºC ºC See OSR Table Below mS 3 grams Non-Corrosive Dry Gases Compatible with Silicon, Glass, LCP, RTV, Gold, Thermo-Epoxy, Silicone Gel, Aluminum and Epoxy. See “Wetted Material by Port Designation” chart. Notes 1. Proper operation requires an external capacitor placed as shown in Application Circuit. Output is not ratiometric to supply voltage. 2. The maximum deviation from a best fit straight line(BFSL) fitted to the output measured over the pressure range at 25°C. Includes all errors due to pressure non linearity, hysteresis, and non repeatability. 3. The maximum deviation from ideal output with respect to input pressure and temperature over the compensated temperature range. Total error band (TEB) includes all accuracy errors, thermal errors over the compensated temperature range, span and offset calibration tolerances. TEB values are valid only at the calibrated supply voltage. 4. The deviation from a best fit straight line (BFSL) from 25°C. to 85°C. 5. Six coefficients must be read by microcontroller software and are used in a mathematical calculation for converting D1 and D2 into compensated pressure and temperature values. Table 2- TYPICAL ACCURACY SPECIFICATION BY PRESSURE RANGE Range 001 002 005 015 030 Port 1 ±0.25 ±0.25 ±0.50 ±0.25 ±0.25 SENSOR SOLUTIONS ///MS5525DSO Port 2 ±1.0 ±0.5 ±1.0 ±0.25 ±0.25 Unit %FSS %FSS %FSS %FSS %FSS 09/2016 Page 4 MS5525DSO (Digital Small Outline) OVERSAMPLNG RATIO (OSR) PERFORMANCE CHARACTERISTICS SUPPLY CURRENT CHARACTERISTICS Parameter Symbol Supply current (1 sample per sec.) IDD Peak supply current Standby supply current Conditions OSR Min. Typ. 12.5 6.3 3.2 1.7 0.9 1.4 0.02 Max Min. 7.40 3.72 1.88 0.95 0.48 Typ. 8.22 4.13 2.08 1.06 0.54 Max 9.04 4.54 2.28 1.17 0.60 Unit Min. Typ. Max 20 400 100% VDD 20% VDD Unit MHz kHz V V 4096 2048 1024 512 256 during conversion at 25°C Unit µA 0.14 mA µA ANALOG DIGITAL CONVERTER (ADC) Parameter Symbol Conversion time Conditions OSR tc 4096 2048 1024 512 256 ms INPUT/OUTPUT SPECIFICATIONS 2 DIGITAL INPUTS (CSB, I C, DIN, SCLK) Parameter Serial data clock Serial data clock Input high voltage Input low voltage Symbol SCLK SCL VIH VIL Ileak25°C Ileak85°C CIN Input leakage current Input capacitance Conditions SPI protocol I2C protocol Pins CSB 80% VDD 0% VDD at 25°C 0.15 µA 6 pF 2 PRESSURE OUTPUTS (I C, DOUT) Parameter Output high voltage Output low voltage Load capacitance SENSOR SOLUTIONS ///MS5525DSO Symbol VOH VOL CLOAD Conditions Isource = 0.6 mA Isink = 0.6 mA Min. 80% VDD 0% VDD 09/2016 Typ. Max 100% VDD 20% VDD 16 Unit V V pF Page 5 MS5525DSO (Digital Small Outline) FUNCTIONAL DESCRIPTION BLOCK DIAGRAM Figure 1: Block diagram of MS5525DSO GENERAL The MS5525DSO consists of a piezo-resistive sensor and a sensor interface IC. The main function of the MS5525DSO is to convert the uncompensated analog output voltage from the piezo-resistive pressure sensor to a 24-bit digital value, as well as providing a 24-bit digital value for the temperature of the sensor. FACTORY CALIBRATION Every module is individually factory calibrated at two temperatures and three pressures. As a result, six coefficients necessary to compensate for process variations and temperature variations are calculated and stored in the 128-bit PROM of each module. These bits, partitioned into six coefficients, C1 through C6, must be read by the microcontroller software and used in the program converting D1 and D2 into compensated pressure and temperature values. The coefficients C0 and C7 are for factory calibration and CRC. SERIAL INTERFACE The MS5525DSO has built in two types of serial interfaces: SPI and I2C. Pulling the Protocol Select pin PS to low selects the SPI protocol, pulling PS to high