MIKROE-3827
MIKROE-3827
    MIKRO
    IAM-20680 加速计,陀螺仪 传感器 mikroBUS™ Click™ 平台评估扩展板
MIKROE-3827 数据手册
IAM-20680 High Performance Automotive 6-Axis MotionTracking Device GENERAL DESCRIPTION APPLICATIONS The IAM-20680 is a 6-axis MotionTracking device for Automotive applications that combines a 3-axis gyroscope and a 3-axis accelerometer in a small 3x3x0.75mm (16-pin LGA) package. It also features a 512byte FIFO that can lower the traffic on the serial bus interface and reduce power consumption by allowing the system processor to burst read sensor data and then go into a low-power mode. IAM-20680, with its 6-axis integration, enables manufacturers to eliminate the costly and complex selection, qualification, and system level integration of discrete devices, guaranteeing optimal motion performance. The gyroscope has a programmable full-scale range of ±250 dps, ±500 dps, ±1000 dps, and ±2000 dps. The accelerometer has a user-programmable accelerometer full-scale range of ±2g, ±4g, ±8g, and ±16g. Factorycalibrated initial sensitivity of both sensors reduces production-line calibration requirements. Other industry-leading features include on-chip 16-bit ADCs, programmable digital filters, an embedded temperature sensor, and programmable interrupts. The device features I2C and SPI serial interfaces, a VDD operating range of 1.71V to 3.6V, and a separate digital IO supply, VDDIO from 1.71V to 3.6V. BLOCK DIAGRAM • • • • • • • ORDERING INFORMATION PART IAM-20680† X Accel ADC Self test Y Accel ADC Self test Z Accel ADC Interrupt Status Register NCS Slave I2C and SPI Serial Interface FIFO • • • • SDO SCLK SDI X Gyro Self test Y Gyro ADC Self test Z Gyro ADC ADC Signal Conditioning Self test User & Config Registers FSYNC Sensor Registers TEMP RANGE PACKAGE -40°C to +85°C 16-Pin LGA Digital-output X-, Y-, and Z-axis angular rate sensors (gyroscopes) with a user-programmable full-scale range of ±250 dps, ±500 dps, ±1000 dps, and ±2000 dps and integrated 16-bit ADCs Digital-output X-, Y-, and Z-axis accelerometer with a programmable full scale range of ±2g, ±4g, ±8g, and ±16g and integrated 16-bit ADCs User-programmable digital filters for gyroscope, accelerometer, and temperature sensor Self-test Wake-on-motion interrupt for low power operation of applications processor Reliability testing performed according to AEC–Q100 o PPAP and qualification data available upon request TYPICAL OPERATING CIRCUIT 1.8 – 3.3VDC RESV VDD C4, 2.2 µF C2, 0.1 µF Temp Sensor MSL* 3 FEATURES INT Self test AXES X,Y,Z †Denotes RoHS and Green-compliant package * Moisture sensitivity level of the package • • IAM-20680 Navigation Systems Aids for Dead Reckoning Lift Gate Motion Detections Accurate Location for Vehicle to Vehicle and Infrastructure 360º View Camera Stabilization Car Alarm Telematics Insurance Vehicle Tracking REGOUT ADC 16 15 14 C1, 0.47 µF Bias & LDOs Charge Pump VDDIO 1.8 – 3.3 VDC VDD GND REGOUT C3, 10 nF SCL SCL/SPC SDA AD0 VDDIO SDA/SDI SA0/SDO CS 13 1 2 3 12 IAM-20680 4 10 5 9 6 RESV TDK Corporation 1745 Technology Drive, San Jose, CA 95110 U.S.A +1(408) 988–7339 www.invensense.com 7 8 FSYNC INT InvenSense reserves the right to change the detail specifications as may be required to permit improvements in the design of its products. 11 Document Number: DS-000196 Revision: 1.1 Rev. Date: 01/30/2018 GND RESV RESV RESV RESV IAM-20680 TABLE OF CONTENTS General Description ............................................................................................................................................. 1 Block Diagram ...................................................................................................................................................... 1 Applications ......................................................................................................................................................... 1 Ordering Information ........................................................................................................................................... 1 Features ............................................................................................................................................................... 1 Typical Operating Circuit...................................................................................................................................... 1 1 2 3 4 Introduction ......................................................................................................................................................... 7 1.1 Purpose and Scope .................................................................................................................................... 7 1.2 Product Overview...................................................................................................................................... 7 1.3 Applications............................................................................................................................................... 7 Features ............................................................................................................................................................... 8 2.1 Gyroscope Features .................................................................................................................................. 8 2.2 Accelerometer Features ............................................................................................................................ 8 2.3 Additional Features ................................................................................................................................... 8 Electrical Characteristics ...................................................................................................................................... 9 3.1 Gyroscope Specifications .......................................................................................................................... 9 3.2 Accelerometer Specifications.................................................................................................................. 10 3.3 Electrical Specifications ........................................................................................................................... 11 3.4 I2C Timing Characterization ..................................................................................................................... 14 3.5 SPI Timing Characterization .................................................................................................................... 15 3.6 Absolute Maximum Ratings .................................................................................................................... 16 3.7 Thermal Information ............................................................................................................................... 16 Applications Information ................................................................................................................................... 17 4.1 Pin Out Diagram and Signal Description ................................................................................................. 17 4.2 Typical Operating Circuit ......................................................................................................................... 18 4.3 Bill of Materials for External Components .............................................................................................. 18 4.4 Block Diagram ......................................................................................................................................... 19 4.5 Overview ................................................................................................................................................. 19 4.6 Three-Axis MEMS Gyroscope with 16-bit ADCs and Signal Conditioning ............................................... 20 4.7 Three-Axis MEMS Accelerometer with 16-bit ADCs and Signal Conditioning......................................... 20 4.8 I2C and SPI Serial Communications Interfaces ........................................................................................ 20 4.9 Self-Test................................................................................................................................................... 21 4.10 Clocking............................................................................................................................................... 21 4.11 Sensor Data Registers ......................................................................................................................... 21 4.12 FIFO ..................................................................................................................................................... 22 4.13 Interrupts ............................................................................................................................................ 22 4.14 Digital-Output Temperature Sensor ................................................................................................... 22 4.15 Bias and LDOs ..................................................................................................................................... 22 4.16 Charge Pump ...................................................................................................................................... 22 Document Number: DS-000196 Revision: 1.1 Page 2 of 52 IAM-20680 5 4.17 Standard Power Modes ...................................................................................................................... 22 4.18 Sensor Initialization and Basic Configuration ..................................................................................... 22 Programmable Interrupts .................................................................................................................................. 24 5.1 6 7 Wake-on-Motion Interrupt ..................................................................................................................... 24 Digital Interface ................................................................................................................................................. 25 6.1 I2C and SPI Serial Interfaces .................................................................................................................... 25 6.2 I2C Interface............................................................................................................................................. 25 6.3 IC Communications Protocol ................................................................................................................... 25 6.4 I2C Terms ................................................................................................................................................. 27 6.5 SPI Interface ............................................................................................................................................ 27 Serial Interface Considerations .......................................................................................................................... 29 7.1 IAM-20680 Supported Interfaces ............................................................................................................ 29 8 Register Map ...................................................................................................................................................... 30 9 Register Descriptions ......................................................................................................................................... 32 9.1 Registers 0 to 2 – Gyroscope Self-Test Registers .................................................................................... 32 9.2 Registers 13 to 15 – Accelerometer Self-Test Registers.......................................................................... 32 9.3 Register 19 – Gyro Offset Adjustment Register ...................................................................................... 33 9.4 Register 20 – Gyro Offset Adjustment Register ...................................................................................... 