8699
8699
    ACLSTATICIDE
    热敏式 硅脂 5 盎司 管装
8699 数据手册
8699 Staticide® Heat Sink Grease Maximum Heat Transfer and Dissipation ACL’s Heat Sink Grease enables heat transfer away from electronic and electrical components. This silicone-based material is thickened with a heat conductive metal oxide to maintain a positive heat sink seal. With its excellent conductivity, Heat Sink Grease is an effective thermal coupler for any heat sink surface. Directions: Cut nozzle to desired length at 45-degree angle. Apply by pushing soft tube. Collapsible tube may be squeezed by hand or with the aid of mechanical wringers. Apply to all mounting and threading surfaces of the device and chassis. For industrial use only. Read SDS carefully prior to use. Material Compatibility: Heat Sink Grease is generally compatible with most materials used in electrical and electronic assemblies. It is safe to use on most plastic and PCB surfaces. With any chemical solvent or component, compatibility with the substrate must be tested on a non-critical area prior to use. ABS Good Buna-N Good EPDM Good Graphite Good HDPE Good Kynar™ Good LDPE Good Lexan™ Fair Neoprene Fair Noryl Fair Nylon™ 66 Good Cross-linked PE Good Polypropylene Good Polystyrene Good PVC Good Silicone Rubber Good Teflon™ Good Viton™ Good Unlike some heat sink formulas, Staticide Heat Sink Grease will not separate. The high dialectic strength and low bleed properties make it ideal for various applications including engineering and design work. Packaged in a convenient five-ounce tube, it is a one-component, ready-to-use product that does not dry out, harden, or melt. Ideal for the following applications: • Industrial MRO • Process Control • Automotive, Marine, and Aerospace • Engineering and design equipment FEATURES: Dialectric strength: 500 volts/mil thickness Temperature range: -60°F (-51°C) to 400°F (200°C) Arc resistance (seconds): 120 Thermal conductivity: 4.35 (BTU/hr) Non-corrosive; non-flammable Conforms to MIL-DTL-47113 1B RoHS, REACH compliant Made in USA Product# 8699 5 oz (142 g) tube/6 per case ACL Inc. registered to ISO-9001 : 2015 Certificate NO. 10002746 Rev. 03/25/2021 MKB
很抱歉,暂时无法提供与“8699”相匹配的价格&库存,您可以联系我们找货
