100NI-L
100NI-L
    ACLSTATICIDE
    腈橡胶 指套 大型 蓝色
100NI-L 数据手册
Staticide Nitrile ESD Finger Cots Latex-free Static Protection ACL’s Nitrile ESD Finger Cots take the worry away for those with latex allergy issues while offering protection against skin and oil contamination. Since nitrile is resistant to many chemicals, it will not dissolve under chemical contact. The inherently anti-static nature of nitrile also offers natural static control without carbon shedding. For EPAs where cleanliness is a concern, blue does not expose as much handling soils. For companies using both non-ESD and ESD finger cots, ACL offers white finger cots to differentiate finger cots with static protection. Ideal for the following applications: EPAs and other ESD-sensitive areas • Defense, avionics • IC industries, Marine and consumer electronics • Assembly areas, wire bonding, and laser diodes • Repair stations, field repair kits Features: White Part# (720 pieces per pack) 90NI-S 90NI-M 90NI-L 90NI-XL • Powder-free / ISO 5 / Class 100 Cleanroom Small Medium Large Extra Large Suggested for Class II static sensitivity devices (thresholds up to 3999v) Blue Part# (720 pieces per pack) Compliant with ASTM and IEST-RP-CC 005.3 standards 100NI-S 100NI-M 100NI-L 100NI-XL Resistance per ANSI/ESD SP15.1: 10e9 ohms Small Medium Large Extra Large RoHS compliant 3 mil thickness Note: Discontinue use if reddening or irritation occurs. Components used in the manufacture of nitrile finger cots may cause allergic reactions in some individuals. Consult your institution’s policies regarding use of these products. 840 W. 49th Place · Chicago, IL 60609 800.782.8420 · 847.981.9212 · fax 847.981.9278 info@staticide.com · www.aclstaticide.com ACL Inc. registered to ISO-9001 : 2008 Certificate NO. 10002746 rev. 10/02/2017 ANM
100NI-L 价格&库存
很抱歉,暂时无法提供与“100NI-L”相匹配的价格&库存,您可以联系我们找货