33 9.5 Register 21 – Gyro Offset Adjustment Register ...................................................................................... 33 9.6 Register 22 – Gyro Offset Adjustment Register ...................................................................................... 33 9.7 Register 23 – Gyro Offset Adjustment Register ...................................................................................... 33 9.8 Register 24 – Gyro Offset Adjustment Register ...................................................................................... 34 9.9 Register 25 – Sample Rate Divider .......................................................................................................... 34 9.10 Register 26 – Configuration ................................................................................................................ 34 9.11 Register 27 – Gyroscope Configuration .............................................................................................. 35 9.12 Register 28 – Accelerometer Configuration ....................................................................................... 35 9.13 Register 29 – Accelerometer Configuration 2..................................................................................... 36 9.14 Register 30 – Low Power Mode Configuration ................................................................................... 37 9.15 Register 31 – Wake-on Motion Threshold (Accelerometer) ............................................................... 37 9.16 Register 35 – FIFO Enable ................................................................................................................... 38 9.17 Register 54 – FSYNC Interrupt Status.................................................................................................. 38 9.18 Register 55 – INT/DRDY Pin / Bypass Enable Configuration ............................................................... 38 9.19 Register 56 – Interrupt Enable ............................................................................................................ 39 9.20 Register 58 – Interrupt Status ............................................................................................................. 39 9.21 Registers 59 to 64 – Accelerometer Measurements .......................................................................... 39 9.22 Registers 65 and 66 – Temperature Measurement ............................................................................ 40 9.23 Registers 67 to 72 – Gyroscope Measurements ................................................................................. 40 9.24 Register 104 – Signal Path Reset......................................................................................................... 41 9.25 Register 105 – Accelerometer Intelligence Control ............................................................................ 41 9.26 Register 106 – User Control ................................................................................................................ 42 Document Number: DS-000196 Revision: 1.1 Page 3 of 52 IAM-20680 10 9.27 Register 107 – Power Management 1 ................................................................................................ 42 9.28 Register 108 – Power Management 2 ................................................................................................ 43 9.29 Registers 114 and 115 – FIFO Count Registers ................................................................................... 43 9.30 Register 116 – FIFO Read Write .......................................................................................................... 44 9.31 Register 117 – Who Am I .................................................................................................................... 44 9.32 Registers 119, 120, 122, 123, 125, 126 Accelerometer Offset Registers ............................................ 44 Assembly ............................................................................................................................................................ 46 10.1 Orientation of Axes ............................................................................................................................. 46 10.2 Package Dimensions ........................................................................................................................... 47 11 Part Number Package Marking .......................................................................................................................... 49 12 Reference ........................................................................................................................................................... 50 13 Revision History ................................................................................................................................................. 51 Document Number: DS-000196 Revision: 1.1 Page 4 of 52 IAM-20680 LIST OF FIGURES Figure 1. I2C Bus Timing Diagram ............................................................................................................................................................. 14 Figure 2. SPI Bus Timing Diagram............................................................................................................................................................. 15 Figure 3. Pin out Diagram for IAM-20680 3.0x3.0x0.75mm LGA ............................................................................................................. 17 Figure 4. IAM-20680 LGA Application Schematic .................................................................................................................................... 18 Figure 5. IAM-20680 Block Diagram ........................................................................................................................................................ 19 Figure 6. IAM-20680 Solution Using I2C Interface.................................................................................................................................... 20 Figure 7. IAM-20680 Solution Using SPI Interface ................................................................................................................................... 21 Figure 8. START and STOP Conditions ...................................................................................................................................................... 25 Figure 9. Acknowledge on the I2C Bus ..................................................................................................................................................... 26 Figure 10. Complete I2C Data Transfer ..................................................................................................................................................... 26 Figure 11. Typical SPI Master/Slave Configuration .................................................................................................................................. 28 Figure 12. I/O Levels and Connections..................................................................................................................................................... 29 Figure 14. Orientation of Axes of Sensitivity and Polarity of Rotation .................................................................................................... 46 Figure 15. Package Dimensions................................................................................................................................................................ 47 Figure 16. Part Number Package Marking ............................................................................................................................................... 49 Document Number: DS-000196 Revision: 1.1 Page 5 of 52 IAM-20680 LIST OF TABLES Table 1. Gyroscope Specifications ............................................................................................................................................................. 9 Table 2. Accelerometer Specifications ..................................................................................................................................................... 10 Table 3. D.C. Electrical Characteristics ..................................................................................................................................................... 11 Table 4. A.C. Electrical Characteristics ..................................................................................................................................................... 13 Table 5. Other Electrical Specifications .................................................................................................................................................... 13 Table 6. I2C Timing Characteristics ........................................................................................................................................................... 14 Table 7. SPI Timing Characteristics (8 MHz Operation) ........................................................................................................................... 15 Table 8. Absolute Maximum Ratings ....................................................................................................................................................... 16 Table 9. Thermal Information .................................................................................................................................................................. 16 Table 10. Signal Descriptions ................................................................................................................................................................... 17 Table 11. Bill of Materials ........................................................................................................................................................................ 18 Table 12. Standard Power Modes for IAM-20680 ................................................................................................................................... 22 Table 13. Table of Interrupt Sources........................................................................................................................................................ 24 Table 14. Serial Interface ......................................................................................................................................................................... 25 Table 15. I2C Terms .................................................................................................................................................................................. 27 Table 16. Configuration............................................................................................................................................................................ 35 Table 17. Accelerometer Data Rates and Bandwidths (Low-noise mode) ............................................................................................... 36 Table 18. Accelerometer Filter Bandwidths, Noise, and Current Consumption ...................................................................................... 36 Table 19. Example Configurations of Gyroscope Low Power Mode ........................................................................................................ 37 Table 20. Package Dimensions ................................................................................................................................................................. 48 Table 21. Part Number Package Marking ................................................................................................................................................ 49 Document Number: DS-000196 Revision: 1.1 Page 6 of 52 IAM-20680 1 INTRODUCTION 1.1 PURPOSE AND SCOPE This document is a product specification, providing description, specifications, and design related information on the IAM-20680 Automotive MotionTracking device. The device is housed in a small 3x3x0.75 mm 16-pin LGA package. 