Adafruit Pi Box Plus ‐ Enclosure for RasPi Model
B+/Pi 2/ Pi 3
PRODUCT ID: 1985
Description
PaintYourDragon is back with another gorgeous laser‐cut masterpiece. This time he's taken a
pass at updating the classic Adafruit Pi Box for the Raspberry Pi Model B+ / Pi 2.
Keep your Raspberry Pi® Model B+ computer safe and sound in this lovely clear acrylic enclosure.
We designed this case to be beautiful, easy to assemble and perfect for any use (but especially
for those who want to tinker!) This enclosure is not compatible with the Raspberry Pi Model A
or B
We also have a fully-injection molded case available in multiple glorious colors!
The case comes as 6 pieces that slide together and secure with four screws. Made of crystal‐clear
acrylic, this case keeps the Pi secure, has a hinged top for connector access, and even has little
feet cut into the sides so that it stands up above your desk. You can use all of the connectors on
the edges of the Pi: HDMI, Audio/Video, microSD slot, micro USB power, Ethernet and the 4 USB
ports. There's also a cut out to allow a 40‐pin IDC cable to the GPIO breakout pins on the Pi and
pass it though the case. For more advanced hacking, the enclosure is designed so that you can lift
or remove the top piece and plug any sort of cables you wish into the breakouts in the middle.
The case is airy enough that no additional vents or cooling is required ‐ we tested the enclosed Pi
over a 24 hour period at full load with no significant increase in temperature.
Be sure to check out more of our awesome Raspberry Pi accessories including:
Bare 4 GB SD card ‐ you'll need this to load the Debian image and is not included in a Pi
computer purchase. Tested and works perfectly! We also have a wide range of preburned SD cards
5V @ 2 Amp USB power supply ‐ you'll need this to power the Pi using a Micro USB
cable. Tested and works perfectly!
HDMI cable ‐ required to connect a Pi to a monitor and is not included in a Pi computer
purchase
Ethernet cable ‐ required if you want to connect your Pi to the Internet via a router
Keyboards and Mice ‐ We have a range of wired and wireless options
A wide range of accessories and essentials
Various small displays as well as nice Pi-compatible HDMI monitors in a range of sizes,
from 2.5" to 10"
o
o
o
o
o
o
o
This product comes with the 6 acrylic pieces and assembly hardware. Raspberry Pi computer is
not included. No other cables or connectors or accessories are included
Technical Details
https://www.adafruit.com/product/1985 7‐25‐17
很抱歉,暂时无法提供与“1985”相匹配的价格&库存,您可以联系我们找货
