Spy Camera for Raspberry Pi
PRODUCT ID: 1937
Description
Is your house haunted? Or, rather, are you convinced that your house is haunted but have never been able to
prove it since you've never had a camera that integrated with your raspberry pi but was still small enough
that the ghosts wouldn't notice it?
Luckily, the Spy Camera for Raspberry Pi is smaller than a thumbnail with a high enough resolution to
see people, or ghosts, or whatever it is you're looking for. It's about the size of a cell phone camera - the
module being just 8.5mm x 11.3mm - and has a stick-on back so it's easy to mount in a doorbell or behind a
teddy bear's eye (might as well be creative!)
The camera comes with a 289mm (11.4") long cable so you can extend and mount your Pi away from the
camera. Like the Raspberry Pi Camera Board, it attaches to your Raspberry Pi by way of one of the two
small sockets on the board upper surface. This interface uses the dedicated CSI interface, which was
designed especially for interfacing to cameras. The CSI bus is capable of extremely high data rates, and it
exclusively carries pixel data. The Raspberry Pi NOT INCLUDED
The camera is connected to the BCM2835 processor on the Pi via the CSI bus, a higher bandwidth link
which carries pixel data from the camera back to the processor. This bus travels along the ribbon cable that
attaches the camera board to the Pi. The ribbon cables is not compatible with the Pi Zero and we do not
have an adapter, check out the 'classic' Raspberry Pi cameras for Pi Zero use
The sensor itself has a native resolution of 5 megapixel, and has a fixed focus lens onboard. In terms of still
images, the camera is capable of 2592 x 1944 pixel static images, and also supports 1080p30, 720p60 and
640x480p60/90 video.
Technical Details
o
o
o
o
Camera Module Dimensions: 8.5mm x 11.3mm / .34" x .45"
Lens Diameter: 7.4mm / .29"
Total Length: 300mm / 11.8"
Weight: 1.9g
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1937”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+352.342871+45.55880