activates the I2C bus protocol. Pin PS Mode Pins used High Low IC SPI SDA, SCL CSB SDI, SDO, SCLK, CSB 2 SPI MODE The external microcontroller clocks in the data through the input SCLK (Serial CLocK) and SDI (Serial Data In). In the SPI mode module can accept both mode 0 and mode 3 for the clock polarity and phase. The sensor responds on the output SDO (Serial Data Out). The pin CSB (Chip Select) is used to enable/disable the interface, so that other devices can talk on the same SPI bus. The CSB pin can be pulled high after the command is sent or after the end of the command execution (for example end of conversion). The best noise performance from the module is obtained when the SPI bus is idle and without communication to other devices during the ADC conversion. SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 6 MS5525DSO (Digital Small Outline) I2C MODE & ADDRESSING The external microcontroller clocks in the data through the input SCL (Serial CLock) and SDA (Serial DAta). The sensor responds on the same pin SDA which is bidirectional for the I2C bus interface. So this interface type uses only 2 signal lines and does not require a chip select, which can be favorable to reduce board space. In I2C -Mode the complement of the pin CSB (Chip Select) represents the LSB of the I2C address. It is possible to use two sensors with two different addresses on the I2C bus. The pin CSB must be connected to VDD or GND do not leave these pins unconnected. Pin CSB Address (7 bits) High Low 0x76 0x77 COMMANDS The MS5525DSO has only five basic commands: 1. Reset 2. Read PROM (128 bit of calibration words) 3. D1 conversion 4. D2 conversion 5. Read ADC result (24 bit pressure / temperature) Size of each command is 1 byte (8 bits) as described in the table below. After ADC read commands the device will return 24 bit result and after the PROM read 16bit result. The address of the PROM is embedded inside of the PROM read command using the Ad2, Ad1 and Ad0 bits. Bit number Bit name Command byte 0 1 2 PRM COV - 3 Typ 4 5 6 7 Ad2/ Ad1/ Ad0/ Stop Os2 Os1 Os0 Command Reset Convert D1 (OSR=256) Convert D1 (OSR=512) Convert D1 (OSR=1024) Convert D1 (OSR=2048) Convert D1 (OSR=4096) Convert D2 (OSR=256) Convert D2 (OSR=512) Convert D2 (OSR=1024) Convert D2 (OSR=2048) Convert D2 (OSR=4096) ADC Read PROM Read 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 1 1 1 1 1 0 0 1 0 0 0 0 1 0 0 0 0 1 0 Ad2 0 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 hex value 1 0 0 1 1 0 0 0 1 1 0 0 Ad1 1 0 1 0 1 0 0 1 0 1 0 0 Ad0 0 0 0 0 0 0 0 0 0 0 0 0 0 0x1E 0x40 0x42 0x44 0x46 0x48 0x50 0x52 0x54 0x56 0x58 0x00 0xA0 to 0xAE Figure 4: Command structure SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 7 MS5525DSO (Digital Small Outline) Start 5525DSO-pp005GS Example Tmin=-40°C , Tmax=125°C Variable C1 Coefficient Description Pressure Sensitivity, SENST1 Recommended Variable Type Size [1] Value [Bit] Min Max Example/ Typical unsigned int 16 16 0 65535 36402 0 65535 39473 C2 Pressure Offset, OFFT1 unsigned int 16 16 C3 Temperature Coefficient, Pressure Sensitivity, TCS unsigned int 16 16 0 65535 40393 C4 Temperature Coefficient, Pressure Offset, TCO unsigned int 16 16 0 65535 29523 unsigned int 16 16 0 65535 29854 unsigned int 16 16 0 65535 21917 C5 C6 Reference Temperature, TREF Temperature Coefficient Temperature, TEMPSENS Read Calibration Data from PROM Read Digital Pressure and Temperature Data D1 Digital Pressure Value unsigned int 32 24 0 16777216 5240585 D2 Digital Temperature Value unsigned int 32 24 0 16777216 3869265 Calculate Temperature dT Difference between actual and reference temperature dT = D2 - TRE F = D2 - C5 * 2Q5 signed int 32 25 -16776960 16777216 47953 TEMP