1871
1871
    ADAFRUIT
    20MM COIN BATT BREAKOUT W/SWITCH
1871 数据手册
20mm Coin Cell Breakout w/On-Off Switch (CR2032) PRODUCT ID: 1871 DESCRIPTION - Simple but effective - this sewable breakout board has a CR2032 coin cell battery holder soldered on, an on/off switch and 0.1" pitch breakout pins for easy connecting. Great for powering very low-current projects, or adding a battery backup circuit to a real-time-clock or similar. There's two ground pins, one 'switched' power pin, and one pin that is always on. Comes with one fully assembled and tested breakout plus a small stick of 0.1" header so you can solder it on and plug into a breadboard. Coin cell battery is not included. http://www.adafruit.com/product/1871 11/12/2015 Technical Details Dimensions: 29mm x 28mm x 1.6mm / 1.1" x 1.1" x 0.06" Mounting hole distance: 22mm x 22mm / 0.9" x 0.9" Weight: 3.5g
很抱歉,暂时无法提供与“1871”相匹配的价格&库存,您可以联系我们找货
    库存:183
