MIKROE-2682
MIKROE-2682
    MIKRO
    MINI-M4 MSP432P401R EVAL BRD
MIKROE-2682 数据手册
Product Folder Order Now Technical Documents Tools & Software Support & Community MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 MSP432P401R, MSP432P401M SimpleLink™ Mixed-Signal Microcontrollers 1 Device Overview 1.1 Features 1 • Core – ARM® 32-Bit Cortex®-M4F CPU With FloatingPoint Unit and Memory Protection Unit – Frequency up to 48 MHz – ULPBench™ Benchmark: – 192.3 ULPMark™-CP – Performance Benchmark: – 3.41 CoreMark/MHz – 1.22 DMIPS/MHz (Dhrystone 2.1) • Advanced Low-Power Analog Features – 14-Bit 1-MSPS SAR ADC With 13.2 ENOB Native and Capability to Reach 16 ENOB With Oversampling, Differential and Single-Ended Inputs – Internal Voltage Reference With 10-ppm/°C Typical Stability – Two Analog Comparators • Memories – Up to 256KB of Flash Main Memory (Organized Into Two Banks Enabling Simultaneous Read/Execute During Erase) – 16KB of Flash Information Memory (Used for BSL, TLV, and Flash Mailbox) – Up to 64KB of SRAM (Including 6KB of Backup Memory) – 32KB of ROM With MSP432™ Peripheral Driver Libraries • Ultra-Low-Power Operating Modes – Active: 80 µA/MHz – Low-Frequency Active: 83 µA at 128 kHz – LPM3 (With RTC): 660 nA – LPM3.5 (With RTC): 630 nA – LPM4: 500 nA – LPM4.5: 25 nA • Development Kits and Software (See Tools and Software) – MSP-EXP432P401R LaunchPad™ Development Kit – MSP-TS432PZ100 100-Pin Target Board – SimpleLink™ MSP432 Software Development Kit (SDK) • Operating Characteristics – Wide Supply Voltage Range: 1.62 V to 3.7 V – Temperature Range (Ambient): –40°C to 85°C • Flexible Clocking Features – Tunable Internal DCO (up to 48 MHz) – 32.768 kHz Low-Frequency Crystal Support (LFXT) – High-Frequency Crystal Support (HFXT) up to 48 MHz – Low-Frequency Internal Reference Oscillator (REFO) – Very Low-Power Low-Frequency Internal Oscillator (VLO) – Module Oscillator (MODOSC) – System Oscillator (SYSOSC) • Code Security Features – JTAG and SWD Lock – IP Protection (up to Four Secure Flash Zones, Each With Configurable Start Address and Size) • Enhanced System Features – Programmable Supervision and Monitoring of Supply Voltage – Multiple-Class Resets for Better Control of Application and Debug – 8-Channel DMA – RTC With Calendar and Alarm Functions • Timing and Control – Up to Four 16-Bit Timers, Each With up to Five Capture, Compare, PWM Capability – Two 32-Bit Timers, Each With Interrupt Generation Capability • Serial Communication – Up to Four eUSCI_A Modules – UART With Automatic Baud-Rate Detection – IrDA Encode and Decode – SPI (up to 16 Mbps) – Up to Four eUSCI_B Modules – I2C (With Multiple-Slave Addressing) – SPI (up to 16 Mbps) • Flexible I/O Features – Ultra-Low-Leakage I/Os (±20 nA Maximum) – All I/Os With Capacitive-Touch Capability – Up to 48 I/Os With Interrupt and Wake-up Capability – Up to 24 I/Os With Port Mapping Capability – Eight I/Os With Glitch Filtering Capability 1 An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. PRODUCTION DATA. MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com • Encryption and Data Integrity Accelerators – 128-, 192-, or 256-Bit AES Encryption and Decryption Accelerator – 32-Bit Hardware CRC Engine 1.2 • • Applications Industrial and Automation – Glass Breakage Detectors – Smart Thermostats – Access Panels – Gas Monitors – Field Transmitters – Process Automation – Home Automation Metering – Flow Meters – Electric Meters – Communication Modules 1.3 • JTAG and Debug Support – 4-Pin JTAG and 2-Pin SWD Debug Interfaces – Serial Wire Trace – Power Debug and Profiling of Applications • • • Test and Measurement – Digital Multimeters – Wireless Digital Multimeters – Contactless and Hand-Held Digital Meters Health and Fitness – Watches – Activity Monitors – Fitness Accessories – Blood Glucose Meters Consumer Electronics – Mobile Devices – Sensor Hubs Description The SimpleLink MSP432P401x microcontrollers (MCUs) are optimized wireless host MCUs with an integrated 14-bit analog-to-digital converter (ADC) capable of up to 16 ENOB delivering ultra-low-power performance including 80 µA/MHz in active power and 660 nA in standby power with FPU and DSP extensions. As an optimized wireless host MCU, the MSP432P401x allows developers to add highprecision analog and memory extension to applications based on SimpleLink wireless connectivity solutions. The MSP432P401x devices are part of the SimpleLink microcontroller (MCU) platform, which consists of Wi-Fi®, Bluetooth® low energy, Sub-1 GHz, and host MCUs. All share a common, easy-to-use development environment with a single core software development kit (SDK) and rich tool set. A one-time integration of the SimpleLink platform lets you add any combination of devices from the portfolio into your design. The ultimate goal of the SimpleLink platform is to achieve 100 percent code reuse when your design requirements change. For more information, visit www.ti.com/simplelink. MSP432P401x devices are supported by a comprehensive ecosystem of tools, software, documentation, training, and support to get your development started quickly. The MSP-EXP432P401R LaunchPad development kit or MSP-TS432PZ100 target socket board (with additional MCU sample) along with the free SimpleLink MSP432 SDK is all you need to get started. Device Information (1) PACKAGE BODY SIZE (2) MSP432P401RIPZ MSP432P401MIPZ LQFP (100) 14 mm × 14 mm MSP432P401RIZXH MSP432P401MIZXH NFBGA (80) 5 mm × 5 mm MSP432P401RIRGC MSP432P401MIRGC VQFN (64) 9 mm × 9 mm PART NUMBER (1) (2) 2 For the most current part, package, and ordering information for all available devices, see the Package Option Addendum in Section 9, or see the TI website. The sizes shown here are approximations. For the package dimensions with tolerances, see the Mechanical Data in Section 9. Device Overview Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com 1.4 SLAS826F – MARCH 2015 – REVISED MARCH 2017 Functional Block Diagram Figure 1-1 shows the functional block diagram of the MSP432P401R and MSP432P401M devices. LFXIN, LFXOUT, HFXIN HFXOUT DCOR PJ.x P1.x to P10.x LPM3.5 Domain Capacitive Touch IO 0, Capacitive Touch IO 1 DMA PCM PSS Power Control Manager Power Supply System CS RTC_C WDT_A Clock System Real-Time Clock Watchdog Timer RSTCTL SYSCTL Reset Controller System Controller Backup Memory SRAM 6KB I/O Ports I/O Ports P1 to P10 78 I/Os PJ 6 I/Os 8 Channels Address CPU ® ARM Cortex™-M4F Bus Control Logic Data Flash 256KB 128KB SRAM (includes Backup Memory) 64KB 32KB ROM (Peripheral Driver Library) 32KB AES256 Security Encryption, Decryption CRC32 MPU NVIC, SysTick FPB, DWT ITM, TPIU JTAG, SWD ADC14 Comp_E0, Comp_E1 REF_A, 14 bit, 1 Msps, SAR A/D Analog Comparator Voltage Reference TA0, TA1, TA2,TA3 Timer32 Timer_A 16 Bit 5 CCR 2 x 32-bit Timers eUSCI_A0, eUSCI_A1, eUSCI_A2, eUSCI_A3 (UART, IrDA, SPI) eUSCI_B0, eUSCI_B1, eUSCI_B2, eUSCI_B3 2 (I C, SPI) Copyright © 2016, Texas Instruments Incorporated Figure 1-1. MSP432P401R, MSP432P401M Functional Block Diagram The CPU and all of the peripherals in the device interact with each other through a common AHB matrix. In some cases, there are bridges between the AHB ports and the peripherals. These bridges are transparent to the application from a memory map perspective and, therefore, are not shown in the block diagram. Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Device Overview 3 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Table of Contents 1 Device Overview ......................................... 1 1.1 Features .............................................. 1 1.2 Applications ........................................... 2 1.3 Description ............................................ 2 1.4 Functional Block Diagram ............................ 3 2 3 Revision History ......................................... 5 Device Comparison ..................................... 6 4 Terminal Configuration and Functions .............. 8 4.1 Pin Diagrams ......................................... 8 4.2 Pin Attributes ........................................ 11 4.3 Signal Descriptions .................................. 17 4.4 Pin Multiplexing 4.5 Buffer Types......................................... 27 4.6 Connection for Unused Pins ........................ 27 ..................................... 6 27 Specifications ........................................... 28 ........................ ........................................ Recommended Operating Conditions ............... Recommended External Components ............. Operating Mode VCC Ranges ....................... Operating Mode CPU Frequency Ranges ......... Operating Mode Peripheral Frequency Ranges .... 5.1 Absolute Maximum Ratings 28 5.2 ESD Ratings 28 5.3 5.4 5.5 5.6 5.7 5.8 28 29 29 30 30 Operating Mode Execution Frequency vs Flash Wait-State Requirements ........................... 31 5.9 5.10 5.11 5.12 5.13 5.14 5.15 5.16 5.17 5.18 4 5.20 Related Products ..................................... 7 3.1 5 5.19 Current Consumption During Device Reset......... Current Consumption in LDO-Based Active Modes – Dhrystone 2.1 Program ................... Current Consumption in DC-DC-Based Active Modes – Dhrystone 2.1 Program ................... Current Consumption in Low-Frequency Active Modes – Dhrystone 2.1 Program ................... Typical Characteristics of Active Mode Currents for CoreMark Program .................................. Typical Characteristics of Active Mode Currents for Prime Number Program ............................. Typical Characteristics of Active Mode Currents for Fibonacci Program .................................. Typical Characteristics of Active Mode Currents for While(1) Program ................................... Typical Characteristics of Low-Frequency Active Mode Currents for CoreMark Program .............. 31 31 8 32 32 33 34 35 36 37 Current Consumption in LDO-Based LPM0 Modes . 38 Table of Contents 7 9 Current Consumption in DC-DC-Based LPM0 Modes ............................................... 38 Current Consumption in Low-Frequency LPM0 Modes ............................................... 38 5.21 Current Consumption in LPM3, LPM4 Modes ...... 39 5.22 Current Consumption in LPM3.5, LPM4.5 Modes .. 39 ........ 40 5.24 Thermal Resistance Characteristics ................ 40 5.25 Timing and Switching Characteristics ............... 41 Detailed Description ................................... 90 6.1 Overview ............................................ 90 6.2 Processor and Execution Features ................. 90 6.3 Memory Map ........................................ 91 6.4 Memories on the MSP432P401x .................. 111 6.5 DMA ................................................ 114 6.6 Memory Map Access Details ...................... 115 6.7 Interrupts ........................................... 117 6.8 System Control..................................... 119 6.9 Peripherals ......................................... 124 6.10 Code Development and Debug .................... 134 6.11 Performance Benchmarks ......................... 136 6.12 Input/Output Diagrams ............................. 138 6.13 Device Descriptors (TLV) .......................... 176 6.14 Identification........................................ 178 Applications, Implementation, and Layout ...... 180 7.1 Device Connection and Layout Fundamentals .... 180 5.23 Current Consumption of Digital Peripherals 7.2 Peripheral and Interface-Specific Design Information ......................................... 181 Device and Documentation Support .............. 183 ................... 8.1 Getting Started and Next Steps 8.2 Device and Development Tool Nomenclature ..... 183 8.3 Tools and Software ................................ 184 8.4 Documentation Support ............................ 186 8.5 Related Links 8.6 Community Resources............................. 188 8.7 Trademarks ........................................ 188 8.8 Electrostatic Discharge Caution 8.9 Export Control Notice .............................. 188 8.10 Glossary............................................ 188 ...................................... ................... 183 187 188 Mechanical, Packaging, and Orderable Information ............................................. 188 Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 2 Revision History NOTE: Page numbers for previous revisions may differ from page numbers in the current version. Changes from July 26, 2016 to March 7, 2017 • • • • • Page Added "SimpleLink" branding, including updates to the titles of referenced documents .................................... 1 Reorganized contents of Section 1.1, Features .................................................................................. 1 Updated Section 1.2, Applications ................................................................................................. 2 Updated Section 1.3, Description ................................................................................................... 2 Updated lists of software and tools in Section 8.3, Tools and Software.................................................... 185 Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Revision History 5 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com 3 Device Comparison Table 3-1 summarizes the features of the MSP432P401x microcontrollers. Table 3-1. Device Comparison (1) eUSCI (1) (2) 6 CHANNEL A: UART, IrDA, SPI CHANNEL B: SPI, I2C 20-mA DRIVE I/O TOTAL I/Os PACKAGE 100 PZ DEVICE FLASH (KB) SRAM (KB) ADC14 (Channels) COMP_E0 (Channels) COMP_E1 (Channels) Timer_A (2) MSP432P401RIPZ 256 64 24 ext, 2 int 8 8 5, 5, 5, 5 4 4 4 84 MSP432P401MIPZ 128 32 24 ext, 2 int 8 8 5, 5, 5, 5 4 4 4 84 100 PZ MSP432P401RIZXH 256 64 16 ext, 2 int 6 8 5, 5, 5 3 4 4 64 80 ZXH MSP432P401MIZXH 128 32 16 ext, 2 int 6 8 5, 5, 5 3 4 4 64 80 ZXH MSP432P401RIRGC 256 64 12 ext, 2 int 2 4 5, 5, 5 3 3 4 48 64 RGC MSP432P401MIRGC 128 32 12 ext, 2 int 2 4 5, 5, 5 3 3 4 48 64 RGC For the most current part, package, and ordering information for all available devices, see the Package Option Addendum in Section 9, or see the TI website at www.ti.com. Each number in the sequence represents an instantiation of Timer_A with its associated number of capture/compare registers and PWM output generators available. For example, a number sequence of 3, 5 would represent two instantiations of Timer_A, the first instantiation having 3 and the second instantiation having 5 capture/compare registers and PWM output generators, respectively. Device Comparison Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com 3.1 SLAS826F – MARCH 2015 – REVISED MARCH 2017 Related Products For information about other devices in this family of products or related products, see the following links. Products for TI Microcontrollers connectivity options. Low-power and high-performance MCUs, with wired and wireless Products for SimpleLink MSP432 MCUs SimpleLink MSP432 MCUs with an ultra-low-power ARM Cortex-M4 core are optimized for Internet-of-Things sensor node applications. With an integrated 14-bit ADC, the family enables acquisition and processing of high-precision signals without sacrificing power and is an optimal host MCU for TI's SimpleLink wireless connectivity solutions. Companion Products for MSP432P401R Review products that are frequently purchased or used with this product. Reference Designs for MSP432P401R The TI Designs Reference Design Library is a robust reference design library that spans analog, embedded processor, and connectivity. Created by TI experts to help you jump start your system design, all TI Designs include schematic or block diagrams, BOMs, and design files to speed your time to market. Search and download designs at ti.com/tidesigns. Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Device Comparison 7 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com 4 Terminal Configuration and Functions 4.1 Pin Diagrams P6.2/UCB1STE/C1.5 P6.3/UCB1CLK/C1.4 P6.4/UCB1SIMO/UCB1SDA/C1.3 P6.5/UCB1SOMI/UCB1SCL/C1.2 P6.6/TA2.3/UCB3SIMO/UCB3SDA/C1.1 P6.7/TA2.4/UCB3SOMI/UCB3SCL/C1.0 DVSS3 RSTn/NMI AVSS2 PJ.2/HFXOUT PJ.3/HFXIN AVCC2 P7.0/PM_SMCLK/PM_DMAE0 P7.1/PM_C0OUT/PM_TA0CLK P7.2/PM_C1OUT/PM_TA1CLK P7.3/PM_TA0.0 PJ.4/TDI PJ.5/TDO/SWO SWDIOTMS SWCLKTCK P9.4/UCA3STE P9.5/UCA3CLK P9.6/UCA3RXD/UCA3SOMI P9.7/UCA3TXD/UCA3SIMO P10.0/UCB3STE Figure 4-1 shows the pinout of the 100-pin PZ package. 67 P5.3/A2 P1.6/UCB0SIMO/UCB0SDA 10 66 P5.2/A3 P1.7/UCB0SOMI/UCB0SCL 11 65 P5.1/A4 VCORE 12 64 P5.0/A5 DVCC1 13 63 P4.7/A6 VSW 14 62 P4.6/A7 DVSS1 15 61 P4.5/A8 P2.0/PM_UCA1STE 16 60 P4.4/HSMCLK/SVMHOUT/A9 P2.1/PM_UCA1CLK 17 59 P4.3/MCLK/RTCCLK/A10 P2.2/PM_UCA1RXD/PM_UCA1SOMI 18 58 P4.2/ACLK/TA2CLK/A11 P2.3/PM_UCA1TXD/PM_UCA1SIMO 19 57 P4.1/A12 P2.4/PM_TA0.1 20 56 P4.0/A13 P2.5/PM_TA0.2 21 55 P6.1/A14 P2.6/PM_TA0.3 22 54 P6.0/A15 P2.7/PM_TA0.4 23 53 P9.1/A16 P10.4/TA3.0/C0.7 24 52 P9.0/A17 P10.5/TA3.1/C0.6 25 51 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 P8.7/A18 P7.4/PM_TA1.4/C0.5 A. B. C. D. E. P8.6/A19 9 P8.5/A20 P5.4/A1 P1.5/UCB0CLK P8.4/A21 68 P8.3/TA3CLK/A22 8 P8.2/TA3.2/A23 P5.5/A0 P1.4/UCB0STE AVCC1 69 DCOR 7 AVSS1 P5.6/TA2.1/VREF+/VeREF+/C1.7 P1.3/UCA0TXD/UCA0SIMO PJ.1/LFXOUT 70 PJ.0/LFXIN 6 AVSS3 P5.7/TA2.2/VREF-/VeREF-/C1.6 P1.2/UCA0RXD/UCA0SOMI P3.7/PM_UCB2SOMI/PM_UCB2SCL 71 P3.6/PM_UCB2SIMO/PM_UCB2SDA 5 P3.5/PM_UCB2CLK DVSS2 P1.1/UCA0CLK P3.4/PM_UCB2STE 72 P3.3/PM_UCA2TXD/PM_UCA2SIMO 4 P3.2/PM_UCA2RXD/PM_UCA2SOMI DVCC2 P1.0/UCA0STE P3.1/PM_UCA2CLK 73 P3.0/PM_UCA2STE 3 P8.1/UCB3CLK/TA2.0/C0.0 P9.2/TA3.3 P10.3/UCB3SOMI/UCB3SCL P8.0/UCB3STE/TA1.0/C0.1 74 P7.7/PM_TA1.1/C0.2 2 P7.6/PM_TA1.2/C0.3 P9.3/TA3.4 P10.2/UCB3SIMO/UCB3SDA P7.5/PM_TA1.3/C0.4 100 99 98 97 96 95 94 93 92 91 90 89 88 87 86 85 84 83 82 81 80 79 78 77 76 1 75 P10.1/UCB3CLK The secondary digital functions on Ports P2, P3, and P7 are fully mappable. This pinout shows only the default mapping. See Section 6.9.2 for details. A glitch filter is implemented on these digital I/Os: P1.0, P1.4, P1.5, P3.0, P3.4, P3.5, P6.6, P6.7. UART BSL pins: P1.2 - BSLRXD, P1.3 - BSLTXD SPI BSL pins: P1.4 - BSLSTE, P1.5 - BSLCLK, P1.6 - BSLSIMO, P1.7 - BSLSOMI I2C BSL pins: P3.6 - BSLSDA, P3.7 - BSLSCL Figure 4-1. 100-Pin PZ Package (Top View) 8 Terminal Configuration and Functions Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 Figure 4-2 shows the pinout of the 80-pin ZXH package. P1.0 SWCLKTCK PJ.5 A1 A2 A3 P1.1 SWDIOTMS PJ.4 A. B. C. D. B3 P7.3 PJ.3 PJ.2 P6.5 P6.4 P6.2 A4 A5 A6 A7 A8 A9 P7.2 P7.0 B4 B5 B1 B2 P1.5 VCORE P1.2 P7.1 C1 C2 C4 C5 P1.6 DVCC1 P1.4 P1.3 D1 D2 D3 D4 P1.7 VSW P2.2 P2.0 E1 E2 E3 E4 P2.1 DVSS1 P2.4 P2.3 F1 F2 F3 F4 P2.5 P2.6 P7.7 G1 G2 G3 P2.7 P7.5 H1 H2 P7.4 J1 RSTn/NMI P6.7 B6 P6.6 P6.3 B7 B8 B9 DVSS3 P5.5 P5.7 C6 C7 C8 C9 DVCC2 AVSS2 P5.3 P5.4 P5.6 D5 D6 D7 D8 D9 AVSS3 DVSS2 P5.0 P5.1 P5.2 E5 E6 E7 E8 E9 AVSS1 AVCC1 P4.5 P4.6 P4.7 F5 F6 F7 F8 F9 P8.1 P3.2 P3.5 P4.2 P4.3 P4.4 G4 G5 G6 G7 G8 G9 P8.0 P3.1 P3.4 P3.7 P6.1 P4.1 P4.0 H3 H4 H5 H6 H7 H8 H9 P7.6 P3.0 P3.3 P3.6 PJ.0 PJ.1 DCOR P6.0 J2 J3 J4 J5 J6 J7 J8 J9 AVCC2 A glitch filter is implemented on these digital I/Os: P1.0, P1.4, P1.5, P3.0, P3.4, P3.5, P6.6, P6.7. UART BSL pins: P1.2 - BSLRXD, P1.3 - BSLTXD SPI BSL pins: P1.4 - BSLSTE, P1.5 - BSLCLK, P1.6 - BSLSIMO, P1.7 - BSLSOMI I2C BSL pins: P3.6 - BSLSDA, P3.7 - BSLSCL Figure 4-2. 80-Pin ZXH Package (Top View) Terminal Configuration and Functions Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Copyright © 2015–2017, Texas Instruments Incorporated 9 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com P6.6/TA2.3/UCB3SIMO/UCB3SDA/C1.1 P6.7/TA2.4/UCB3SOMI/UCB3SCL/C1.0 DVSS3 RSTn/NMI AVSS2 PJ.2/HFXOUT PJ.3/HFXIN AVCC2 P7.0/PM_SMCLK/PM_DMAE0 P7.1/PM_C0OUT/PM_TA0CLK P7.2/PM_C1OUT/PM_TA1CLK P7.3/PM_TA0.0 PJ.4/TDI PJ.5/TDO/SWO SWDIOTMS SWCLKTCK Figure 4-3 shows the pinout of the 64-pin RGC package. 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 P1.0/UCA0STE 1 48 DVCC2 P1.1/UCA0CLK 2 47 DVSS2 P1.2/UCA0RXD/UCA0SOMI 3 46 P5.7/TA2.2/VREF-/VeREF-/C1.6 P1.3/UCA0TXD/UCA0SIMO 4 45 P5.6/TA2.1/VREF+/VeREF+/C1.7 P1.4/UCB0STE 5 44 P5.5/A0 P1.5/UCB0CLK 6 43 P5.4/A1 P1.6/UCB0SIMO/UCB0SDA 7 42 P5.3/A2 P1.7/UCB0SOMI/UCB0SCL 8 41 P5.2/A3 VCORE 9 40 P5.1/A4 DVCC1 10 39 P5.0/A5 VSW 11 38 P4.7/A6 DVSS1 12 37 P4.6/A7 A. B. C. D. E. F. P4.2/ACLK/TA2CLK/A11 AVCC1 DCOR AVSS1 PJ.1/LFXOUT PJ.0/LFXIN AVSS3 P3.7/PM_UCB2SOMI/PM_UCB2SCL P3.6/PM_UCB2SIMO/PM_UCB2SDA 16 33 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 P3.5/PM_UCB2CLK P4.3/MCLK/RTCCLK/A10 P2.3/PM_UCA1TXD/PM_UCA1SIMO P3.4/PM_UCB2STE 34 P3.3/PM_UCA2TXD/PM_UCA2SIMO 15 P3.2/PM_UCA2RXD/PM_UCA2SOMI P4.4/HSMCLK/SVMHOUT/A9 P2.2/PM_UCA1RXD/PM_UCA1SOMI P3.1/PM_UCA2CLK P4.5/A8 35 P3.0/PM_UCA2STE 36 14 P8.1/UCB3CLK/TA2.0/C0.0 13 P8.0/UCB3STE/TA1.0/C0.1 P2.0/PM_UCA1STE P2.1/PM_UCA1CLK The secondary digital functions on Ports P2, P3, and P7 are fully mappable. This pinout shows only the default mapping. See Section 6.9.2 for details. A glitch filter is implemented on these digital I/Os: P1.0, P1.4, P1.5, P3.0, P3.4, P3.5, P6.6, P6.7. TI recommends connecting the thermal pad on the QFN package to DVSS. UART BSL pins: P1.2 - BSLRXD, P1.3 - BSLTXD SPI BSL pins: P1.4 - BSLSTE, P1.5 - BSLCLK, P1.6 - BSLSIMO, P1.7 - BSLSOMI I2C BSL pins: P3.6 - BSLSDA, P3.7 - BSLSCL Figure 4-3. 64-Pin RGC Package (Top View) 10 Terminal Configuration and Functions Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com 4.2 SLAS826F – MARCH 2015 – REVISED MARCH 2017 Pin Attributes Table 4-1 describes the attributes of the pins. Table 4-1. Pin Attributes PIN NO. (1) PZ ZXH RGC 1 N/A N/A 2 3 N/A N/A N/A 4 A1 1 5 B1 2 6 7 C4 D4 3 4 8 D3 5 9 C1 6 10 D1 7 BUFFER TYPE (5) POWER SOURCE (6) RESET STATE AFTER POR (7) P10.1 (RD) I/O LVCMOS DVCC OFF UCB3CLK I/O LVCMOS DVCC N/A P10.2 (RD) I/O LVCMOS DVCC OFF UCB3SIMO I/O LVCMOS DVCC N/A UCB3SDA I/O LVCMOS DVCC N/A P10.3 (RD) I/O LVCMOS DVCC OFF UCB3SOMI I/O LVCMOS DVCC N/A UCB3SCL I/O LVCMOS DVCC N/A P1.0 (RD) I/O LVCMOS DVCC OFF UCA0STE I/O LVCMOS DVCC N/A P1.1 (RD) I/O LVCMOS DVCC OFF UCA0CLK I/O LVCMOS DVCC N/A P1.2 (RD) I/O LVCMOS DVCC OFF UCA0RXD I LVCMOS DVCC N/A UCA0SOMI I/O LVCMOS DVCC N/A P1.3 (RD) I/O LVCMOS DVCC OFF UCA0TXD O LVCMOS DVCC N/A UCA0SIMO I/O LVCMOS DVCC N/A P1.4 (RD) I/O LVCMOS DVCC OFF UCB0STE I/O LVCMOS DVCC N/A P1.5 (RD) I/O LVCMOS DVCC OFF UCB0CLK I/O LVCMOS DVCC N/A P1.6 (RD) I/O LVCMOS DVCC OFF UCB0SIMO I/O LVCMOS DVCC N/A UCB0SDA I/O LVCMOS DVCC N/A P1.7 (RD) I/O LVCMOS DVCC OFF UCB0SOMI I/O LVCMOS DVCC N/A UCB0SCL (3) 11 E1 8 I/O LVCMOS DVCC N/A 12 C2 9 VCORE – Power DVCC N/A 13 D2 10 DVCC1 – Power N/A N/A 14 E2 11 VSW – Power N/A N/A 15 F2 12 DVSS1 – Power N/A N/A P2.0 (RD) I/O LVCMOS DVCC OFF PM_UCA1STE I/O LVCMOS DVCC N/A 16 (1) (2) (3) (4) (5) (6) (7) N/A SIGNAL TYPE (4) SIGNAL NAME (2) E4 13 N/A = not available on this package (RD) indicates the reset default signal name for that pin. To determine the pin mux encodings for each pin, see Section 6.12, Input/Output Diagrams. Signal Types: I = Input, O = Output, I/O = Input or Output, P = power Buffer Types: see Table 4-3 for details The power source shown in this table is the I/O power source, which may differ from the module power source. Reset States: OFF = High-impedance with Schmitt trigger and pullup or pulldown (if available) disabled PD = High-impedance input with pulldown enabled PU = High-impedance input with pullup enabled N/A = Not applicable Terminal Configuration and Functions Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Copyright © 2015–2017, Texas Instruments Incorporated 11 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Table 4-1. Pin Attributes (continued) PIN NO. (1) PZ ZXH RGC 17 F1 14 18 E3 15 19 20 F4 F3 16 N/A 21 G1 N/A 22 G2 N/A 23 H1 N/A 24 N/A N/A 25 26 N/A J1 N/A N/A SIGNAL TYPE (4) BUFFER TYPE (5) POWER SOURCE (6) RESET STATE AFTER POR (7) P2.1 (RD) I/O LVCMOS DVCC OFF PM_UCA1CLK I/O LVCMOS DVCC N/A P2.2 (RD) SIGNAL NAME (2) I/O LVCMOS DVCC OFF PM_UCA1RXD I LVCMOS DVCC N/A PM_UCA1SOMI I/O LVCMOS DVCC N/A P2.3 (RD) I/O LVCMOS DVCC OFF PM_UCA1TXD O LVCMOS DVCC N/A PM_UCA1SIMO I/O LVCMOS DVCC N/A P2.4 (RD) I/O LVCMOS DVCC OFF PM_TA0.1 I/O LVCMOS DVCC N/A P2.5 (RD) I/O LVCMOS DVCC OFF PM_TA0.2 I/O LVCMOS DVCC N/A P2.6 (RD) I/O LVCMOS DVCC OFF PM_TA0.3 I/O LVCMOS DVCC N/A P2.7 (RD) I/O LVCMOS DVCC OFF PM_TA0.4 I/O LVCMOS DVCC N/A P10.4 (RD) I/O LVCMOS DVCC OFF TA3.0 I/O LVCMOS DVCC N/A C0.7 I Analog DVCC N/A P10.5 (RD) I/O LVCMOS DVCC OFF TA3.1 I/O LVCMOS DVCC N/A C0.6 I Analog DVCC N/A P7.4 (RD) I/O LVCMOS DVCC OFF PM_TA1.4 I/O LVCMOS DVCC N/A I Analog DVCC N/A P7.5 (RD) I/O LVCMOS DVCC OFF PM_TA1.3 I/O LVCMOS DVCC N/A I Analog DVCC N/A P7.6 (RD) I/O LVCMOS DVCC OFF PM_TA1.2 I/O LVCMOS DVCC N/A I Analog DVCC N/A P7.7 (RD) I/O LVCMOS DVCC OFF PM_TA1.1 I/O LVCMOS DVCC N/A I Analog DVCC N/A P8.0 (RD) I/O LVCMOS DVCC OFF UCB3STE I/O LVCMOS DVCC N/A TA1.0 I/O LVCMOS DVCC N/A C0.1 I Analog DVCC N/A P8.1 (RD) I/O LVCMOS DVCC OFF UCB3CLK I/O LVCMOS DVCC N/A TA2.0 I/O LVCMOS DVCC N/A C0.0 I Analog DVCC N/A P3.0 (RD) I/O LVCMOS DVCC OFF PM_UCA2STE I/O LVCMOS DVCC N/A P3.1 (RD) I/O LVCMOS DVCC OFF PM_UCA2CLK I/O LVCMOS DVCC N/A C0.5 27 H2 N/A C0.4 28 J2 N/A C0.3 29 G3 N/A C0.2 30 31 32 33 12 H3 G4 J3 H4 17 18 19 20 (3) Terminal Configuration and Functions Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 Table 4-1. Pin Attributes (continued) PIN NO. (1) PZ ZXH RGC 34 G5 21 SIGNAL NAME (2) P3.2 (RD) 35 36 37 38 39 J4 H5 G6 J5 H6 22 23 24 25 26 E5 27 SIGNAL TYPE (4) BUFFER TYPE (5) POWER SOURCE (6) RESET STATE AFTER POR (7) I/O LVCMOS DVCC OFF PM_UCA2RXD I LVCMOS DVCC N/A PM_UCA2SOMI I/O LVCMOS DVCC N/A P3.3 (RD) I/O LVCMOS DVCC OFF PM_UCA2TXD O LVCMOS DVCC N/A PM_UCA2SIMO I/O LVCMOS DVCC N/A P3.4 (RD) I/O LVCMOS DVCC OFF PM_UCB2STE I/O LVCMOS DVCC N/A P3.5 (RD) I/O LVCMOS DVCC OFF PM_UCB2CLK I/O LVCMOS DVCC N/A P3.6 (RD) I/O LVCMOS DVCC OFF PM_UCB2SIMO I/O LVCMOS DVCC N/A PM_UCB2SDA I/O LVCMOS DVCC N/A P3.7 (RD) I/O LVCMOS DVCC OFF PM_UCB2SOMI I/O LVCMOS DVCC N/A I LVCMOS DVCC N/A PM_UCB2SCL 40 (3) AVSS3 – Power N/A N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A PJ.1 (RD) I/O LVCMOS DVCC OFF LFXOUT O Analog DVCC N/A PJ.0 (RD) 41 J6 28 42 J7 29 43 F5 30 AVSS1 – Power N/A N/A 44 J8 31 DCOR – Analog N/A N/A 45 F6 32 AVCC1 – Power N/A N/A P8.2 (RD) I/O LVCMOS DVCC OFF TA3.2 I/O LVCMOS DVCC N/A 46 N/A N/A LFXIN A23 P8.3 (RD) 47 N/A N/A TA3CLK A22 48 N/A N/A 49 N/A N/A 50 N/A N/A 51 N/A N/A 52 N/A N/A 53 N/A N/A 54 J9 N/A 55 H7 N/A P8.4 (RD) A21 P8.5 (RD) A20 P8.6 (RD) A19 P8.7 (RD) A18 P9.0 (RD) A17 P9.1 (RD) A16 P6.0 (RD) A15 P6.1 (RD) A14 I Analog DVCC N/A I/O LVCMOS DVCC OFF I LVCMOS DVCC N/A I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A Terminal Configuration and Functions Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Copyright © 2015–2017, Texas Instruments Incorporated 13 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Table 4-1. Pin Attributes (continued) PIN NO. PZ ZXH RGC 56 H9 N/A 57 H8 N/A 58 59 60 61 62 G7 G8 G9 F7 F8 33 34 35 36 37 63 F9 38 64 E7 39 65 E8 40 66 E9 41 67 D7 42 68 D8 43 69 C8 44 70 71 14 (1) D9 C9 45 46 SIGNAL TYPE (4) BUFFER TYPE (5) POWER SOURCE (6) RESET STATE AFTER POR (7) I/O LVCMOS DVCC OFF I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A P4.2 (RD) I/O LVCMOS DVCC OFF ACLK O LVCMOS DVCC N/A TA2CLK I LVCMOS DVCC N/A A11 I Analog DVCC N/A P4.3 (RD) I/O LVCMOS DVCC OFF MCLK O LVCMOS DVCC N/A RTCCLK O LVCMOS DVCC N/A A10 I Analog DVCC N/A P4.4 (RD) I/O LVCMOS DVCC OFF HSMCLK O LVCMOS DVCC N/A SVMHOUT O LVCMOS DVCC N/A A9 I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A I/O LVCMOS DVCC OFF SIGNAL NAME (2) P4.0 (RD) A13 P4.1 (RD) A12 P4.5 (RD) A8 P4.6 (RD) A7 P4.7 (RD) A6 P5.0 (RD) A5 P5.1 (RD) A4 P5.2 (RD) A3 P5.3 (RD) A2 (3) I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A I/O LVCMOS DVCC OFF I Analog DVCC N/A P5.6 (RD) I/O LVCMOS DVCC OFF TA2.1 I/O LVCMOS DVCC N/A VREF+ O Analog DVCC N/A VeREF+ I Analog DVCC N/A C1.7 I Analog DVCC N/A P5.7 (RD) I/O LVCMOS DVCC OFF TA2.2 I/O LVCMOS DVCC N/A VREF- O Analog DVCC N/A VeREF- I Analog DVCC N/A C1.6 I Analog DVCC N/A P5.4 (RD) A1 P5.5 (RD) A0 72 E6 47 DVSS2 – Power N/A N/A 73 C6 48 DVCC2 – Power N/A N/A Terminal Configuration and Functions Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 Table 4-1. Pin Attributes (continued) PIN NO. (1) PZ ZXH RGC 74 N/A N/A 75 N/A N/A 76 A9 N/A SIGNAL TYPE (4) BUFFER TYPE (5) POWER SOURCE (6) RESET STATE AFTER POR (7) P9.2 (RD) I/O LVCMOS DVCC OFF TA3.3 I/O LVCMOS DVCC N/A P9.3 (RD) I/O LVCMOS DVCC OFF TA3.4 I/O LVCMOS DVCC N/A P6.2 (RD) I/O LVCMOS DVCC OFF UCB1STE I/O LVCMOS DVCC N/A SIGNAL NAME (2) C1.5 77 B9 N/A I Analog DVCC N/A P6.3 (RD) I/O LVCMOS DVCC OFF UCB1CLK I/O LVCMOS DVCC N/A C1.4 78 A8 N/A I Analog DVCC N/A P6.4 (RD) I/O LVCMOS DVCC OFF UCB1SIMO I/O LVCMOS DVCC N/A UCB1SDA I/O LVCMOS DVCC N/A I Analog DVCC N/A P6.5 (RD) I/O LVCMOS DVCC OFF UCB1SOMI I/O LVCMOS DVCC N/A UCB1SCL I/O LVCMOS DVCC N/A I Analog DVCC N/A P6.6 (RD) I/O LVCMOS DVCC OFF TA2.3 I/O LVCMOS DVCC N/A UCB3SIMO I/O LVCMOS DVCC N/A UCB3SDA I/O LVCMOS DVCC N/A C1.3 79 A7 N/A C1.2 80 B8 49 C1.1 81 B7 50 82 C7 51 83 B6 52 84 D6 53 85 A6 54 86 A5 55 87 D5 56 88 B5 57 I Analog DVCC N/A P6.7 (RD) I/O LVCMOS DVCC OFF TA2.4 I/O LVCMOS DVCC N/A UCB3SOMI I/O LVCMOS DVCC N/A UCB3SCL I/O LVCMOS DVCC N/A C1.0 I Analog DVCC N/A DVSS3 – Power N/A N/A RSTn (RD) I LVCMOS DVCC PU NMI I LVCMOS DVCC N/A AVSS2 – Power N/A N/A PJ.2 (RD) I/O LVCMOS DVCC OFF HFXOUT O Analog DVCC N/A PJ.3 (RD) I/O LVCMOS DVCC OFF I Analog DVCC N/A HFXIN AVCC2 – Power N/A N/A P7.0 (RD) I/O LVCMOS DVCC OFF PM_SMCLK O LVCMOS DVCC N/A PM_DMAE0 89 C5 58 I LVCMOS DVCC N/A P7.1 (RD) I/O LVCMOS DVCC OFF PM_C0OUT O LVCMOS DVCC N/A PM_TA0CLK 90 B4 59 (3) I LVCMOS DVCC N/A P7.2 (RD) I/O LVCMOS DVCC OFF PM_C1OUT O LVCMOS DVCC N/A PM_TA1CLK I LVCMOS DVCC N/A Terminal Configuration and Functions Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Copyright © 2015–2017, Texas Instruments Incorporated 15 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Table 4-1. Pin Attributes (continued) PIN NO. PZ ZXH RGC 91 A4 60 92 B3 61 SIGNAL TYPE (4) BUFFER TYPE (5) POWER SOURCE (6) RESET STATE AFTER POR (7) P7.3 (RD) I/O LVCMOS DVCC OFF PM_TA0.0 I/O LVCMOS DVCC N/A PJ.4 I/O LVCMOS DVCC N/A I LVCMOS DVCC PU PJ.5 I/O LVCMOS DVCC N/A TDO (RD) O LVCMOS DVCC N/A SIGNAL NAME (2) TDI (RD) (3) 93 A3 62 SWO O LVCMOS DVCC N/A 94 B2 63 SWDIOTMS I/O LVCMOS DVCC PU 95 A2 64 SWCLKTCK I LVCMOS DVCC PD 96 N/A N/A P9.4 (RD) I/O LVCMOS DVCC OFF UCA3STE I/O LVCMOS DVCC N/A P9.5 (RD) I/O LVCMOS DVCC OFF UCA3CLK I/O LVCMOS DVCC N/A P9.6 (RD) I/O LVCMOS DVCC OFF UCA3RXD I LVCMOS DVCC N/A UCA3SOMI I/O LVCMOS DVCC N/A P9.7 (RD) I/O LVCMOS DVCC OFF UCA3TXD O LVCMOS DVCC N/A UCA3SIMO I/O LVCMOS DVCC N/A P10.0 (RD) I/O LVCMOS DVCC OFF UCB3STE I/O LVCMOS DVCC N/A QFN Pad – – N/A – 97 98 99 16 (1) N/A N/A N/A N/A N/A N/A 100 N/A N/A N/A N/A Pad Terminal Configuration and Functions Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com 4.3 SLAS826F – MARCH 2015 – REVISED MARCH 2017 Signal Descriptions Table 4-2 describes the signals for all device variants and package options. Table 4-2. Signal Descriptions ADC Clock (1) (2) SIGNAL NO. (1) PZ ZXH RGC SIGNAL TYPE (2) A0 69 C8 44 I ADC analog input A0 A1 68 D8 43 I ADC analog input A1 A2 67 D7 42 I ADC analog input A2 A3 66 E9 41 I ADC analog input A3 A4 65 E8 40 I ADC analog input A4 A5 64 E7 39 I ADC analog input A5 A6 63 F9 38 I ADC analog input A6 A7 62 F8 37 I ADC analog input A7 A8 