1.2 PRODUCT OVERVIEW The IAM-20680 is a 6-axis MotionTracking device for Automotive applications, that combines a 3-axis gyroscope and a 3-axis accelerometer in a small 3x3x0.75 mm (16-pin LGA) package. It also features a 512-byte FIFO that can lower the traffic on the serial bus interface and reduce power consumption by allowing the system processor to burst read sensor data and then go into a lowpower mode. IAM-20680, with its 6-axis integration, enables manufacturers to eliminate the costly and complex selection, qualification, and system level integration of discrete devices, guaranteeing optimal motion performance. The gyroscope has a programmable full-scale range of ±250 dps, ±500 dps, ±1000 dps, and ±2000 dps. The accelerometer has a userprogrammable accelerometer full-scale range of ±2g, ±4g, ±8g, and ±16g. Factory-calibrated initial sensitivity of both sensors reduces production-line calibration requirements. Other industry-leading features include on-chip 16-bit ADCs, programmable digital filters, an embedded temperature sensor, and programmable interrupts. The device features I2C and SPI serial interfaces, a VDD operating range of 1.71V to 3.6V, and a separate digital IO supply, VDDIO from 1.71V to 3.6V. Communication with all registers of the device is performed using either I2C at 40 0kHz or SPI at 8 MHz. By leveraging its patented and volume-proven CMOS-MEMS fabrication platform, which integrates MEMS wafers with companion CMOS electronics through wafer-level bonding, InvenSense has driven the package size down to a footprint and thickness of 3x3x0.75 mm (16-pin LGA), to provide a very small yet high-performance, low-cost package. The device provides high robustness by supporting 10,000g shock reliability. 1.3 APPLICATIONS • • • • • • • Navigation Systems Aids for Dead Reckoning Lift Gate Motion Detections Accurate Location for Vehicle to Vehicle and Infrastructure 360º View Camera Stabilization Car Alarm Telematics Insurance Vehicle Tracking Document Number: DS-000196 Revision: 1.1 Page 7 of 52 IAM-20680 2 FEATURES 2.1 GYROSCOPE FEATURES The triple-axis MEMS gyroscope in the IAM-20680 includes a wide range of features: • • • • • Digital-output X-, Y-, and Z-axis angular rate sensors (gyroscopes) with a user-programmable full-scale range of ±250 dps, ±500 dps, ±1000 dps, and ±2000 dps and integrated 16-bit ADCs Digitally-programmable low-pass filter Low-power gyroscope operation Factory calibrated sensitivity scale factor Self-test 2.2 ACCELEROMETER FEATURES The triple-axis MEMS accelerometer in IAM-20680 includes a wide range of features: • • • • Digital-output X-, Y-, and Z-axis accelerometer with a programmable full scale range of ±2g, ±4g, ±8g and ±16g and integrated 16-bit ADCs User-programmable interrupts Wake-on-motion interrupt for low power operation of applications processor Self-test 2.3 ADDITIONAL FEATURES The IAM-20680 includes the following additional features: • • • • • • • • • • Smallest and thinnest LGA package for portable devices: 3x3x0.75 mm (16-pin LGA) Minimal cross-axis sensitivity between the accelerometer and gyroscope axes 512-byte FIFO buffer enables the applications processor to read the data in bursts Digital-output temperature sensor User-programmable digital filters for gyroscope, accelerometer, and temperature sensor 10,000g shock tolerant 400 kHz Fast Mode I2C for communicating with all registers 8 MHz SPI serial interface for communicating with all registers MEMS structure hermetically sealed and bonded at wafer level RoHS and Green compliant Document Number: DS-000196 Revision: 1.1 Page 8 of 52 IAM-20680 3 ELECTRICAL CHARACTERISTICS 3.1 GYROSCOPE SPECIFICATIONS Typical Operating Circuit of section 4.2, VDD = 1.8V, VDDIO = 1.8V, TA = 25°C, unless otherwise noted. All Zero-rate output, sensitivity, and noise specifications include board soldering effects. PARAMETER Full-Scale Range Gyroscope ADC Word Length Sensitivity Scale Factor Nonlinearity Cross-Axis Sensitivity Initial ZRO Tolerance ZRO Variation Over Temperature Rate Noise Spectral Density Gyroscope Mechanical Frequencies Low Pass Filter Response Gyroscope Start Up Time Output Data Rate CONDITIONS GYROSCOPE SENSITIVITY FS_SEL=0 FS_SEL=1 FS_SEL=2 FS_SEL=3 MIN FS_SEL=0 FS_SEL=1 FS_SEL=2 FS_SEL=3 Best fit straight line; 25°C 25°C ZERO-RATE OUTPUT (ZRO) 25°C -40°C to +85°C GYROSCOPE NOISE PERFORMANCE (FS_SEL=0) -40°C to +85°C -40°C to +85°C, including lifetime drift 25 Programmable Range 5 From Sleep mode Programmable, Normal 4 (Filtered) mode TYP UNITS NOTES ±250 ±500 ±1000 ±2000 16 131 65.5 32.8 16.4 ±0.1 ±5 dps dps dps dps bits LSB/(dps) LSB/(dps) LSB/(dps) LSB/(dps) % % 3 3 3 3 3 3 3 3 3 1 1 -0.8 ±1 dps dps 2 1 0.005 dps/√Hz 1,4 0.010 dps/√Hz 1,4 29 250 KHz Hz ms 2 3 1 8000 Hz 1 27 MAX 35 Table 1. Gyroscope Specifications Notes: 1. 2. 3. 4. Derived from validation or characterization of parts, not guaranteed in production. Tested in production. Guaranteed by design. Calculated from Total RMS Noise. Document Number: DS-000196 Revision: 1.1 Page 9 of 52 IAM-20680 3.2 ACCELEROMETER SPECIFICATIONS Typical Operating Circuit of section 4.2, VDD = 1.8V, VDDIO = 1.8V, TA = 25°C, unless otherwise noted. All Zero-g output, sensitivity, and noise specifications include board soldering effects. PARAMETER Full-Scale Range ADC Word Length Sensitivity Scale Factor Nonlinearity Cross-Axis Sensitivity Initial Tolerance Zero-G Level Change vs. Temperature Power Spectral Density Low Pass Filter Response Accelerometer Startup Time Output Data Rate CONDITIONS ACCELEROMETER SENSITIVITY AFS_SEL=0 AFS_SEL=1 AFS_SEL=2 AFS_SEL=3 Output in two’s complement format AFS_SEL=0 AFS_SEL=1 AFS_SEL=2 AFS_SEL=3 Best Fit Straight Line for 2g, 25°C 25°C ZERO-G OUTPUT All axes, 25°C -40°C to +85°C NOISE PERFORMANCE Low noise mode, -40°C to +85°C Low noise mode, -40°C to +85°C, including lifetime drift Programmable Range From Sleep mode From Cold Start, 1ms VDD ramp Low power (duty-cycled) Low noise (active) MIN TYP MAX UNITS NOTES ±5 g g g g bits LSB/g LSB/g LSB/g LSB/g % % 3 3 3 3 3 3 3 3 3 1 1 ±50 ±50 mg mg 1 1 135 µg/√Hz 1,4 190 µg/√Hz 1,4 Hz ms ms Hz Hz 3 1 1 ±2 ±4 ±8 ±16 16 16,384 8,192 4,096 2,048 -0.25 5 0.24 4 +0.25 218 20 30 500 4000 1 Table 2. Accelerometer Specifications Please contact TDK-InvenSense for a datasheet with maximum and minimum performance values over temperature and lifetime. Notes: 1. 2. 3. 4. Derived from validation or characterization of parts, not guaranteed in production. Tested in production. Guaranteed by design. Calculated from Total RMS Noise. Document Number: DS-000196 Revision: 1.1 Page 10 of 52 IAM-20680 3.3 ELECTRICAL SPECIFICATIONS D.C. Electrical Characteristics Typical Operating Circuit of section 4.2, VDD = 1.8V, VDDIO = 1.8V, TA = 25°C, unless otherwise noted. PARAMETER CONDITIONS SUPPLY VOLTAGES VDD VDDIO Normal Mode Accelerometer Low -Power Mode Gyroscope Low-Power Mode 6-Axis Low-Power Mode (Gyroscope Low-Power Mode; Accelerometer Low-Noise Mode) Full-Chip Sleep Mode Specified Temperature Range MIN TYP MAX UNITS NOTES 1.71 1.71 1.8 1.8 3.6 3.6 V V 1 1 SUPPLY CURRENTS & BOOT TIME 6-axis Gyroscope + Accelerometer 3-axis Gyroscope 3-axis Accelerometer, 4 kHz ODR 3 2.6 390 mA mA µA 1 1 1 100 Hz ODR, 1x averaging 57 µA 2 100 Hz ODR, 1x averaging 1.6 mA 2 100 Hz ODR, 1x averaging 1.92 mA 2 6 µA 1 °C 1 TEMPERATURE RANGE Performance parameters are not applicable beyond Specified Temperature Range -40 +85 Table 3. D.C. Electrical Characteristics Notes: 1. 2. Derived from validation or characterization of parts, not guaranteed in production. Based on simulation. Document Number: DS-000196 Revision: 1.1 Page 11 of 52 IAM-20680 A.C. Electrical Characteristics Typical Operating Circuit of section 4.2, VDD = 1.8V, VDDIO = 1.8V, TA = 25°C, unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS NOTES 100 ms 1 85 °C °C LSB/°C 1 1 1 SUPPLIES Supply Ramp Time (TRAMP) Operating Range Room Temperature Offset Sensitivity Supply Ramp Time (TRAMP) Start-up time for register read/write I2C ADDRESS VIH, High Level Input Voltage VIL, Low Level Input Voltage CI, Input Capacitance VOH, High Level Output Voltage VOL1, LOW-Level Output Voltage VOL.INT, INT Low-Level Output Voltage Output Leakage Current tINT, INT Pulse Width VIL, LOW Level Input Voltage VIH, HIGH-Level Input Voltage Vhys, Hysteresis VOL, LOW-Level Output Voltage IOL, LOW-Level Output Current Output Leakage Current tof, Output Fall Time from VIHmax to VILmax Document Number: DS-000196 Revision: 1.1 Monotonic ramp. Ramp 0.01 rate is 10% to 90% of the final value TEMPERATURE SENSOR Ambient -40 25°C 0 Untrimmed 326.8 POWER-ON RESET Valid power-on RESET 0.01 From power-up 11 From sleep SA0 = 0 1101000 SA0 = 1 1101001 DIGITAL INPUTS (FSYNC, SA0, SPC, SDI, CS) 0.7*VDDIO 100 100 5 ms ms ms 0.3*VDDIO DIGITAL OUTPUT (SDO, INT) RLOAD=1 MΩ; 0.9*VDDIO RLOAD=1 MΩ; OPEN=1, 0.3mA sink Current OPEN=1 LATCH_INT_EN=0 I2C I/O (SCL, SDA) -0.5V 0.7*VDDIO < 10 0.1*VDDIO 0.1 100 50 Cb bus capacitance in pf 0 0.3*VDDIO VDDIO + 0.5 V 20+0.1Cb 3 6 100 V V pF V V V 1 1 nA µs 0.1*VDDIO 3 mA sink current VOL=0.4V VOL=0.6V 1 1 1 0.4 300 V V V V mA mA nA ns Page 12 of 52 1 IAM-20680 Sample Rate Clock Frequency Initial Tolerance Frequency Variation over Temperature INTERNAL CLOCK SOURCE FCHOICE_B=1,2,3 SMPLRT_DIV=0 FCHOICE_B=0; DLPFCFG=0 or 7 SMPLRT_DIV=0 FCHOICE_B=0; DLPFCFG=1,2,3,4,5,6; SMPLRT_DIV=0 CLK_SEL=0, 6 or gyro -5 inactive; 25°C CLK_SEL=1,2,3,4,5 and gyro -1 active; 25°C CLK_SEL=0,6 or gyro -10 inactive CLK_SEL=1,2,3,4,5 and gyro -1 active 32 kHz 2 8 kHz 2 1 kHz 2 +5 % 1 +1 % 1 +10 % 1 +1 % 1 Table 4. A.C. Electrical Characteristics Notes: 1. 2. Derived from validation or characterization of parts, not guaranteed in production. Guaranteed by design. Other Electrical Specifications Typical Operating Circuit of section 4.2, VDD = 1.8V, VDDIO = 1.8V, TA = 25°C, unless otherwise noted. PARAMETER SPI Operating Frequency, All Registers Read/Write CONDITIONS SERIAL INTERFACE MIN Low Speed Characterization High Speed Characterization SPI Modes I2C Operating Frequency All registers, Fast-mode All registers, Standard-mode TYP 100 ±10% 1 Modes 0 and 3 MAX UNITS NOTES kHz 1 8 MHz 1, 2 400 100 kHz kHz 1 1 Table 5. Other Electrical Specifications Notes: 1. 2. Derived from validation or characterization of parts, not guaranteed in production. SPI clock duty cycle between 45% and 55% should be used for 8 MHz operation. Document Number: DS-000196 Revision: 1.1 Page 13 of 52 IAM-20680 3.4 I2C TIMING CHARACTERIZATION Typical Operating Circuit of section 4.2, VDD = 1.8V, VDDIO = 1.8V, TA = 25°C, unless otherwise noted. PARAMETERS I2C TIMING fSCL, SCL Clock Frequency tHD.STA, (Repeated) START Condition Hold Time tLOW, SCL Low Period tHIGH, SCL High Period tSU.STA, Repeated START Condition Setup Time tHD.DAT, SDA Data Hold Time tSU.DAT, SDA Data Setup Time tr, SDA and SCL Rise Time tf, SDA and SCL Fall Time tSU.STO, STOP Condition Setup Time CONDITIONS I2C FAST-MODE MIN Cb bus cap. from 10 to 400 pF Cb bus cap. from 10 to 400 pF MAX UNITS NOTES 400 0.6 kHz µs 1 1 1.3 0.6 0.6 0 100 20+0.1Cb 20+0.1Cb 0.6 µs µs µs µs ns ns ns µs 1 1 1 1 1 1 1 1 µs 1 pF µs µs 1 1 1 tBUF, Bus Free Time Between STOP and START Condition Cb, Capacitive Load for each Bus Line tVD.DAT, Data Valid Time tVD.ACK, Data Valid Acknowledge Time TYP 300 300 1.3 < 400 0.9 0.9 Table 6. I2C Timing Characteristics Notes: 1. Based on characterization of 5 parts over temperature and voltage as mounted on evaluation board or in sockets. tf SDA tSU.DAT tr 70% 30% 70% 30% continued below at tf SCL tr 70% 30% S tHD.STA tVD.DAT 70% 30% tHD.DAT 1/fSCL tLOW 1st clock cycle 9th clock cycle tHIGH tBUF SDA 70% 30% A tSU.STA tHD.STA SCL 70% 30% Sr tSU.STO tVD.ACK 9th clock cycle P S Figure 1. I2C Bus Timing Diagram Document Number: DS-000196 Revision: 1.1 Page 14 of 52 A IAM-20680 3.5 SPI TIMING CHARACTERIZATION Typical Operating Circuit of section 4.2, VDD = 1.8V, VDDIO = 1.8V, TA = 25°C, unless otherwise noted. PARAMETERS SPI TIMING fSPC, SPC Clock Frequency CONDITIONS MIN TYP MAX UNITS 8 NOTES MHz 1 tLOW, SPC Low Period 56 ns 1 tHIGH, SPC High Period 56 ns 1 tSU.CS, CS Setup Time 2 ns 1 tHD.CS, CS Hold Time 63 ns 1 tSU.SDI, SDI Setup Time 3 ns 1 tHD.SDI, SDI Hold Time 7 ns 1 40 ns 1 ns 1 tDIS.SDO, SDO Output Disable Time 20 ns 1 tFall, SCLK Fall Time 6.5 ns 2 tRise, SCLK Rise Time 6.5 ns 2 tVD.SDO, SDO Valid Time Cload = 20 pF tHD.SDO, SDO Hold Time Cload = 20 pF 6 Table 7. SPI Timing Characteristics (8 MHz Operation) Notes: 1. 