SFUI008GJ1AE1TO-I-5S-2AP-STD
    SWISSBIT
    模块
    存储器 - 模块 8GB 模块
SFUI008GJ1AE1TO-I-5S-2AP-STD 数据手册
Product Data Sheet Industrial USB Flash Drive Module U-58 Series USB 3.1 SuperSpeed, pSLC Commercial and Industrial Temperature Grade Date : Re vi si o n: Janu ar y 1 3, 20 2 0 1 .0 0 Contents 1. PRODUCT SUMMARY ............................................................................................................ 3 2. PRODUCT FEATURES ............................................................................................................ 4 3. ORDERING INFORMATION ...................................................................................................... 5 4. PRODUCT DESCRIPTION ......................................................................................................... 6 4.1 PERFORMANCE SPECIFICATIONS ...................................................................................................... 7 4.2 CURRENT CONSUMPTION ............................................................................................................ 7 4.3 ENVIRONMENTAL SPECIFICATIONS .................................................................................................. 8 4.4 REGULATORY COMPLIANCE ......................................................................................................... 9 4.5 MECHANICAL SPECIFICATIONS ...................................................................................................... 9 4.6 RELIABILITY AND ENDURANCE .................................................................................................... 10 4.7 DRIVE GEOMETRY SPECIFICATION .................................................................................................. 10 5. ELECTRICAL INTERFACE ......................................................................................................... 11 6. ELECTRICAL SPECIFICATION .................................................................................................... 12 7. PACKAGE MECHANICAL ........................................................................................................ 13 8. ATA PASS-THROUGH COMMANDS (IDENTIFY DEVICE AND S.M.A.R.T.) .................................................. 14 8.1 ATA PASS-THROUGH COMMANDS .................................................................................................. 14 8.2 IDENTIFY DEVICE .................................................................................................................. 14 8.3 S.M.A.R.T. COMMANDS .......................................................................................................... 15 9. PART NUMBER DECODER ...................................................................................................... 18 10. MARKING SPECIFICATION ..................................................................................................... 20 10.1 TOP VIEW........................................................................................................................ 20 10.2 LABEL CONTENT .................................................................................................................. 20 11. REVISION HISTORY ............................................................................................................. 21 Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 2 of 21 U-58 Series – Industrial USB Flash Drive Module (eUSB) 8 GBytes up to 16 GBytes 1. Product Summary             1 2 Capacities: 8 GBytes, 16 GBytes Form Factor: o USB3.1 solid state flash drive for internal 9(10)-pin USB connector terminal (26.65mm x 36.8mm) o 2.54mm or 2.00mm connector with keyed pin9 Compliance: USB 3.1 Gen 1 SuperSpeed specification compatible (backward compliance with USB 2.0/1.1) Performance: o Read Performance: Sequential Read up to 180 MBytes/s, Random Read IOPS up to 4,100 o Write Performance: Sequential Write up to 76 MBytes/s, Random Write IOPS up to 1,680 Operating Temperature Range 1: o Commercial: 0 °C to 70 °C o Industrial: -40 °C to 85 °C Storage Temperature Range: -40 °C to 85 °C Operating Voltage: 3.3V ±5% or 5V ± 10% Data Retention: 10 Years @ Life Begin; 1 Year @ Life End