2017
2017
    ADAFRUIT
    BREADBOARD TERM STRIP 0.70X0.30"
2017 数据手册
      Mini Solderless Breadboard - 2x4 Points PRODUCT ID: 2017         Description  Add a micro‐slice standard solderless breadboard to your Perma‐Proto or other perf‐board. This 2x4  point solder‐less breadboard is a good way to add some solderless prototyping space if you just need to  have a couple points. In our example photo, we put a chip and some jumper wires in the breadboard,  but you can use anything with 0.1" spaced header.  Comes with one 18mm x 8mm x 8mm piece of solder‐less breadboard.  There are two white posts on  the bottom for PCB positioning. In our example we snapped those off and soldered two of them into  our Perma‐Proto.    Technical Details  o o o o 2 rows of 4 holes  Breadboard: 18mm x 8mm x 8mm / 0.7" x 0.3" x 0.3"  Metal pins: 3mm   Weight: 1.4g        https://www.adafruit.com/product/1988 7‐25‐17
很抱歉,暂时无法提供与“2017”相匹配的价格&库存,您可以联系我们找货
  • 1+6.402201+0.81540
库存:70