2. Based on characterization of 5 parts over temperature and voltage as mounted on evaluation board or in sockets Based on other parameter values CS 70% 30% tFall tSU;CS SCLK tHIGH 70% 30% tHD;SDI tLOW LSB IN MSB IN tVD;SDO SDO tHD;CS 70% 30% tSU;SDI SDI tRise 1/fCLK MSB OUT tDIS;SDO tHD;SDO 70% 30% LSB OUT Figure 2. SPI Bus Timing Diagram Document Number: DS-000196 Revision: 1.1 Page 15 of 52 IAM-20680 3.6 ABSOLUTE MAXIMUM RATINGS Stress above those listed as “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these conditions is not implied. Exposure to the absolute maximum ratings conditions for extended periods may affect device reliability. PARAMETER Supply Voltage, VDD Supply Voltage, VDDIO REGOUT Input Voltage Level (SA0, FSYNC, SCL, SDA) Acceleration (Any Axis, unpowered) Operating Temperature Range Storage Temperature Range Electrostatic Discharge (ESD) Protection Latch-up RATING -0.5V to 4V -0.5V to 4V -0.5V to 2V -0.5V to VDDIO + 0.5V 10,000g for 0.2 ms -40°C to +85°C -40°C to +125°C 2 kV (HBM); 250V (MM) JEDEC Class II (2),125°C ±100 mA Table 8. Absolute Maximum Ratings 3.7 THERMAL INFORMATION THERMAL METRIC θJA ψJT DESCRIPTION Junction-to-ambient thermal resistance Junction-to-top characterization parameter VALUE 84.58 °C/W 7 °C/W Table 9. Thermal Information Document Number: DS-000196 Revision: 1.1 Page 16 of 52 IAM-20680 4 APPLICATIONS INFORMATION 4.1 PIN OUT DIAGRAM AND SIGNAL DESCRIPTION PIN NUMBER 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 PIN NAME VDDIO SCL/SPC SDA/SDI SA0/SDO CS INT RESV FSYNC RESV RESV RESV RESV GND REGOUT RESV 16 VDD PIN DESCRIPTION Digital I/O supply voltage. I2C serial clock (SCL); SPI serial clock (SPC). I2C serial data (SDA); SPI serial data input (SDI). I2C slave address LSB (SA0); SPI serial data output (SDO). Chip select (0 = SPI mode; 1 = I2C mode). Interrupt digital output (totem pole or open-drain). Reserved. Do not connect. Synchronization digital input (optional). Connect to GND if unused. Reserved. Connect to GND. Reserved. Connect to GND. Reserved. Connect to GND. Reserved. Connect to GND. Connect to GND. Regulator filter capacitor connection. Reserved. Connect to GND. Power Supply. Table 10. Signal Descriptions Note: Power up with SCL/SPC and CS pins held low is not a supported use case. In case this power up approach is used, software reset is required using the PWR_MGMT_1 register, prior to initialization. RESV REGOUT 14 VDD 16 15 VDDIO 1 13 GND SCL/SPC 2 12 RESV +Z IAM-20680 SDA/SDI 3 11 RESV SA0/SDO 4 10 RESV CS 5 9 RESV 6 7 8 IAM -20 68 0 INT RESV FSYNC +Y LGA Package (Top View) 16-pin, 3mm x 3mm x 0.75mm Typical Footprint and thickness +X Orientation of Axes of Sensitivity and Polarity of Rotation Figure 3. Pin out Diagram for IAM-20680 3.0x3.0x0.75mm LGA Document Number: DS-000196 Revision: 1.1 Page 17 of 52 IAM-20680 4.2 TYPICAL OPERATING CIRCUIT 1.8 – 3.3VDC RESV VDD C4, 2.2 µF C2, 0.1 µF 16 VDDIO 1.8 – 3.3 VDC C3, 10 nF SCL SCL/SPC SDA AD0 VDDIO SDA/SDI SA0/SDO CS REGOUT 15 14 C1, 0.47 µF 1 13 2 12 IAM-20680 3 11 4 10 5 9 7 RESV RESV RESV RESV INT RESV 8 FSYNC 6 GND Figure 4. IAM-20680 LGA Application Schematic Note: I2C lines are open drain and pullup resistors (e.g. 10kΩ) are required. 4.3 BILL OF MATERIALS FOR EXTERNAL COMPONENTS COMPONENT REGOUT Capacitor VDD Bypass Capacitors VDDIO Bypass Capacitor LABEL C1 SPECIFICATION X7R, 0.47 µF ±10% QUANTITY 1 C2 X7R, 0.1 µF ±10% 1 C4 X7R, 2.2 µF ±10% 1 C3 X7R, 10 nF ±10% 1 Table 11. Bill of Materials Document Number: DS-000196 Revision: 1.1 Page 18 of 52 IAM-20680 4.4 BLOCK DIAGRAM IAM-20680 INT Self test X Accel ADC Self test Y Accel ADC Interrupt Status Register CS Slave I2C and SPI Serial Interface FIFO SA0 / SDO SCL / SPC SDA / SDI Z Accel ADC Self test X Gyro ADC Self test Y Gyro ADC Self test Z Gyro ADC Temp Sensor Signal Conditioning Self test User & Config Registers FSYNC Sensor Registers ADC Bias & LDOs Charge Pump VDD GND REGOUT Figure 5. IAM-20680 Block Diagram 4.5 OVERVIEW The IAM-20680 is comprised of the following key blocks and functions: • • • • • • • • • • • • Three-axis MEMS rate gyroscope sensor with 16-bit ADCs and signal conditioning Three-axis MEMS accelerometer sensor with 16-bit ADCs and signal conditioning Primary I2C and SPI serial communications interfaces Self-Test Clocking Sensor Data Registers FIFO Interrupts Digital-Output Temperature Sensor Bias and LDOs Charge Pump Standard Power Modes Document Number: DS-000196 Revision: 1.1 Page 19 of 52 IAM-20680 4.6 THREE-AXIS MEMS GYROSCOPE WITH 16-BIT ADCS AND SIGNAL CONDITIONING The IAM-20680 consists of three independent vibratory MEMS rate gyroscopes, which detect rotation about the X-, Y-, and Z- Axes. When the gyros are rotated about any of the sense axes, the Coriolis Effect causes a vibration that is detected by a capacitive pickoff. The resulting signal is amplified, demodulated, and filtered to produce a voltage that is proportional to the angular rate. This voltage is digitized using individual on-chip 16-bit Analog-to-Digital Converters (ADCs) to sample each axis. The full-scale range of the gyro sensors may be digitally programmed to ±250, ±500, ±1000, or ±2000 degrees per second (dps). The ADC sample rate is programmable from 8,000 samples per second, down to 3.9 samples per second, and user-selectable low-pass filters enable a wide range of cut-off frequencies. 4.7 THREE-AXIS MEMS ACCELEROMETER WITH 16-BIT ADCS AND SIGNAL CONDITIONING The IAM-20680’s 3-Axis accelerometer uses separate proof masses for each axis. Acceleration along a particular axis induces displacement on the corresponding proof mass, and capacitive sensors detect the displacement differentially. The IAM-20680’s architecture reduces the accelerometers’ susceptibility to fabrication variations as well as to thermal drift. When the device is placed on a flat surface, it will measure 0g on the X- and Y-axes and +1g on the Z-axis. The accelerometers’ scale factor is calibrated at the factory and is nominally independent of supply voltage. Each sensor has a dedicated sigma-delta ADC for providing digital outputs. The full scale range of the digital output can be adjusted to ±2g, ±4g, ±8g, or ±16g. 4.8 I2C AND SPI SERIAL COMMUNICATIONS INTERFACES The IAM-20680 communicates to a system processor using either a SPI or an I2C serial interface. The IAM-20680 always acts as a slave when communicating to the system processor. The LSB of the I2C slave address is set by pin 4 (SA0). IAM-20680 Solution Using I2C Interface In Figure 6, the system processor is an I2C master to the IAM-20680. Interrupt Status Register IAM-20680 INT SA0 Slave I2C or SPI Serial Interface I2C Processor Bus: for reading all sensor data from MPU VDDIO or GND SCL SCL SDA SDA System Processor FIFO User & Config Registers Sensor Register Factory Calibration Bias & LDOs VDD GND REGOUT Figure 6. IAM-20680 Solution Using I2C Interface Document Number: DS-000196 Revision: 1.1 Page 20 of 52 IAM-20680 IAM-20680 Solution Using SPI Interface In Figure 7, the system processor is an SPI master to the IAM-20680. Pins 2, 3, 4, and 5 are used to support the SPC, SDI, SDO, and CS signals for SPI communications. Processor SPI Bus: for reading all data from MPU and for configuring MPU Interrupt Status Register INT CS IAM-20680 2 Slave I C or SPI Serial Interface nCS SDO SDI SPC SPC SDI SDO System Processor FIFO Config Register Sensor Register Factory Calibration Bias & LDOs VDD GND REGOUT Figure 7. IAM-20680 Solution Using SPI Interface 4.9 SELF-TEST Self-test allows for the testing of the mechanical and electrical portions of the sensors. The self-test for each measurement axis can be activated by means of the gyroscope and accelerometer self-test registers (registers 27 and 28). When the self-test is activated, the electronics cause the sensors to be actuated and produce an output signal. The output signal is used to observe the self-test response. The self-test response is defined as follows: SELF-TEST RESPONSE = SENSOR OUTPUT WITH SELF-TEST ENABLED – SENSOR OUTPUT WITH SELF-TEST DISABLED When the value of the self-test response is within the specified min/max limits of the product specification, the part has passed selftest. When the self-test response exceeds the min/max values, the part is deemed to have failed self-test. 4.10 CLOCKING The IAM-20680 has a flexible clocking scheme, allowing a variety of internal clock sources to be used for the internal synchronous circuitry. This synchronous circuitry includes the signal conditioning and ADCs, and various control circuits and registers. An on-chip PLL provides flexibility in the allowable inputs for generating this clock. Allowable internal sources for generating the internal clock are: a) An internal relaxation oscillator b) Auto-select between internal relaxation oscillator and gyroscope MEMS oscillator to use the best available source The only setting supporting specified performance in all modes is option b). It is recommended that option b) be used. 4.11 SENSOR DATA REGISTERS The sensor data registers contain the latest gyroscope, accelerometer, and temperature measurement data. They are read-only registers, and are accessed via the serial interface. Data from these registers may be read anytime. Document Number: DS-000196 Revision: 1.1 Page 21 of 52 IAM-20680 4.12 FIFO The IAM-20680 contains a 512-byte FIFO register that is accessible via the Serial Interface. The FIFO configuration register determines which data are written into the FIFO. Possible choices include gyro data, accelerometer data, temperature readings, and FSYNC input. A FIFO counter keeps track of how many bytes of valid data are contained in the FIFO. The FIFO register supports burst reads. The interrupt function may be used to determine when new data are available. The IAM-20680 allows FIFO read in low-power accelerometer mode. 4.13 INTERRUPTS Interrupt functionality is configured via the Interrupt Configuration register. Items that are configurable include the INT pin configuration, the interrupt latching and clearing method, and triggers for the interrupt. Items that can trigger an interrupt are (1) Clock generator locked to new reference oscillator (used when switching clock sources); (2) new data are available to be read (from the FIFO and Data registers); (3) accelerometer event interrupts; (4) FIFO overflow. The interrupt status can be read from the Interrupt Status register. 4.14 DIGITAL-OUTPUT TEMPERATURE SENSOR An on-chip temperature sensor and ADC are used to measure the IAM-20680 die temperature. The readings from the ADC can be read from the FIFO or the Sensor Data registers. 4.15 BIAS AND LDOS The bias and LDO section generates the internal supply and the reference voltages and currents required by the IAM-20680. Its two inputs are an unregulated VDD and a VDDIO logic reference supply voltage. The LDO output is bypassed by a capacitor at REGOUT. For further details on the capacitor, please refer to the Bill of Materials for External Components. 4.16 CHARGE PUMP An on-chip charge pump generates the high voltage required for the MEMS oscillator. 4.17 STANDARD POWER MODES Table 12 lists the user-accessible power modes for IAM-20680. MODE 1 2 3 4 5 6 7 8 NAME Sleep Mode Standby Mode Accelerometer Low-Power Mode Accelerometer Low-Noise Mode Gyroscope Low-Power Mode Gyroscope Low-Noise Mode 6-Axis Low-Noise Mode 6-Axis Low-Power Mode GYRO Off Drive On Off Off Duty-Cycled On On Duty-Cycled ACCEL Off Off Duty-Cycled On Off Off On On Table 12. Standard Power Modes for IAM-20680 Notes: 1. Power consumption for individual modes can be found in section 3.3.1. 