Country of Origin :
China
Operating Temperature :
0~40 [°C]
Dimension :
93.5 x 46 x 35.8 [mm]
Certified AC Plugs:
EU, UK, USA/Japan, Aus, Korea, Brazil, Argentina, China, India, S. Africa
Efficiency level (ErP) :
VI
GREEN MODE
RoHS
Approvals / Marks :
BIS
Specifications
Voltage DC
[V]
Loading
[A]
Max. Power
[W]
Ripple / Noise
[mV] p-p
Connector
[mm]
SYS1541-1505-Wxx*
5
0~3.0
15
180
2.1x5.5x11
SYS1541-1809-Wxx*
9
0~2.0
18
180
2.1x5.5x11
SYS1541-2412-Wxx*
12
0~2.0
24
180
2.1x5.5x11
SYS1541-2415-Wxx*
15
0~1.6
24
200
2.1x5.5x11
SYS1541-2418-Wxx*
18
0~1.33
24
240
2.1x5.5x11
SYS1541-2424-Wxx*
24
0~1.0
24
300
2.1x5.5x11
Model
Features:
Certified plugs
Wxx = W2E - Europe | W3U - England | W2 - USA, Canada, Japan,Taiwan | W2A - Australia | W2B - Brazil | W2G - Argentina | W2C - China | W2K - Korea | W2I - India | W3S - South Africa
Output connector: standard: 2.1 x 5.5 x 11mm or customer requirement | Regulated Output With Low Ripple Noise | Safety Agency Requirements and EMI/EMS Certified
Private Label Marking Available | Modified and Custom Design Available | 2 Years Warranty
OUTPUT
EMC
Turn delay
5000ms max@AC low line input@output full load
Hold up time
5ms min@AC nominal input@output full load (>half cycle)
Efficiency (Normal)
Meet CEC,DOE,ERP,MEPS Level VI
@115v/60HZ,230V/50HZ
Transient response
(dv,tmax)
0.4V dv max At AC nominal input loading from 20%load to
80%load
16ms tmax Dynamic rise time 10us max,duty 40ms
max,Dynamic load step is slew rate of 0.5A/us
Power out.Limit
Peak 28w
Burn in limit
Full load 2 Hours
Power consumption
Less than 0.075W ms max. At AC nominal input@output min
load
INPUT
Meet EN550022 class B, FCCpart 15 Sub part B class B
EN 60950-1:2006+All|LVD2006/95/EC|IEC 60950-1:2005
SAFETY
UL | GS | CB | CE | FCC | CCC | BSMI | EK-Mark (2412/2424) | SAA | RCM | PSB (2424) | EAC |
INMETRO | BIS (2424)
OTHERS
Dielectric Strength
(Hi-pot)
Primary to Secondary:3000VAC 10mA/60S
M.T.B.F
500,000 Calculated Hours at 25ºC, by Telcordia SR-332
Cable Length
1500mm (5 feet) standard cable or as required
Line power surge | Line voltage SAG-more info on request
Voltage
(90~264)VAC
PLD
(power line disturbance)
Frequency
(47~63)hz
Cooling method
Natural Convection Cooling
Current
0.5A rms@AC low line input and DC output full load
Housing material
PC
Inrush Surge Current
(cold start)
40/60A max@power supply cold start,ambient temperature
25°C @115Vac/230Vac nominal AC input
Temperature coefficient:
很抱歉,暂时无法提供与“MIKROE-2183”相匹配的价格&库存,您可以联系我们找货
