Slow Vibration Sensor Switch (Hard to trigger)
PRODUCT ID: 1767
Description
The "poor man's" accelerometer/motion sensor! These spring-vibration switches are low sensitivity non-directional
vibration induced trigger switches. Inside is a stiff spring coiled around a long metal pin. When the switch is moved,
the spring touches the center pole to make contact. So, when there's motion, the two pins will act like a closed
switch. When everything is still, the switch is open. Great for basic projects and wearables!
We also have a version with a less stiff spring which makes it a little easier to trigger, and a version with a very soft
spring which makes it much easier to trigger!
Technical Details
Electrical characteristics:
o
o
o
o
o
o
o
o
o
o
o
Maximum Voltage: 12V
Contact Resistance: 10M ohm
Temperature Range: -40 to 80ºC
Operating lifespan: 100,000 cycles
Diameter: 5mm/0.2"
Height (w/ pins): 21mm/0.8"
Height (w/o pins): 11mm/0.4"
Weight: 0.30g
Engineered in NYC Adafruit ® https://www.adafruit.com/product/1767 5‐5‐17
很抱歉,暂时无法提供与“1767”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.374341+1.08684
