2460
2460
    ADAFRUIT
    1.575GHz 通用 陶瓷贴片 RF 天线 2dBi U.FL(UMCC),IPEX MHF1 表面贴装型
2460 数据手册
Passive GPS Antenna uFL - 9mm x 9mm 2dBi gain PRODUCT ID: 2460  Description Wow that's a tiny GPS antenna! This passive antenna is only 9mm x 9mm x 6.5mm in size, with a 50mm long uFL cable. Great for when you want to keep things small. Comes with a standard uFL connector on the end. Perfect for our FONA 808! Not good for our Ultimate GPS breakouts/shields/hat as those are designed for active antennas. This is the 9mm version - we also have a slightly bigger (15mm) uFL GPS Antenna.  Technical Details o o o o Interface: IPX uFL Gain: approx -2 dBi Wire Length: 50mm / 2" Weight: 2.4g        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“2460”相匹配的价格&库存,您可以联系我们找货