Measured temperature TEMP=20°C+dT*TEMPSENS=2000+dT*C6/2Q6 signed int 32 41 -4000 12500 =25.01°C 2501 Calculate Temperature Compensated Pressure OFF Offset at actual temperature OFF=OFFT1+TCO * dT=C2*2Q2+(C4*dT)/2Q4 signed int 64 41 5218046194 SENS Sensitivity at actual temperature SENS=SENST1+TCS*dT=C1*2Q1+(C3*dT)/2Q3 signed int 64 41 2415906558 P Temperature Compensated Pressure P=D1*SENS-OFF=(D1*SENS/221-OFF)/215 signed int 32 61 24996 =2.4996psi Display Pressure and Temperature Value Figure 1: Flow chart for pressure and temperature reading and software compensation. SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 8 MS5525DSO (Digital Small Outline) Qx Coefficients Matrix by Pressure Range Part Number Pmin Pmax Q1 Q2 Q3 Q4 Q5 7 Q6 21 TRES PRES (°C) (PSI) 0.01 0.0001 5525DSO-pp001GS 0 1 14 16 7 5 5525DSO-pp001DS -1 1 15 17 7 5 7 21 0.01 0.0001 5525DSO-pp002GS 0 2 14 15 8 6 7 22 0.01 0.0001 5525DSO-pp002DS -2 2 16 18 6 4 7 22 0.01 0.0001 5525DSO-pp005GS 0 5 16 17 6 5 7 21 0.01 0.0001 5525DSO-pp005DS -5 5 17 19 5 3 7 22 0.01 0.0001 5525DSO-pp0015AS 0 15 16 17 6 5 7 22 0.01 0.0001 5525DSO-pp0015GS 0 15 16 17 6 5 7 22 0.01 0.0001 5525DSO-pp0015DS -15 15 17 19 5 3 7 22 0.01 0.0001 5525DSO-pp0030AS 0 30 17 18 5 4 7 22 0.01 0.0001 5525DSO-pp0030GS 0 30 17 18 5 4 7 22 0.01 0.0001 5525DSO-pp0030DS -30 30 18 20 4 1 7 22 0.01 0.0001 11 10 9 MEMORY MAPPING Memory Mapping Address 15 14 13 12 8 7 6 0 Reserved for Manufacturer 1 Coefficient 1 (C1) 2 Coefficient 2 (C2) 3 Coefficient 3 (C3) 4 Coefficient 4 (C4) 5 Coefficient 5 (C5) 6 Coefficient 6 (C6) 5 7 4 3 2 1 0 CRC Figure 2: Memory PROM Mapping Notes [1] Maximal size of intermediate result during evaluation of variable. SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 9 MS5525DSO (Digital Small Outline) SPI INTERFACE RESET SEQUENCE The Reset sequence shall be sent once after power-on to make sure that the calibration PROM gets loaded into the internal register. It can be also used to reset the device ROM from an unknown condition SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 10 MS5525DSO (Digital Small Outline) CONVERSION SEQUENCE The conversion command is used to initiate uncompensated pressure (D1) or uncompensated temperature (D2) conversion. The chip select can be disabled during this time to communicate with other devices. After the conversion, using ADC read command the result is clocked out with the MSB first. If the conversion is not executed before the ADC read command, or the ADC read command is repeated, it will give 0 as the output result. If the ADC read command is sent during conversion the result will be 0, the conversion will not stop and the final result will be wrong. Conversion sequence sent during the already started conversion process will yield incorrect result as well. PROM READ SEQUENCE The read command for PROM shall be executed once after reset by the user to read the content of the calibration PROM and to calculate the calibration coefficients. There are in total 8 addresses resulting in a total memory of 128 bit. Address 0 contains factory data and the setup, addresses 1-6 calibration coefficients and address 7 contains the serial code and CRC. The command sequence is 8 bits long with a 16 bit result which is clocked with the MSB first. SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 11 MS5525DSO (Digital Small Outline) I2C INTERFACE COMMANDS Each I2C communication message starts with the start condition and it is ended with the stop condition. The MS5525DSO address is 111011Cx, where C is the complementary value of the pin CSB. Since the IC does not have a microcontroller inside, the commands for I2C and SPI are quite similar. RESET SEQUENCE The reset can be sent at any time. In the event that there is not a successful power on reset this may be caused by the SDA being blocked by the module in the acknowledge state. The only way to get the MS5525DSO to function is to send several SCLKs followed by a reset sequence or to repeat power on reset. 