2121
2121
    ADAFRUIT
    DRILL BIT CARBIDE 0.043
2121 数据手册
Carbide PCB Drill Bit - 1.1mm PRODUCT ID: 2121 Description If you've started designing your own PCBs in Eagle or KiCad and want to make your PCB a reality, you may start out with an etching system to pattern out traces. But that's only half the job! You'll also need a way to drill some tiny and accurate holes. That's why we've started selling these PCB drill tips in a variety of sizes. They're made from carbide (tungsten steel) and are suitable for circuit boards, electronics, SMT, molding, metal processing, telecommunications, and other uses. Each drill tip has a high hardness, wear resistance and strength and they're also super sharp which helps when drilling through PCBs. The drill bits also don't easily bend or break and come in a nice plastic case to store your tips when you're not using them. This product comes with one 1.1mm Carbide PCB Drill Bit in a protective plastic case. Technical Details o Total length: 38mm o 1/8" Shank o Diameter: 1.1mm                               Engineered in NYC Adafruit ® https://www.adafruit.com/product/2121 6‐26‐17
很抱歉,暂时无法提供与“2121”相匹配的价格&库存,您可以联系我们找货
  • 1+22.549991+2.92291