4.18 SENSOR INITIALIZATION AND BASIC CONFIGURATION The basic configuration of the IAM-20680 includes the following steps: • • • • • Sensor initialization and clock source selection Output data rate (i.e. sampling frequency) selection Full scale range selection Filter frequency selection Power mode selection Sensor Initialization and Clock Source Selection To initialize the sensor, perform a reset and let the IAM-20680 select the best clock source by setting the register PWR_MGMT1 (address 0x6B) to 0x81 (see section 9.27). Document Number: DS-000196 Revision: 1.1 Page 22 of 52 IAM-20680 Output Data Rate Selection To set the output data rate (ODR) to the desired frequency, select the sample rate divider by setting the register SMPLRT_DIV(address 0x19) to the desired value (see section 9.9). For instance, to set the output data rate to 100 Hz, write 0x09 into SMPLRT_DIV. Full Scale Range Selection To set the full-scale range (FSR) of the accelerometer, set the register ACCEL_CONFIG (address 0x1C) to the desired value (see section 9.12). For instance, to set the FSR of the accelerometer to 2g, write 0x00 into ACCEL_CONFIG. To set the FSR of the gyroscope, set the register GYRO_CONFIG (address 0x1B) to the desired value (see section 9.11). For instance, to set the FSR of the gyroscope to 250 dps, write 0x00 into GYRO_CONFIG. Filter Selection To set the corner frequency of the digital low-pass filter (DLPF) of the accelerometer, set the register ACCEL_CONFIG2 (address 0x1D) to the desired value (see section 9.13). For instance, to set the corner frequency of the DLPF of the accelerometer to 10.2 Hz, write 0x05 into ACCEL_CONFIG2. To set the corner frequency of the DLPF of the gyroscope, set the register CONFIG (address 0x1A) to the desired value (see section 9.10). For instance, to set the corner frequency of the DLPF of the gyroscope to 10 Hz, write 0x05 into CONFIG. Document Number: DS-000196 Revision: 1.1 Page 23 of 52 IAM-20680 5 PROGRAMMABLE INTERRUPTS The IAM-20680 has a programmable interrupt system which can generate an interrupt signal on the INT pin. Status flags indicate the source of an interrupt. Interrupt sources may be enabled and disabled individually. INTERRUPT NAME Motion Detection FIFO Overflow Data Ready MODULE Motion FIFO Sensor Registers Table 13. Table of Interrupt Sources 5.1 WAKE-ON-MOTION INTERRUPT The IAM-20680 provides motion detection capability. A qualifying motion sample is one where the high passed sample from any axis has an absolute value exceeding a user-programmable threshold. The following steps explain how to configure the Wake-on-Motion Interrupt. Step 1: Ensure that Accelerometer is running • • In PWR_MGMT_1 register (0x6B) set CYCLE = 0, SLEEP = 0, and GYRO_STANDBY = 0 In PWR_MGMT_2 register (0x6C) set STBY_XA = STBY_YA = STBY_ZA = 0, and STBY_XG = STBY_YG = STBY_ZG = 1 Step 2: Accelerometer Configuration • In ACCEL_CONFIG2 register (0x1D) set ACCEL_FCHOICE_B = 0 and A_DLPF_CFG[2:0] = 1 (b001) Step 3: Enable Motion Interrupt • In INT_ENABLE register (0x38) set WOM_INT_EN = 111 to enable motion interrupt Step 4: Set Motion Threshold • Set the motion threshold in ACCEL_WOM_THR register (0x1F) Step 5: Enable Accelerometer Hardware Intelligence • In ACCEL_INTEL_CTRL register (0x69) set ACCEL_INTEL_EN = ACCEL_INTEL_MODE = 1; Ensure that bit 0 is set to 0 Step 6: Set Frequency of Wake-Up • In SMPLRT_DIV register (0x19) set SMPLRT_DIV[7:0] = 3.9 Hz – 500 Hz Step 7: Enable Cycle Mode (Accelerometer Low-Power Mode) • In PWR_MGMT_1 register (0x6B) set CYCLE = 1 Document Number: DS-000196 Revision: 1.1 Page 24 of 52 IAM-20680 6 DIGITAL INTERFACE 6.1 I2C AND SPI SERIAL INTERFACES The internal registers and memory of the IAM-20680 can be accessed using either I2C at 400 kHz or SPI at 8 MHz. SPI operates in four-wire mode. PIN NUMBER 1 PIN NAME VDDIO PIN DESCRIPTION Digital I/O supply voltage. 4 2 3 SA0 / SDO SCL / SPC SDA / SDI I2C Slave Address LSB (SA0); SPI serial data output (SDO). I2C serial clock (SCL); SPI serial clock (SPC). I2C serial data (SDA); SPI serial data input (SDI). Table 14. Serial Interface Note: To prevent switching into I2C mode when using SPI, the I2C interface should be disabled by setting the I2C_IF_DIS configuration bit. Setting this bit should be performed immediately after waiting for the time specified by the “Start-Up Time for Register Read/Write” in section 3.3.2. For further information regarding the I2C_IF_DIS bit, please refer to sections 8 and 9 of this document. 6.2 I2C INTERFACE I2C is a two-wire interface comprised of the signals serial data (SDA) and serial clock (SCL). In general, the lines are open-drain and bidirectional. In a generalized I2C interface implementation, attached devices can be a master or a slave. The master device puts the slave address on the bus, and the slave device with the matching address acknowledges the master. The IAM-20680 always operates as a slave device when communicating to the system processor, which thus acts as the master. SDA and SCL lines typically need pull-up resistors to VDD. The maximum bus speed is 400 kHz. The slave address of the IAM-20680 is b110100X which is 7 bits long. The LSB bit of the 7-bit address is determined by the logic level on pin SA0. This allows two IAM-20680s to be connected to the same I2C bus. When used in this configuration, the address of one of the devices should be b1101000 (pin SA0 is logic low) and the address of the other should be b1101001 (pin SA0 is logic high). 6.3 IC COMMUNICATIONS PROTOCOL START (S) and STOP (P) Conditions Communication on the I2C bus starts when the master puts the START condition (S) on the bus, which is defined as a HIGH-to-LOW transition of the SDA line while SCL line is HIGH (see figure below). The bus is considered to be busy until the master puts a STOP condition (P) on the bus, which is defined as a LOW to HIGH transition on the SDA line while SCL is HIGH (see Figure 8). Additionally, the bus remains busy if a repeated START (Sr) is generated instead of a STOP condition. SDA SCL S P START condition STOP condition Figure 8. START and STOP Conditions Data Format / Acknowledge I2C data bytes are defined to be 8-bits long. There is no restriction to the number of bytes transmitted per data transfer. Each byte transferred must be followed by an acknowledge (ACK) signal. The clock for the acknowledge signal is generated by the master, while the receiver generates the actual acknowledge signal by pulling down SDA and holding it low during the HIGH portion of the acknowledge clock pulse. Document Number: DS-000196 Revision: 1.1 Page 25 of 52 IAM-20680 If a slave is busy and cannot transmit or receive another byte of data until some other task has been performed, it can hold SCL LOW, thus forcing the master into a wait state. Normal data transfer resumes when the slave is ready, and releases the clock line (refer to the following figure). DATA OUTPUT BY TRANSMITTER (SDA) not acknowledge DATA OUTPUT BY RECEIVER (SDA) acknowledge SCL FROM MASTER 1 2 8 9 clock pulse for acknowledgement START condition Figure 9. Acknowledge on the I2C Bus Communications After beginning communications with the START condition (S), the master sends a 7-bit slave address followed by an 8th bit, the read/write bit. The read/write bit indicates whether the master is receiving data from or is writing to the slave device. Then, the master releases the SDA line and waits for the acknowledge signal (ACK) from the slave device. Each byte transferred must be followed by an acknowledge bit. To acknowledge, the slave device pulls the SDA line LOW and keeps it LOW for the high period of the SCL line. Data transmission is always terminated by the master with a STOP condition (P), thus freeing the communications line. However, the master can generate a repeated START condition (Sr), and address another slave without first generating a STOP condition (P). A LOW to HIGH transition on the SDA line while SCL is HIGH defines the stop condition. All SDA changes should take place when SCL is low, with the exception of start and stop conditions. SDA SCL 1–7 8 9 1–7 8 9 1–7 8 9 S P START ADDRESS condition R/W ACK DATA ACK DATA ACK STOP condition Figure 10. Complete I2C Data Transfer To write the internal IAM-20680 registers, the master transmits the start condition (S), followed by the I2C address and the write bit (0). At the 9th clock cycle (when the clock is high), the IAM-20680 acknowledges the transfer. Then the master puts the register address (RA) on the bus. After the IAM-20680 acknowledges the reception of the register address, the master puts the register data onto the bus. This is followed by the ACK signal, and data transfer may be concluded by the stop condition (P). To write multiple bytes after the last ACK signal, the master can continue outputting data rather than transmitting a stop signal. In this case, the IAM20680 automatically increments the register address and loads the data to the appropriate register. The following figures show single and two-byte write sequences. Single-Byte Write Sequence Master S AD+W Slave Document Number: DS-000196 Revision: 1.1 RA ACK DATA ACK P ACK Page 26 of 52 IAM-20680 Burst Write Sequence Master S AD+W RA Slave ACK DATA DATA ACK ACK P ACK To read the internal IAM-20680 registers, the master sends a start condition, followed by the I2C address and a write bit, and then the register address that is going to be read. Upon receiving the ACK signal from the IAM-20680, the master transmits a start signal followed by the slave address and read bit. As a result, the IAM-20680 sends an ACK signal and the data. The communication ends with a not acknowledge (NACK) signal and a stop bit from master. The NACK condition is defined such that the SDA line remains high at the 9th clock cycle. The following figures show single and two-byte read sequences. Single-Byte Read Sequence Master S AD+W Slave RA ACK S AD+R ACK NACK ACK P DATA Burst Read Sequence Master S AD+W Slave RA ACK S ACK AD+R ACK ACK DATA NACK P DATA 6.4 I2C TERMS SIGNAL S AD W R ACK NACK RA DATA P DESCRIPTION Start Condition: SDA goes from high to low while SCL is high Slave I2C address Write bit (0) Read bit (1) Acknowledge: SDA line is low while the SCL line is high at the 9th clock cycle Not-Acknowledge: SDA line stays high at the 9th clock cycle IAM-20680 internal register address Transmit or received data Stop condition: SDA going from low to high while SCL is high Table 15. I2C Terms 6.5 SPI INTERFACE SPI is a 4-wire synchronous serial interface that uses two control lines and two data lines. The IAM-20680 always operates as a Slave device during standard Master-Slave SPI operation. With respect to the Master, the Serial Clock output (SPC), the Serial Data Output (SDO) and the Serial Data Input (SDI) are shared among the Slave devices. Each SPI slave device requires its own Chip Select (CS) line from the master. CS goes low (active) at the start of transmission and goes back high (inactive) at the end. Only one CS line is active at a time, ensuring that only one slave is selected at any given time. The CS lines of the non-selected slave devices are held high, causing their SDO lines to remain in a high-impedance (high-z) state so that they do not interfere with any active devices. SPI Operational Features 1. 2. 3. 4. 