1988
1988
    ADAFRUIT
    Raspberry Pi - 缆线组件
1988 数据手册
        GPIO Ribbon Cable for Raspberry Pi Model A+/B+/Pi 2/Pi 3/Pi 4 - (40 pins) Product ID: 1988 Description That new Raspberry Pi® Model B+ computer you just got has a row of 2x20 pin headers soldered on - those are the GPIO (general purpose input/output) pins and for those of us who like to hack electronics, they are where the real fun is. By programming the Pi, you can twiddle those pins high or low, send and receive I2C and SPI data, and access the 3V and 5V power rails. This cable is not compatible with the Raspberry Pi Model B or Model A! If you want to bridge those contacts out onto another PCB, you'll want this cable! It's 6" long and has 40 socket & wire sets. Pin #1 is marked with a white wire. It's available in custom Adafruit Black and is an essential accessory for getting started with your brand new B+! Note: The Raspberry Pi Model A+, Raspberry Pi 2, Raspberry Pi 3, and Raspberry Pi 4 are also compatible with this product! Technical Details Dimensions:   ~150mm x 50mm / ~5.9" x 1.9"  Weight: 20.6g                                https://www.adafruit.com/product/1988/1‐19‐22
很抱歉,暂时无法提供与“1988”相匹配的价格&库存,您可以联系我们找货
