1953
1953
    ADAFRUIT
    跳线 公型至母型, 3.00"(76.20mm) 28AWG
1953 数据手册
        Premium Female/Male 'Extension' Jumper Wires - 20 x 3" PRODUCT ID: 1953         Description These Female/Male 'extension' jumper wires for making wire harnesses or jumpering between headers  on PCB's. These premium jumper wires are 3" (75mm) long and come in a 'strip' of 20 (2 pieces of each  of ten rainbow colors). They have 0.1" male header contacts on one end and 0.1" female header  contacts on the other. They fit cleanly next to each other on standard‐pitch 0.1" (2.54mm) header. The  best part is they come in a 20‐pin ribbon cable. You can always pull the ribbon wires off to make  individual jumpers, or keep them together to make neatly organized wire harnesses.   We have tons of different Jumper Wires available, in all shapes and sizes!    Note: The length of the jumper wires is sometimes a bit longer than what is listed.    For best results, when plugging these in a line, have the sides with the 'silver latch bit' sticking out  since that side is a tiny bit wider than 0  Technical Details o o o Length: 75mm / 3"  Weight: 9.7g  Each wire is 28 AWG (7 strands @ 36 AWG)        https://www.adafruit.com/product/1953 7‐25‐17
很抱歉,暂时无法提供与“1953”相匹配的价格&库存,您可以联系我们找货