5. Data are delivered MSB first and LSB last Data are latched on the rising edge of SPC Data should be transitioned on the falling edge of SPC The maximum frequency of SPC is 8 MHz SPI read and write operations are completed in 16 or more clock cycles (two or more bytes). The first byte contains the SPI Address, and the following byte(s) contain(s) the SPI data. The first bit of the first byte contains the Read/Write bit and indicates the Read (1) or Write (0) operation. The following 7 bits contain the Register Address. In cases of multiplebyte Read/Writes, data are two or more bytes: Document Number: DS-000196 Revision: 1.1 Page 27 of 52 IAM-20680 SPI Address format MSB R/W A6 A5 A4 A3 A2 A1 LSB A0 D6 D5 D4 D3 D2 D1 LSB D0 SPI Data format MSB D7 6. Supports Single or Burst Read/Writes. SPC SDI SDO SPI Master CS1 SPI Slave 1 CS CS2 SPC SDI SDO CS SPI Slave 2 Figure 11. Typical SPI Master/Slave Configuration Document Number: DS-000196 Revision: 1.1 Page 28 of 52 IAM-20680 7 SERIAL INTERFACE CONSIDERATIONS 7.1 IAM-20680 SUPPORTED INTERFACES The IAM-20680 supports I2C communications on its serial interface. The IAM-20680’s I/O logic levels are set to be VDDIO. Figure 12 depicts a sample circuit of IAM-20680. It shows the relevant logic levels and voltage connections. VDDIO (0V - VDDIO) VDD VDDIO VDD INT SDA (0V - VDDIO) SYNC VDDIO SCL SYSTEM BUS VDD_IO System Processor IO (0V - VDDIO) (0V - VDDIO) (0V - VDDIO) IAM-20680 VDDIO (0V, VDDIO) SA0 Figure 12. I/O Levels and Connections Document Number: DS-000196 Revision: 1.1 Page 29 of 52 IAM-20680 8 REGISTER MAP The following table lists the register map for the IAM-20680. Addr (Hex) Addr (Dec.) Register Name Serial I/F Accessible (writable) in Sleep Mode 00 00 SELF_TEST_X_GYRO R/W N XG_ST_DATA[7:0] 01 01 SELF_TEST_Y_GYRO R/W N YG_ST_DATA[7:0] 02 02 SELF_TEST_Z_GYRO R/W N ZG_ST_DATA[7:0] 0D 13 SELF_TEST_X_ACCEL R/W N XA_ST_DATA[7:0] 0E 14 SELF_TEST_Y_ACCEL R/W N YA_ST_DATA[7:0] 0F 15 SELF_TEST_Z_ACCEL R/W N ZA_ST_DATA[7:0] 13 19 XG_OFFS_USRH R/W N X_OFFS_USR [15:8] 14 20 XG_OFFS_USRL R/W N X_OFFS_USR [7:0] 15 21 YG_OFFS_USRH R/W N Y_OFFS_USR [15:8] 16 22 YG_OFFS_USRL R/W N Y_OFFS_USR [7:0] 17 23 ZG_OFFS_USRH R/W N Z_OFFS_USR [15:8] 18 24 ZG_OFFS_USRL R/W N Z_OFFS_USR [7:0] 19 25 SMPLRT_DIV R/W N 1A 26 1B 1C N Bit7 Bit6 Bit5 Bit4 Bit3 - N XG_ST YG_ST ZG_ST FS_SEL [1:0] N XA_ST YA_ST ZA_ST ACCEL_FS_SEL[1:0] R/W 27 GYRO_CONFIG R/W 28 ACCEL_CONFIG R/W 1D 29 ACCEL_CONFIG 2 R/W N 1E 30 LP_MODE_CFG R/W N 1F 31 ACCEL_WOM_THR R/W N Bit1 Bit0 SMPLRT_DIV[7:0] FIFO_ MODE CONFIG Bit2 EXT_SYNC_SET[2:0] - - FCHOICE_B[1:0] - ACCEL_FCHOI CE_B DEC2_CFG GYRO_CYCL E DLPF_CFG[2:0] A_DLPF_CFG G_AVGCFG[2:0] WOM_THR[7:0] 23 35 FIFO_EN R/W N TEMP _FIFO_EN 36 54 FSYNC_INT R/C N FSYNC_INT YG_FIFO_EN ZG_FIFO_EN ACCEL_FIFO_ EN - - - INT_OPEN LATCH _INT_EN - - - - - - - INT_RD _CLEAR FSYNC_INT_L EVEL FSYNC _INT_MODE_ EN - - 37 55 INT_PIN_CFG R/W Y 38 56 INT_ENABLE R/W Y WOM_INT_EN[7:5] FIFO _OFLOW _EN - GDRIVE_INT_ EN - DATA_RDY_I NT_EN 3A 58 INT_STATUS R/C N WOM_INT[7:5] FIFO _OFLOW _INT - GDRIVE_INT - DATA _RDY_INT 3B 59 ACCEL_XOUT_H R N 3C 60 ACCEL_XOUT_L R N ACCEL_XOUT_L[7:0] 3D 61 ACCEL_YOUT_H R N ACCEL_YOUT_H[15:8] 3E 62 ACCEL_YOUT_L R N ACCEL_YOUT_L[7:0] 3F 63 ACCEL_ZOUT_H R N ACCEL_ZOUT_H[15:8] 40 64 ACCEL_ZOUT_L R N ACCEL_ZOUT_L[7:0] 41 65 TEMP_OUT_H R N TEMP_OUT[15:8] 42 66 TEMP_OUT_L R N TEMP_OUT[7:0] 43 67 GYRO_XOUT_H R N GYRO_XOUT[15:8] 44 68 GYRO_XOUT_L R N GYRO_XOUT[7:0] 45 69 GYRO_YOUT_H R N GYRO_YOUT[15:8] 46 70 GYRO_YOUT_L R N GYRO_YOUT[7:0] 47 71 GYRO_ZOUT_H R N GYRO_ZOUT[15:8] 48 72 GYRO_ZOUT_L R N GYRO_ZOUT[7:0] 68 104 SIGNAL_PATH_RESET R/W N - - - ACCEL _RST TEMP _RST 69 105 ACCEL_INTEL_CTRL R/W N ACCEL_INTE L_EN ACCEL_INTEL _MODE 6A 106 USER_CTRL R/W N - FIFO_EN - I2C_IF _DIS - FIFO _RST - SIG_COND _RST 6B 107 PWR_MGMT_1 R/W Y DEVICE_RES ET SLEEP ACCEL_CYCLE GYRO_ STANDBY TEMP_DIS Document Number: DS-000196 Revision: 1.1 INT_LEVEL XG_FIFO_EN ACCEL_XOUT_H[15:8] - - - CLKSEL[2:0] Page 30 of 52 IAM-20680 Accessible (writable) in Sleep Mode Bit7 Bit6 Bit5 Bit4 Bit3 R/W Y FIFO_LP_EN - STBY_XA STBY_YA STBY_ZA R N FIFO_COUNTL R N FIFO_COUNT[7:0] FIFO_R_W R/W N FIFO_DATA[7:0] 117 WHO_AM_I R N WHOAMI[7:0] 77 119 XA_OFFSET_H R/W N XA_OFFS [14:7] Addr (Hex) Addr (Dec.) Register Name Serial I/F 6C 108 PWR_MGMT_2 72 114 FIFO_COUNTH 73 115 74 116 75 78 120 XA_OFFSET_L R/W N 7A 122 YA_OFFSET_H R/W N 7B 123 YA_OFFSET_L R/W N 7D 125 ZA_OFFSET_H R/W N 7E 126 ZA_OFFSET_L R/W N - Bit2 Bit1 Bit0 STBY_XG STBY_YG STBY_ZG FIFO_COUNT[12:8] XA_OFFS [6:0] - YA_OFFS [14:7] YA_OFFS [6:0] - ZA_OFFS [14:7] ZA_OFFS [6:0] - Note: Register Names ending in _H and _L contain the high and low bytes, respectively, of an internal register value. In the detailed register tables that follow, register names are in capital letters, while register values are in capital letters and italicized. For example, the ACCEL_XOUT_H register (Register 59) contains the 8 most significant bits, ACCEL_XOUT[15:8], of the 16bit X-Axis accelerometer measurement, ACCEL_XOUT. The reset value is 0x00 for all registers other than the registers below, also the self-test registers contain pre-programmed values and will not be 0x00 after reset. • • Register 107 (0x40) Power Management 1 Register 117 (0xA9) WHO_AM_I Document Number: DS-000196 Revision: 1.1 Page 31 of 52 IAM-20680 9 REGISTER DESCRIPTIONS This section describes the function and contents of each register within the IAM-20680. Note: The device will come up in sleep mode upon power-up. 9.1 REGISTERS 0 TO 2 – GYROSCOPE SELF-TEST REGISTERS Register Name: SELF_TEST_X_GYRO, SELF_TEST_Y_GYRO, SELF_TEST_Z_GYRO Type: READ/WRITE Register Address: 00, 01, 02 (Decimal); 00, 01, 02 (Hex) REGISTER BIT NAME SELF_TEST_X_GYRO [7:0] XG_ST_DATA[7:0] SELF_TEST_Y_GYRO [7:0] YG_ST_DATA[7:0] SELF_TEST_Z_GYRO [7:0] ZG_ST_DATA[7:0] FUNCTION The value in this register indicates the self-test output generated during manufacturing tests. This value is to be used to check against subsequent self-test outputs performed by the end user. The value in this register indicates the self-test output generated during manufacturing tests. This value is to be used to check against subsequent self-test outputs performed by the end user. The value in this register indicates the self-test output generated during manufacturing tests. This value is to be used to check against subsequent self-test outputs performed by the end user. The equation to convert self-test codes in OTP to factory self-test measurement is: ST _ OTP = ( 2620 / 2 FS ) * 1.01( ST _ code−1) (lsb) where ST_OTP is the value that is stored in OTP of the device, FS is the Full Scale value, and ST_code is based on the Self-Test value (ST_ FAC) determined in InvenSense’s factory final test and calculated based on the following equation: ST _ code = round ( log(ST _ FAC /(2620 / 2 FS )) ) +1 log(1.01) 9.2 REGISTERS 13 TO 15 – ACCELEROMETER SELF-TEST REGISTERS Register Name: SELF_TEST_X_ACCEL, SELF_TEST_Y_ACCEL, SELF_TEST_Z_ACCEL Type: READ/WRITE Register Address: 13, 14, 15 (Decimal); 0D, 0E, 0F (Hex) REGISTER BITS NAME SELF_TEST_X_ACCEL [7:0] XA_ST_DATA[7:0] SELF_TEST_Y_ACCEL [7:0] YA_ST_DATA[7:0] SELF_TEST_Z_ACCEL [7:0] ZA_ST_DATA[7:0] FUNCTION The value in this register indicates the self-test output generated during manufacturing tests. This value is to be used to check against subsequent self-test outputs performed by the end user. The value in this register indicates the self-test output generated during manufacturing tests. This value is to be used to check against subsequent self-test outputs performed by the end user. The value in this register indicates the self-test output generated during manufacturing tests. This value is to be used to check against subsequent self-test outputs performed by the end user. The equation to convert self-test codes in OTP to factory self-test measurement is: ST _ OTP = ( 2620 / 2 FS ) * 1.01( ST _ code−1) (lsb) where ST_OTP is the value that is stored in OTP of the device, FS is the Full Scale value, and ST_code is based on the Self-Test value (ST_ FAC) determined in InvenSense’s factory final test and calculated based on the following equation: ST _ code = round ( Document Number: DS-000196 Revision: 1.1 log(ST _ FAC /(2620 / 2 FS )) ) +1 log(1.01) Page 32 of 52 IAM-20680 9.3 REGISTER 19 – GYRO OFFSET ADJUSTMENT REGISTER Register Name: XG_OFFS_USRH Register Type: READ/WRITE Register Address: 19 (Decimal); 13 (Hex) BIT [7:0] NAME X_OFFS_USR[15:8] FUNCTION Bits 15 to 8 of the 16-bit offset of X gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register. 9.4 REGISTER 20 – GYRO OFFSET ADJUSTMENT REGISTER Register Name: XG_OFFS_USRL Register Type: READ/WRITE Register Address: 20 (Decimal); 14 (Hex) BIT [7:0] NAME X_OFFS_USR[7:0] FUNCTION Bits 7 to 0 of the 16-bit offset of X gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register. 9.5 REGISTER 21 – GYRO OFFSET ADJUSTMENT REGISTER Register Name: YG_OFFS_USRH Register Type: READ/WRITE Register Address: 21 (Decimal); 15 (Hex) BIT [7:0] NAME Y_OFFS_USR[15:8] FUNCTION Bits 15 to 8 of the 16-bit offset of Y gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register. 9.6 REGISTER 22 – GYRO OFFSET ADJUSTMENT REGISTER Register Name: YG_OFFS_USRL Register Type: READ/WRITE Register Address: 22 (Decimal); 16 (Hex) BIT [7:0] NAME Y_OFFS_USR[7:0] FUNCTION Bits 7 to 0 of the 16-bit offset of Y gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register. 9.7 REGISTER 23 – GYRO OFFSET ADJUSTMENT REGISTER Register Name: ZG_OFFS_USRH Register Type: READ/WRITE Register Address: 23 (Decimal); 17 (Hex) BIT [7:0] NAME Z_OFFS_USR[15:8] Document Number: DS-000196 Revision: 1.1 FUNCTION Bits 15 to 8 of the 16-bit offset of Z gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register. Page 33 of 52 IAM-20680 9.8 REGISTER 24 – GYRO OFFSET ADJUSTMENT REGISTER Register Name: ZG_OFFS_USRL Register Type: READ/WRITE Register Address: 24 (Decimal); 18 (Hex) BIT [7:0] NAME Z_OFFS_USR[7:0] FUNCTION Bits 7 to 0 of the 16-bit offset of Z gyroscope (2’s complement). This register is used to remove DC bias from the sensor output. The value in this register is added to the gyroscope sensor value before going into the sensor register. 9.9 REGISTER 25 – SAMPLE RATE DIVIDER Register Name: SMPLRT_DIV Register Type: READ/WRITE Register Address: 25 (Decimal); 19 (Hex) BIT [7:0] NAME SMPLRT_DIV[7:0] FUNCTION Divides the internal sample rate (see register CONFIG) to generate the sample rate that controls sensor data output rate, FIFO sample rate. Note: This register is only effective when FCHOICE_B register bits are 2’b00, and (0 < DLPF_CFG < 7). This is the update rate of the sensor register: SAMPLE_RATE = INTERNAL_SAMPLE_RATE / (1 + SMPLRT_DIV) Where INTERNAL_SAMPLE_RATE = 1 kHz 9.10 REGISTER 26 – CONFIGURATION Register Name: CONFIG Register Type: READ/WRITE Register Address: 26 (Decimal); 1A (Hex) BIT [7] [6] NAME FIFO_MODE [5:3] EXT_SYNC_SET[2:0] [2:0] DLPF_CFG[2:0] FUNCTION Always set to 0. When set to ‘1’, when the FIFO is full, additional writes will not be written to FIFO. When set to ‘0’, when the FIFO is full, additional writes will be written to the FIFO, replacing the oldest data. Enables the FSYNC pin data to be sampled. EXT_SYNC_SET 0 1 2 3 4 5 6 7 FSYNC bit location function disabled TEMP_OUT_L[0] GYRO_XOUT_L[0] GYRO_YOUT_L[0] GYRO_ZOUT_L[0] ACCEL_XOUT_L[0] ACCEL_YOUT_L[0] ACCEL_ZOUT_L[0] FSYNC will be latched to capture short strobes. This will be done such that if FSYNC toggles, the latched value toggles, but won’t toggle again until the new latched value is captured by the sample rate strobe. For the DLPF to be used, FCHOICE_B[1:0] is 2’b00. See Table 16. The DLPF is configured by DLPF_CFG, when FCHOICE_B [1:0] = 2b’00. The gyroscope and temperature sensor are filtered according to the value of DLPF_CFG and FCHOICE_B as shown in Table 16. Document Number: DS-000196 Revision: 1.1 Page 34 of 52 IAM-20680 FCHOICE_B Temperature Sensor Gyroscope DLPF_CFG X 1 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 X X 0 1 2 3 4 5 6 7 3-dB BW (Hz) Noise BW (Hz) Rate (kHz) 8173 3281 250 176 92 41 20 10 5 3281 8595.1 32 3451.0 306.6 177.0 108.6 59.0 30.5 15.6 8.0 3451.0 32 8 1 1 1 1 1 1 8 3-dB BW (Hz) 4000 4000 4000 188 98 42 20 10 5 4000 Table 16. Configuration 9.11 REGISTER 27 – GYROSCOPE CONFIGURATION Register Name: GYRO_CONFIG Register Type: READ/WRITE Register Address: 27 (Decimal); 1B (Hex) BIT [7] [6] [5] XG_ST YG_ST ZG_ST NAME [4:3] FS_SEL[1:0] [2] [1:0] FCHOICE_B[1:0] FUNCTION X Gyro self-test. Y Gyro self-test. Z Gyro self-test. Gyro Full Scale Select: 00 = ±250 dps 01= ±500 dps 10 = ±1000 dps 11 = ±2000 dps Reserved. Used to bypass DLPF as shown in Table 16 above. 