Endurance in TeraBytes Written (TBW) @ Max Capacity2: o Enterprise Workload ≥ 67.2 Shock/Vibration: 1,500 g / 50 g High-Performance 32-Bit Processor with Integrated, Parallel Flash Interface Engines: o Triple-Level Cell (TLC) 3D NAND Flash in pSLC mode o Hardware BCH Code ECC (up to 60bit correction per 1 KByte page) High Reliability: o Mean Time Between Failure (MTBF): > 3,000,000 hours o Data Reliability: < 1 non-recoverable error per 1016 bits read Adequate airflow is required to ensure the drive temperature, as reported in the S.M.A.R.T. data, does not exceed the specified maximum operating temperature. According to JEDEC (JESD47I), the time to write the full TBW is a minimum of 18 months. Higher average daily data volume reduces the specified TBW. The values listed are estimates and are subject to change without notice. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 3 of 21 2. Product Features         Page based Flash management for increased endurance & random performance Optimized FW algorithms especially for high read access and long data retention applications o Proven power fail management for highest reliability o Near Miss ECC technology Minimize the risk of uncorrectable bit failure over the product life time. Each read command analyzes the ECC margin level and refreshes data if necessary. o Read Disturb Management The read commands are monitored and the content is refreshed when critical levels have occurred. o Wear Leveling technology Equal wear leveling of static and dynamic data. The wear leveling assures that dynamic data as well as static data is balanced evenly across the memory. This guarantees the maximum write endurance of the device. o Data Care Management The interruptible background process controls the user data for read disturb effects or high temperature related retention degradation and refreshes data if necessary. Detailed S.M.A.R.T. support and extended vendor information LED for operation indication In-field firmware update Swissbit Life Time Monitoring (SBLTM) tool and SDK for SBLTM (on request) Controlled BOM & PCN process Customized options like registers, removable device, connector options, write protect switch, grounded mounting hole, densities, uploads, label, etc. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 4 of 21 3. Ordering Information Table 1: Standard Product List Temperature Capacity Commercial Industrial Part Number Part Number 8 GBytes SFUI008GcxAE1TO-C-5S-2yP-STD SFUI008GcxAE1TO-I-5S-2yP-STD 16 GBytes SFUI016GcxAE1TO-C-6B-2yP-STD SFUI016GcxAE1TO-I-6B-2yP-STD c = connector, x = product generation, y = firmware revision Table 2: Available Part Numbers Industrial Temperature Capacity Part Number Connector 8 GBytes SFUI008GJ1AE1TO-I-5S-2AP-STD 2.54mm pitch 8 GBytes SFUI008GK1AE1TO-I-5S-2AP-STD 2.00mm pitch 16 GBytes SFUI016GJ1AE1TO-I-6B-2AP-STD 2.54mm pitch 16 GBytes SFUI016GK1AE1TO-I-6B-2AP-STD 2.00mm pitch Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 5 of 21 4. Product Description The Swissbit U-58 USB 3.1 embedded USB flash drive provides a robust, high performance, and reliable storage product with industry compatible interface and small form factor. The U-58 pSLC technology both enables high 3D TLC NAND flash operation and excellent endurance. The use of page based Flash management and a global wear leveling extends the endurance to unprecedented values for USB products. The 10-pin connector makes easy integration into existing or newly designed system boards possible. The U-58 is compatible with standard on-board USB connectors that use a single USB 2.0 or USB 3.1 channel. It may not be used in mainboard USB 2.0 connectors that support two USB channels per socket. The embedded USB module serves applications which utilize USB products as acceleration cache for HDDs or as a boot media, for example networking and telecommunication systems. For outdoor use or in poorly ventilated systems the U-58 is available in industrial temperature grade from -40°C to +85°C. Each individual industrial temperature grade drive is tested at these corners to verify the temperature resistance. The U-58 firmware includes data care management features which refresh storage areas that are not or only