Large Arcade Button with LED - 60mm
Green
PRODUCT ID: 1193
Description
BAM! This 60mm diameter arcade button is large and inviting and ready for all sorts of
pressing and pushing. We've seen these on some games of skill in arcades, they're easy to
mount on nearly any kind of enclosure. They're not waterproof or weatherproof, so best
used indoors.
This button has a flat green plastic cover with a black retaining ring around it. There's an
optional LED included that will light up the button. The LED has a built in resistor so
you can run it up to 12V but given the shallow depth of the button, it doesn't illuminate
the entire button face evenly. The button activates a common arcade microswitch
(included), the switch contacts are normally open. When the button is pressed, the
contacts close.
Technical Details
o
o
o
12mm / .5" height when pressed
15.2mm / .6" height when not pressed
52.5mm / 2.1" long stem with switch installed
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1193”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+24.736591+3.21459
- 国内价格 香港价格
- 3+24.736593+3.21459
