2732
2732
    ADAFRUIT
    LIGHTBLUE BEAN
2732 数据手册
    LightBlue Bean PRODUCT ID: 2732 The LightBlue Bean is a low energy Bluetooth Arduino microcontroller that is programmed wirelessly and is perfect for your smartphone controlled projects! Using Bluetooth 4.0, this Arduino-compatible board is a serial protocol that allows the LBM313 Bluetooth Low Energy module and Atmega328p to communicate both messages from the client (OS X, iOS, etc.) to theArduino. As well as send special commands to the LBM313 to do things like read the temperature sensor and set the LED. In other words, this tiny little bean can handle anything from opening your combination lock with your phone to reminding you to pick up Almond milk from the grocery store, to turning your fan on automatically when you get too hot. All while running on a single coin cell battery! The folks over at Punch Through Design have made it easy to wirelessly program The LightBlue Bean from your iPhone, iPad, Android phone, Mac or PC! Features Include:  3-axis accelerometer  Temperature sensor  RGB LED  CR2032 coin cell battery  ATmega 328p  8 MHz clock speed  3V operating voltage  6 digital I/O pins, 2 analog pins  Bluetooth LE Peripheral  Wireless programming  Support on OS X and iOS  Including Windows 8 support! Not supported by Windows 7 For more information check out Bean Talk, the LightBlue Bean forums! Note: Battery is included TECHNICAL DETAILS Schematic and board layout https://cdn-shop.adafruit.com/product-files/2732/Bean_revE_board_export.pdf For product support, replacement parts and warranty for all Beantalk products, click here! http://beantalk.punchthrough.com/ Product Dimensions: 45.7mm x 20.5mm x 8.5mm / 1.8" x 0.8" x 0.3" Product Weight: 7.3g / 0.3oz                                              https://www.adafruit.com/product/2732 4‐3‐18
很抱歉,暂时无法提供与“2732”相匹配的价格&库存,您可以联系我们找货
