2457
2457
    ADAFRUIT
    铰接夹 橡胶尖头
2457 数据手册
Toggle Clamp - Large Size - 201B PRODUCT ID: 2457 Description   *Ka-thunk* Pin down that PCB with our Toggle Clamp, a sturdy and reliable way to quickly press and release with precision! A pogo-pin bed is a great way to connect and test boards without any soldering, but you have to somehow get that PCB aligned right and evenly pressed down on each pogo. After much experimenting, we settled on this toggle clamp and we use it all the time in our testing processes. This beauty is strong enough to grip onto a PCB, but the rounded rubber tip ensures it won't mar or damage any circuits. You'll need to bolt it securely, then attach the rubber nub with the included hex nuts. The height of the nub can be adjusted, as can the location along the clamp.   Technical Details  o o Diagram https://cdn-shop.adafruit.com/product-files/2457/201-bx.jpg Weight: 0.3lbs                               Engineered in NYC Adafruit ® https://www.adafruit.com/product/2457 5‐5‐17
很抱歉,暂时无法提供与“2457”相匹配的价格&库存,您可以联系我们找货