61 F7 36 I ADC analog input A8 A9 60 G9 35 I ADC analog input A9 A10 59 G8 34 I ADC analog input A10 A11 58 G7 33 I ADC analog input A11 A12 57 H8 N/A I ADC analog input A12 A13 56 H9 N/A I ADC analog input A13 A14 55 H7 N/A I ADC analog input A14 A15 54 J9 N/A I ADC analog input A15 A16 53 N/A N/A I ADC analog input A16 A17 52 N/A N/A I ADC analog input A17 A18 51 N/A N/A I ADC analog input A18 A19 50 N/A N/A I ADC analog input A19 A20 49 N/A N/A I ADC analog input A20 A21 48 N/A N/A I ADC analog input A21 A22 47 N/A N/A I ADC analog input A22 A23 46 N/A N/A I ADC analog input A23 ACLK 58 G7 33 O ACLK clock output DCOR 44 J8 31 – DCO external resistor pin HFXIN 86 A5 55 I Input for high-frequency crystal oscillator HFXT HFXOUT 85 A6 54 O Output for high-frequency crystal oscillator HFXT HSMCLK 60 G9 35 O HSMCLK clock output LFXIN 41 J6 28 I Input for low-frequency crystal oscillator LFXT LFXOUT 42 J7 29 O Output of low-frequency crystal oscillator LFXT MCLK 59 G8 34 O MCLK clock output FUNCTION SIGNAL NAME DESCRIPTION N/A = not available I = input, O = output Terminal Configuration and Functions Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Copyright © 2015–2017, Texas Instruments Incorporated 17 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Table 4-2. Signal Descriptions (continued) FUNCTION Comparator SIGNAL NO. (1) PZ ZXH RGC SIGNAL TYPE (2) C0.0 31 G4 18 I Comparator_E0 input 0 C0.1 30 H3 17 I Comparator_E0 input 1 C0.2 29 G3 N/A I Comparator_E0 input 2 C0.3 28 J2 N/A I Comparator_E0 input 3 C0.4 27 H2 N/A I Comparator_E0 input 4 C0.5 26 J1 N/A I Comparator_E0 input 5 C0.6 25 N/A N/A I Comparator_E0 input 6 C0.7 24 N/A N/A I Comparator_E0 input 7 C1.0 81 B7 50 I Comparator_E1 input 0 C1.1 80 B8 49 I Comparator_E1 input 1 C1.2 79 A7 N/A I Comparator_E1 input 2 C1.3 78 A8 N/A I Comparator_E1 input 3 C1.4 77 B9 N/A I Comparator_E1 input 4 C1.5 76 A9 N/A I Comparator_E1 input 5 C1.6 71 C9 46 I Comparator_E1 input 6 C1.7 70 D9 45 I Comparator_E1 input 7 SWCLKTCK 95 A2 64 I Serial wire clock input (SWCLK)/JTAG clock input (TCK) SWDIOTMS 94 B2 63 I/O Serial wire data input/output (SWDIO)/JTAG test mode select (TMS) SWO 93 A3 62 O Serial wire trace output TDI 92 B3 61 I JTAG test data input TDO 93 A3 62 O JTAG test data output P1.0 4 A1 1 I/O General-purpose digital I/O with port interrupt, wakeup, and glitch filtering capability P1.1 5 B1 2 I/O General-purpose digital I/O with port interrupt and wake-up capability P1.2 6 C4 3 I/O General-purpose digital I/O with port interrupt and wake-up capability P1.3 7 D4 4 I/O General-purpose digital I/O with port interrupt and wake-up capability P1.4 8 D3 5 I/O General-purpose digital I/O with port interrupt, wakeup, and glitch filtering capability P1.5 9 C1 6 I/O General-purpose digital I/O with port interrupt, wakeup, and glitch filtering capability P1.6 10 D1 7 I/O General-purpose digital I/O with port interrupt and wake-up capability P1.7 11 E1 8 I/O General-purpose digital I/O with port interrupt and wake-up capability SIGNAL NAME Debug GPIO 18 Terminal Configuration and Functions DESCRIPTION Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 Table 4-2. Signal Descriptions (continued) FUNCTION SIGNAL NAME P2.0 P2.1 P2.2 GPIO (continued) SIGNAL NO. (1) PZ 16 17 18 ZXH E4 F1 E3 RGC 13 14 15 SIGNAL TYPE (2) DESCRIPTION I/O General-purpose digital I/O with port interrupt and wake-up capability and with reconfigurable port mapping secondary function. This I/O can be configured for high drive operation with up to 20-mA drive capability. I/O General-purpose digital I/O with port interrupt and wake-up capability and with reconfigurable port mapping secondary function. This I/O can be configured for high drive operation with up to 20-mA drive capability. I/O General-purpose digital I/O with port interrupt and wake-up capability and with reconfigurable port mapping secondary function. This I/O can be configured for high drive operation with up to 20-mA drive capability. P2.3 19 F4 16 I/O General-purpose digital I/O with port interrupt and wake-up capability and with reconfigurable port mapping secondary function. This I/O can be configured for high drive operation with up to 20-mA drive capability. P2.4 20 F3 N/A I/O General-purpose digital I/O with port interrupt and wake-up capability and with reconfigurable port mapping secondary function P2.5 21 G1 N/A I/O General-purpose digital I/O with port interrupt and wake-up capability and with reconfigurable port mapping secondary function P2.6 22 G2 N/A I/O General-purpose digital I/O with port interrupt and wake-up capability and with reconfigurable port mapping secondary function P2.7 23 H1 N/A I/O General-purpose digital I/O with port interrupt and wake-up capability and with reconfigurable port mapping secondary function P3.0 32 J3 19 I/O General-purpose digital I/O with port interrupt, wakeup, and glitch filtering capability, and with reconfigurable port mapping secondary function P3.1 33 H4 20 I/O General-purpose digital I/O with port interrupt and wake-up capability and with reconfigurable port mapping secondary function P3.2 34 G5 21 I/O General-purpose digital I/O with port interrupt and wake-up capability and with reconfigurable port mapping secondary function P3.3 35 J4 22 I/O General-purpose digital I/O with port interrupt and wake-up capability and with reconfigurable port mapping secondary function P3.4 36 H5 23 I/O General-purpose digital I/O with port interrupt, wakeup, and glitch filtering capability, and with reconfigurable port mapping secondary function P3.5 37 G6 24 I/O General-purpose digital I/O with port interrupt, wakeup, and glitch filtering capability, and with reconfigurable port mapping secondary function P3.6 38 J5 25 I/O General-purpose digital I/O with port interrupt and wake-up capability and with reconfigurable port mapping secondary function P3.7 39 H6 26 I/O General-purpose digital I/O with port interrupt and wake-up capability and with reconfigurable port mapping secondary function Terminal Configuration and Functions Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Copyright © 2015–2017, Texas Instruments Incorporated 19 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Table 4-2. Signal Descriptions (continued) FUNCTION GPIO (continued) 20 SIGNAL NO. (1) PZ ZXH RGC SIGNAL TYPE (2) P4.0 56 H9 N/A I/O General-purpose digital I/O with port interrupt and wake-up capability P4.1 57 H8 N/A I/O General-purpose digital I/O with port interrupt and wake-up capability P4.2 58 G7 33 I/O General-purpose digital I/O with port interrupt and wake-up capability P4.3 59 G8 34 I/O General-purpose digital I/O with port interrupt and wake-up capability P4.4 60 G9 35 I/O General-purpose digital I/O with port interrupt and wake-up capability P4.5 61 F7 36 I/O General-purpose digital I/O with port interrupt and wake-up capability P4.6 62 F8 37 I/O General-purpose digital I/O with port interrupt and wake-up capability P4.7 63 F9 38 I/O General-purpose digital I/O with port interrupt and wake-up capability P5.0 64 E7 39 I/O General-purpose digital I/O with port interrupt and wake-up capability P5.1 65 E8 40 I/O General-purpose digital I/O with port interrupt and wake-up capability P5.2 66 E9 41 I/O General-purpose digital I/O with port interrupt and wake-up capability P5.3 67 D7 42 I/O General-purpose digital I/O with port interrupt and wake-up capability P5.4 68 D8 43 I/O General-purpose digital I/O with port interrupt and wake-up capability P5.5 69 C8 44 I/O General-purpose digital I/O with port interrupt and wake-up capability P5.6 70 D9 45 I/O General-purpose digital I/O with port interrupt and wake-up capability P5.7 71 C9 46 I/O General-purpose digital I/O with port interrupt and wake-up capability P6.0 54 J9 N/A I/O General-purpose digital I/O with port interrupt and wake-up capability P6.1 55 H7 N/A I/O General-purpose digital I/O with port interrupt and wake-up capability P6.2 76 A9 N/A I/O General-purpose digital I/O with port interrupt and wake-up capability P6.3 77 B9 N/A I/O General-purpose digital I/O with port interrupt and wake-up capability P6.4 78 A8 N/A I/O General-purpose digital I/O with port interrupt and wake-up capability P6.5 79 A7 N/A I/O General-purpose digital I/O with port interrupt and wake-up capability P6.6 80 B8 49 I/O General-purpose digital I/O with port interrupt, wakeup, and glitch filtering capability P6.7 81 B7 50 I/O General-purpose digital I/O with port interrupt, wakeup, and glitch filtering capability SIGNAL NAME Terminal Configuration and Functions DESCRIPTION Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 Table 4-2. Signal Descriptions (continued) FUNCTION GPIO (continued) SIGNAL NO. (1) PZ ZXH RGC SIGNAL TYPE (2) P7.0 88 B5 57 I/O General-purpose digital I/O with reconfigurable port mapping secondary function (RD) P7.1 89 C5 58 I/O General-purpose digital I/O with reconfigurable port mapping secondary function (RD) P7.2 90 B4 59 I/O General-purpose digital I/O with reconfigurable port mapping secondary function (RD) P7.3 91 A4 60 I/O General-purpose digital I/O with reconfigurable port mapping secondary function (RD) P7.4 26 J1 N/A I/O General-purpose digital I/O with reconfigurable port mapping secondary function (RD) P7.5 27 H2 N/A I/O General-purpose digital I/O with reconfigurable port mapping secondary function (RD) P7.6 28 J2 N/A I/O General-purpose digital I/O with reconfigurable port mapping secondary function (RD) P7.7 29 G3 N/A I/O General-purpose digital I/O with reconfigurable port mapping secondary function (RD) P8.0 30 H3 17 I/O General-purpose digital I/O P8.1 31 G4 18 I/O General-purpose digital I/O P8.2 46 N/A N/A I/O General-purpose digital I/O P8.3 47 N/A N/A I/O General-purpose digital I/O P8.4 48 N/A N/A I/O General-purpose digital I/O P8.5 49 N/A N/A I/O General-purpose digital I/O P8.6 50 N/A N/A I/O General-purpose digital I/O P8.7 51 N/A N/A I/O General-purpose digital I/O P9.0 52 N/A N/A I/O General-purpose digital I/O P9.1 53 N/A N/A I/O General-purpose digital I/O P9.2 74 N/A N/A I/O General-purpose digital I/O P9.3 75 N/A N/A I/O General-purpose digital I/O P9.4 96 N/A N/A I/O General-purpose digital I/O P9.5 97 N/A N/A I/O General-purpose digital I/O P9.6 98 N/A N/A I/O General-purpose digital I/O P9.7 99 N/A N/A I/O General-purpose digital I/O P10.0 100 N/A N/A I/O General-purpose digital I/O P10.1 1 N/A N/A I/O General-purpose digital I/O P10.2 2 N/A N/A I/O General-purpose digital I/O P10.3 3 N/A N/A I/O General-purpose digital I/O P10.4 24 N/A N/A I/O General-purpose digital I/O P10.5 25 N/A N/A I/O General-purpose digital I/O PJ.0 41 J6 28 I/O General-purpose digital I/O PJ.1 42 J7 29 I/O General-purpose digital I/O PJ.2 85 A6 54 I/O General-purpose digital I/O PJ.3 86 A5 55 I/O General-purpose digital I/O PJ.4 92 B3 61 I/O General-purpose digital I/O PJ.5 93 A3 62 I/O General-purpose digital I/O SIGNAL NAME DESCRIPTION Terminal Configuration and Functions Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Copyright © 2015–2017, Texas Instruments Incorporated 21 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Table 4-2. Signal Descriptions (continued) FUNCTION I2C 22 SIGNAL NO. (1) PZ ZXH RGC SIGNAL TYPE (2) UCB0SCL 11 E1 8 I/O I2C clock – eUSCI_B0 I2C mode UCB0SDA 10 D1 7 I/O I2C data – eUSCI_B0 I2C mode UCB1SCL 79 A7 N/A I/O I2C clock – eUSCI_B1 I2C mode UCB1SDA 78 A8 N/A I/O I2C data – eUSCI_B1 I2C mode UCB3SCL 3 N/A N/A I/O I2C clock – eUSCI_B3 I2C mode UCB3SCL 81 B7 50 I/O I2C clock – eUSCI_B3 I2C mode UCB3SDA 2 N/A N/A I/O I2C data – eUSCI_B3 I2C mode UCB3SDA 80 B8 49 I/O I2C data – eUSCI_B3 I2C mode SIGNAL NAME Terminal Configuration and Functions DESCRIPTION Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 Table 4-2. Signal Descriptions (continued) FUNCTION Port Mapper SIGNAL NO. (1) PZ ZXH RGC SIGNAL TYPE (2) PM_C0OUT 89 C5 58 O Default mapping: Comparator_E0 output PM_C1OUT 90 B4 59 O Default mapping: Comparator_E1 output PM_DMAE0 88 B5 57 I Default mapping: DMA external trigger input PM_SMCLK 88 B5 57 O Default mapping: SMCLK clock output PM_TA0.0 91 A4 60 I/O Default mapping: TA0 CCR0 capture: CCI0A input, compare: Out0 PM_TA0.1 20 F3 N/A I/O Default mapping: TA0 CCR1 capture: CCI1A input, compare: Out1 PM_TA0.2 21 G1 N/A I/O Default mapping: TA0 CCR2 capture: CCI2A input, compare: Out2 PM_TA0.3 22 G2 N/A I/O Default mapping: TA0 CCR3 capture: CCI3A input, compare: Out3 PM_TA0.4 23 H1 N/A I/O Default mapping: TA0 CCR4 capture: CCI4A input, compare: Out4 PM_TA0CLK 89 C5 58 I PM_TA1.2 28 J2 N/A I/O Default mapping: TA1 CCR2 capture: CCI2A input, compare: Out2 PM_TA1.3 27 H2 N/A I/O Default mapping: TA1 CCR3 capture: CCI3A input, compare: Out3 PM_TA1.4 26 J1 N/A I/O Default mapping: TA1 CCR4 capture: CCI4A input, compare: Out4 PM_TA1CLK 90 B4 59 I PM_UCA1CLK 17 F1 14 I/O PM_UCA1RXD 18 E3 15 I Default mapping: Receive data – eUSCI_A1 UART mode PM_UCA1SIMO 19 F4 16 I/O Default mapping: Slave in, master out – eUSCI_A1 SPI mode PM_UCA1SOMI 18 E3 15 I/O Default mapping: Slave out, master in – eUSCI_A1 SPI mode PM_UCA1STE 16 E4 13 I/O Default mapping: Slave transmit enable – eUSCI_A1 SPI mode PM_UCA1TXD 19 F4 16 O Default mapping: Transmit data – eUSCI_A1 UART mode PM_UCA2CLK 33 H4 20 I/O Default mapping: Clock signal input – eUSCI_A2 SPI slave mode Clock signal output – eUSCI_A2 SPI master mode PM_UCA2RXD 34 G5 21 I Default mapping: Receive data – eUSCI_A2 UART mode PM_UCA2SIMO 35 J4 22 I/O Default mapping: Slave in, master out – eUSCI_A2 SPI mode PM_UCA2SOMI 34 G5 21 I/O Default mapping: Slave out, master in – eUSCI_A2 SPI mode PM_UCA2STE 32 J3 19 I/O Default mapping: Slave transmit enable – eUSCI_A2 SPI mode PM_UCA2TXD 35 J4 22 O Default mapping: Transmit data – eUSCI_A2 UART mode SIGNAL NAME DESCRIPTION Default mapping: TA0 input clock Default mapping: TA1 input clock Default mapping: Clock signal input – eUSCI_A1 SPI slave mode Clock signal output – eUSCI_A1 SPI master mode Terminal Configuration and Functions Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Copyright © 2015–2017, Texas Instruments Incorporated 23 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Table 4-2. Signal Descriptions (continued) FUNCTION Port Mapper (continued) Power RTC Reference (3) 24 SIGNAL NO. (1) PZ ZXH RGC SIGNAL TYPE (2) PM_UCB2CLK 37 G6 24 I/O PM_UCB2SCL 39 H6 26 I Default mapping: I2C clock – eUSCI_B2 I2C mode PM_UCB2SDA 38 J5 25 I/O Default mapping: I2C data – eUSCI_B2 I2C mode PM_UCB2SIMO 38 J5 25 I/O Default mapping: Slave in, master out – eUSCI_B2 SPI mode PM_UCB2SOMI 39 H6 26 I/O Default mapping: Slave out, master in – eUSCI_B2 SPI mode PM_UCB2STE 36 H5 23 I/O Default mapping: Slave transmit enable – eUSCI_B2 SPI mode AVCC1 45 F6 32 – Analog power supply AVCC2 87 D5 56 – Analog power supply AVSS1 43 F5 30 – Analog ground supply AVSS2 84 D6 53 – Analog ground supply AVSS3 40 E5 27 – Analog ground supply DVCC1 13 D2 10 – Digital power supply DVCC2 73 C6 48 – Digital power supply DVSS1 15 F2 12 – Digital ground supply DVSS2 72 E6 47 – Digital ground supply DVSS3 82 C7 51 – Must be connected to ground VCORE (3) 12 C2 9 – Regulated core power supply (internal use only, no external current loading) VSW 14 E2 11 – DC-to-DC converter switching output RTCCLK 59 G8 34 O RTC_C clock calibration output VREF+ 70 D9 45 O Internal shared reference voltage positive terminal VREF- 71 C9 46 O Internal shared reference voltage negative terminal VeREF+ 70 D9 45 I Positive terminal of external reference voltage to ADC VeREF- 71 C9 46 I Negative terminal of external reference voltage to ADC (recommended to connect to onboard ground) SIGNAL NAME DESCRIPTION Default mapping: Clock signal input – eUSCI_B2 SPI slave mode Clock signal output – eUSCI_B2 SPI master mode VCORE is for internal use only. No