ISSS316-512GCTB5
ISSS316-512GCTB5
    ADATAINDUSTRIAL
    固态硬盘(SSD) FLASH - NAND(SLC) 512GB SATA III 2.5" 5V
ISSS316-512GCTB5 数据手册
ADATA ISSS316 industrial-grade 2.5" solid-state drives (SSD) implement 3D NAND Flash for excellent read/write speeds of up to 550/520MB per second, and come in capacities ranging from 32GB to 1TB. They are ideally suited for industrial computing, embedded applications, gaming, surveillance, healthcare, defense, and general automation. With support for LDPC (Low-Density Parity-Check) error correcting code technology, ISSS316 SSDs can detect and fix errors to ensure data integrity and thus enjoy an extended lifespan. What’s more, they take full advantage of ADATA’s proprietary A + Testing Methodology, which encompasses Functionality Testing and Reliability Validation. This guarantees the drives meet the exacting requirements of industrial and enterprise applications. Key Features - Wide range of capacities from 32GB to 1TB - P/E Cycle upgrade to 3K – improved endurance and reliability - 3D NAND Flash for higher capacity, durability and power efficiency - Low power consumption: 1.79W - Supports DEVSLP, LDPC ECC and Wear Leveling - Supports S.M.A.R.T., NCQ and TRIM Command Target Applications Transportation, Personal Computing, Server, Networking, Medical, Aerospace, Military industrial.ada t a.com Specifications Model ISSS316 Interface SATA III Form Factor 2.5-inch Dimensions (L x W x H) 100.25 x 69.85 x 7mm Flash Type 3D TLC Capacity 32GB – 1TB Sequential Read (Max.) 550MB/s Sequential Write (Max.) 520MB/s Operating Temperature (Commercial) 0ºC to 70ºC Operating Temperature (Industrial) -40ºC to 85ºC Operating Voltage 5V Operating Humidity 5%-95% RH non-condensing Power Consumption (Max.) 1.79W MTBF (Est.) >2,000,000 hours Shock Resistance 1500G/0.5ms, Half Sine Wave Vibration Resistance 20G (10-2000Hz) Technologies LDPC ECC, DEVSLP, S.M.A.R.T., NCQ and TRIM Command Ordering Information Dimensions Commercial Industrial (0ºC to 70ºC) (-40ºC to 85ºC) 32GB ISSS316-032GD ISSS316-032GP 64GB ISSS316-064GD ISSS316-064GP 128GB ISSS316-128GD ISSS316-128GP 256GB ISSS316-256GD ISSS316-256GP 512GB ISSS316-512GD ISSS316-512GP 1TB ISSS333-001TD ISSS333-001TP Capacity ADATA Technology 2F, No. 258, Liancheng Rd., Zhonghe Dist., New Taipei City 235, Taiwan industrial.ada t a.com
ISSS316-512GCTB5 价格&库存
很抱歉,暂时无法提供与“ISSS316-512GCTB5”相匹配的价格&库存,您可以联系我们找货
