2.8" TFT Display with Resistive
Touchscreen
PRODUCT ID: 1774
This is a screen for advanced hackers who like the look of the TFT screen we've
put into the PiTFT, TFT shield v2 and 2.8" TFT breakout. This display has
320x240 pixels and is driven with the ILI9341 chipset. This is just the display
module! No PCB is included! You can talk to this chip with SPI (4 or 3 wire), 8 bit
parallel, or 16 bit parallel. It also can be put into "dot clock mode" for raw TTL
signal in but we have never done this ourselves so there's no example code for
that.
We're selling this module bare for those who want to integrate it into their own
project. If this is your first time working with this TFT we suggest our breakout
board which makes it easy to use SPI or 8-bit interfacing and also has mounting
holes, level shifting, etc.. Otherwise you can pick up one of our 50-pin FPC
breakouts and an 50-pin FPC connector and solder it up by hand. For the TFT
command set, the data sheet is very complete, but we also have some Arduino
code you can refer to here to get started
A 50 pin, 0.5mm pitch, top-contact FPC connector is required to connect to this
screen. We show one in the photos but it is not included! You cannot solder this
connector directly to a PCB - a matching connector is required, you can pick one
up here.
The resistive touch screen is a classic 'analog' touch screen which requires
either a micro controller with analog inputs OR the use of a touch screen
controller such as this one
TECHNICAL DETAILS
2.8" diagonal LCD TFT display datasheet 240x320 resolution, 18-bit
(262,000) color capable - our code uses only 16-bits since its faster.
ILI9341 (datasheet) controller with built in video RAM buffer
Adafruit ILI9341 SPI library
8-bit RGB TFT Library (not as well supported, most uses prefer SPI)
Dimensions:
69mm x 50mm x 4mm / 2.7" x 2" x 0.2"
Weight: 24g
https://www.adafruit.com/product/1774 8‐6‐18
很抱歉,暂时无法提供与“1774”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+282.11760
- 200+112.56840
- 国内价格 香港价格
- 1+166.994171+21.63159