external current loading is possible. VCORE should only be connected to the recommended capacitor value, CVCORE. Terminal Configuration and Functions Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 Table 4-2. Signal Descriptions (continued) FUNCTION SPI System Thermal SIGNAL NO. (1) PZ ZXH RGC SIGNAL TYPE (2) UCA0CLK 5 B1 2 I/O Clock signal input – eUSCI_A0 SPI slave mode Clock signal output – eUSCI_A0 SPI master mode UCA0SIMO 7 D4 4 I/O Slave in, master out – eUSCI_A0 SPI mode UCA0SOMI 6 C4 3 I/O Slave out, master in – eUSCI_A0 SPI mode UCA0STE 4 A1 1 I/O Slave transmit enable – eUSCI_A0 SPI mode UCA3CLK 97 N/A N/A I/O Clock signal input – eUSCI_A3 SPI slave mode Clock signal output – eUSCI_A3 SPI master mode UCA3SIMO 99 N/A N/A I/O Slave in, master out – eUSCI_A3 SPI mode UCA3SOMI 98 N/A N/A I/O Slave out, master in – eUSCI_A3 SPI mode UCA3STE 96 N/A N/A I/O Slave transmit enable – eUSCI_A3 SPI mode UCB0CLK 9 C1 6 I/O Clock signal input – eUSCI_B0 SPI slave mode Clock signal output – eUSCI_B0 SPI master mode UCB0SIMO 10 D1 7 I/O Slave in, master out – eUSCI_B0 SPI mode UCB0SOMI 11 E1 8 I/O Slave out, master in – eUSCI_B0 SPI mode UCB0STE 8 D3 5 I/O Slave transmit enable – eUSCI_B0 SPI mode UCB1CLK 77 B9 N/A I/O Clock signal input – eUSCI_B1 SPI slave mode Clock signal output – eUSCI_B1 SPI master mode UCB1SIMO 78 A8 N/A I/O Slave in, master out – eUSCI_B1 SPI mode UCB1SOMI 79 A7 N/A I/O Slave out, master in – eUSCI_B1 SPI mode UCB1STE 76 A9 N/A I/O Slave transmit enable – eUSCI_B1 SPI mode UCB3CLK 1 N/A N/A I/O Clock signal input – eUSCI_B3 SPI slave mode Clock signal output – eUSCI_B3 SPI master mode UCB3CLK 31 G4 18 I/O Clock signal input – eUSCI_B3 SPI slave mode Clock signal output – eUSCI_B3 SPI master mode UCB3SIMO 2 N/A N/A I/O Slave in, master out – eUSCI_B3 SPI mode UCB3SIMO 80 B8 49 I/O Slave in, master out – eUSCI_B3 SPI mode UCB3SOMI 3 N/A N/A I/O Slave out, master in – eUSCI_B3 SPI mode UCB3SOMI 81 B7 50 I/O Slave out, master in – eUSCI_B3 SPI mode UCB3STE 30 H3 17 I/O Slave transmit enable – eUSCI_B3 SPI mode UCB3STE 100 N/A N/A I/O Slave transmit enable – eUSCI_B3 SPI mode NMI 83 B6 52 I External nonmaskable interrupt RSTn 83 B6 52 I External reset (active low) SVMHOUT 60 G9 35 O SVMH output QFN Pad N/A N/A Pad – QFN package exposed thermal pad. TI recommends connection to VSS. SIGNAL NAME DESCRIPTION Terminal Configuration and Functions Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Copyright © 2015–2017, Texas Instruments Incorporated 25 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Table 4-2. Signal Descriptions (continued) FUNCTION Timer UART 26 SIGNAL NO. (1) PZ ZXH RGC SIGNAL TYPE (2) PM_TA1.1 29 G3 N/A I/O Default mapping: TA1 CCR1 capture: CCI1A input, compare: Out1 TA1.0 30 H3 17 I/O TA1 CCR0 capture: CCI0A input, compare: Out0 TA2.0 31 G4 18 I/O TA2 CCR0 capture: CCI0A input, compare: Out0 TA2.1 70 D9 45 I/O TA2 CCR1 capture: CCI1A input, compare: Out1 TA2.2 71 C9 46 I/O TA2 CCR2 capture: CCI2A input, compare: Out2 TA2.3 80 B8 49 I/O TA2 CCR3 capture: CCI3A input, compare: Out3 TA2.4 81 B7 50 I/O TA2 CCR4 capture: CCI4A input, compare: Out4 TA2CLK 58 G7 33 I TA3.0 24 N/A N/A I/O TA3 CCR0 capture: CCI0A input, compare: Out0 TA3.1 25 N/A N/A I/O TA3 CCR1 capture: CCI1A input, compare: Out1 TA3.2 46 N/A N/A I/O TA3 CCR2 capture: CCI2A input, compare: Out2 TA3.3 74 N/A N/A I/O TA3 CCR3 capture: CCI3A input, compare: Out3 TA3.4 75 N/A N/A I/O TA3 CCR4 capture: CCI4A input, compare: Out4 TA3CLK 47 N/A N/A I TA3 input clock UCA0RXD 6 C4 3 I Receive data – eUSCI_A0 UART mode UCA0TXD 7 D4 4 O Transmit data – eUSCI_A0 UART mode UCA3RXD 98 N/A N/A I Receive data – eUSCI_A3 UART mode UCA3TXD 99 N/A N/A O Transmit data – eUSCI_A3 UART mode SIGNAL NAME Terminal Configuration and Functions DESCRIPTION TA2 input clock Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com 4.4 SLAS826F – MARCH 2015 – REVISED MARCH 2017 Pin Multiplexing Pin multiplexing for these devices is controlled by both register settings and operating modes (for example, if the device is in test mode). For details of the settings for each pin and diagrams of the multiplexed ports, see Section 6.12. 4.5 Buffer Types Table 4-3 describes the buffer types that are referenced in Table 4-1. Table 4-3. Buffer Type NOMINAL VOLTAGE HYSTERESIS PU OR PD NOMINAL PU OR PD STRENGTH (µA) OUTPUT DRIVE STRENGTH (mA) Analog (1) 3.0 V N N/A N/A N/A HVCMOS 13.0 V Y N/A N/A See Typical Characteristics LVCMOS 3.0 V Y (2) Programmable See GeneralPurpose I/Os See Typical Characteristics Power (DVCC) (3) 3.0 V N N/A N/A N/A Power (AVCC) (3) 3.0 V N N/A N/A N/A Power (DVSS and AVSS) (3) 0V N N/A N/A N/A BUFFER TYPE (STANDARD) (1) (2) (3) OTHER CHARACTERISTICS See analog modules in Specifications for details SVSMH enables hysteresis on DVCC This is a switch, not a buffer. Only for input pins This is supply input, not a buffer. 4.6 Connection for Unused Pins Table 4-4 lists the correct termination of all unused pins. Table 4-4. Connection for Unused Pins (1) PIN POTENTIAL AVCC DVCC AVSS DVSS Px.0 to Px.7 Open Set to port function, output direction, and leave unconnected on the PC board RSTn/NMI DVCC or VCC 47-kΩ pullup with 1.1-nF pulldown. PJ.4/TDI Open The JTAG TDI pin is shared with general-purpose I/O function (PJ.4). If not being used, this pin should be set to port function, output direction. When used as JTAG TDI pin, it should remain open. PJ.5/TDO/SWO DVCC or VCC The JTAG TDO/SWO pin is shared with general-purpose I/O function (PJ.5). If not being used, this pin should be set to port function, output direction. When used as JTAG TDO/SWO pin, it should be pulled down externally. SWDIOTMS DVCC or VCC This pin should be pulled up externally. SWCLKTCK DVSS or VSS This pin should be pulled down externally. (1) COMMENT For any unused pin with a secondary function that is shared with general-purpose I/O, follow the guidelines for the Px.0 to Px.7 pins. Terminal Configuration and Functions Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Copyright © 2015–2017, Texas Instruments Incorporated 27 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com 5 Specifications Absolute Maximum Ratings (1) 5.1 over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) Voltage applied at DVCC and AVCC pins to VSS Voltage difference between DVCC and AVCC pins Voltage applied to any pin MIN MAX UNIT –0.3 4.17 V ±0.3 V –0.3 VCC + 0.3 V (4.17 V MAX) V (2) (3) Diode current at any device pin Storage temperature, Tstg (4) –40 Maximum junction temperature, TJ (1) (2) (3) (4) ±2 mA 125 °C 95 °C Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. Voltage differences between DVCC and AVCC exceeding the specified limits may cause malfunction of the device. All voltages referenced to VSS. Higher temperature may be applied during board soldering according to the current JEDEC J-STD-020 specification with peak reflow temperatures not higher than classified on the device label on the shipping boxes or reels. 5.2 ESD Ratings VALUE V(ESD) (1) (2) (3) Electrostatic discharge Human-body model (HBM), per ANSI/ESDA/JEDEC JS-001 (1) (2) UNIT ±1000 Charged-device model (CDM), per JEDEC specification JESD22-C101 (3) V ±250 JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. Pins listed as ±1000 V may actually have higher performance. All pins except DVSS3 pass HBM up to ±1000 V. The DVSS3 pin is used for TI internal test purposes. Connect the DVSS3 pin to supply ground on the customer application board. JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process. Pins listed as ±250 V may actually have higher performance. 5.3 Recommended Operating Conditions Typical data are based on VCC = 3.0 V, TA = 25°C (unless otherwise noted) MIN Supply voltage range at all DVCC and AVCC pins (1) (2) (3) VCC 3.7 Normal operation with internal VCC supervision 1.71 3.7 Normal operation without internal VCC supervision 1.62 3.7 Supply voltage on all DVSS and AVSS pins IINRUSH Inrush current into the VCC pins (4) fMCLK Frequency of the CPU and AHB clock in the system (5) TA Operating free-air temperature TJ Operating junction temperature –40 (2) (3) (4) (5) 28 MAX 1.71 VSS (1) NOM At power-up (with internal VCC supervision) 0 UNIT V V 100 mA 0 48 MHz –40 85 °C 85 °C TI recommends powering AVCC and DVCC from the same source. A maximum difference of ±0.1 V between AVCC and DVCC can be tolerated during power up and operation. See Section 5.4 for decoupling capacitor recommendations. Supply voltage must not change faster than 1 V/ms. Faster changes can cause the VCCDET to trigger a reset even within the recommended supply voltage range. Modules may have a different supply voltage range specification. See the specification of the respective module in this data sheet. Does not include I/O currents (driven by application requirements). Operating frequency may require the flash to be accessed with wait states. See Section 5.8 for further details. Specifications Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 Recommended External Components (1) 5.4 CDVCC Capacitor on DVCC pin CVCORE (2) (3) MIN TYP For DC-DC operation (4) 3.3 4.7 For LDO-only operation 3.3 4.7 1.54 4.7 9 µF 70 100 9000 nF For DC-DC operation, including capacitor tolerance Capacitor on VCORE pin For LDO-only operation, including capacitor tolerance MAX UNIT µF CAVCC Capacitor on AVCC pin 3.3 4.7 LVSW Inductor between VSW and VCORE pins for DC-DC 3.3 4.7 13 µH RLVSW-DCR Allowed DCR for LVSW 150 350 mΩ ISAT-LVSW LVSW saturation current (1) (2) (3) (4) 5.5 µF 700 mA For optimum performance, select the component value to match the typical value given in the table. See the section on board guidelines for further details on component selection, placement as well as related PCB design guidelines. Tolerance of the capacitance and inductance values should be taken into account when choosing a component, to ensure that the MIN and MAX limits are never exceeded. CDVCC should not be smaller than CVCORE. Operating Mode VCC Ranges over operating free-air temperature (unless otherwise noted) PARAMETER VCC_LDO OPERATING MODE AM_LDO_VCORE0 AM_LF_VCORE0 LPM0_LDO_VCORE0 LPM0_LF_VCORE0 LPM3_VCORE0 LPM4_VCORE0 LPM3.5 AM_LDO_VCORE1 AM_LF_VCORE1 LPM0_LDO_VCORE1 LPM0_LF_VCORE1 LPM3_VCORE1 LPM4_VCORE1 (1) (2) TEST CONDITIONS MIN MAX LDO active, SVSMH disabled 1.62 3.7 LDO active, SVSMH enabled 1.71 3.7 UNIT V VCC_DCDC_DF0 AM_DCDC_VCORE0 LPM0_DCDC_VCORE0 AM_DCDC_VCORE1 LPM0_DCDC_VCORE1 DC-DC active, DC-DC operation not forced (DCDC_FORCE = 0), SVSMH enabled or disabled (3) 2.0 3.7 V VCC_DCDC_DF1 AM_DCDC_VCORE0 LPM0_DCDC_VCORE0 AM_DCDC_VCORE1 LPM0_DCDC_VCORE1 DC-DC active, DC-DC operation forced (DCDC_FORCE = 1), SVSMH enabled or disabled 1.8 3.7 V LDO disabled, SVSMH disabled 1.62 3.7 LDO disabled, SVSMH enabled 1.71 3.7 VCC_VCORE_OFF (1) (2) (3) (4) (4) LPM4.5 V Flash remains active only in active modes and LPM0 modes. Low-frequency active, low-frequency LPM0, LPM3, LPM4, and LPM3.5 modes are based on LDO only. When VCC falls below the specified MIN value, the DC-DC operation switches to LDO automatically, as long as the VCC drop is slower than the rate that is reliably detected. See Table 5-19 for more details. Core voltage is off in LPM4.5 mode. Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 29 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Operating Mode CPU Frequency Ranges (1) 5.6 over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER OPERATING MODE fMCLK DESCRIPTION MIN MAX UNIT fAM_LDO_VCORE0 AM_LDO_VCORE0 Normal performance mode with LDO as the active regulator 0 24 MHz fAM_LDO_VCORE1 AM_LDO_VCORE1 High performance mode with LDO as the active regulator 0 48 MHz fAM_DCDC_VCORE0 AM_DCDC_VCORE0 Normal performance mode with DC-DC as the active regulator 0 24 MHz fAM_DCDC_VCORE1 AM_DCDC_VCORE1 High performance mode with DC-DC as the active regulator 0 48 MHz fAM_LF_VCORE0 AM_LF_VCORE0 Low-frequency mode with LDO as the active regulator 0 128 kHz fAM_LF_VCORE1 AM_LF_VCORE1 Low-frequency mode with LDO as the active regulator 0 128 kHz MIN MAX UNIT Peripheral frequency range in LDO or DC-DC based active or LPM0 modes for VCORE0 0 12 MHz Peripheral frequency range in LDO or DC-DC based active or LPM0 modes for VCORE1 0 24 MHz Peripheral frequency range in low-frequency active or low frequency LPM0 modes for VCORE0 and VCORE1 0 128 kHz LPM3_VCORE1 Peripheral frequency in LPM3 mode for VCORE0 and VCORE1 0 32.768 kHz LPM3.5 Peripheral frequency in LPM3.5 mode 0 32.768 kHz (1) DMA can be operated at the same frequency as CPU. 5.7 Operating Mode Peripheral Frequency Ranges over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER OPERATING MODE DESCRIPTION AM_LDO_VCORE0 fAM_LPM0_VCORE0 AM_DCDC_VCORE0 LPM0_LDO_VCORE0 LPM0_DCDC_VCORE0 AM_LDO_VCORE1 fAM_LPM0_VCORE1 AM_DCDC_VCORE1 LPM0_LDO_VCORE1 LPM0_DCDC_VCORE1 AM_LF_VCORE0 fAM_LPM0_LF AM_LF_VCORE1 LPM0_LF_VCORE0 LPM0_LF_VCORE1 LPM3_VCORE0 fLPM3 (1) fLPM3.5 (1) (1) 30 Only RTC and WDT can be active. Specifications Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com 5.8 SLAS826F – MARCH 2015 – REVISED MARCH 2017 Operating Mode Execution Frequency vs Flash Wait-State Requirements over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) NUMBER OF FLASH WAIT STATES FLASH READ MODE fMAX_NRM_FLWAIT0 0 fMAX_NRM_FLWAIT1 PARAMETER MAXIMUM SUPPORTED MCLK FREQUENCY (1) (2) AM_LDO_VCORE0, AM_DCDC_VCORE0 AM_LDO_VCORE1, AM_DCDC_VCORE1 UNIT Normal read mode 16 24 MHz 1 Normal read mode 24 48 MHz fMAX_ORM_FLWAIT0 0 Other read modes (3) 8 12 MHz fMAX_ORM_FLWAIT1 1 Other read modes (3) 16 24 MHz fMAX_ORM_FLWAIT2 2 Other read modes (3) 24 36 MHz fMAX_ORM_FLWAIT3 3 Other read modes (3) 24 48 MHz (1) (2) (3) Violation of the maximum frequency limitation for a given wait-state configuration results in nondeterministic data or instruction fetches from the flash memory. In low-frequency active modes, the flash can always be accessed with zero wait states, because the maximum MCLK frequency is limited to 128 kHz. Other read modes refers to Read Margin 0, Read Margin 1, Program Verify, and Erase Verify. 5.9 Current Consumption During Device Reset over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER IRESET (1) (2) (3) VCC Current during device reset MIN (1) (2) (3) TYP 2.2 V 510 3.0 V 600 MAX 850 UNIT µA Device held in reset through RSTn/NMI pin. Current measured into VCC. All other input pins tied to 0 V or VCC. Outputs do not source or sync any current. 5.10 Current Consumption in LDO-Based Active Modes – Dhrystone 2.1 Program over recommended operating free-air temperature (unless otherwise noted) (1) PARAMETER EXECUTION MEMORY MCLK = 1 MHz MCLK = 8 MHz VCC (2) (3) (4) (5) MCLK = 16 MHz MCLK = 24 MHz MCLK = 32 MHz MCLK = 40 MHz MCLK = 48 MHz TYP MAX TYP MAX TYP MAX 5300 5800 6500 7100 7700 8400 3650 4020 4470 4900 5280 5760 TYP MAX TYP MAX TYP MAX TYP MAX IAM_LDO_VCORE0,Flash (6) (7) (8) Flash 3.0 V 490 625 1500 1700 2650 2950 3580 3900 IAM_LDO_VCORE1,Flash (6) (7) (8) Flash 3.0 V 510 685 1650 1900 2970 3300 4260 4700 IAM_LDO_VCORE0,SRAM (9) SRAM 3.0 V 435 565 1070 1240 1800 2010 2530 2800 IAM_LDO_VCORE1,SRAM (9) SRAM 3.0 V 450 620 1160 1370 1980 2250 2800 3120 (1) (2) (3) (4) (5) (6) (7) (8) (9) UNIT µA µA µA µA MCLK sourced by DCO. Current measured into VCC. All other input pins tied to 0 V or VCC. Outputs do not source or sync any current. All SRAM banks kept active. All peripherals are inactive. Device executing the Dhrystone 2.1 program. Code execution from flash. Stack and data in SRAM. Flash configured to minimum wait states required to support operation at given frequency and core voltage level. Flash instruction and data buffers are enabled (BUFI = BUFD = 1). Device executing the Dhrystone 2.1 program. Code execution from SRAM. Stack and data in SRAM. Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 31 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com 5.11 Current Consumption in DC-DC-Based Active Modes – Dhrystone 2.1 Program over recommended operating free-air temperature (unless otherwise noted) (1) EXECUTION MEMORY PARAMETER MCLK = 1 MHz MCLK = 8 MHz VCC TYP MAX (2) (3) (4) (5) MCLK = 16 MHz MCLK = 24 MHz MCLK = 32 MHz MCLK = 40 MHz MCLK = 48 MHz TYP MAX TYP MAX TYP MAX 3290 3700 4020 4500 4720 5300 2200 2480 2670 3000 3050 3420 TYP MAX TYP MAX TYP MAX IAM_DCDC_VCORE0,Flash (6) (7) (8) Flash 3.0 V 400 475 925 1050 1530 1720 2060 2300 IAM_DCDC_VCORE1,Flash (6) (7) (8) Flash 3.0 V 430 550 1100 1280 1880 2140 2650 3000 IAM_DCDC_VCORE0,SRAM (9) SRAM 3.0 V 370 450 680 780 1040 1180 1410 1600 IAM_DCDC_VCORE1,SRAM (9) SRAM 3.0 V 390 510 790 940 1250 1440 1720 1960 (1) (2) (3) (4) (5) (6) (7) (8) (9) UNIT µA µA µA µA MCLK sourced by DCO. Current measured into VCC. All other input pins tied to 0 V or VCC. Outputs do not source or sync any current. All SRAM banks are active. All peripherals are inactive. Device executing the Dhrystone 2.1 program. Code execution from flash. Stack and data in SRAM. Flash configured to minimum wait states required to support operation at given frequency and core voltage level. Flash instruction and data buffers are enabled (BUFI = BUFD = 1). Device executing the Dhrystone 2.1 program. Code execution from SRAM. Stack and data in SRAM. 5.12 Current Consumption in Low-Frequency Active Modes – Dhrystone 2.1 Program over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) (1) PARAMETER IAM_LF_VCORE0, Flash IAM_LF_VCORE1, Flash IAM_LF_VCORE0, SRAM IAM_LF_VCORE1, SRAM (1) (2) (3) (4) (5) (6) (7) (8) (9) 32 (6) (7) (8) (6) (7) (8) (9) (9) EXECUTION MEMORY Flash Flash SRAM SRAM VCC –40°C TYP MAX 25°C TYP 2.2 V 75 80 3.0 V 78 83 2.2 V 78 85 3.0 V 81 88 2.2 V 68 73 3.0 V 71 76 2.2 V 70 77 3.0 V 73 90 60°C MAX TYP (2) (3) (4) (5) 85°C MAX TYP 95 115 98 118 105 125 108 128 90 105 92 93 108 98 117 102 101 120 100 110 MAX 200 245 190 235 UNIT μA μA μA μA Current measured into VCC. All other input pins tied to 0 V or VCC. Outputs do not source or sync any current. MCLK, HSMCLK, and SMCLK sourced by REFO at 128 kHz All peripherals are inactive. SRAM banks 0 and 1 enabled for execution from flash, and SRAM banks 0 to 3 enabled for execution from SRAM. Flash configured to 0 wait states. Device executing the Dhrystone 2.1 program. Code execution from flash. Stack and data in SRAM. Flash instruction and data buffers are enabled (BUFI = BUFD = 1). Device executing the Dhrystone 2.1 program. Code execution from SRAM. Stack and data in SRAM. Specifications Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 5.13 Typical Characteristics of Active Mode Currents for CoreMark Program 8 8 AM_LDO_VCORE0 AM_LDO_VCORE1 7 6 Current (mA) Current (mA) 6 5 4 3 5 4 3 2 2 1 1 0 0 1 8 15 22 29 Frequency (MHz) Flash Execution 36 43 1 50 8 15 D030 VCC = 3 V TA = 25°C 22 29 Frequency (MHz) SRAM Execution Figure 5-1. Frequency vs Current Consumption 36 43 50 D031 VCC = 3 V TA = 25°C Figure 5-2. Frequency vs Current Consumption 8 8 AM_DCDC_VCORE0 AM_DCDC_VCORE1 7 AM_DCDC_VCORE0 AM_DCDC_VCORE1 7 6 Current (mA) 6 Current (mA) AM_LDO_VCORE0 AM_LDO_VCORE1 7 5 4 3 5 4 3 2 2 1 1 0 0 1 8 Flash Execution 15 22 29 Frequency (MHz) 36 VCC = 3 V 43 50 1 8 15 D032 TA = 25°C Figure 5-3. Frequency vs Current Consumption SRAM Execution 22 29 Frequency (MHz) VCC = 3 V 36 43 50 D033 TA = 25°C Figure 5-4. Frequency vs Current Consumption Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 33 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com 5.14 Typical Characteristics of Active Mode Currents for Prime Number Program 8 8 AM_LDO_VCORE0 AM_LDO_VCORE1 7 6 Current (mA) Current (mA) 6 5 4 3 5 4 3 2 2 1 1 0 0 1 8 15 22 29 Frequency (MHz) Flash Execution 36 43 50 1 VCC = 3 V TA = 25°C 15 22 29 Frequency (MHz) SRAM Execution 36 43 50 D035 VCC = 3 V TA = 25°C Figure 5-6. Frequency vs Current Consumption 8 8 AM_DCDC_VCORE0 AM_DCDC_VCORE1 7 AM_DCDC_VCORE0 AM_DCDC_VCORE1 7 6 Current (mA) 6 Current (mA) 8 D034 Figure 5-5. Frequency vs Current Consumption 5 4 3 5 4 3 2 2 1 1 0 0 1 8 Flash Execution 15 22 29 Frequency (MHz) VCC = 3 V 36 43 50 Specifications 1 8 15 D036 TA = 25°C Figure 5-7. Frequency vs Current Consumption 34 AM_LDO_VCORE0 AM_LDO_VCORE1 7 SRAM Execution 22 29 Frequency (MHz) VCC = 3 V 36 43 50 D037 TA = 25°C Figure 5-8. Frequency vs Current Consumption Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 5.15 Typical Characteristics of Active Mode Currents for Fibonacci Program 8 8 AM_LDO_VCORE0 AM_LDO_VCORE1 7 6 Current (mA) Current (mA) 6 5 4 3 5 4 3 2 2 1 1 0 0 1 8 15 22 29 Frequency (MHz) Flash Execution 36 43 50 1 8 15 D038 VCC = 3 V TA = 25°C 22 29 Frequency (MHz) SRAM Execution Figure 5-9. Frequency vs Current Consumption 36 43 50 D039 VCC = 3 V TA = 25°C Figure 5-10. Frequency vs Current Consumption 8 8 AM_DCDC_VCORE0 AM_DCDC_VCORE1 7 AM_DCDC_VCORE0 AM_DCDC_VCORE1 7 6 Current (mA) 6 Current (mA) AM_LDO_VCORE0 AM_LDO_VCORE1 7 5 4 3 5 4 3 2 2 1 1 0 0 1 8 Flash Execution 15 22 29 Frequency (MHz) 36 VCC = 3 V 43 50 1 8 15 D040 TA = 25°C Figure 5-11. Frequency vs Current Consumption SRAM Execution 22 29 Frequency (MHz) VCC = 3 V 36 43 50 D041 TA = 25°C Figure 5-12. Frequency vs Current Consumption Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 35 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com 5.16 Typical Characteristics of Active Mode Currents for While(1) Program 8 8 AM_LDO_VCORE0 AM_LDO_VCORE1 7 6 Current (mA) Current (mA) 6 5 4 3 5 4 3 2 2 1 1 0 0 1 8 15 22 29 Frequency (MHz) Flash Execution 36 43 1 50 VCC = 3 V TA = 25°C 15 22 29 Frequency (MHz) SRAM Execution 36 43 50 D043 VCC = 3 V TA = 25°C Figure 5-14. Frequency vs Current Consumption 8 8 AM_DCDC_VCORE0 AM_DCDC_VCORE1 7 AM_DCDC_VCORE0 AM_DCDC_VCORE1 7 6 Current (mA) 6 Current (mA) 8 D042 Figure 5-13. Frequency vs Current Consumption 5 4 3 5 4 3 2 2 1 1 0 0 1 8 Flash Execution 15 22 29 Frequency (MHz) VCC = 3 V 36 43 50 Specifications 1 8 15 D044 TA = 25°C Figure 5-15. Frequency vs Current Consumption 36 AM_LDO_VCORE0 AM_LDO_VCORE1 7 SRAM Execution 22 29 Frequency (MHz) VCC = 3 V 36 43 50 D045 TA = 25°C Figure 5-16. Frequency vs Current Consumption Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 5.17 Typical Characteristics of Low-Frequency Active Mode Currents for CoreMark Program 100 100 AM_LF_VCORE0 AM_LF_VCORE1 AM_LF_VCORE0 AM_LF_VCORE1 96 Current (µA) Current (µA) 96 92 88 84 80 2.2 92 88 84 2.3 Flash Execution 2.4 2.5 2.6 2.7 Supply Voltage (V) 2.8 TA = 25°C 2.9 3 80 2.2 2.3 2.4 D046 MCLK = 128 kHz Figure 5-17. Supply Voltage vs Current Consumption SRAM Execution 2.5 2.6 2.7 Supply Voltage (V) TA = 25°C 2.8 2.9 3 D046 MCLK = 128 kHz Figure 5-18. Supply Voltage vs Current Consumption Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 37 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com 5.18 Current Consumption in LDO-Based LPM0 Modes over recommended operating free-air temperature (unless otherwise noted) (1) PARAMETER ILPM0_LDO_VCORE0 ILPM0_LDO_VCORE1 (1) (2) (3) (4) (5) (6) VCC MCLK = 1 MHz MCLK = 8 MHz MCLK = 16 MHz (2) (3) (4) (5) (6) MCLK = 24 MHz MCLK = 32 MHz TYP MAX MCLK = 40 MHz TYP MCLK = 48 MHz TYP MAX TYP MAX TYP MAX TYP MAX MAX TYP 2.2 V 355 485 465 605 590 735 710 860 3.0 V 355 485 465 605 590 735 710 860 2.2 V 365 530 495 665 640 820 775 970 965 1160 1130 1330 1235 1450 3.0 V 365 530 495 665 640 820 775 970 965 1160 1130 1330 1230 1450 UNIT MAX µA µA MCLK sourced by DCO. Current measured into VCC. All other input pins tied to 0 V or VCC. Outputs do not source or sync any current. CPU is off. Flash and SRAM not accessed. All SRAM banks are active. All peripherals are inactive. 5.19 Current Consumption in DC-DC-Based LPM0 Modes over recommended operating free-air temperature (unless otherwise noted) (1) PARAMETER ILPM0_DCDC_VCORE0 ILPM0_DCDC_VCORE1 (1) (2) (3) (4) (5) (6) VCC MCLK = 1 MHz MCLK = 8 MHz MCLK = 16 MHz (2) (3) (4) (5) (6) MCLK = 24 MHz MCLK = 32 MHz TYP MAX MCLK = 40 MHz TYP MCLK = 48 MHz TYP MAX TYP MAX TYP MAX TYP MAX MAX TYP 2.2 V 330 425 400 510 485 600 570 690 3.0 V 325 400 380 460 440 530 510 610 2.2 V 350 485 445 590 555 710 660 820 810 970 935 1110 1020 1200 3.0 V 345 450 420 530 500 620 585 720 700 830 800 940 870 1020 UNIT MAX µA µA MCLK sourced by DCO. Current measured into VCC. All other input pins tied to 0 V or VCC. Outputs do not source or sync any current. CPU is off. Flash and SRAM not accessed. All SRAM banks are active. All peripherals are inactive. 5.20 Current Consumption in Low-Frequency LPM0 Modes over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) (1) PARAMETER ILPM0_LF_VCORE0 ILPM0_LF_VCORE1 (1) (2) (3) (4) (5) (6) 38 VCC –40°C TYP 25°C MAX TYP 2.2 V 58 63 3.0 V 61 66 2.2 V 60 66 3.0 V 63 69 60°C MAX TYP 82 90 (2) (3) (4) (5) (6) 85°C MAX TYP 78 94 81 97 84 104 87 107 MAX 180 220 UNIT μA μA Current measured into VCC. All other input pins tied to 0 V or VCC. Outputs do not source or sync any current. MCLK, HSMCLK, and SMCLK sourced by REFO at 128 kHz. All peripherals are inactive. Bank 0 of SRAM kept active. Rest of the banks are powered down. CPU is off. Flash and SRAM not accessed. Specifications Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 5.21 Current Consumption in LPM3, LPM4 Modes over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) (1) PARAMETER ILPM3_VCORE0_RTCLF (7) (8) ILPM3_VCORE0_RTCREFO ILPM3_VCORE1_RTCLF ILPM4_VCORE0 (10) ILPM4_VCORE1 (10) (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (9) (8) (7) (8) ILPM3_VCORE1_RTCREFO –40°C VCC (9) (8) TYP 25°C MAX TYP 2.2 V 0.52 0.64 3.0 V 0.54 0.66 2.2 V 0.85 1.07 3.0 V 0.95 1.16 2.2 V 0.72 0.93 3.0 V 0.75 0.95 2.2 V 1.04 1.3 3.0 V 1.14 1.4 2.2 V 0.37 0.48 3.0 V 0.4 0.5 2.2 V 0.54 0.7 3.0 V 0.56 0.72 60°C MAX TYP 85°C MAX TYP 1.11 2.43 1.13 2.46 1.55 2.89 1.64 2.98 1.47 2.95 1.5 2.98 1.87 3.34 1.96 3.44 0.92 2.19 0.65 0.94 2.2 1.2 2.58 0.98 1.23 2.6 0.85 1.35 1.35 1.7 (2) (3) (4) (5) (6) MAX 5 5.6 6 6.5 4.8 5.6 UNIT μA μA μA μA μA μA Current measured into VCC. All other input pins tied to 0 V or VCC. Outputs do not source or sync any current. CPU is off, and flash is powered down. Bank 0 of SRAM retained, all other banks are powered down. See Table 5-47 for details on additional current consumed for each extra Bank that is enabled for retention. SVSMH is disabled. RTC sourced by LFXT. Effective load capacitance of LF crystal is 3.7 pF. WDT module is disabled. RTC sourced by REFO. RTC and WDT modules disabled. 5.22 Current Consumption in LPM3.5, LPM4.5 Modes over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) (1) PARAMETER ILPM3.5_RTCLF (3) (4) (5) (6) (7) ILPM3.5_RTCREFO ILPM4.5 (1) (2) (3) (4) (5) (6) (7) (8) (9) (9) (7) (3) (4) (8) (6) (7) –40°C VCC TYP 25°C MAX TYP 2.2 V 0.48 0.6 3.0 V 0.5 0.63 2.2 V 0.82 1.03 3.0 V 0.92 1.12 2.2 V 10 20 3.0 V 15 25 60°C MAX 0.81 1.3 35 TYP (2) 85°C MAX TYP 1.07 2.36 1.1 2.38 1.52 2.81 1.61 2.9 45 125 50 150 MAX 4.9 5.5 300 UNIT μA μA nA Current measured into VCC. All other input pins tied to 0 V or VCC. Outputs do not source or sync any current. CPU and flash are powered down. Bank 0 of SRAM retained, all other banks powered down. RTC sourced by LFXT. Effective load capacitance of LF crystal is 3.7 pF. WDT module is disabled. SVSMH is disabled. RTC sourced by REFO. No core voltage. CPU, flash, and all banks of SRAM are powered down. Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 39 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com 5.23 Current Consumption of Digital Peripherals over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) (1) PARAMETER TEST CONDITIONS TYP MAX UNIT ITIMER_A Timer_A configured as PWM timer with 50% duty cycle 5 µA/MHz ITIMER32 Timer32 enabled 3.5 µA/MHz IUART eUSCI_A configured in UART mode 6.5 µA/MHz ISPI eUSCI_A configured in SPI master mode 5 µA/MHz 2 II2C eUSCI_B configured in I C master mode 5 µA/MHz IWDT_A WDT_A configured in interval timer mode 6 µA/MHz IRTC_C RTC_C enabled and sourced from 32-kHz LFXT IAES256 ICRC32 (1) 100 nA AES256 active 19 µA/MHz CRC32 active 2 µA/MHz Measured with VCORE = 1.2 V 5.24 Thermal Resistance Characteristics THERMAL METRICS (1) PACKAGE (3) VALUE (2) UNIT RθJA Junction-to-ambient thermal resistance, still air 50.9 °C/W RθJC(TOP) Junction-to-case (top) thermal resistance (4) 9.7 °C/W RθJB Junction-to-board thermal resistance (5) 27.2 °C/W ΨJB Junction-to-board thermal characterization parameter 26.9 °C/W ΨJT Junction-to-top thermal characterization parameter 0.2 °C/W RθJC(BOTTOM) Junction-to-case (bottom) thermal resistance (6) N/A °C/W RθJA Junction-to-ambient thermal resistance, still air (3) 58.1 °C/W 26.1 °C/W 22.6 °C/W 22.0 °C/W LQFP-100 (PZ) (4) RθJC(TOP) Junction-to-case (top) thermal resistance RθJB Junction-to-board thermal resistance (5) ΨJB Junction-to-board thermal characterization parameter ΨJT Junction-to-top thermal characterization parameter 0.5 °C/W RθJC(BOTTOM) Junction-to-case (bottom) thermal resistance (6) N/A °C/W RθJA Junction-to-ambient thermal resistance, still air (3) 29.4 °C/W RθJC(TOP) Junction-to-case (top) thermal resistance (4) 14.8 °C/W 8.3 °C/W 8.2 °C/W 0.2 °C/W 1.0 °C/W (5) RθJB Junction-to-board thermal resistance ΨJB Junction-to-board thermal characterization parameter ΨJT Junction-to-top thermal characterization parameter RθJC(BOTTOM) (1) (2) (3) (4) (5) (6) 40 NFBGA-80 (ZXH) Junction-to-case (bottom) thermal resistance VQFN-64 (RGC) (6) For more information about traditional and new thermal metrics, see Semiconductor and IC Package Thermal Metrics. N/A = not applicable The junction-to-ambient thermal resistance under natural convection is obtained in a simulation on a JEDEC-standard, High-K board, as specified in JESD51-7, in an environment described in JESD51-2a. The junction-to-case (top) thermal resistance is obtained by simulating a cold plate test on the package top. No specific JEDECstandard test exists, but a close description can be found in the ANSI SEMI standard G30-88. The junction-to-board thermal resistance is obtained by simulating in an environment with a ring cold plate fixture to control the PCB temperature, as described in JESD51-8. The junction-to-case (bottom) thermal resistance is obtained by simulating a cold plate test on the exposed (power) pad. No specific JEDEC standard test exists, but a close description can be found in the ANSI SEMI standard G30-88. Specifications Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 5.25 Timing and Switching Characteristics 5.25.1 Reset Timing Table 5-1 lists the latencies to recover from different types of resets. Table 5-1. Reset Recovery Latencies over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER MIN TYP (1) MAX UNIT 5 MCLK cycles Latency from release of hard reset to release of soft reset 25 MCLK cycles tPOR Latency from release of device POR to release of hard reset 15 25 µs tCOLDPWR,100 nF Latency from a cold power-up condition to release of device POR, CVCORE = 100 nF 300 400 µs tCOLDPWR,4.7 µF Latency from a cold power-up condition to release of device POR, CVCORE = 4.7 µF 400 500 µs tSOFT Latency from release of soft reset to first CPU instruction fetch tHARD (1) See Section 6.8.1 for details on the various classes of resets on the device Table 5-2 lists the latencies to recover from an external reset applied on RSTn pin. Table 5-2. External Reset Recovery Latencies (1) over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER TEST CONDITIONS tAM_RSTn External reset applied when device is in LDO or DC-DC based active modes, MCLK = 1 to 48 MHz tAMLF_RSTn, 128 kHz MIN MAX UNIT 5 ms External reset applied when device is in low-frequency active modes, MCLK = 128 kHz 5.5 ms tAMLF_RSTn, 32 kHz External reset applied when device is in low-frequency active modes, MCLK = 32.768 kHz 6.5 ms tLPM0_RSTn External reset applied when device is in LDO or DC-DC based LPM0 modes, MCLK = 1 to 48 MHz 5 ms tLPM0LF_RSTn, 128 kHz External reset applied when device is in low-frequency LPM0 modes, MCLK = 128 kHz 5.5 ms tLPM0LF_RSTn, 32 kHz External reset applied when device is in low-frequency LPM0 modes, MCLK = 32.768 kHz 6.5 ms tLPM3_LPM4_RSTn External reset applied when device is in LPM3 or LPM4 modes, MCLK = 24 or 48 MHz while entering LPM3 or LPM4 modes 5 ms tLPMx.5_RSTn External reset applied when device is in LPM3.5 or LPM4.5 modes 5 ms (1) External reset is applied on RSTn pin, and the latency is measured from release of external reset to start of user application code. Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 41 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com 5.25.2 Mode Transition Timing Table 5-3 lists the latencies required to change between different active modes. Table 5-3. Active Mode Transition Latencies over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) ORIGINAL OPERATING MODE FINAL OPERATING MODE TEST CONDITIONS Power Off AM_LDO_VCORE0 From VCC reaching 1.71 V to start of user application code tAMLDO0_AMLDO1 AM_LDO_VCORE0 AM_LDO_VCORE1 Transition from AM_LDO_VCORE0 to AM_LDO_VCORE1 MCLK frequency = 24 MHz tAMLDO1_AMLDO0 AM_LDO_VCORE1 AM_LDO_VCORE0 tAMLDO0_AMDCDC0 AM_LDO_VCORE0 PARAMETER tOFF_AMLDO0 TYP MAX UNIT 6 ms 300 350 µs Transition from AM_LDO_VCORE1 to AM_LDO_VCORE0 MCLK frequency = 24 MHz 4 5 µs Transition from AM_LDO_VCORE0 AM_DCDC_VCORE0 to AM_DCDC_VCORE0 MCLK frequency = 24 MHz 20 30 µs 10 15 µs 20 30 µs Transition from AM_DCDC_VCORE1 to AM_LDO_VCORE1 MCLK frequency = 48 MHz 10 15 µs tAMDCDC0_AMLDO0 AM_DCDC_VCORE0 tAMLDO1_AMDCDC1 AM_LDO_VCORE1 tAMDCDC1_AMLDO1 AM_DCDC_VCORE1 AM_LDO_VCORE1 AM_LDO_VCORE0 AM_LF_VCORE0 Transition from AM_LDO_VCORE0 to AM_LF_VCORE0 SELM = 2, REFO frequency = 128 kHz 90 100 µs AM_LDO_VCORE0 Transition from AM_LF_VCORE0 to AM_LDO_VCORE0 SELM = 2, REFO frequency = 128 kHz 50 60 µs AM_LF_VCORE1 Transition from AM_LDO_VCORE1 to AM_LF_VCORE1 SELM = 2, REFO frequency = 128 kHz 90 100 µs AM_LDO_VCORE1 Transition from AM_LF_VCORE1 to AM_LDO_VCORE1 SELM = 2, REFO frequency = 128 kHz 50 60 µs tAMLDO0_AMLF0 tAMLF0_AMLDO0 tAMLDO1_AMLF1 tAMLF1_AMLDO1 42 Specifications AM_LF_VCORE0 AM_LDO_VCORE1 AM_LF_VCORE1 AM_LDO_VCORE0 Transition from AM_DCDC_VCORE0 to AM_LDO_VCORE0 MCLK frequency = 24 MHz Transition from AM_LDO_VCORE1 AM_DCDC_VCORE1 to AM_DCDC_VCORE1 MCLK frequency = 48 MHz Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 Table 5-4 lists the latencies required to change between different active and LPM0 modes. Table 5-4. LPM0 Mode Transition Latencies over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER tAMLDOx_LPM0LDOx (1) tLPM0LDOx_AMLDOx (2) tAMDCDCx_LPM0DCDCx (1) tLPM0DCDCx_AMDCDCx (2) tAMLFx_LPM0LFx (1) tLPM0LFx_AMLFx (2) (1) (2) ORIGINAL OPERATING MODE AM_LDO_VCOREx LPM0_LDO_VCOREx AM_DCDC_VCOREx LPM0_DCDC_VCOREx AM_LF_VCOREx LPM0_LF_VCOREx FINAL OPERATING MODE TEST CONDITIONS TYP LPM0_LDO_VCOREx Transition from AM_LDO_VCORE0 or AM_LDO_VCORE1 to LPM0_LDO_VCORE0 or LPM0_LDO_VCORE1 1 AM_LDO_VCOREx Transition from LPM0_LDO_VCORE0 or LPM0_LDO_VCORE1 to AM_LDO_VCORE0 or AM_LDO_VCORE1 through I/O interrupt 3 LPM0_DCDC_VCOREx Transition from AM_DCDC_VCORE0 or AM_DCDC_VCORE1 to LPM0_DCDC_VCORE0 or LPM0_DCDC_VCORE1 1 AM_DCDC_VCOREx Transition from LPM0_DCDC_VCORE0 or LPM0_DCDC_VCORE1 to AM_DCDC_VCORE0 or AM_DCDC_VCORE1 through I/O interrupt 3 Transition from AM_LF_VCORE0 or AM_LF_VCORE1 to LPM0_LF_VCORE0 or LPM0_LF_VCORE1 1 Transition from LPM0_LF_VCORE0 or LPM0_LF_VCORE1 to AM_LF_VCORE0 or AM_LF_VCORE1 through I/O interrupt 3 LPM0_LF_VCOREx AM_LF_VCOREx MAX UNIT MCLK cycles 4 MCLK cycles MCLK cycles 4 MCLK cycles MCLK cycles 4 MCLK cycles This is the latency between execution of WFI instruction by CPU to assertion of SLEEPING signal at CPU output. This is the latency between I/O interrupt event to deassertion of SLEEPING signal at CPU output. Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 43 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Table 5-5 lists the latencies required to change between different active modes and LPM3 or LPM4 modes. Table 5-5. LPM3, LPM4 Mode Transition Latencies over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) ORIGINAL OPERATING MODE PARAMETER tAMLDO0_LPMx0 (1) tLPMx0_AMLDO0_NORIO (2) tLPMx0_AMLDO0_GFLTIO tAMLDO1_LPMx1 (1) tLPMx1_AMLDO1_NORIO tLPMx1_AMLDO1_GFLTIO tAMLFx_LPMx_128k tAMLFx_LPMx_32k (2) (1) (1) tLPMx_AMLFx_NORIO_128k tLPMx_AMLFx_NORIO_32k (1) (2) 44 (2) (2) TYP MAX UNIT SELM = 3. DCO frequency = 24 MHz 22 24 µs AM_LDO_VCORE0 Transition from LPM3 or LPM4 at VCORE0 to AM_LDO_VCORE0 through wake-up event from nonglitch filter type I/O SELM = 3. DCO frequency = 24 MHz 8 9 µs AM_LDO_VCORE0 Transition from LPM3 or LPM4 at VCORE0 to AM_LDO_VCORE0 through wake-up event from glitch filter type I/O, GLTFLT_EN = 1 SELM = 3. DCO frequency = 24 MHz 9 10 µs Transition from LPM3_LPM4_VCORE1 AM_LDO_VCORE1 to LPM3 or LPM4 at VCORE1 SELM = 3. DCO frequency = 48 MHz 21 23 µs AM_LDO_VCORE1 Transition from LPM3 or LPM4 at VCORE1 to AM_LDO_VCORE1 through wake-up event from nonglitch filter type I/O SELM = 3. DCO frequency = 48 MHz 7.5 8 µs LPM3_LPM4_VCORE1 AM_LDO_VCORE1 Transition from LPM3 or LPM4 at VCORE1 to AM_LDO_VCORE1 through wake-up event from glitch filter type I/O, GLTFLT_EN = 1 SELM = 3. DCO frequency = 48 MHz 8 9 µs AM_LF_VCOREx LPM3_LPM4_VCOREx Transition from AM_LF_VCORE0 or AM_LF_VCORE1 to LPM3 or LPM4 at VCORE0/1 SELM = 2. REFO frequency = 128 kHz 240 260 µs AM_LF_VCOREx LPM3_LPM4_VCOREx Transition from AM_LF_VCORE0 or AM_LF_VCORE1 to LPM3 or LPM4 at VCORE0/1 SELM = 0. LFXT frequency = 32.768 kHz 880 900 µs AM_LF_VCOREx Transition from LPM3 or LPM4 at VCORE0/1 to AM_LF_VCORE0 or AM_LF_VCORE1 through wake-up event from nonglitch filter type I/O SELM = 2. REFO frequency = 128 kHz 45 50 µs AM_LF_VCOREx Transition from LPM3 or LPM4 at VCORE0/1 to AM_LF_VCORE0 or AM_LF_VCORE1 through wake-up event from nonglitch filter type I/O SELM = 0. LFXT frequency = 32.768 kHz 150 170 µs LPM3_LPM4_VCORE0 LPM3_LPM4_VCORE0 AM_LDO_VCORE1 (2) TEST CONDITIONS Transition from LPM3_LPM4_VCORE0 AM_LDO_VCORE0 to LPM3 or LPM4 at VCORE0 AM_LDO_VCORE0 (2) FINAL OPERATING MODE LPM3_LPM4_VCORE1 LPM3_LPM4_VCOREx LPM3_LPM4_VCOREx This is the latency from WFI instruction execution by CPU to LPM3 or LPM4 entry. This is the latency from I/O wake-up event to MCLK clock start at device pin. Specifications Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 Table 5-6 lists the latencies required to change to and from LPM3.5 and LPM4.5 modes. Table 5-6. LPM3.5, LPM4.5 Mode Transition Latencies over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) ORIGINAL OPERATING MODE FINAL OPERATING MODE tAMLDOx_LPM3.5 (1) AM_LDO_VCOREx LPM3.5 tAMDCDCx_LPM3.5 (1) AM_DCDC_VCOREx PARAMETER TYP MAX Transition from AM_LDO_VCORE0 or AM_LDO_VCORE1 to LPM3.5 25 30 µs LPM3.5 Transition from AM_DCDC_VCORE0 or AM_DCDC_VCORE1 to LPM3.5 35 50 µs AM_LF_VCOREx LPM3.5 Transition from AM_LF_VCORE0 or AM_LF_VCORE1 to LPM3.5 225 250 µs tAMLDOx_LPM4.5 (2) AM_LDO_VCOREx LPM4.5 Transition from AM_LDO_VCORE0 or AM_LDO_VCORE1 to LPM4.5 25 30 µs tAMDCDCx_LPM4.5 (2) AM_DCDC_VCOREx LPM4.5 Transition from AM_DCDC_VCORE0 or AM_DCDC_VCORE1 to LPM4.5 35 50 µs AM_LF_VCOREx LPM4.5 Transition from AM_LF_VCORE0 or AM_LF_VCORE1 to LPM4.5 250 270 µs tLPM3.5_AMLDO0 (3) LPM3.5 AM_LDO_VCORE0 Transition from LPM3.5 to AM_LDO_VCORE0 0.7 0.8 ms tLPM4.5_AMLDO0_SVSMON, 100 nF (3) LPM4.5 AM_LDO_VCORE0 Transition from LPM4.5 to AM_LDO_VCORE0, SVSMH enabled while in LPM4.5, CVCORE = 100 nF 0.8 0.9 ms tLPM4.5_AMLDO0_SVSMON, 4.7 µF (3) LPM4.5 AM_LDO_VCORE0 Transition from LPM4.5 to AM_LDO_VCORE0, SVSMH enabled while in LPM4.5, CVCORE = 4.7 µF 0.9 1 ms tLPM4.5_AMLDO0_SVSMOFF, 100 nF (3) LPM4.5 AM_LDO_VCORE0 Transition from LPM4.5 to AM_LDO_VCORE0, SVSMH disabled while in LPM4.5, CVCORE = 100 nF 1 1.1 ms tLPM4.5_AMLDO0_SVSMOFF, 4.7 µF (3) LPM4.5 AM_LDO_VCORE0 Transition from LPM4.5 to AM_LDO_VCORE0, SVSMH disabled while in LPM4.5, CVCORE = 4.7 µF 1.1 1.2 ms tAMLFx_LPM3.5 (1) tAMLFx_LPM4.5 (2) (1) (2) (3) TEST CONDITIONS UNIT This is the latency from WFI instruction execution by CPU to LPM3.5 mode entry. This is the latency from WFI instruction execution by CPU to LPM4.5 mode entry. This is the latency from I/O wake-up event to start of user application code. Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 45 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com 5.25.3 Clock Specifications Table 5-7 lists the input requirement for the low-frequency crystal oscillator, LFXT. Table 5-7. Low-Frequency Crystal Oscillator, LFXT, Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) PARAMETER TEST CONDITIONS MIN TYP MAX 16 40 65 kΩ CLFXT Capacitance from LFXT input to ground and from LFXT output to ground (1) 7.4 12 24 pF CSHUNT Crystal shunt capacitance 0.6 0.8 1.6 pF Cm Crystal motional capacitance 1 2 10 fF ESR Crystal equivalent series resistance (1) fOSC = 32.768 kHz UNIT Does not include board parasitics. Package and board add additional capacitance to CLFXT. Table 5-8 lists the characteristics of the low-frequency crystal oscillator, LFXT. Table 5-8. Low-Frequency Crystal Oscillator, LFXT over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER IVCC,LFXT Current consumption TEST CONDITIONS (1) VCC MIN 100 fOSC = 32.768 kHz, LFXTBYPASS = 0, LFXTDRIVE = {1}, CL,eff = 6 pF, Typical ESR and CSHUNT 120 fOSC = 32.768 kHz, LFXTBYPASS = 0, LFXTDRIVE = {2}, CL,eff = 9 pF, Typical ESR and CSHUNT fLFXT LFXT oscillator crystal frequency LFXTBYPASS = 0 (2) DCLFXT LFXT oscillator duty cycle fLFXT = 32.768 kHz (2) fLFXT,SW LFXT oscillator logic-level square-wave input frequency LFXTBYPASS = 1 DCLFXT, LFXT oscillator logic-level square-wave input duty cycle LFXTBYPASS = 1 OALFXT (1) (2) (3) (4) (5) 46 Oscillation allowance for LF crystals (5) MAX 3.0 V UNIT nA 150 fOSC = 32.768 kHz, LFXTBYPASS = 0, LFXTDRIVE = {3}, CL,eff = 12 pF, Typical ESR and CSHUNT SW TYP fOSC = 32.768 kHz, LFXTBYPASS = 0, LFXTDRIVE = {0}, CL,eff = 3.7 pF, Typical ESR and CSHUNT 170 32.768 30% (3) (4) 10 kHz 70% 32.768 30% 50 kHz 70% LFXTBYPASS = 0, LFXTDRIVE = {1}, fLFXT = 32.768 kHz, CL,eff = 6 pF 200 240 LFXTBYPASS = 0, LFXTDRIVE = {3}, fLFXT = 32.768 kHz, CL,eff = 12 pF 300 340 kΩ Total current measured on both AVCC and DVCC supplies. Measured at ACLK pin. When LFXTBYPASS is set, LFXT circuits are automatically powered down. Input signal is a digital square wave with parametrics defined in the Schmitt-trigger Inputs section of this data sheet. Duty cycle requirements are defined by DCLFXT, SW. Maximum frequency of operation of the entire device cannot be exceeded. Oscillation allowance is based on a safety factor of 5 for recommended crystals. The oscillation allowance is a function of the LFXTDRIVE settings and the effective load. In general, comparable oscillator allowance can be achieved based on the following guidelines, but should be evaluated based on the actual crystal selected for the application: • For LFXTDRIVE = {0}, CL,eff = 3.7 pF. • For LFXTDRIVE = {1}, 6 pF ≤ CL,eff ≤ 9 pF. • For LFXTDRIVE = {2}, 6 pF ≤ CL,eff ≤ 10 pF. • For LFXTDRIVE = {3}, 6 pF ≤ CL,eff ≤ 12 pF. Specifications Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 Table 5-8. Low-Frequency Crystal Oscillator, LFXT (continued) over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER TEST CONDITIONS VCC MIN TYP MAX UNIT CLFXIN Integrated load capacitance at LFXIN terminal (6) (7) 2 pF CLFXOUT Integrated load capacitance at LFXOUT terminal (6) (7) 2 pF fOSC = 32.768 kHz, LFXTBYPASS = 0, LFXTDRIVE = {0}, CL,eff = 3.7 pF, Typical ESR and CSHUNT, FCNTLF_EN = 0 (2) tSTART,LFXT Start-up time (8) fFault,LFXT Oscillator fault frequency (9) fOSC = 32.768 kHz, LFXTBYPASS = 0, LFXTDRIVE = {3}, CL,eff = 12 pF, Typical ESR and CSHUNT, FCNTLF_EN = 0 (2) 1.1 3.0 V s 1.3 (10) 1 3 kHz (6) This represents all the parasitic capacitance present at the LFXIN and LFXOUT terminals, respectively, including parasitic bond and package capacitance. The effective load capacitance, CL,eff can be computed as CIN x COUT / (CIN + COUT), where CIN and COUT are the total capacitance at the LFXIN and LFXOUT terminals, respectively. (7) Requires external capacitors at both terminals to meet the effective load capacitance specified by crystal manufacturers. Recommended effective load capacitance values supported are 3.7 pF, 6 pF, 9 pF, and 12 pF. Maximum shunt capacitance of 1.6 pF. Because the PCB adds additional capacitance, it must also be considered in the overall capacitance. TI recommends verifying that the recommended effective load capacitance of the selected crystal is met. (8) Does not include programmable start-up counter. (9) Frequencies above the MAX specification do not set the fault flag. Frequencies in between the MIN and MAX specification may set the flag. A static condition or stuck at fault condition will set the fault flag. (10) Measured with logic-level input frequency but also applies to operation with crystals. Table 5-9 lists the input requirements for the high-frequency crystal oscillator, HFXT. Table 5-9. High-Frequency Crystal Oscillator, HFXT, Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) PARAMETER ESR TEST CONDITIONS Crystal equivalent series resistance TYP MAX fOSC = 1 MHz to ≤4 MHz MIN 75 150 UNIT fOSC = >4 MHz to ≤8 MHz 75 150 fOSC = >8 MHz to ≤16 MHz 40 80 fOSC = >16 MHz to ≤24 MHz 30 60 fOSC = >24 MHz to ≤32 MHz 20 40 fOSC = >32 MHz to ≤48 MHz 15 30 36 pF Ω CHFXT Capacitance from HFXT input to ground and from HFXT output to ground fOSC = 1 MHz to 48 MHz 28 32 CSHUNT Crystal shunt capacitance fOSC = 1 MHz to 48 MHz 1 3 7 pF Cm Crystal motional capacitance fOSC = 1 MHz to 48 MHz 3 7 30 fF Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 47 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Table 5-10 lists the characteristics of the high-frequency crystal oscillator, HFXT. Table 5-10. High-Frequency Crystal Oscillator, HFXT over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER IDVCC,HFXT TEST CONDITIONS HFXT oscillator crystal current HF mode at typical ESR HFXT oscillator crystal frequency, crystal mode fHFXT 60 fOSC = 8 MHz, HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 1, CL,eff = 16 pF, Typical ESR and CSHUNT 100 fOSC = 16 MHz, HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 2, CL,eff = 16 pF, Typical ESR and CSHUNT 180 fOSC = 40 MHz, HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 5, CL,eff = 16 pF, Typical ESR and CSHUNT 480 fOSC = 48 MHz, HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 6, CL,eff = 16 pF, Typical ESR and CSHUNT 550 HFXTBYPASS = 0, HFFREQ = 0 (1) 1 HFXTBYPASS = 0, HFFREQ = 1 (1) 4.01 8 HFXTBYPASS = 0, HFFREQ = 2 (1) 8.01 16 HFXTBYPASS = 0, HFFREQ = 3 (1) 16.01 24 HFXTBYPASS = 0, HFFREQ = 4 (1) 24.01 32 HFXTBYPASS = 0, HFFREQ = 5 (1) 32.01 40 HFXTBYPASS = 0, HFFREQ = 6 (1) 40.01 48 HFXTBYPASS = 1 (1) (2) 48 260 320 HFXT oscillator logic-level square-wave input frequency, bypass mode UNIT µA fOSC = 32 MHz, HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 4, CL,eff = 16 pF, Typical ESR and CSHUNT fHFXT,SW (1) (2) MAX 3.0 V fOSC = 24 MHz, HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 3, CL,eff = 16 pF, Typical ESR and CSHUNT Measured at MCLK or HSMCLK, fHFXT = 1 MHz to 48 MHz HFXT oscillator logic-level square-wave input duty cycle TYP fOSC = 4 MHz, HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 0, CL,eff = 16 pF, Typical ESR and CSHUNT HFXT oscillator duty cycle SW MIN 40 DCHFXT DCHFXT, VCC fOSC = 1 MHz, HFXTBYPASS = 0, HFXTDRIVE = 0, HFFREQ = 0, CL,eff = 16 pF, Typical ESR and CSHUNT 40% 4 50% MHz 60% 0.8 48 HFXTBYPASS = 1, External clock used as a direct source to MCLK or HSMCLK with no divider (DIVM = 0 or DIVHS = 0). 