infrequently read. At high temperature storage these areas are prone to retention loss. The firmware monitors the state of the NAND blocks and refreshes those that show a high level of degradation, thus preventing uncorrectable errors. This is an important feature for USB flash drives that are used as read only boot media. The U-58 consists of a high performance 32bit RISC USB controller, the 10pin connector, power circuitry and different numbers of NAND dies. The U-58 can flexibly operate at 3.3V ±5% or 5V ± 10%. It supports USB 3.1 Gen 1 SuperSpeed and is fully backwards compatible to USB 2.0/1.1 High/Full Speed. Figure 1: U-58 Functional Block Diagram Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 6 of 21 4.1 Performance Specifications The U-58 read/write sequential and random CDM performance benchmarks are detailed in the following Table 3 and Table 4. Table 3: Read/Write Performance in SuperSpeed mode3 Capacity Sequential Read (MBPS) Sequential Write (MBPS) Random Read 4K (IOPS) Random Write 4K (IOPS) 8 GBytes 97.4 42.7 4,160 1,620 16 GBytes 180 76 4,100 1,680 Table 4: Read/Write Performance in High-Speed mode3 Capacity Sequential Read (MBPS) Sequential Write (MBPS) Random Read 4K (IOPS) Random Write 4K (IOPS) 8 GBytes 39.2 30.4 2,970 1,440 16 GBytes 39 30 2,970 1,500 4.2 Current Consumption The drive-level current consumption as a function of operating mode is shown in the following Table 5. Table 5: Current Consumption4 3 4 Capacity Sequential Read Sequential Write Random Read 4K Random Write 4K Idle 8 GBytes 93 82 73 78 59 16 GBytes 146 120 92 98 41 Unit mA The values are measured using CrystalDiskMark 5.1.2 x64 (CDM) with Seq Q1T1 and 4KiB Q8T8. Performance depends on flash type and number, file/cluster size, and burst speed. All values are the typical recorded at 25 °C, with 5V supply voltage at fastest CrystalDiskMark 5.1.2 x64 (CDM) in SuperSpeed mode. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 7 of 21 4.3 Environmental Specifications Recommended Operating Conditions The recommended operating conditions for the U-58 USB flash drives are provided in the following Table 6. Table 6: Recommended Operating Conditions5 Parameter Value Commercial Operating Temperature 0 °C to 70 °C Industrial Operating Temperature -40 °C to 85 °C 3.3 V ± 5% or 5.0 V ± 10% Power Supply VCC Voltage Recommended Storage Conditions The recommended storage conditions are listed in the following Table 7. Table 7: Recommended Storage Conditions Parameter Value Commercial Storage Temperature -40 °C to 85 °C6 Industrial Storage Temperature -40 °C to 85 °C6 Shock, Vibration and Humidity The maximum shock, vibration and humidity conditions are listed in the following Table 8. Table 8: Shock, Vibration and Humidity Parameter Value 1,500 g (JESD22-B110, IEC 60068-2-27) Non-Operating Shock Non-Operating Vibration 50 g (IEC 60068-2-6, MIL-STD-883 M2007.3) Humidity (Non-Condensing) 5 6 85% RH 85 °C, 1000 hrs (JESD22-A101) Adequate airflow is required to ensure the drive temperature, as reported in the S.M.A.R.T. data, does not exceed the specified maximum operating temperature. The retention at high temperature is reduced. The acceleration factor at 85°C compared with 40°C is 170, i.e. the initial endurance at 10 years@40°C is reduced to 22 days@85°C. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 8 of 21 4.4 Regulatory Compliance The U-58 devices comply with the standards listed in the following Table 9. Table 9: Regulatory Compliance Compliance Country Type Standard(s)/Directive CE European Union Compliance 2014/30/EU EN 55032:2015 EN 61000-6-4:2007 +A1:2011 EN 55035:2017 EN 61000-6-2:2005/AC:2015 EN 61000-4-2:2009 FCC United States Compliance 47 CFR Part 15, class B RoHS European Union Compliance 2011/65/EU, 2015/863 WEEE European Union Compliance 2012/19/EU REACH European Union Compliance 1907/2006 UL United States Compliance Conformity by subparts 4.5 Mechanical Specifications Physical dimensions are detailed in the following Table 10. Figure 2 and Figure 3 on page 13 illustrate the U-58 dimensions. Table 10: Measured Physical Dimensions Physical Dimensions Unit Length 36.8±0.15 Width 26.65±0.15 Thickness (Max) 9.7±0.25 Weight (Max