9.12 REGISTER 28 – ACCELEROMETER CONFIGURATION Register Name: ACCEL_CONFIG Register Type: READ/WRITE Register Address: 28 (Decimal); 1C (Hex) BIT [7] [6] [5] XA_ST YA_ST ZA_ST NAME [4:3] ACCEL_FS_SEL[1:0] [2:0] - Document Number: DS-000196 Revision: 1.1 FUNCTION X Accel self-test. Y Accel self-test. Z Accel self-test. Accel Full Scale Select: ±2g (00), ±4g (01), ±8g (10), ±16g (11) Reserved. Page 35 of 52 IAM-20680 9.13 REGISTER 29 – ACCELEROMETER CONFIGURATION 2 Register Name: ACCEL_CONFIG2 Register Type: READ/WRITE Register Address: 29 (Decimal); 1D (Hex) BIT [7:6] - NAME [5:4] DEC2_CFG[1:0] [3] [2:0] ACCEL_FCHOICE_B A_DLPF_CFG FUNCTION Reserved. Averaging filter settings for Low Power Accelerometer mode: 0 = Average 4 samples 1 = Average 8 samples 2 = Average 16 samples 3 = Average 32 samples Used to bypass DLPF as shown in Table 17. Accelerometer low pass filter setting as shown in Table 17. Accelerometer ACCEL_FCHOICE_B A_DLPF_CFG 3-dB BW (Hz) Noise BW (Hz) Rate (kHz) 1 0 0 0 0 0 0 0 0 X 0 1 2 3 4 5 6 7 1046.0 218.1 218.1 99.0 44.8 21.2 10.2 5.1 420.0 1100.0 235.0 235.0 121.3 61.5 31.0 15.5 7.8 441.6 4 1 1 1 1 1 1 1 1 Table 17. Accelerometer Data Rates and Bandwidths (Low-noise mode) The data output rate of the DLPF filter block can be further reduced by a factor of 1/(1+SMPLRT_DIV), where SMPLRT_DIV is an 8-bit integer. Following is a small subset of ODRs that are configurable for the accelerometer in the low-noise mode in this manner (Hz): 3.91, 7.81, 15.63, 31.25, 62.50, 125, 250, 500, 1K. Table 18 lists the accelerometer filter bandwidths, noise, and current consumption available in the low-power mode of operation. In the low-power mode of operation, the accelerometer is duty-cycled. ACCEL_FCHOICE_B A_DLPF_CFG DEC2_CFG Averages Ton (ms) Noise BW (Hz) Noise (mg) TYP based on 250 µg/√Hz SMPLRT_DIV ODR (Hz) 255 3.9 127 7.8 63 15.6 31 31.3 15 62.5 7 125.0 3 250.0 1 500.0 1 x x 1x 1.084 1100.0 8.3 8.4 9.8 12.8 18.7 30.4 57.4 100.9 194.9 0 0 0 7 7 7 0 1 2 4x 8x 16x 1.84 2.84 4.84 441.6 235.4 121.3 5.3 3.8 2.8 Current Consumption (µA) TYP 9.4 10.8 13.6 11.9 14.7 20.3 17.0 22.5 33.7 27.1 38.2 60.4 47.2 69.4 113.9 87.5 132.0 220.9 168.1 257.0 N/A 329.3 N/A 0 7 3 32x 8.84 61.5 2.0 19.2 31.4 55.9 104.9 202.8 N/A Table 18. Accelerometer Filter Bandwidths, Noise, and Current Consumption Document Number: DS-000196 Revision: 1.1 Page 36 of 52 IAM-20680 9.14 REGISTER 30 – LOW POWER MODE CONFIGURATION Register Name: LP_MODE_CFG Register Type: READ/WRITE Register Address: 30 (Decimal); 1E (Hex) BIT [7] NAME GYRO_CYCLE [6:4] G_AVGCFG[2:0] [3:0] - FUNCTION When set to ‘1’ low-power gyroscope mode is enabled. Default setting is ‘0’ Averaging filter configuration for low-power gyroscope mode. Default setting is ‘000’ Reserved. To operate in gyroscope low-power mode or 6-axis low-power mode, GYRO_CYCLE should be set to ‘1.’ Gyroscope filter configuration is determined by G_AVGCFG[2:0] that sets the averaging filter configuration. It is not dependent on DLPF_CFG[2:0]. Table 19 shows some example configurations for gyroscope low power mode. FCHOICE_B G_AVGCFG Averages Ton (ms) Noise BW (Hz) Noise (dps) TYP based on 0.008 dps/√Hz SMPLRT_DIV ODR (Hz) 255 3.9 99 10.0 64 15.4 32 30.3 19 50.0 9 100.0 7 125.0 4 200.0 3 250.0 2 333.3 1 500.0 0 0 1x 1.73 650.8 0 1 2x 2.23 407.1 0 2 4x 3.23 224.2 0 3 8x 5.23 117.4 0 4 16x 9.23 60.2 0 5 32x 17.23 30.6 0 6 64x 33.23 15.6 0 7 128x 65.23 8.0 0.20 0.16 0.12 0.09 0.06 0.04 0.03 0.02 1.4 1.6 1.8 2.2 2.8 1.5 1.9 2.2 1.8 2.5 N/A 1.3 1.3 1.4 1.4 1.5 1.6 1.7 1.9 2.1 2.3 2.9 1.3 1.3 1.4 1.4 1.5 1.7 1.8 2.1 2.3 2.6 1.3 1.4 1.4 1.5 1.6 1.9 2.0 2.5 2.7 Current Consumption (mA) TYP 1.3 1.4 1.4 1.5 1.5 1.6 1.6 1.8 1.8 2.1 2.2 3.0 2.5 N/A N/A N/A N/A N/A N/A Table 19. Example Configurations of Gyroscope Low Power Mode 9.15 REGISTER 31 – WAKE-ON MOTION THRESHOLD (ACCELEROMETER) Register Name: ACCEL_WOM_THR Register Type: READ/WRITE Register Address: 31 (Decimal); 1F (Hex) BIT [7:0] NAME WOM_THR[7:0] Document Number: DS-000196 Revision: 1.1 FUNCTION This register holds the threshold value for the Wake on Motion Interrupt for accelerometer. Page 37 of 52 IAM-20680 9.16 REGISTER 35 – FIFO ENABLE Register Name: FIFO_EN Register Type: READ/WRITE Register Address: 35 (Decimal); 23 (Hex) BIT NAME [7] TEMP_FIFO_EN [6] XG_FIFO_EN [5] YG_FIFO_EN FUNCTION 1 – Write TEMP_OUT_H and TEMP_OUT_L to the FIFO at the sample rate; If enabled, buffering of data occurs even if data path is in standby. 0 – Function is disabled. 1 – Write GYRO_XOUT_H and GYRO_XOUT_L to the FIFO at the sample rate; If enabled, buffering of data occurs even if data path is in standby. 0 – Function is disabled. 1 – Write GYRO_YOUT_H and GYRO_YOUT_L to the FIFO at the sample rate; If enabled, buffering of data occurs even if data path is in standby. 0 – Function is disabled. Note: Enabling any one of the bits corresponding to the Gyros or Temp data paths, data are buffered into the FIFO even though that data path is not enabled. [4] ZG_FIFO_EN [3] ACCEL_FIFO_EN [2:0] - 1 – Write GYRO_ZOUT_H and GYRO_ZOUT_L to the FIFO at the sample rate; If enabled, buffering of data occurs even if data path is in standby. 0 – Function is disabled. 1 – Write ACCEL_XOUT_H, ACCEL_XOUT_L, ACCEL_YOUT_H, ACCEL_YOUT_L, ACCEL_ZOUT_H, and ACCEL_ZOUT_L to the FIFO at the sample rate; 0 – Function is disabled. Reserved. 9.17 REGISTER 54 – FSYNC INTERRUPT STATUS Register Name: FSYNC_INT Register Type: READ to CLEAR Register Address: 54 (Decimal); 36 (Hex) BIT [7] NAME FSYNC_INT FUNCTION This bit automatically sets to 1 when a FSYNC interrupt has been generated. The bit clears to 0 after the register has been read. 9.18 REGISTER 55 – INT/DRDY PIN / BYPASS ENABLE CONFIGURATION Register Name: INT_PIN_CFG Register Type: READ/WRITE Register Address: 55 (Decimal); 37 (Hex) BIT NAME [7] INT_LEVEL [6] INT_OPEN [5] LATCH_INT_EN [4] INT_RD_CLEAR [3] FSYNC_INT_LEVEL [2] FSYNC_INT_MODE_EN [1] [0] - Document Number: DS-000196 Revision: 1.1 FUNCTION 1 – The logic level for INT/DRDY pin is active low. 0 – The logic level for INT/DRDY pin is active high. 1 – INT/DRDY pin is configured as open drain. 0 – INT/DRDY pin is configured as push-pull. 1 – INT/DRDY pin level held until interrupt status is cleared. 0 – INT/DRDY pin indicates interrupt pulse’s width is 50 µs. 1 – Interrupt status is cleared if any read operation is performed. 0 – Interrupt status is cleared only by reading INT_STATUS register. 1 – The logic level for the FSYNC pin as an interrupt is active low. 0 – The logic level for the FSYNC pin as an interrupt is active high. When this bit is equal to 1, the FSYNC pin will trigger an interrupt when it transitions to the level specified by FSYNC_INT_LEVEL. When this bit is equal to 0, the FSYNC pin is disabled from causing an interrupt. Reserved. Always set to 0. Page 38 of 52 IAM-20680 9.19 REGISTER 56 – INTERRUPT ENABLE Register Name: INT_ENABLE Register Type: READ/WRITE Register Address: 56 (Decimal); 38 (Hex) BIT NAME [7:5] WOM_INT_EN[7:5] [4] FIFO_OFLOW_EN [3] [2] [1] [0] GDRIVE_INT_EN DATA_RDY_INT_EN FUNCTION 111 – Enable WoM interrupt on accelerometer. 000 – Disable WoM interrupt on accelerometer. 1 – Enables a FIFO buffer overflow to generate an interrupt. 0 – Function is disabled. Reserved. Gyroscope Drive System Ready interrupt enable. Reserved. Data ready interrupt enable. 9.20 REGISTER 58 – INTERRUPT STATUS Register Name: INT_STATUS Register Type: READ to CLEAR Register Address: 58 (Decimal); 3A (Hex) BIT NAME [7:5] WOM_INT [4] FIFO_OFLOW_INT [3] [2] [1] GDRIVE_INT - [0] DATA_RDY_INT FUNCTION Accelerometer WoM interrupt status. Cleared on Read. 111 – WoM interrupt on accelerometer This bit automatically sets to 1 when a FIFO buffer overflow has been generated. The bit clears to 0 after the register has been read. Reserved. Gyroscope Drive System Ready interrupt Reserved. This bit automatically sets to 1 when a Data Ready interrupt is generated. The bit clears to 0 after the register has been read. 9.21 REGISTERS 59 TO 64 – ACCELEROMETER MEASUREMENTS Register Name: ACCEL_XOUT_H Register Type: READ only Register Address: 59 (Decimal); 3B (Hex) BIT [7:0] NAME ACCEL_XOUT_H[15:8] FUNCTION High byte of accelerometer x-axis data. Register Name: ACCEL_XOUT_L Register Type: READ only Register Address: 60 (Decimal); 3C (Hex) BIT [7:0] NAME ACCEL_XOUT_L[7:0] FUNCTION Low byte of accelerometer x-axis data. Register Name: ACCEL_YOUT_H Register Type: READ only Register Address: 61 (Decimal); 3D (Hex) BIT [7:0] NAME ACCEL_YOUT_H[15:8] Document Number: DS-000196 Revision: 1.1 FUNCTION High byte of accelerometer y-axis data. Page 39 of 52 IAM-20680 Register Name: ACCEL_YOUT_L Register Type: READ only Register Address: 62 (Decimal); 3E (Hex) BIT [7:0] NAME ACCEL_YOUT_L[7:0] FUNCTION Low byte of accelerometer y-axis data. Register Name: ACCEL_ZOUT_H Register Type: READ only Register Address: 63 (Decimal); 3F (Hex) BIT [7:0] NAME ACCEL_ZOUT_H[15:8] FUNCTION High byte of accelerometer z-axis data. Register Name: ACCEL_ZOUT_L Register Type: READ only Register Address: 64 (Decimal); 40 (Hex) BIT [7:0] NAME ACCEL_ZOUT_L[7:0] FUNCTION Low byte of accelerometer z-axis data. 9.22 REGISTERS 65 AND 66 – TEMPERATURE MEASUREMENT Register Name: TEMP_OUT_H Register Type: READ only Register Address: 65 (Decimal); 41 (Hex) BIT [7:0] NAME TEMP_OUT[15:8] FUNCTION High byte of the temperature sensor output. Register Name: TEMP_OUT_L Register Type: READ only Register Address: 66 (Decimal); 42 (Hex) BIT [7:0] NAME FUNCTION Low byte of the temperature sensor output. TEMP_degC TEMP_OUT[7:0] = ((TEMP_OUT – RoomTemp_Offset)/Temp_Sensitivity) + 25degC 9.23 REGISTERS 67 TO 72 – GYROSCOPE MEASUREMENTS Register Name: GYRO_XOUT_H Register Type: READ only Register Address: 67 (Decimal); 43 (Hex) BIT [7:0] NAME GYRO_XOUT[15:8] FUNCTION High byte of the X-Axis gyroscope output. Register Name: GYRO_XOUT_L Register Type: READ only Register Address: 68 (Decimal); 44 (Hex) BIT NAME [7:0] GYRO_XOUT[7:0] Document Number: DS-000196 Revision: 1.1 FUNCTION Low byte of the X-Axis gyroscope output. GYRO_XOUT = Nominal Conditions Gyro_Sensitivity * X_angular_rate FS_SEL = 0 Gyro_Sensitivity = 131 LSB/(dps) Page 40 of 52 IAM-20680 Register Name: GYRO_YOUT_H Register Type: READ only Register Address: 69 (Decimal); 45 (Hex) BIT [7:0] NAME GYRO_YOUT[15:8] FUNCTION High byte of the Y-Axis gyroscope output. Register Name: GYRO_YOUT_L Register Type: READ only Register Address: 70 (Decimal); 46 (Hex) BIT NAME [7:0] GYRO_YOUT[7:0] FUNCTION Low byte of the Y-Axis gyroscope output. GYRO_YOUT = Nominal Conditions Gyro_Sensitivity * Y_angular_rate FS_SEL = 0 Gyro_Sensitivity = 131 LSB/(dps) Register Name: GYRO_ZOUT_H Register Type: READ only Register Address: 71 (Decimal); 47 (Hex) BIT [7:0] NAME GYRO_ZOUT[15:8] FUNCTION High byte of the Z-Axis gyroscope output. Register Name: GYRO_ZOUT_L Register Type: READ only Register Address: 72 (Decimal); 48 (Hex) BIT [7:0] NAME GYRO_ZOUT[7:0] FUNCTION Low byte of the Z-Axis gyroscope output. GYRO_ZOUT = Nominal Conditions Gyro_Sensitivity * Z_angular_rate FS_SEL = 0 Gyro_Sensitivity = 131 LSB/(dps) 9.24 REGISTER 104 – SIGNAL PATH RESET Register Name: SIGNAL_PATH_RESET Register Type: READ/WRITE Register Address: 104 (Decimal); 68 (Hex) BIT [7:2] NAME - [1] ACCEL_RST [0] TEMP_RST FUNCTION Reserved. Reset accel digital signal path. Note: Sensor registers are not cleared. Use SIG_COND_RST to clear sensor registers. Reset temp digital signal path. Note: Sensor registers are not cleared. Use SIG_COND_RST to clear sensor registers. 9.25 REGISTER 105 – ACCELEROMETER INTELLIGENCE CONTROL Register Name: ACCEL_INTEL_CTRL Register Type: READ/WRITE Register Address: 105 (Decimal); 69 (Hex) BIT [7] NAME ACCEL_INTEL_EN [6] ACCEL_INTEL_MODE [5:0] - Document Number: DS-000196 Revision: 1.1 FUNCTION This bit enables the Wake-on-Motion detection logic. 0 – Do not use. 1 – Compare the current sample with the previous sample. Reserved. Page 41 of 52 IAM-20680 9.26 REGISTER 106 – USER CONTROL Register Name: USER_CTRL Register Type: READ/WRITE Register Address: 106 (Decimal); 6A (Hex) BIT [7] - NAME [6] FIFO_EN [5] [4] [3] I2C_IF_DIS [2] FIFO_RST [1] - [0] SIG_COND_RST - FUNCTION Reserved. 1 – Enable FIFO operation mode. 0 – Disable FIFO access from serial interface. To disable FIFO writes by DMA, use FIFO_EN register. Reserved. 1 – Disable I2C Slave module and put the serial interface in SPI mode only. Reserved. 1 – Reset FIFO module. Reset is asynchronous. This bit auto clears after one clock cycle of the internal 20 MHz clock. Reserved. 1 – Reset all gyro digital signal path, accel digital signal path, and temp digital signal path. This bit also clears all the sensor registers. 