2058
2058
    ADAFRUIT
    KNOB FLUTED METAL POTENTIOMETER
2058 数据手册
      Slim Metal Potentiometer Knob - 10mm Diameter x 10mm - T18 PRODUCT ID: 2058        Description This slim and modern potentiometer is small and compact, yet looks good and has a nice feel.  We hand selected the best knobs for your project in different sizes and varieties.  This one is  the Slim Metal Knob 10mm diameter x 10mm Tall (T18 Splines).  It's a brushed aluminum knob with a shiny black (anodized?) coating.  It kind of looks like the  type of knob you'd find in a very fancy, modern kitchen.  There's a silver mark on the black  finish so you can know where you are and figure out where you're going.  It's a good knob if  you're looking for something basic and subtle and it's super tiny and subdued.  We also have a  taller version in the same style.  This knob will not work on our Rotary Encoder (which has a D shaft)! It will work, however, on  all of our Potentiometers (which have T18 shafts)      Technical Details  Diameter: 10mm / 0.4"  Height: 10mm / 0.4"  Weight: 1g        https://www.adafruit.com/product/2058 7‐25‐17
2058
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管输出,6脚光电晶体管负极。
4. 参数特性:工作温度范围为-20℃至+70℃,隔离电压可达5000Vrms。
5. 功能详解:EL817通过光电效应实现电信号的传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于工业控制系统、医疗设备、通信设备等领域。
7. 封装信息:采用DIP6封装形式。
很抱歉,暂时无法提供与“2058”相匹配的价格&库存,您可以联系我们找货
