1189
1189
    ADAFRUIT
    按钮开关 SPST-NO 标准,发光式 前面板安装
1189 数据手册
Massive Arcade Button with LED - 100mm Blue PRODUCT ID: 1189  Description OMG WATCH OUT! This 100mm diameter arcade button with a 16mm deep plastic base is so massive and inviting it may collapse upon itself and form a black hole from which not even light can escape! Until it does, however, it ready for all sorts of pressing and pushing. Science has shown no one can resist pressing its shiny surface and saying "beep!". We've seen these on some games of skill in arcades, they're easy to mount on nearly any kind of enclosure. They're not waterproof or weatherproof, so best used indoors. This button has a domed blue plastic cover with a black retaining ring around it. There's an optional LED included that will light up the button. The LED has a built in resistor so you can run it up to 12V but given the massive size and shallow depth of the button, it doesn't illuminate the entire button face evenly. The button activates a common arcade microswitch (included), the switch contacts are normally open. When the button is pressed, the contacts close. Technical Details        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1189”相匹配的价格&库存,您可以联系我们找货
