1074
1074
    ADAFRUIT
    插件,P=2.54mm
    接线端子 间距:2.54mm 每排针脚数:3 排数:单排
1074 数据手册
      Configurable Spring Terminal Blocks - 3 Pin 0.1" Pitch R/A - x 5 PRODUCT ID: 1074 Spring terminal blocks will simplify your wiring and make your project more rugged. Instead of soldering wires to your perf board, solder in these 0.1" pitch terminal blocks. There's a little spring contact so you can pull back on the plastic bit and slip in your 20 to 26 AWG solid or stranded-core wires. Each terminal block is electrically isolated from those next to it. Each block also has two solder pins per contact for strong mechanical strength when soldering in place. These are the "right angle" style - the wires go in from the side. We also have "straight" style if you want the wire to go in from the top. What we like about these terminal blocks is that they are re-configurable! The pack comes in a set of 5 pieces of 3-pin blocks. However, by carefully removing the end cap on each one you can snap together any number and then reattach the end cap. So you could use this to have 5 x 3 pin contacts, or 1 x 15 pin contact, or 3 x 5 pin contacts, etc. Keep these around in your toolkit, and arrange them as needed! These are a really great accompaniment to our PermaProto boards.   TECHNICAL DETAILS  1.73g each                                                        https://www.adafruit.com/product/1074 7‐13‐18
很抱歉,暂时无法提供与“1074”相匹配的价格&库存,您可以联系我们找货
  • 1+43.639301+5.65649