9.27 REGISTER 107 – POWER MANAGEMENT 1 Register Name: PWR_MGMT_1 Register Type: READ/WRITE Register Address: 107 (Decimal); 6B (Hex) BIT NAME [7] DEVICE_RESET [6] SLEEP [5] ACCEL_CYCLE [4] GYRO_STANDBY [3] TEMP_DIS [2:0] CLKSEL[2:0] FUNCTION 1 – Reset the internal registers and restores the default settings. The bit automatically clears to 0 once the reset is done. When set to 1, the chip is set to sleep mode. Note: The default value is 1, the chip comes up in Sleep mode. When set to 1, and SLEEP and STANDBY are not set to 1, the chip will cycle between sleep and taking a single accelerometer sample at a rate determined by SMPLRT_DIV Note: When all accelerometer axes are disabled via PWR_MGMT_2 register bits and cycle is enabled, the chip will wake up at the rate determined by the respective registers above, but will not take any samples. When set, the gyro drive and pll circuitry are enabled, but the sense paths are disabled. This is a low power mode that allows quick enabling of the gyros. When set to 1, this bit disables the temperature sensor. Code 0 1 2 3 4 5 6 7 Clock Source Internal 20 MHz oscillator. Auto selects the best available clock source – PLL if ready, else use the Internal oscillator. Auto selects the best available clock source – PLL if ready, else use the Internal oscillator. Auto selects the best available clock source – PLL if ready, else use the Internal oscillator. Auto selects the best available clock source – PLL if ready, else use the Internal oscillator. Auto selects the best available clock source – PLL if ready, else use the Internal oscillator. Internal 20 MHz oscillator. Stops the clock and keeps timing generator in reset. Note: The default value of CLKSEL[2:0] is 000. It is required that CLKSEL[2:0] be set to 001 to achieve full gyroscope performance. Document Number: DS-000196 Revision: 1.1 Page 42 of 52 IAM-20680 9.28 REGISTER 108 – POWER MANAGEMENT 2 Register Name: PWR_MGMT_2 Register Type: READ/WRITE Register Address: 108 (Decimal); 6C (Hex) BIT [7] [6] NAME FIFO_LP_EN [5] STBY_XA [4] STBY_YA [3] STBY_ZA [2] STBY_XG [1] STBY_YG [0] STBY_ZG - FUNCTION 1 – Enable FIFO in low-power accelerometer mode. Default setting is 0. Reserved. 1 – X accelerometer is disabled. 0 – X accelerometer is on. 1 – Y accelerometer is disabled. 0 – Y accelerometer is on. 1 – Z accelerometer is disabled. 0 – Z accelerometer is on. 1 – X gyro is disabled. 0 – X gyro is on. 1 – Y gyro is disabled. 0 – Y gyro is on. 1 – Z gyro is disabled. 0 – Z gyro is on. 9.29 REGISTERS 114 AND 115 – FIFO COUNT REGISTERS Register Name: FIFO_COUNTH Register Type: READ Only Register Address: 114 (Decimal); 72 (Hex) BIT [7:5] - NAME [4:0] FIFO_COUNT[12:8] FUNCTION Reserved. High Bits; count indicates the number of written bytes in the FIFO. Reading this byte latches the data for both FIFO_COUNTH, and FIFO_COUNTL. Register Name: FIFO_COUNTL Register Type: READ Only Register Address: 115 (Decimal); 73 (Hex) BIT NAME [7:0] FIFO_COUNT[7:0] Document Number: DS-000196 Revision: 1.1 FUNCTION Low Bits; count indicates the number of written bytes in the FIFO. Note: Must read FIFO_COUNTH to latch new data for both FIFO_COUNTH and FIFO_COUNTL. Page 43 of 52 IAM-20680 9.30 REGISTER 116 – FIFO READ WRITE Register Name: FIFO_R_W Register Type: READ/WRITE Register Address: 116 (Decimal); 74 (Hex) BIT [7:0] NAME FIFO_DATA[7:0] FUNCTION Read/Write command provides Read or Write operation for the FIFO. Description: This register is used to read and write data from the FIFO buffer. Data are written to the FIFO in order of register number (from lowest to highest). If all the FIFO enable flags (see below) are enabled, the contents of registers 59 through 72 will be written in order at the Sample Rate. The contents of the sensor data registers (Registers 59 to 72) are written into the FIFO buffer when their corresponding FIFO enable flags are set to 1 in FIFO_EN (Register 35). If the FIFO buffer has overflowed, the status bit FIFO_OFLOW_INT is automatically set to 1. This bit is located in INT_STATUS (Register 58). When the FIFO buffer has overflowed, the oldest data will be lost and new data will be written to the FIFO unless register 26 CONFIG, bit[6] FIFO_MODE = 1. If the FIFO buffer is empty, reading register FIFO_DATA will return a unique value of 0xFF until new data are available. Normal data are precluded from ever indicating 0xFF, so 0xFF gives a trustworthy indication of FIFO empty. 9.31 REGISTER 117 – WHO AM I Register Name: WHO_AM_I Register Type: READ only Register Address: 117 (Decimal); 75 (Hex) BIT [7:0] NAME WHOAMI FUNCTION Register to indicate to user which device is being accessed. This register is used to verify the identity of the device. The contents of WHOAMI is an 8-bit device ID. The default value of the register is 0xA9. This is different from the I2C address of the device as seen on the slave I2C controller by the applications processor. The I2C address of the IAM-20680 is 0x68 or 0x69 depending upon the value driven on AD0 pin. 9.32 REGISTERS 119, 120, 122, 123, 125, 126 ACCELEROMETER OFFSET REGISTERS Register Name: XA_OFFSET_H Register Type: READ/WRITE Register Address: 119 (Decimal); 77 (Hex) BIT [7:0] NAME XA_OFFS[14:7] FUNCTION Upper bits of the X accelerometer offset cancellation. ±16g Offset cancellation in all Full Scale modes, 15 bit 0.98-mg steps. Register Name: XA_OFFSET_L Register Type: READ/WRITE Register Address: 120 (Decimal); 78 (Hex) BIT NAME [7:1] XA_OFFS[6:0] [0] - Document Number: DS-000196 Revision: 1.1 FUNCTION Lower bits of the X accelerometer offset cancellation. ±16g Offset cancellation in all Full Scale modes, 15 bit 0.98-mg steps. Reserved. Page 44 of 52 IAM-20680 Register Name: YA_OFFSET_H Register Type: READ/WRITE Register Address: 122 (Decimal); 7A (Hex) BIT [7:0] NAME YA_OFFS[14:7] FUNCTION Upper bits of the Y accelerometer offset cancellation. ±16g Offset cancellation in all Full Scale modes, 15 bit 0.98-mg steps. Register Name: YA_OFFSET_L Register Type: READ/WRITE Register Address: 123 (Decimal); 7B (Hex) BIT NAME [7:1] YA_OFFS[6:0] [0] - FUNCTION Lower bits of the Y accelerometer offset cancellation. ±16g Offset cancellation in all Full Scale modes, 15 bit 0.98-mg steps. Reserved. Register Name: ZA_OFFSET_H Register Type: READ/WRITE Register Address: 125 (Decimal); 7D (Hex) BIT [7:0] NAME ZA_OFFS[14:7] FUNCTION Upper bits of the Z accelerometer offset cancellation. ±16g Offset cancellation in all Full Scale modes, 15 bit 0.98-mg steps. Register Name: ZA_OFFSET_L Register Type: READ/WRITE Register Address: 126 (Decimal); 7E (Hex) BIT NAME [7:1] ZA_OFFS[6:0] [0] - Document Number: DS-000196 Revision: 1.1 FUNCTION Lower bits of the Z accelerometer offset cancellation. ±16g Offset cancellation in all Full Scale modes, 15 bit 0.98-mg steps. Reserved. Page 45 of 52 IAM-20680 10 ASSEMBLY This section provides general guidelines for assembling InvenSense Micro Electro-Mechanical Systems (MEMS) gyros packaged in LGA package. 10.1 ORIENTATION OF AXES Figure 14 shows the orientation of the axes of sensitivity and the polarity of rotation. Note the pin 1 identifier (•) in the figure. +Z +Y +Z +Y IA M- 20 68 0 +X +X Figure 13. Orientation of Axes of Sensitivity and Polarity of Rotation Document Number: DS-000196 Revision: 1.1 Page 46 of 52 IAM-20680 10.2 PACKAGE DIMENSIONS 16 Lead LGA (3x3x0.75) mm NiAu pad finish Figure 14. Package Dimensions Document Number: DS-000196 Revision: 1.1 Page 47 of 52 IAM-20680 DIMENSIONS IN MILLIMETERS Total Thickness Substrate Thickness Mold Thickness Body Size Lead Width Lead Length Lead Pitch Lead Count Edge Ball Center to Center Body Center to Contact Ball Ball Width Ball Diameter Ball Opening Ball Pitch Ball Count Pre-Solder Package Edge Tolerance Mold Flatness Coplanarity Ball Offset (Package) Ball Offset (Ball) Lead Edge to Package Edge SYMBOLS A A1 A2 D E W L e n D1 E1 SD SE b MIN 0.7 0.105 0.63 2.9 2.9 0.2 0.3 MAX 0.8 REF REF 3 3 0.25 0.35 0.5 3.1 3.1 0.3 0.4 BSC 16 2 1 ------- e1 n1 --aaa bbb ddd eee fff M NOM 0.75 0.01 BSC BSC BSC BSC ------------0.1 0.2 0.08 ----0.06 --- --- 0.11 Table 20. Package Dimensions Document Number: DS-000196 Revision: 1.1 Page 48 of 52 IAM-20680 11 PART NUMBER PACKAGE MARKING The part number package marking for IAM-20680 devices is summarized below: PART NUMBER IAM-20680 PART NUMBER PACKAGE MARKING IA268 Table 21. Part Number Package Marking TOP VIEW Part Number Lot Traceability Code IA268 XXXXXX YYWW Y Y = Year Code W W = Work Week Figure 15. Part Number Package Marking Document Number: DS-000196 Revision: 1.1 Page 49 of 52 IAM-20680 12 REFERENCE Please refer to “InvenSense MEMS Handling Application Note (AN-IVS-0002A-00)” for the following information: • • Manufacturing Recommendations o Assembly Guidelines and Recommendations o PCB Design Guidelines and Recommendations o MEMS Handling Instructions o ESD Considerations o Reflow Specification o Storage Specifications o Package Marking Specification o Tape & Reel Specification o Reel & Pizza Box Label o Packaging o Representative Shipping Carton Label Compliance o Environmental Compliance o DRC Compliance o Compliance Declaration Disclaimer Document Number: DS-000196 Revision: 1.1 Page 50 of 52 IAM-20680 13 REVISION HISTORY REVISION DATE REVISION DESCRIPTION 12/21/2016 1.0 Initial Release 01/30/2018 1.1 Changed to TDK format, added automotive in the document title, added sections “Thermal Information section” and “Sensor Initialization and Basic Configuration”, fixed typo in register 0x48 documentation (the table had GYRO_YOUT instead of GYRO_ZOUT) Document Number: DS-000196 Revision: 1.1 Page 51 of 52 IAM-20680 This information furnished by InvenSense, Inc. (“InvenSense”) is believed to be accurate and reliable. However, no responsibility is assumed by InvenSense for its use, or for any infringements of patents or other rights of third parties that may result from its use. Specifications are subject to change without notice. InvenSense reserves the right to make changes to this product, including its circuits and software, in order to improve its design and/or performance, without prior notice. InvenSense makes no warranties, neither expressed nor implied, regarding the information and specifications contained in this document. InvenSense assumes no responsibility for any claims or damages arising from information contained in this document, or from the use of products and services detailed therein. This includes, but is not limited to, claims or damages based on the infringement of patents, copyrights, mask work and/or other intellectual property rights. Certain intellectual property owned by InvenSense and described in this document is patent protected. No license is granted by implication or otherwise under any patent or patent rights of InvenSense. This publication supersedes and replaces all information previously supplied. Trademarks that are registered trademarks are the property of their respective companies. InvenSense sensors should not be used or sold in the development, storage, production or utilization of any conventional or mass-destructive weapons or for any other weapons or life threatening applications, as well as in any other life critical applications such as medical equipment, transportation, aerospace and nuclear instruments, undersea equipment, power plant equipment, disaster prevention and crime prevention equipment. ©2017 InvenSense. All rights reserved. InvenSense, MotionTracking, MotionProcessing, MotionProcessor, MotionFusion, MotionApps, DMP, AAR, and the InvenSense logo are trademarks of InvenSense, Inc. The TDK logo is a trademark of TDK Corporation. Other company and product names may be trademarks of the respective companies with which they are associated. ©2016—2018 InvenSense. All rights reserved. Document Number: DS-000196 Revision: 1.1 Page 52 of 52
MIKROE-3827
物料型号:IAM-20680
器件简介: IAM-20680是一款高性能的汽车6轴运动追踪设备,集成了3轴陀螺仪和3轴加速度计,采用小型3x3x0.75mm (16引脚LGA)封装。它还具备512字节的FIFO,可以降低串行总线接口的通信量,并通过允许系统处理器批量读取传感器数据然后进入低功耗模式来降低功耗。
引脚分配: - VDDIO:数字/模拟电源电压。 - SCL/SPC:I2C串行时钟(SCL);SPI串行时钟(SPC)。 - SDA/SDI:I2C串行数据(SDA);SPI串行数据输入(SDI)。 - SA0/SDO:I2C从设备地址最低位(SA0);SPI串行数据输出(SDO)。 - CS:芯片选择(0=SPI模式;1=I2C模式)。 - INT:中断数字输出。 - FSYNC:同步数字输入(可选)。
参数特性: - 陀螺仪具有可编程的满量程范围:±250 dps, ±500 dps, ±1000 dps, 和 ±2000 dps。 - 加速度计具有用户可编程的满量程范围:±2g, ±4g, ±8g, 和 ±16g。 - 工厂校准的初始灵敏度,减少了生产线校准需求。
功能详解: - 具备数字输出的X、Y、Z轴角速度传感器(陀螺仪)和集成的16位ADC。 - 数字输出的X、Y、Z轴加速度计,具有可编程的满量程范围,并集成了16位ADC。 - 用户可编程的数字滤波器,用于陀螺仪、加速度计和温度传感器。 - 自我检测功能。 - 低功耗运行模式。
应用信息: - 导航系统:航位推算辅助。 - 举升门运动检测。 - 车辆与车辆、基础设施间的精确定位。 - 360度全景摄像头稳定。 - 汽车报警。 - 远程通信。 - 保险车辆追踪。
MIKROE-3827 价格&库存
很抱歉,暂时无法提供与“MIKROE-3827”相匹配的价格&库存,您可以联系我们找货
MIKROE-3827
  • 1+386.232201+49.19170
库存:4
MIKROE-3827
  • 1+339.53275
  • 5+332.74293
库存:5
