1869
1869
    ADAFRUIT
    SOLDER REWORK STA 580W 1 CH 120V
1869 数据手册
  Hot Air Soldering Rework Station w/ Three Nozzles - Quick 957DW+ PRODUCT ID: 1869           Description If you've ever made a mistake when surface‐mount soldering, you'll know how much of a pain it can be  to fix it without the right tools. It can add critical time to a project and can seriously dampen your  soldering momentum if you run into a bad component or a faulty reflow. With the Quick 957D  Soldering Station, you can easily rework your boards and get your project back on track. Its also  possible to use solder paste (in a syringe for example) to apply paste and then blow hot air over it to  melt the solder and get the components into place.    This essential tool has an internal pump and heater to blow a steady stream of temperature controlled  hot air to make it super easy to remove components, fix joints and jumpers, replace missing  components, or just correct something you've done wrong. The Quick 957D is great for beginners  because of it's low price and relative ease of use, there's also different nozzles for different sized parts.    It has a closed‐loop temperature control range between 100‐450°C (212‐842°F) and a digital display so  you can easily tell what temperature the air's blowing at. It has a power consumption of 580W and an  intelligent cooling system so the airflow remains on until it gets to below 100°C. Max air flow is  100L/minute ‐ but for most work you'll want to keep it a lot lower than that.    Just make sure to let the rework station heat up all the way before using it and be careful to use tools  and not your hands when using as it spits out, well, really hot air. Comes with three nozzles, use the  smallest size you can get away with ‐ they help avoid damaging other components if you are trying to  isolate one part of the board while avoiding a connector for example.  Technical Details o o o o o Rework Station: 180mm x 99mm x 145mm / 7.1" x 3.9" x 5.7"  Hose Length: 105 cm / 41.5"  Weight: 1588g / 3.5lbs  120VAC ‐ 580 Watts  Outer Diameters of Three Nozzles:   3mm / 0.12"   6.4mm / 0.25"   8.4mm / 0.33"                                                              https://www.adafruit.com/product/3632 10‐17‐17
很抱歉,暂时无法提供与“1869”相匹配的价格&库存,您可以联系我们找货
