2018
2018
    ADAFRUIT
    BREADBOARD TERM STRIP 1.10X0.30"
2018 数据手册
Mini Solderless Breadboard - 2x8 Points PRODUCT ID: 2018  Description Add a micro-slice standard solderless breadboard to your Perma-Proto or other perf-board. This 2x8 point solder-less breadboard is a good way to add some solderless prototyping space if you just need to have a couple points. In our example photo, we put a Trinket in the breadboard, but you can use anything with 0.1" spaced header. Comes with one 29mm x 8mm x 8mm piece of solder-less breadboard. There are two white posts on the bottom for PCB positioning. In our example we snapped those off and soldered two of them into our Perma-Proto.  Technical Details o o o o 2 rows of 8 holes Breadboard: 29mm x 8mm x 8mm / 1.1" x 0.3" x 0.3" Metal pins: 3mm Weight: 2.2g                                Engineered in NYC Adafruit ® https://www.adafruit.com/product/2018 7‐3‐17
很抱歉,暂时无法提供与“2018”相匹配的价格&库存,您可以联系我们找货