Capacity) Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland mm 5 Confidential www.swissbit.com industrial@swissbit.com g Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 9 of 21 4.6 Reliability and Endurance The Mean Time Between Failure (MTBF) is specified to exceed the value listed in the following Table 11. Data reliability with effective error tolerance and data retention at the beginning and end of life is also provided. Table 11: Reliability Parameter Value MTBF (at 25 °C) > 3,000,000 hours Data Reliability < 1 Non-Recoverable Error per 10 Bits Read Data Retention 10 Years at Start (JESD47), 1 Year at EOL 16 Endurance represented as both TeraBytes Written (TBW) and full Drive Writes Per Day (DWPD) is provided in the following Table 12. Table 12: Endurance7 Drive Capacity Enterprise TBW DWPD8 8 GBytes 35.8 4.1 16 GBytes 67.2 3.8 Total LBA User Addressable Bytes Decimal (Unformatted) 8 GBytes 15,663,104 8,019,509,248 16 GBytes 31,326,208 16,039,018,496 4.7 Drive Geometry Specification Table 13: Drive Geometry Raw Capacity 7 8 Enterprise workload follows the JEDEC JESD219 standard. Enterprise workload values are measured based on 168 hours of runtime. 1 TByte = 1012 bytes DWPD values are based on a service life of 3 years Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 10 of 21 5. Electrical Interface    USB connector 10pin (2mm or 2.54mm pitch) Do not connect the drives to a standard USB2 host pin header with two USB 2.0 ports! If pin 2 has 5V at the host side, it can destroy the USB3 SSRX+ input of the device. USB 3.1 Gen1 SuperSpeed interface, USB2.0 high-speed and 1.1 full-speed compatible Table 14: Electrical pinout from device and host view. Never connect >1.8V to pin2 and pin4. 1 Signal device view V_Bus Signal host view V_Bus Description host view Operating voltage 2 SSRX+ SSTX+ Host transmit + Pin 3 D- D- Data signal pair 4 SSRX- SSTX- Host transmit - 5 D+ D+ Data signal pair 6 GND GND Ground 7 GND GND Ground 8 SSTX+ SSRX+ Host receive + 9 - - Keyed at connector 10 SSTX- SSRX- Host receive - 2 4 6 1 3 5 8 7 10 See also chapter 7 Package Mechanical Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 11 of 21 6. Electrical Specification Table 15: Absolute Maximum Ratings Parameter Symbol Min Max Power Supply Voltage V_Bus -0.5 6.0 Voltage at D+ and D- V_Data -0.5 5.0 Voltage at USB3 pins V_Data -0.5 1.8 0 70 -40 85 Commercial Operating Temperature T_A Industrial Operating Temperature Unit V °C Table 16: DC characteristics for SuperSpeed operation (T=25°C, V_Bus=5V) Parameter Symbol Supply Voltage V_Bus Write current I_WR Read current I_RD Idle current Suspend current Density Min Typ Max Unit all 3.1 V 3.3 or 5.0 5.50 8 GBytes 82 90 16 GBytes 120 132 8 GBytes 93 103 16 GBytes 146 161 I_IDL all 599 65 I_CCS all 1.9 2.5 mA Table 17: DC characteristics for High-Speed operation (T=25°C, V_Bus=5V) Parameter Symbol Supply Voltage V_Bus Write current I_WR Read current I_RD Idle current Suspend current 9 Density Min Typ Max Unit all 3.1 V 3.3 or 5.0 5.50 8 GBytes 49 54 16 GBytes 61 67 8 GBytes 54 60 16 GBytes 67 74 I_IDL all 9 40 2.1 2.5 36 I_CCS all High Speed Idle Level V_HSOI all -10 10 High Speed Data Signaling LOW V_HSOL all -10 10 High Speed Data Signaling HIGH V_HSOH all 360 440 Chirp J Level (differential) V_CHIRPJ all 360 440 Chirp K Level (differential) V_CHIRPK all -440 -360 mA mV Typically 5 minutes after power on the device performs a background data care management, that needs up to 119mA in SuperSpeed and 112mA in High-Speed mode. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 12 of 21 7. Package Mechanical       Standard form factor of PCBs 36.8mm x 26.65mm Hole for mechanical fixture (optional grounded) 3 additional holes LED for operation indication (optional without LED) 2 connector types o 2.54mm pitch, 7.5mm long standard o 2.00mm pitch, 3.68mm long low profile Component heights max. 1.4mm on connector side max. 1.4mm on flash side Figure 2: Mechanical Dimensions for U-58 8GB drive All dimensions are in millimeters, tolerance: ±0.15 Figure 3: Mechanical Dimensions for U-58 16GB drive All dimensions are in millimeters, tolerance: ±0.15 Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 13 of 21 8. ATA Pass-Through