1597
1597
    ADAFRUIT
    拆焊 泵,带尖头 银 8.100"(205.74mm)
1597 数据手册
Professional Silicone-Tip Solder Sucker PRODUCT ID: 1597 Description  Ever go to a diner and they give you a bottle of ketchup and it says "Extra Fancy" and you're thinking to yourself "what makes this ketchup 'extra fancy' anyhow?" Well, this professional grade solder sucker is "Extra Fancy" and there's no question as to why. When you hold its machined aluminum body, you'll think "Fancy!", the smooth action and release is also "Fancy" and the replacable silicone rubber tip? "Extra Fancy!" This Japanese upgrade to the classic $5 solder sucker is a joy to use. Since the tip is rubbery soft silicone you don't have to worry about it melting. You also get a long tube in case it gets clogged or dirty. To use, depress the end to engage the vacuum. Then heat up the to-be-desoldered joint until it is liquid. With your other hand hold the plastic tip as close as possible to the joint and depress the button to suck up all the liquid solder. If necessary, clean up the remaining solder with wick.    Technical Details  o o o Dimensions: 8.1 x 3.4 x 0.7 inches Weight: 52g Cylinder Capacity: 9cc                                 Engineered in NYC Adafruit ® https://www.adafruit.com/product/1597 5‐5‐17
很抱歉,暂时无法提供与“1597”相匹配的价格&库存,您可以联系我们找货
  • 1+202.510731+26.28919
库存:896
