2670
2670
    ADAFRUIT
    模拟板,通用 无镀层通孔(NPTH) 一孔一焊盘(圆形) 0.1"(2.54mm)栅格
2670 数据手册
Bakelite Universal Perfboard Plates - Pack of 10 PRODUCT ID: 2670 Description   Make your next project as you imagine it with prototyping perfboards that can easily be cut with scissors like these Bakelite Universal Perfboard Plates! We wanted a perfboard that was both customizable and durable and bakelite was the answer. Like most perfboards these plates come on thin (1.2mm) sheets with holes drilled in a grid, each spaced 0.1" apart. There are some big copper pads (for mechanical connections? We're not exactly sure) on both ends of the board and each individual hole is ringed with copper on the bottom side. A perfboard as opposed to our classic perma-protos or breadboards has no default connectivity so you have total freedom with how you'd like to lay-out your circuits. Cut and solder away! We used our classic Super Scissors in the example. Comes in a pack of 10 for all your prototyping needs! Technical Details  o o o o Holes are 30x24 Mounting holes distances: 82mm x 62mm / 3.2" x 2.4" Dimensions: 70.1mm x 90.8mm x 1.2mm / 2.8" x 3.6" x 0.05" Weight: 8.5g                                 Engineered in NYC Adafruit ® https://www.adafruit.com/product/2670 5‐17‐17
很抱歉,暂时无法提供与“2670”相匹配的价格&库存,您可以联系我们找货
  • 8+8.591208+1.11150
库存:86
2670
  • 1+43.678961+5.65104
    • 1+8.443921+1.09245
    库存:86
