1326
1326
    ADAFRUIT
    CASE- ENCLOSURE FOR RASPBERRY PI
1326 数据手册
Adafruit Pi Case- Enclosure for Raspberry Pi Model A or B PRODUCT ID: 1326 DESCRIPTION We are happy to finally release Adafruit's lovely Raspberry Pi case, designed by Mike Doell ( who made our really terrific Arduino enclosures as well). We wanted a beautiful, elegant case, not just functional but also something you'd really like having on your desk. Gaze lovingly at its curves & its glossy clear cover! Using this case is very easy and works with Raspberry Pi Model A, Model B rev 1 and Model B rev 2. This enclosure is not compatible with the Raspberry Pi Model B+ Snap the Pi into the case bottom for a secure press-fit. If you want to poke around you can leave the top cover off. If you want to protect your Pi, fit the cover on, it will fit securely so you can put the Pi into your book bag without worry. There's a slot for a GPIO ribbon cable so you can connect a Pi Cobbler while the cover is still on, and remove it easily as well by popping the top off. Please note: this case is not compatible with our low-profile microSD card adapter. The Pi is press-fit in the case so when removing the GPIO cable, make sure to either fully remove the Pi or hold it down so it doesn't pop up. Does not come with a Raspberry Pi or GPIO cable (but we do have them in the store, so you can pick one up!) Adafruit Pi Case- Enclosure for Raspberry Pi Model A or B (16:47) TECHNICAL DETAILS Weight: 46.62g Dimensions: 68.4mm / 2.69" x 102.29mm / 4" x 24.18mm / 0.95" https://www.adafruit.com/product/942 1-9-18
很抱歉,暂时无法提供与“1326”相匹配的价格&库存,您可以联系我们找货