commands (Identify Device and S.M.A.R.T.) 8.1 ATA Pass-Through commands Additional to the standard SCSI commands the device also supports the ATA Pass-Through commands. Table 18: ATA PASS-TRHOUGH(x) commands SCSI command OpCode ATA PASS-THROUGH(12) A1h ATA PASS-THROUGH(16) 85h Description Write and read ATA registers to send commands and read information http://www.t10.org/ftp/t10/document.04/04-262r8.pdf Table 19: ATA register addressing Offset address Input Output 0 Type Data 1 Identify device e.g. SMART commands Byte xx yyh* Word Feature Error 2 Sector count Byte xx 01h 3 LBA_Low Byte xx xx 4 LBA_Mid Byte xx 4Fh 5 LBA_High Byte xx C2h Byte E0h E0h Byte ECh B0h 6 Drive/head 7 Command Status * see below 8.2 Identify Device The Identify Device returns a identify sector compatible to ATA and SATA devices. Here an example of the interpretation of this sector. Table 20: Identify Device Information Word(s) Default Value 0 0040h … … 10-19 aaaa* Total Bytes … … Data Field Type Information 2 Standard Configuration Fixed (optional 848Ah for removable) … … 20 Serial number in ASCII (right-justified) … … … … 23-26 XXXX* 8 Firmware revision in ASCII (big-endian byte order in Word) 27-46 XXXX* 40 Model number in ASCII (right-justified) … … … … 60-61 XXXXh 4 Total number of sectors addressable in LBA mode … … … … 82 0101h 7701h* 4063h* 2 Command set: SMART feature set, service interrupt … … … … 85 000Xh 0701h* 4063h* 2 Command set enabled: SMART feature set enabled/disabled … … … … 255 XXA5h 2 Integrity Word … … … … * Values depend on device configuration. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 14 of 21 8.3 S.M.A.R.T. commands The intent of the SMART command feature set is to protect user data and minimize the likelihood of unscheduled system downtime that may be caused by predictable degradation and/or fault of the device. By monitoring and storing critical performance and calibration parameters, SMART feature set devices attempt to predict the likelihood of a near-term degradation or fault condition. Providing the host system the knowledge of a negative reliability condition allows the host system to warn the user of the impending risk of a data loss and advise the user of the appropriate action. All S.M.A.R.T. commands have the command code B0h. The different commands are selected by the Feature register. Table 21: S.M.A.R.T. Features Supported Feature Sect Count LBA low LBA mid LBA high DRV head Command S.M.A.R.T. Read Data D0h 01h xx 4Fh C2h E0h B0h S.M.A.R.T. Read Attribute Thresholds D1h 01h xx 4Fh C2h E0h B0h S.M.A.R.T. Enable Operations D8h xx xx 4Fh C2h E0h B0h S.M.A.R.T. Disable Operations D9h xx xx 4Fh C2h E0h B0h S.M.A.R.T. Return Status DAh xx xx 4Fh C2h E0h B0h Operation All commands are aborted, if the LBA signature is invalid. S.M.A.R.T. Read Data (D0h) When the drive receives the S.M.A.R.T. Read Data subcommand, it returns one sector (512 bytes) of data. See the following table for the data structure of this sector. Table 22: S.M.A.R.T. Data Structure Byte(s) Value Description 0-1 0010h S.M.A.R.T. structure version 2-361 XXh Attribute entries 1 to 30 (see Table 23) 362 00h Off-line data collection status (no off-line data collection started) 363 00h Self-test execution status byte (self-test completed) 364-365 0000h 366 00h Vendor specific 367 00h Off-line data collection capability (no off-line data collection) 368-369 0003h 370 00h No Error logging capability 371 00h Vendor specific 372 00h Short self-test routine recommended polling time, in minutes 373 00h Extended self-test routine recommended polling time, in minutes 374-385 00h Reserved 386-387 0004h SMART Version 388-510 XXh Vendor specific 511 XXh Data structure checksum Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Total time, in seconds, to complete off-line data collection S.M.A.R.T. capabilities Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 15 of 21 S.M.A.R.T. Attribute Entry Structure Each attribute entry (Bytes 2-361) consists of 12 bytes. See the following table for the data structure of each entry. Table 23: Attribute Entry Offset Byte(s) Value Description 0 XXh 1-2 XXXXh 3 XXh Current value as a percentage 64h = 100% 4 XXh Worst value as a percentage 