Arcade/Button Quick-Connect Wire Pair Set of 10 pairs
PRODUCT ID: 1152
Description
Quick connector wire sets will make wiring up our arcade-style or metal buttons quicky-quick. Each wire
comes as a 'pair' with two 0.11" quick-connects pre-crimped onto 20cm long wires. The wires are then
terminated together in a JST 2.5mm/0.1" spaced 2-pin connector (we don't have the exact part number yet
for the connector but you can just use 0.1" header) Of course you can cut this off if you don't have use for
it.
Works best with our round plain arcade buttons, doesn't work as well on the square or round "illuminated"
buttons.
If you need a connector for the other side, try this JST XH (matching part from digikey here)
http://www.jst-mfg.com/product/detail_e.php?series=277
http://www.digikey.com/products/en?x=0&y=0&lang=en&site=us&KeyWords=455-2247-ND
Technical Details
Datasheet showing dimensions for an equivalent 0.11" quick connect part number
https://cdn-shop.adafruit.com/datasheets/quickconnect110.pdf
Engineered in NYC Adafruit ® https://www.adafruit.com/product/1152 6‐23‐17
很抱歉,暂时无法提供与“1152”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+32.677591+4.23564
- 国内价格
- 1+92.27520
- 200+36.82800
- 500+35.59680