1 1 1 0 1 1 CSB 0 0 1 0 1 0 0 1 1 0 0 Device Address command S Device Address W A cmd byte A P From Master From Slave S = Start Condition P = Stop Condition W = Write R = Read A = Acknowledge N = Not Acknowledge Figure 10: I2C Reset Command PROM READ SEQUENCE The PROM Read command consists of two parts. First command sets up the system into PROM read mode. The second part gets the data from the system. 1 1 1 0 1 1 CSB 0 0 1 0 1 0 0 1 1 0 0 Device Address command S Device Address W A cmd byte A P From Master From Slave S = Start Condition P = Stop Condition W = Write R = Read A = Acknowledge N = Not Acknowledge Figure 11: I2C Command to read memory address= 011 (Coefficient 3) 1 1 1 0 1 1 CSB 1 0 1 1 0 0 X X X X 0 X X X X X X X X 0 Device Address data data S Device Address R A Memory bit 15 - 8 A Memory bit 7 - 0 N P From Master From Slave S = Start Condition P = Stop Condition W = Write R = Read A = Acknowledge N = Not Acknowledge Figure 12: I2C response from MS5525DSO SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 12 MS5525DSO (Digital Small Outline) CONVERSION SEQUENCE A conversion can be started by sending the command to MS5525DSO. When command is sent to the system it stays busy until conversion is done. When conversion is finished the data can be accessed by sending a Read command, when an acknowledge appears from the MS5525DSO, 24 SCLK cycles may be sent to receive all result bits. Every 8-bit the system waits for an acknowledge signal. 1 1 1 0 1 1 CSB 0 0 0 1 0 0 1 0 0 0 0 Device Address command S Device Address W A cmd byte A P From Master From Slave S = Start Condition P = Stop Condition W = Write R = Read A = Acknowledge N = Not Acknowledge Figure 13: I2C Command to initiate a pressure conversion (OSR=4096, typ=D1) 1 1 1 0 1 1 CSB 0 0 0 0 0 0 0 0 0 0 0 Device Address command S Device Address W A cmd byte A P From Master From Slave S = Start Condition P = Stop Condition W = Write R = Read A = Acknowledge N = Not Acknowledge Figure 14: I2C ADC read sequence 1 1 1 0 1 1 CSB 1 0 X X X X X X X X 0 X X X X X X X X 0 X X X X X X X X 0 Device Address data data data S Device Address R A Data 23-16 A Data 8 - 15 A Data 7 - 0 N P From Master From Slave S = Start Condition P = Stop Condition W = Write R = Read A = Acknowledge N = Not Acknowledge Figure 15: I2C response from MS5525DSO CYCLIC REDUNDANCY CHECK (CRC) MS5525DSO contains a PROM memory with 128-Bit. A 4-bit CRC has been implemented to check the data validity in memory. The application note AN520 describes in detail CRC-4 code used. SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 13 MS5525DSO (Digital Small Outline) PINOUT, MARKING, AND PRESSURE TYPE CONFIGURATION Pressure Type Pmin 0psiA Pmax +Prange -Prange +Prange 0psiG +Prange Absolute Differential/ Bidirectional Gauge Pin Name Pin SGND SOUTSDO 1,3 2,4 5 6 SDA/SDI Description Output is proportional to the difference between 0psiA (Pmin) and pressure applied to Port 1. Output is proportional to the difference between Port 1 and Port 2. Output swings positive when Port 2> Port 1. Output is 50% of total counts when Port 1=Port 2. Output is proportional to the difference between 0psiG (Pmin) and Port 1. Output swings positive when Port 2> Port 1. Function I2C Sensor Ground Sensor Outputs, Negative Serial Data Output 2 I C Data Input and Output SPI Serial Data Input 2 SCL/SCLK 7 I C Clock CSB GND PS 8 2 9 10 SPI SPI Clock Defines I C