64h = 100% 5-10 XXXXh 11 00h Attribute ID (see Table 24) Flags (little-endian) Bit0: Advisory (0) or Prefailure (1) Bit1: Not used (0) or updated during normal operation (1) Raw value (little-endian) Reserved S.M.A.R.T. Attributes The drives support the S.M.A.R.T. attributes listed in the following table. The Threshold values can be read out with the S.M.A.R.T. Read Attribute Thresholds command (D1h) The first attributes (196, 213, 229) are “Pre-Fail” type, while all other are Advisory (Old Age). Table 24: S.M.A.R.T. Attributes ID dec ID hex Value Worst Description RAW values Offset 5-10 196 C4h X% X% 25 Spare Block Count Number of total available NAND spare blocks Initial (offset 5-7) and current (offset 8-10) number of spare blocks 213 D5h X% X% 25 Spare Block Count worst channel Spare block count for the NAND with the lowest number of remaining spare blocks Initial (offset 5-7) and current (offset 8-10) number of spare blocks of the channel with the lowest current number of spare blocks 229 E5h X% X% 2 Total Erase Count Estimated number of Estimated number of total NAND total NAND block erases block erases 203 CBh 100 100 0 Total ECC Errors All recorded ECC errors Total number of ECC errors (correctable and uncorrectable) (offset 5-8) 204 CCh 100 100 0 Correctable ECC Total recorded ECC Errors errors that were corrected during the life of the drive Total number of correctable ECC errors (offset 5-8) 199 C7h 100 100 0 UDMA CRC Errors Dummy attribute, included for legacy reasons This value is fixed at 0. 232 E8h 100 100 0 Total Number of Reads Total number of NAND READ commands Total number of NAND READ commands 12 0Ch 100 100 0 Power-On Count Count of power-on events Number of power cycles (offset 5-8) 241 F1h 100 100 0 Total LBAs Written Total amount of data written to the drive Total number of LBAs written to the disk, divided by 65536 242 F2h 100 100 0 Total LBAs Read Total amount of data read from the drive Total number of LBAs read from the disk, divided by 65536 214 D6h 100 100 0 Management Block status Total number of times the management block has been updated Management block write count (offset 5-8) 215 D7h X% X% 0 Trim Status Amount of device content that is currently in the trimmed state This value is fixed at 0. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland ThresAttribute hold Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 16 of 21 ID dec ID hex Value Worst 194 C2h X°C Max °C ThresAttribute hold 0 Temperature Status Description RAW values Offset 5-10 Device temperature in Celsius (°C) Current (offset 5) /Min (offset 6) / Max temperature (offset 7) * These threshold values are changeable using the Write Attribute Thresholds command. S.M.A.R.T. Read Attribute Thresholds (D1h) When the drive receives the S.M.A.R.T. Read Attribute Thresholds subcommand, it returns one sector (512 bytes) of data similar as S.M.A.R.T. Read data sector, but with the threshold value in offset 1 of each attribute (see Table 24). S.M.A.R.T. Enable Operations (D8h) This command enables access to the S.M.A.R.T. capabilities of the drive. The state of SMART (enabled or disabled) is preserved across power cycles. S.M.A.R.T. Disable Operations (D9h) This command disables access to the S.M.A.R.T. capabilities of the drive. The state of SMART (enabled or disabled) is preserved across power cycles. S.M.A.R.T. Return Status (DAh) Table 25: S.M.A.R.T. Return Status Feature Sect Count LBA low LBA mid LBA high DRV head Command DAh xx xx 4Fh C2h E0h B0h S.M.A.R.T. Return Status OK xx xx xx 4Fh C2h xx xx S.M.A.R.T. Return Status Pre-FAIL* xx xx xx F4h 2Ch xx xx Operation Command S.M.A.R.T. Return Status Response * If a threshold exceeded condition exists for either the Spare Block Count Worst Channel attribute or the Erase Count attribute, the device will set the Cylinder Low register to F4h and the Cylinder High register to 2Ch. In this case the drive should be replaced soon. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 17 of 21 9. Part Number Decoder S F UI 016G J 1 A E 1 TO 1 2 3 4 5 6 7 8 9 10 Manuf. Memory Type. Product Type Density Platform Product Generation Memory Organization - I 11 - 6 B 12 13 - 2AP 14 - STD 15 Option Configuration Manuf. Code: Flash Mode Manuf. Code: Flash Package Temp. Option Flash Vendor Code Number of Flash Chips Technology 9.1 Manufacturer Swissbit code S Flash F U-xxx USB Flash Drive Module (Internal) UI 9.2 Memory Type 9.3 Product Type 9.4 Density 8 GBytes 008G 16 GBytes 016G 32 GBytes 032G 9.5 Platform U-xxx – 2.54mm plug J U-xxx – 2.00mm plug K First generation 1 x8 A U-5xx platform UFD E 1 Flash 1 2 Flash 2 Toshiba TO 9.6 Product Generation 9.7 Memory Organization 9.8 Technology 9.9 Number of Flash Chips 9.10 Flash Code Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 18 of 21 9.11 Temperature Option Commercial Temperature Range: 0 °C to 70 °C C Industrial Temperature Range: -40 °C to 85 °C I 3D TLC MONO (single die package) 5 3D TLC DDP (dual die package) 6 3D TLC QDP (quad die package) 7 3D TLC ODP (octal die package) 8 9.12 Die Classification 9.13 Pin Mode BGA TSOP Single nCE and Single R/nB A S Dual nCE and Dual R/nB B T Quad nCE and Quad R/nB C U Octal nCE and Octal R/nB V * *Not Available 9.14 Configuration XYZ X = Configuration Configuration X Removable Drive 1 Fixed Drive 2 Y = Firmware Revision FW Revision Y Revision 1 A Z= Optional setting Optional Setting Z Default (SLC or MLC) 1 pSLC (pseudo SLC) P Swissbit / Standard STD Customized version XXX 9.15 Option Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 19 of 21 10. Marking Specification 10.1 Top View Figure 4: U-58 top view (example) 10.2 Label content Figure 5: U-58 label details Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 20 of 21 11. Revision History Table 26: Document Revision History Date Revision Description Revision Details 16-Aug-2019 0.90 Preliminary release - 09-Sep-2019 0.91 Correction in Table 12 Doc. req. no. 3175 13-Jan-2020 1.00 Initial release Doc. req. no. 3378 Disclaimer: No part of this document may be copied or reproduced in any form or by any means, or transferred to any third party, without the prior written consent of an authorized representative of Swissbit AG (“SWISSBIT”). The information in this document is subject to change without notice. SWISSBIT assumes no responsibility for any errors or omissions that may appear in this document and disclaims responsibility for any consequences resulting from the use of the information set forth herein. SWISSBIT makes no commitments to update or to keep current information contained in this document. The products listed in this document are not suitable for use in applications such as, but not limited to, aircraft control systems, aerospace equipment, submarine cables, nuclear reactor control systems and life support systems. Moreover, SWISSBIT does not recommend or approve the use of any of its products in life support devices or systems or in any application where failure could result in injury or death. If a customer wishes to use SWISSBIT products in applications not intended by SWISSBIT, said customer must contact an authorized SWISSBIT representative to determine SWISSBIT willingness to support a given application. The information set forth in this document does not convey any license under the copyrights, patent rights, trademarks or other intellectual property rights claimed and owned by SWISSBIT. The information set forth in this document is considered to be “Proprietary” and “Confidential” property owned by SWISSBIT. ALL PRODUCTS SOLD BY SWISSBIT ARE COVERED BY THE PROVISIONS APPEARING IN SWISSBIT’S TERMS AND CONDITIONS OF SALE ONLY, INCLUDING THE LIMITATIONS OF LIABILITY, WARRANTY AND INFRINGEMENT PROVISIONS. SWISSBIT MAKES NO WARRANTIES OF ANY KIND, EXPRESS, STATUTORY, IMPLIED OR OTHERWISE, REGARDING INFORMATION SET FORTH HEREIN OR REGARDING THE FREEDOM OF THE DESCRIBED PRODUCTS FROM INTELLECTUAL PROPERTY INFRINGEMENT AND EXPRESSLY DISCLAIMS ANY SUCH WARRANTIES INCLUDING WITHOUT LIMITATION ANY EXPRESS, STATUTORY OR IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. © 2020 SWISSBIT AG All rights reserved. Swissbit AG Industriestrasse 4 CH-9552 Bronschhofen Switzerland Confidential www.swissbit.com industrial@swissbit.com Revision: 1.00 Doc-2827 File: U-58_data_sheet_UI-xxAE_STD_Rev100 Page 21 of 21
SFUI008GJ1AE1TO-I-5S-2AP-STD 价格&库存
很抱歉,暂时无法提供与“SFUI008GJ1AE1TO-I-5S-2AP-STD”相匹配的价格&库存,您可以联系我们找货