45% 55% HFXTBYPASS = 1, External clock used as a direct source to MCLK or HSMCLK with divider (DIVM > 0 or DIVHS > 0) or not used as a direct source to MCLK or HSMCLK. 40% 60% MHz Maximum frequency of operation of the entire device cannot be exceeded. When HFXTBYPASS is set, HFXT circuits are automatically powered down. Input signal is a digital square wave with parametrics defined in the Schmitt-trigger Inputs section of this data sheet. Duty cycle requirements are defined by DCHFXT, SW. Specifications Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 Table 5-10. High-Frequency Crystal Oscillator, HFXT (continued) over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER OAHFXT (3) Oscillation allowance for HFXT crystals (3) MIN TYP HFXTBYPASS = 0, HFXTDRIVE = 0, HFFREQ = 0, fHFXT,HF = 1 MHz, CL,eff = 16 pF TEST CONDITIONS VCC 1225 5000 HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 0, fHFXT,HF = 4 MHz, CL,eff = 16 pF 640 1250 HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 1, fHFXT,HF = 8 MHz, CL,eff = 16 pF 360 750 HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 2, fHFXT,HF = 16 MHz, CL,eff = 16 pF 200 425 HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 3, fHFXT,HF = 24 MHz, CL,eff = 16 pF 135 275 HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 4, fHFXT,HF = 32 MHz, CL,eff = 16 pF 110 225 HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 5 fHFXT,HF = 40 MHz, CL,eff = 16 pF 105 160 HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 6, fHFXT,HF = 48 MHz, CL,eff = 16 pF 80 140 MAX UNIT Ω Oscillation allowance is based on a safety factor of 5 for recommended crystals. Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 49 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Table 5-10. High-Frequency Crystal Oscillator, HFXT (continued) over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER tSTART,HFXT TEST CONDITIONS Start-up time (4) VCC MIN TYP fOSC = 1 MHz, HFXTBYPASS = 0, HFXTDRIVE = 0, HFFREQ = 0, CL,eff = 16 pF, Typical ESR and CSHUNT, FCNTHF_EN = 0 4 fOSC = 4 MHz, HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 0, CL,eff = 16 pF, Typical ESR and CSHUNT, FCNTHF_EN = 0 1.8 fOSC = 8 MHz, HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 1, CL,eff = 16 pF, Typical ESR and CSHUNT, FCNTHF_EN = 0 0.7 fOSC = 16 MHz, HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 2, CL,eff = 16 pF, Typical ESR and CSHUNT, FCNTHF_EN = 0 0.6 MAX UNIT ms 3.0 V fOSC = 24 MHz, HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 3, CL,eff = 16 pF, Typical ESR and CSHUNT, FCNTHF_EN = 0 450 fOSC = 32 MHz, HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 4, CL,eff = 16 pF, Typical ESR and CSHUNT, FCNTHF_EN = 0 300 fOSC = 40 MHz, HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 5, CL,eff = 16 pF, Typical ESR and CSHUNT, FCNTHF_EN = 0 250 fOSC = 48 MHz, HFXTBYPASS = 0, HFXTDRIVE = 1, HFFREQ = 6, CL,eff = 16 pF, Typical ESR and CSHUNT, FCNTHF_EN = 0 250 µs CHFXIN Integrated load capacitance at HFXIN terminal (5) (6) 2 pF CHFXOUT Integrated load capacitance at HFXOUT terminal (5) (6) 2 pF fFault,HFXT Oscillator fault frequency (7) (4) (5) (6) (7) (8) 50 (8) 400 700 kHz Does not include programable start-up counter. This represents all the parasitic capacitance present at the HFXIN and HFXOUT terminals, respectively, including parasitic bond and package capacitance. The effective load capacitance, CL,eff can be computed as CIN x COUT / (CIN + COUT), where CIN and COUT is the total capacitance at the HFXIN and HFXOUT terminals, respectively. Requires external capacitors at both terminals to meet the effective load capacitance specified by crystal manufacturers. Recommended effective load capacitance values supported are 14 pF, 16 pF, and 18 pF. Maximum shunt capacitance of 7 pF. Because the PCB adds additional capacitance, it must also be considered in the overall capacitance. TI recommends verifying that the recommended effective load capacitance of the selected crystal is met. Frequencies above the MAX specification do not set the fault flag. Frequencies in between the MIN and MAX might set the flag. A static condition or stuck at fault condition will set the flag. Measured with logic-level input frequency but also applies to operation with crystals. Specifications Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 Table 5-11 lists the characteristics of the DCO. Table 5-11. DCO over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER fRSEL0_CTR fRSEL1_CTR fRSEL2_CTR fRSEL3_CTR fRSEL4_CTR fRSEL5_CTR dfDCO/dT MIN TYP MAX DCO center frequency accuracy for range 0 with calibrated factory settings Internal resistor mode, DCORSEL = 0, DCOTUNE = 0 TEST CONDITIONS 1.443 1.5 1.557 External resistor mode, DCORSEL = 0, DCOTUNE = 0 1.482 1.5 1.518 DCO center frequency accuracy for range 1 with calibrated factory settings Internal resistor mode, DCORSEL = 1, DCOTUNE = 0 2.885 3 3.115 External resistor mode, DCORSEL = 1, DCOTUNE = 0 2.964 3 3.036 DCO center frequency accuracy for range 2 with calibrated factory settings Internal resistor mode, DCORSEL = 2, DCOTUNE = 0 5.77 6 6.23 External resistor mode, DCORSEL = 2, DCOTUNE = 0 5.928 6 6.072 DCO center frequency accuracy for range 3 with calibrated factory settings Internal resistor mode, DCORSEL = 3, DCOTUNE = 0 11.541 12 12.459 External resistor mode, DCORSEL = 3, DCOTUNE = 0 11.856 12 12.144 DCO center frequency accuracy for range 4 with calibrated factory settings Internal resistor mode, DCORSEL = 4, DCOTUNE = 0 23.082 24 24.918 External resistor mode, DCORSEL = 4, DCOTUNE = 0 23.712 24 24.288 DCO center frequency accuracy for range 5 with calibrated factory settings Internal resistor mode, DCORSEL = 5, DCOTUNE = 0 46.164 48 49.836 External resistor mode, DCORSEL = 5, DCOTUNE = 0 47.424 48 48.576 DCO frequency drift with temperature (1) VCC, TA UNIT MHz MHz MHz MHz MHz MHz Internal resistor mode, At fixed voltage 1.62 V to 3.7 V 250 External resistor mode (2) At fixed voltage 1.62 V to 3.7 V 40 –40°C to 85 °C 0.1 %/V ppm/°C dfDCO/dVCC DCO frequency voltage drift with voltage (3) At fixed temperature, applicable for both DCO Internal and External resistor modes fRSEL0 DCO frequency range 0 DCORSEL = 0 DCO internal or external resistor mode 3.0 V, 25℃ 0.98 2.26 MHz fRSEL1 DCO frequency range 1 DCORSEL = 1 DCO internal or external resistor mode 3.0 V, 25℃ 1.96 4.51 MHz fRSEL2 DCO frequency range 2 DCORSEL = 2 DCO internal or external resistor mode 3.0 V, 25℃ 3.92 9.02 MHz fRSEL3 DCO frequency range 3 DCORSEL = 3 DCO internal or external resistor mode 3.0 V, 25℃ 7.84 18.04 MHz fRSEL4 DCO frequency range 4 DCORSEL = 4 DCO internal or external resistor mode 3.0 V, 25℃ 15.68 36.07 MHz fRSEL5 DCO frequency range 5 DCORSEL = 5 DCO internal or external resistor mode 3.0 V, 25℃ 31.36 52 MHz fDCO_DC Duty cycle (1) (2) (3) 47% 50% 53% Calculated using the box method: (MAX(–40°C to 85°C) – MIN(–40°C to 85°C)) / MIN(–40°C to 85°C) / (85°C – (–40°C)) Does not include temperature coefficient of external resistor. Recommended value of external resistor at DCOR pin: 91 kΩ, 0.1%, ±25 ppm/℃. Calculated using the box method: (MAX(1.62 V to 3.7 V) – MIN(1.62 V to 3.7 V)) / MIN(1.62 V to 3.7 V) / (3.7 V – 1.62 V) Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 51 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Table 5-11. DCO (continued) over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER tDCO_JITTER TEST CONDITIONS DCO period jitter TYP MAX DCORSEL = 5, DCOTUNE = 0 VCC, TA MIN 50 90 DCORSEL = 4, DCOTUNE = 0 80 120 DCORSEL = 3, DCOTUNE = 0 115 170 DCORSEL = 2, DCOTUNE = 0 160 240 DCORSEL = 1, DCOTUNE = 0 225 340 450 550 DCORSEL = 0, DCOTUNE = 0 UNIT ps TDCO_STEP Step size Step size of the DCO. tDCO_SETTLE_RANGE DCO settling from worst case DCORSELn to DCORSELm DCO settled to within 1.5% of steady state frequency 10 µs tDCO_SETTLE_TUNE DCO settling worst case DCOTUNEn to DCOTUNEm within any DCORSEL setting DCO settled to within 1.5% of steady state frequency 10 µs tSTART DCO start-up time (4) DCO settled to within 0.5% of steady state frequency (4) 0.2% 5 µs The maximum parasitic capacitance at the DCO external resistance pin (DCOR) should not exceed 5 pF to ensure the specified DCO start-up time. Table 5-12 lists the overall tolerance of the DCO. Table 5-12. DCO Overall Tolerance over operating free-air temperature range (unless otherwise noted) RESISTOR OPTION Internal resistor External resistor with 25-ppm TCR 52 Specifications TEMPERATURE CHANGE TEMPERATURE DRIFT (%) VOLTAGE CHANGE VOLTAGE DRIFT (%) OVERALL DRIFT (%) OVERALL ACCURACY (%) –40°C to 85 °C ±3.125 1.62 V to 3.7 V ±0.2 ±3.325 ±3.825 0°C 0 1.62 V to 3.7 V ±0.2 ±0.2 ±0.7 –40°C to 85 °C ±3.125 0V 0 ±3.125 ±3.625 –40°C to 85 °C ±0.5 1.62 V to 3.7 V ±0.2 ±0.7 ±1.2 0°C 0 1.62 V to 3.7 V ±0.2 ±0.2 ±0.7 –40°C to 85 °C ±0.5 0V 0 ±0.5 ±1 Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 Table 5-13 lists the characteristics of the internal very-low-power low-frequency oscillator (VLO). Table 5-13. Internal Very-Low-Power Low-Frequency Oscillator (VLO) over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER TEST CONDITIONS IVLO Current consumption (1) fVLO VLO frequency dfVLO/dT VLO frequency temperature drift (2) dfVLO/dVCC VLO frequency supply voltage drift (3) DCVLO Duty cycle (1) (2) (3) MIN TYP MAX 50 6 nA 9.4 14 0.1 kHz %/°C 0.2 40% UNIT %/V 50% 60% Current measured on DVCC supply Calculated using the box method: (MAX(–40°C to 85°C) – MIN(–40°C to 85°C)) / MIN(–40°C to 85°C) / (85°C – (–40°C)) Calculated using the box method: (MAX(1.62 V to 3.7 V) – MIN(1.62 V to 3.7 V)) / MIN(1.62 V to 3.7 V) / (3.7 V – 1.62 V) Table 5-14 lists the characteristics of the internal-reference low-frequency oscillator (REFO) in 32.768‑kHz mode. Table 5-14. Internal-Reference Low-Frequency Oscillator (REFO) in 32.768-kHz Mode (1) over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER TEST CONDITIONS VCC MIN REFO frequency calibrated fREFO REFO absolute tolerance calibrated dfREFO/dT REFO frequency temperature drift (3) dfREFO/dVCC REFO frequency supply voltage drift (4) DCREFO REFO duty cycle (1) (2) (3) (4) TYP REFO current consumption (2) IREFO MAX µA 32.768 kHz TA = –40°C to 85°C TA = 25°C UNIT 0.6 ±3% 3V ±1.5% 0.012 %/°C 0.2 %/V 40% 50% 60% REFO is configured to 32.768-kHz mode with REFOFSEL = 0. Total current measured on both AVCC and DVCC supplies. Calculated using the box method: (MAX(–40°C to 85°C) – MIN(–40°C to 85°C)) / MIN(–40°C to 85°C) / (85°C – (–40°C)) Calculated using the box method: (MAX(1.62 V to 3.7 V) – MIN(1.62 V to 3.7 V)) / MIN(1.62 V to 3.7 V) / (3.7 V – 1.62 V) Table 5-15 lists the characteristics of the internal-reference low-frequency oscillator (REFO) in 128‑kHz mode. Table 5-15. Internal-Reference Low-Frequency Oscillator (REFO) in 128-kHz Mode (1) over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER REFO TEST CONDITIONS VCC MIN REFO current consumption (2) REFO absolute tolerance calibrated ±6% 3V ±1.5% (3) REFO frequency temperature drift dfREFO/dVCC REFO frequency supply voltage drift (4) DCREFO REFO duty cycle kHz TA = –40°C to 85°C TA = 25°C UNIT µA 128 dfREFO/dT (1) (2) (3) (4) MAX 1 REFO frequency calibrated fREFO TYP 0.018 %/°C 0.4 40% 50% %/V 60% REFO is configured to 128-kHz mode with REFOFSEL = 1. Total current measured on both AVCC and DVCC supplies. Calculated using the box method: (MAX(–40°C to 85°C) – MIN(–40°C to 85°C)) / MIN(–40°C to 85°C) / (85°C – (–40°C)) Calculated using the box method: (MAX(1.62 V to 3.7 V) – MIN(1.62 V to 3.7 V)) / MIN(1.62 V to 3.7 V) / (3.7 V – 1.62 V) Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 53 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Table 5-16 lists the characteristics of the module oscillator (MODOSC). Table 5-16. Module Oscillator (MODOSC) over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER TEST CONDITIONS IMODOSC Current consumption (1) fMODOSC MODOSC frequency dfMODOSC/dT MODOSC frequency temperature drift (2) dfMODOSC/dV CC MODOSC frequency supply voltage drift (3) DCMODOSC Duty cycle (1) (2) (3) VCC MIN TYP MAX 50 23 40% 25 UNIT µA 27 MHz 0.02 %/℃ 0.3 %/V 50% 60% Total current measured on both AVCC and DVCC supplies. Calculated using the box method: (MAX(–40°C to 85°C) – MIN(–40°C to 85°C)) / MIN(–40°C to 85°C) / (85°C – (–40°C)) Calculated using the box method: (MAX(1.62 V to 3.7 V) – MIN(1.62 V to 3.7 V)) / MIN(1.62 V to 3.7 V) / (3.7 V – 1.62 V) Table 5-17 lists the characteristics of the system oscillator (SYSOSC). Table 5-17. System Oscillator (SYSOSC) over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER TEST CONDITIONS ISYSOSC Current consumption (1) fSYSOSC SYSOSC frequency dfSYSOSC/ dT SYSOSC frequency temperature drift (2) dfSYSOSC/ dVCC SYSOSC frequency supply voltage drift (3) DCSYSOSC Duty cycle (1) (2) (3) 54 VCC MIN TYP MAX 30 4.25 40% 5.0 UNIT µA 5.75 MHz 0.03 %/℃ 0.5 %/V 50% 60% Current measured on AVCC supply. Calculated using the box method: (MAX(–40°C to 85°C) – MIN(–40°C to 85°C)) / MIN(–40°C to 85°C) / (85°C – (–40°C)) Calculated using the box method: (MAX(1.62 V to 3.7 V) – MIN(1.62 V to 3.7 V)) / MIN(1.62 V to 3.7 V) / (3.7 V – 1.62 V) Specifications Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 5.25.4 Power Supply System Table 5-18 lists the LDO VCORE regulator characteristics. Table 5-18. VCORE Regulator (LDO) Characteristics MIN TYP MAX UNIT VCORE0-HP Static VCORE voltage Level 0 in active and LPM0 modes PARAMETER Device power modes AM_LDO_VCORE0, LPM0_LDO_VCORE0 TEST CONDITIONS 1.12 1.2 1.28 V VCORE1-HP Static VCORE voltage Level 1 in active and LPM0 modes Device power modes AM_LDO_VCORE1, LPM0_LDO_VCORE1 1.31 1.4 1.49 V VCORE0-LF Static VCORE voltage Level 0 in low-frequency active and low Device power modes AM_LF_VCORE0 frequency LPM0 modes 1.12 1.2 1.28 V VCORE1-LF Static VCORE voltage Level 1 in low-frequency active and low Device power modes AM_LF_VCORE1 frequency LPM0 modes 1.31 1.4 1.49 V VCORE0-LPM34 Static VCORE voltage Level 0 in LPM3 and LPM4 modes Device power modes LPM3, LPM4 1.08 1.2 1.32 V VCORE1-LPM34 Static VCORE voltage Level 1 in LPM3 and LPM4 modes Device power modes LPM3, LPM4 1.27 1.4 1.53 V VCORE0-LPM35 Static VCORE voltage Level 0 in LPM3.5 mode Device power mode LPM3.5 1.08 1.2 1.32 V IINRUSH-ST Inrush current at start-up Device power-up 200 mA IPEAK-LDO Peak current drawn by LDO from DVCC 350 mA ISC-coreLDO Short circuit current limit for core LDO 300 mA Measured when output is shorted to ground Table 5-19 lists the DC-DC VCORE regulator characteristics. Table 5-19. VCORE Regulator (DC-DC) Characteristics PARAMETER DVCC-DCDC VDCDC_SO (1) TEST CONDITIONS MIN TYP MAX UNIT Allowed DVCC range for DC-DC operation DCDC_FORCE = 1 1.8 3.7 V DC-DC to LDO switch over voltage dDVCC/dt = 1 V/ms, DCDC_FORCE = 0 1.8 2.0 V VCORE0-DCDC Device power modes Static VCORE voltage Level 0 in AM_DCDC_VCORE0, DC-DC high-performance modes LPM0_DCDC_VCORE0 1.12 1.2 1.28 V VCORE1-DCDC Device power modes Static VCORE voltage Level 1 in AM_DCDC_VCORE1, DC-DC high-performance modes LPM0_DCDC_VCORE1 1.31 1.4 1.49 V IPEAK-DCDC Peak current drawn by DC-DC from DVCC 300 mA ISC-DCDC Short circuit current limit for DCDC 500 mA (1) Measured when output is shorted to ground When DVCC falls below this voltage, internally the regulator switches over to LDO from DC-DC. Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 55 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Table 5-20 lists the VCCDET characteristics. Table 5-20. PSS, VCCDET over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER MIN TYP MAX UNIT VVCC_VCCDET- VCCDET power-down level dDVCC/dt < 3 V/s (1) - trip point with falling VCC 0.64 1.12 1.55 V VVCC_VCCDET+ VCCDET power-up level trip point with rising VCC 0.70 1.18 1.59 V VVCC_VCC_hys VCCDET hysteresis 30 65 100 mV (1) TEST CONDITIONS dDVCC/dt < 3 V/s (1) The VCCDET levels are measured with a slow-changing supply. Faster slopes can result in different levels. Table 5-21 lists the SVSMH characteristics. Table 5-21. PSS, SVSMH over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER ISVSMH VSVSMH-,HP VSVSMH+,HP 56 TEST CONDITIONS SVSMH current consumption, low-power mode SVSMH current consumption, high-performance mode SVSMH threshold level during high-performance mode (falling DVCC) SVSMH threshold level; High Performance Mode [rising DVCC] Specifications MIN TYP MAX UNIT SVSMHOFF = 0, SVSMHLP = 1 200 400 nA SVSMHOFF = 0, SVSMHLP = 0 7 10 μA SVSMHOFF = 0, SVSMHLP = 0, SVSMHTH = 0, DC (dDVCC/dt < 1V/s) 1.59 1.64 1.71 SVSMHOFF = 0, SVSMHLP = 0, SVSMHTH = 1, DC (dDVCC/dt < 1V/s) 1.59 1.64 1.71 SVSMHOFF = 0, SVSMHLP = 0, SVSMHTH = 2, DC (dDVCC/dt < 1V/s) 1.59 1.64 1.71 SVSMHOFF = 0, SVSMHLP = 0, SVSMHTH = 3, DC (dDVCC/dt < 1V/s) 2.0 2.06 2.12 SVSMHOFF = 0, SVSMHLP = 0, SVSMHTH = 4, DC (dDVCC/dt < 1V/s) 2.2 2.26 2.32 SVSMHOFF = 0, SVSMHLP = 0, SVSMHTH = 5, DC (dDVCC/dt < 1V/s) 2.4 2.47 2.54 SVSMHOFF = 0, SVSMHLP = 0, SVSMHTH = 6, DC (dDVCC/dt < 1V/s) 2.7 2.79 2.88 SVSMHOFF = 0, SVSMHLP = 0, SVSMHTH = 7, DC (dDVCC/dt < 1V/s) 2.9 3.0 3.1 SVSMHOFF = 0, SVSMHLP = 0, SVSMHTH = 0, DC (dDVCC/dt < 1V/s) 1.6 1.66 1.71 SVSMHOFF = 0, SVSMHLP = 0, SVSMHTH = 1, DC (dDVCC/dt < 1V/s) 1.6 1.66 1.71 SVSMHOFF = 0, SVSMHLP = 0, SVSMHTH = 2, DC (dDVCC/dt < 1V/s) 1.6 1.66 1.71 SVSMHOFF = 0, SVSMHLP = 0, SVSMHTH = 3, DC (dDVCC/dt < 1V/s) 2.02 2.07 2.14 SVSMHOFF = 0, SVSMHLP = 0, SVSMHTH = 4, DC (dDVCC/dt < 1V/s) 2.22 2.27 2.34 SVSMHOFF = 0, SVSMHLP = 0, SVSMHTH = 5, DC (dDVCC/dt < 1V/s) 2.42 2.48 2.56 SVSMHOFF = 0, SVSMHLP = 0, SVSMHTH = 6, DC (dDVCC/dt < 1V/s) 2.72 2.8 2.9 SVSMHOFF = 0, SVSMHLP = 0, SVSMHTH = 7, DC (dDVCC/dt < 1V/s) 2.92 3.01 3.12 V V Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 Table 5-21. PSS, SVSMH (continued) over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER VSVSMH-,LP VSVSMH_hys tPD,SVSMH t(SVSMH) (1) TEST CONDITIONS SVSMH threshold level; Low Power Mode [falling DVCC] MIN TYP MAX SVSMHOFF = 0, SVSMHLP = 1, SVSMHTH = 0, DC (dDVCC/dt < 1V/s) 1.55 1.62 1.71 SVSMHOFF = 0, SVSMHLP = 1, SVSMHTH = 1, DC (dDVCC/dt < 1V/s) 1.55 1.62 1.71 SVSMHOFF = 0, SVSMHLP = 1, SVSMHTH = 2, DC (dDVCC/dt < 1V/s) 1.55 1.62 1.71 SVSMHOFF = 0, SVSMHLP = 1, SVSMHTH = 3, DC (dDVCC/dt < 1V/s) 2.0 2.09 2.18 SVSMHOFF = 0, SVSMHLP = 1, SVSMHTH = 4, DC (dDVCC/dt < 1V/s) 2.2 2.3 2.4 SVSMHOFF = 0, SVSMHLP = 1, SVSMHTH = 5, DC (dDVCC/dt < 1V/s) 2.4 2.51 2.62 SVSMHOFF = 0, SVSMHLP = 1, SVSMHTH = 6, DC (dDVCC/dt < 1V/s) 2.7 2.83 2.94 SVSMHOFF = 0, SVSMHLP = 1, SVSMHTH = 7, DC (dDVCC/dt < 1V/s) 2.87 3.0 3.13 15 30 SVSMH hysteresis UNIT V SVSH propagation delay, high-performance mode SVSMHOFF = 0, SVSMHLP = 0, very fast dVDVCC/dt 3 10 SVSH propagation delay, lowpower mode SVSMHOFF = 0, SVSMHLP = 1, very fast dVDVCC/dt 25 100 SVSMH on or off delay time SVSMHOFF = 1 → 0, SVSMHLP = 0 17 40 mV μs (1) μs If the SVSMH is kept disabled in active mode and is enabled before entering a low-power mode of the device (LPM3, LPM4, LPM3.5, or LPM4.5) care should be taken that sufficient time has elapsed since enabling of the module before entry into the device low-power mode to allow for successful wake up of the SVSMH module per the SVSMH on or off delay time specification. Otherwise, SVSMH may trip, causing the device to reset and wake up from the low-power mode. Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 57 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com 5.25.5 Digital I/Os Table 5-22 lists the characteristics of the digital inputs. Table 5-22. Digital Inputs (Applies to Both Normal and High-Drive I/Os) over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER TEST CONDITIONS VCC MIN 2.2 V 0.99 TYP MAX 1.65 3V 1.35 2.25 2.2 V 0.55 1.21 3V 0.75 1.65 2.2 V 0.32 0.84 3V 0.4 1.0 UNIT VIT+ Positive-going input threshold voltage VIT– Negative-going input threshold voltage Vhys Input voltage hysteresis (VIT+ – VIT–) RPull Pullup or pulldown resistor For pullup: VIN = VSS, For pulldown: VIN = VCC CI,dig Input capacitance, digital only port pins VIN = VSS or VCC 3 pF CI,ana Input capacitance, port pins shared with analog functions VIN = VSS or VCC 5 pF Ilkg,ndio Normal I/O high-impedance input leakage current See (1) (2) 2.2 V, 3 V ±20 nA Ilkg,hdio High-drive I/O high-impedance input leakage current See (1) (2) 2.2 V, 3 V ±20 nA tint tRST (1) (2) (3) (4) (5) 58 External interrupt timing (external trigger pulse duration to set interrupt flag) External reset pulse duration on RSTn pin (5) 20 Ports with interrupt capability and without glitch filter (3) 2.2 V, 3 V 20 Ports with interrupt capability and with glitch filter but glitch filter disabled (GLTFLT_EN = 0) (3) 2.2 V, 3 V 20 Ports with interrupt capability and with glitch filter, glitch filter enabled (GLTFTL_EN = 1) (4) 2.2 V, 3 V 0.25 2.2 V, 3 V 1 30 40 V V V kΩ ns 1 µs µs The input leakage current is measured with VSS or VCC applied to the corresponding pins, unless otherwise noted. The input leakage of the digital port pins is measured individually. The port pin is selected for input and the pullup/pulldown resistor is disabled. An external signal sets the interrupt flag every time the minimum interrupt pulse duration tint is met. It may be set by trigger signals shorter than tint. A trigger pulse duration less than the MIN value is always filtered, and a trigger pulse duration more than the MAX value is always passed. The trigger pulse may or may not be filtered if the duration is between the MIN and MAX values. Not applicable if RSTn/NMI pin configured as NMI. Specifications Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 Table 5-23 lists the characteristics of the normal-drive digital outputs. See Figure 5-19 through Figure 5-22 for the typical characteristics graphs. Table 5-23. Digital Outputs, Normal I/Os over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER TEST CONDITIONS VCC I(OHmax) = –1 mA (1) VOH 2.2 V I(OHmax) = –3 mA (2) High-level output voltage I(OHmax) = –2 mA (1) 3.0 V I(OHmax) = –6 mA (2) I(OLmax) = 1 mA (1) VOL 2.2 V I(OLmax) = 3 mA (2) Low-level output voltage I(OLmax) = 2 mA (1) 3.0 V I(OLmax) = 6 mA (2) Port output frequency (with RC load) (3) fPx.y dPx.y fPort_CLK dPort_CLK trise,dig tfall,dig trise,ana tfall,ana (1) (2) (3) (4) (5) (6) (7) VCORE = 1.4 V, CL = 20 pF, RL Port output duty cycle (with RC Load) VCORE = 1.4 V, CL = 20 pF, RL Clock output frequency (3) VCORE = 1.4 V, CL = 20 pF (5) Clock output duty cycle VCORE = 1.4 V, CL = 20 pF Port output rise time, digital only port pins Port output fall time, digital only port pins Port output rise time, port pins with shared analog functions Port output fall time, port pins with shared analog functions CL = 20 pF CL = 20 pF CL = 20 pF CL = 20 pF (6) (7) (6) (7) (5) (4) (5) (4) (5) MIN MAX VCC – 0.25 VCC VCC – 0.60 VCC VCC – 0.25 VCC VCC – 0.60 VCC VSS VSS + 0.25 VSS VSS + 0.60 VSS VSS + 0.25 VSS VSS + 0.60 1.62 V 24 2.2 V 24 3.0 V 24 1.62 V 40% 60% 2.2 V 40% 60% 3.0 V 45% 55% 1.62 V 24 2.2 V 24 3.0 V 24 1.62 V 40% 60% 2.2 V 40% 60% 3.0 V 45% 55% UNIT V V MHz MHz 1.62 V 8 2.2 V 5 3.0 V 3 1.62 V 8 2.2 V 5 3.0 V 3 1.62 V 8 2.2 V 5 3.0 V 3 1.62 V 8 2.2 V 5 3.0 V 3 ns ns ns ns The maximum total current, I(OHmax) and I(OLmax), for all outputs combined should not exceed ±48 mA to hold the maximum voltage drop specified. The maximum total current, I(OHmax) and I(OLmax), for all outputs combined should not exceed ±100 mA to hold the maximum voltage drop specified. The port can output frequencies at least up to the specified limit - it might support higher frequencies. A resistive divider with 2 × R1 and R1 = 3.2kΩ between VCC and VSS is used as load. The output is connected to the center tap of the divider. CL = 20 pF is connected to the output to VSS. The output voltage reaches at least 20% and 80% VCC at the specified toggle frequency. Measured between 20% of VCC to 80% of VCC. Measured between 80% of VCC to 20% of VCC. Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 59 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com Table 5-24 lists the characteristics of the high-drive digital outputs. See Figure 5-23 through Figure 5-26 for the typical characteristics graphs. Table 5-24. Digital Outputs, High-Drive I/Os over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER TEST CONDITIONS VCC I(OHmax) = –5 mA (1) VOH 2.2 V I(OHmax) = –15 mA (2) High-level output voltage I(OHmax) = –10 mA (1) 3.0 V I(OHmax) = –20 mA (2) I(OLmax) = 5 mA (1) VOL 2.2 V I(OLmax) = 15 mA (2) Low-level output voltage I(OLmax) = 10 mA (1) 3.0 V I(OLmax) = 20 mA (2) Port output frequency (with RC load) (3) fPx.y Port output duty cycle (with RC Load) dPx.y fPort_CLK dPort_CLK trise (2) (3) (4) (5) (6) (7) Clock output duty cycle Port output rise time tfall (1) Clock output frequency (3) Port output fall time VCORE = 1.4 V, CL = 80 pF, RL VCORE = 1.4 V, CL = 80 pF, RL (4) (5) (4) (5) VCORE = 1.4 V, CL = 80 pF (5) VCORE = 1.4 V, CL = 80 pF CL = 80 pF CL = 80 pF (5) (6) (7) MIN MAX VCC – 0.25 VCC VCC – 0.60 VCC VCC – 0.25 VCC VCC – 0.50 VCC VSS VSS + 0.25 VSS VSS + 0.60 VSS VSS + 0.25 VSS VSS + 0.50 1.62 V 24 2.2 V 24 3.0 V 24 1.62 V 45% 55% 2.2 V 45% 55% 3.0 V 45% 55% 1.62 V 24 2.2 V 24 3.0 V 24 1.62 V 45% 55% 2.2 V 45% 55% 3.0 V 45% 55% UNIT V V MHz MHz 1.62 V 8 2.2 V 5 3.0 V 3 1.62 V 8 2.2 V 5 3.0 V 3 ns ns The maximum total current, I(OHmax) and I(OLmax), for all outputs combined should not exceed ±48 mA to hold the maximum voltage drop specified. The maximum total current, I(OHmax) and I(OLmax), for all outputs combined should not exceed ±100 mA to hold the maximum voltage drop specified. The port can output frequencies at least up to the specified limit, and it might support higher frequencies. A resistive divider with 2 × R1 and R1 = 3.2 kΩ between VCC and VSS is used as load. The output is connected to the center tap of the divider. CL = 80 pF is connected to the output to VSS. The output voltage reaches at least 20% and 80% VCC at the specified toggle frequency. Measured between 20% of VCC to 80% of VCC. Measured between 80% of VCC to 20% of VCC. Table 5-25 lists the frequencies of the pin-oscillator ports. See Figure 5-27 and Figure 5-28 for the typical characteristics graphs. Table 5-25. Pin-Oscillator Frequency, Ports Px over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER foPx.y (1) 60 Pin-oscillator frequency TEST CONDITIONS VCC MIN TYP MAX UNIT Px.y, CL = 10 pF (1) 3.0 V 1900 kHz Px.y, CL = 20 pF (1) 3.0 V 1150 kHz CL is the external load capacitance connected from the output to VSS and includes all parasitic effects such as PCB traces. Specifications Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 18 30 16 27 Low-Level Output Current (mA) Low-Level Output Current (mA) 5.25.5.1 Typical Characteristics, Normal-Drive I/O Outputs at 3.0 V and 2.2 V 14 12 10 8 6 4 2 TA = 25°C TA = 85°C 0 24 21 18 15 12 9 6 3 TA = 25°C TA = 85°C 0 -2 -3 0 0.25 0.5 0.75 1 1.25 1.5 1.75 Low-Level Output Voltage (V) VCC = 2.2 V 2 2.25 0 P7.0 0.6 0.9 1.2 1.5 1.8 2.1 2.4 Low-Level Output Voltage (V) VCC = 3.0 V Figure 5-19. Low-Level Output Voltage vs Low-Level Output Current 2.7 3 D010 P7.0 Figure 5-20. Low-Level Output Voltage vs Low-Level Output Current 0 0 TA = 25°C TA = 85°C -2 -4 -6 -8 -10 -12 -14 -6 -9 -12 -15 -18 -21 -24 -27 -16 -30 -18 -33 0 0.25 0.5 VCC = 2.2 V TA = 25°C TA = 85°C -3 High-Level Output Current (mA) High-Level Output Current (mA) 0.3 D006 0.75 1 1.25 1.5 1.75 High-Level Output Voltage (V) 2 P7.0 Figure 5-21. High-Level Output Voltage vs High-Level Output Current 2.25 0 0.3 0.6 D004 0.9 1.2 1.5 1.8 2.1 2.4 High-Level Output Voltage (V) VCC = 3.0 V 2.7 3 D008 P7.0 Figure 5-22. High-Level Output Voltage vs High-Level Output Current Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 61 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com 5.25.5.2 Typical Characteristics, High-Drive I/O Outputs at 3.0 V and 2.2 V 160 100 Low-Level Output Current (mA) Low-Level Output Current (mA) 90 80 70 60 50 40 30 20 10 TA = 25°C TA = 85°C 0 -10 140 120 100 80 60 40 20 TA = 25°C TA = 85°C 0 0 0.25 0.5 0.75 1 1.25 1.5 1.75 Low-Level Output Voltage (V) VCC = 2.2 V 2 2.25 0 P2.1 0.9 1.2 1.5 1.8 2.1 2.4 Low-Level Output Voltage (V) 2.7 3 D009 P2.1 Figure 5-24. Low-Level Output Voltage vs Low-Level Output Current 0 -5 TA = 25°C TA = 85°C High-Level Output Current (mA) High-Level Output Current (mA) 0.6 VCC = 3.0 V Figure 5-23. Low-Level Output Voltage vs Low-Level Output Current -15 -25 -35 -45 -55 -65 -75 -85 0 0.25 0.5 VCC = 2.2 V 0.75 1 1.25 1.5 1.75 High-Level Output Voltage (V) 2 P2.1 Figure 5-25. High-Level Output Voltage vs High-Level Output Current 62 0.3 D005 Specifications 2.25 TA = 25°C TA = 85°C -20 -40 -60 -80 -100 -120 -140 -160 0 0.3 0.6 D003 0.9 1.2 1.5 1.8 2.1 2.4 High-Level Output Voltage (V) VCC = 3.0 V 2.7 3 D007 P2.1 Figure 5-26. High-Level Output Voltage vs High-Level Output Current Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M MSP432P401R, MSP432P401M www.ti.com SLAS826F – MARCH 2015 – REVISED MARCH 2017 5.25.5.3 Typical Characteristics, Pin-Oscillator Frequency 1750 TA = 25°C TA = 85°C 1800 Pin Oscillator Frequency (kHz) Pin Oscillator Frequency (kHz) 2100 1500 1200 900 600 300 10 20 30 40 50 Load Capacitance (pF) One output active at a time 60 70 80 100 D002 VCC = 3.0 V Figure 5-27. Load Capacitance vs Pin Oscillator Frequency TA = 25°C TA = 85°C 1500 1250 1000 750 500 250 10 20 30 40 50 Load Capacitance (pF) One output active at a time 60 70 80 100 D001 VCC = 2.2 V Figure 5-28. Load Capacitance vs Pin Oscillator Frequency Copyright © 2015–2017, Texas Instruments Incorporated Submit Documentation Feedback Product Folder Links: MSP432P401R MSP432P401M Specifications 63 MSP432P401R, MSP432P401M SLAS826F – MARCH 2015 – REVISED MARCH 2017 www.ti.com 5.25.6 14-Bit ADC Table 5-26 lists the power supply and input range conditions for the ADC. Table 5-26. 14-Bit ADC, Power Supply and Input Range Conditions over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) PARAMETER TEST CONDITIONS VCC MIN AVCC Analog supply voltage AVCC and DVCC are connected together, AVSS and DVSS are connected together, V(AVSS) = V(DVSS) = 0 V, ADC14PWRMD = 2 AVCC Analog supply voltage AVCC and DVCC are connected together, AVSS and DVSS are connected together, V(AVSS) = V(DVSS) = 0 V, ADC14PWRMD = 0 V(Ax) Analog input voltage range (1) All ADC analog input pins Ax 0 VCM Input common-mode range All ADC analog input pins Ax (ADC14DIF = 1) 0 I(ADC14) single-ended mode I(ADC14) differential mode CI RI (1) (2) (3) 64 Operating supply current into AVCC and DVCC terminals (2) Operating supply current into AVCC and DVCC terminals (2) MAX 3.7 V 1.8 3.7 V AVCC V VREF /2 VREF V 3.0 V 490 640 2.2 V 450 580 fADC14CLK = 5 MHz, 200 ksps (ADC14PWRMD = 2), ADC14ON = 1, ADC14DIF = 0, ADC14VRSEL = 0xE, REFON = 0, ADC14SHT0x = 0x0, ADC14SHT1x = 0x0 3.0 V 215 270 2.2 V 210 260 fADC14CLK = 25 MHz, 1 Msps (ADC14PWRMD = 0), ADC14ON = 1, ADC14DIF = 1, ADC14VRSEL = 0xE, REFON = 0, ADC14SHT0x = 0x0, ADC14SHT1x = 0x0 3.0 V 690 875 2.2 V 620 785 fADC14CLK = 5 MHz, 200 ksps (ADC14PWRMD = 2), ADC14ON = 1, ADC14DIF = 1, ADC14VRSEL = 0xE, REFON = 0, ADC14SHT0x = 0x0, ADC14SHT1x = 0x0 3.0 V 275 335 2.2 V 260 320 12 15 1.8 V to 3.7 V 0.135 1 1.62 V to
MIKROE-2682 价格&库存
很抱歉,暂时无法提供与“MIKROE-2682”相匹配的价格&库存,您可以联系我们找货
MIKROE-2682
  • 1+293.01414
  • 5+287.16156
库存:1
MIKROE-2682
  • 1+295.241541+38.19400