Address Ground Chip Select (Active Low) Protocol Select PS = (VDD) PS = (GND) 2 I C Protocol Selected SPI Protocol Selected 2 CSB= (VDD) I C Address =1110110X (0xEC, 0xED) 2 CSB= (GND) I C Address=1110111X (0xEE, 0xEF) Supply+ 11,13 Positive Supply Voltage SOUT+ 12,14 Sensor Outputs, Positive WETTED MATERIAL BY PORT DESIGNATION Port LCP Style All Port 1 Port 2 X X Material Thermo-Epoxy Epoxy Resin X X X X RTV Glass Silicon X X X Silicone Gel X "X" Indicates Wetted Materials SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 14 MS5525DSO (Digital Small Outline) RECOMMEND PCB LAYOUT SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 15 MS5525DSO (Digital Small Outline) APPLICATION CIRCUIT The MS5525DSO is a circuit that can be used in conjunction with a microcontroller. It is designed for lowvoltage systems with a supply voltage of 3 V. Figure 17: Typical application circuit with SPI / I2C protocol communication Note 1. Place 100nF capacitor between Supply and GND to within 2 cm of sensor. SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 16 MS5525DSO (Digital Small Outline) DIMENSIONS MS5525DSO-DBxxxyS SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 17 MS5525DSO (Digital Small Outline) MS5525DSO-STxxxyS SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 18 MS5525DSO (Digital Small Outline) MS5525DSO-SBxxxyS SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 19 MS5525DSO (Digital Small Outline) MS5525DSO-DHxxxyS SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 20 MS5525DSO (Digital Small Outline) MS5525DSO-FTxxxyS SENSOR SOLUTIONS ///MS5525DSO 09/2016 Page 21 MS5525DSO (Digital Small Outline) ORDERING INFORMATION 5525DSO - DB 005 G S Pressure Type Pin Style Model - Package Style Pressure Range MS5525DSO - DB = Dual Barb SB = Single Barb ST = Single Tube DH = Dual Hole FT = Front Tube 001 002 005 015 030 A = Absolute D = Differential G = Gauge S = Gull Wing NORTH AMERICA EUROPE ASIA Measurement Specialties, Inc., a TE Connectivity company 45738 Northport Loop West Fremont, CA 94538 Tel: +1 800 767 1888 Fax: +1 510 498 1578 customercare.frmt@te.com MEAS Switzerland Sarl, a TE Connectivity company Ch. Chapons-des-Prés 11 CH-2022 Bevaix Tel: +41 32 847 9550 Fax: +41 32 847 9569 customercare.bevx@te.com Measurement Specialties (China) Ltd., a TE Connectivity company No. 26 Langshan Road Shenzhen High-Tech Park (North) Nanshan District, Shenzhen, 518057 China Tel: +86 755 3330 5088 Fax: +86 755 3330 5099 customercare.shzn@te.com TE.com/sensorsolutions Measurement Specialties, Inc., a TE Connectivity company. Measurement Specialties, TE Connectivity, TE Connectivity (logo) and EVERY CONNECTION COUNTS are trademarks. All other logos, products and/or company names referred to herein might be trademarks of their respective owners. The information given herein, including drawings, illustrations and schematics which are intended for illustration purposes only, is believed to be reliable. However, TE Connectivity makes no warranties as to its accuracy or completeness and disclaims any liability in connection with its use. TE Connectivity‘s obligations shall only be as set forth in TE Connectivity‘s Standard Terms and Conditions of Sale for this product and in no case will TE Connectivity be liable for any incidental, indirect or consequential damages arising out of the sale, resale, use or misuse of the product. Users of TE Connectivity products should make their own evaluation to determine the suitability of each such product for the specific application. © 2015 TE Connectivity Ltd. family of companies SENSOR SOLUTIONS ///MS5525DSO All Rights Reserved. 09/2016 Page 22
MIKROE-2550 价格&库存
很抱歉,暂时无法提供与“MIKROE-2550”相匹配的价格&库存,您可以联系我们找货
