USB to 2.1mm DC Booster Cable - 12V
PRODUCT ID: 2778
DESCRIPTION
This cable is kinda fascinating - it has an integrated boost converter, so you can
plug it into any USB port (from a computer, battery pack, etc) and it will give you
a higher DC voltage! It's a handy way to power 12V powered devices with a
center-positive 2.1mm DC barrel jack from a USB port. We also have a version
that provides 9V, and if you just need a passthough cable, here's one for 5VDC.
These are rated at 500mA output, but you can go a little higher, we pulled
700mA and we got a little voltage droop but it worked fine. Probably best not to
draw 700mA continuously though!
Here's our measurements for various current draws when we set our bench
supply to provide a steady 5V voltage
50mA (12.4V output), 150mA, 83% efficiency
100ma (12.4V), 290mA in, 86% efficiency
200ma (12.3V): 570mA in, 86% efficiency
300ma (12.2V): 870mA in, 84% efficiency
500ma (12.1V): 1500mA in, 81% efficiency
700ma (11.4V): 2140mA in, 75% efficiency
So, overall there's a 85% efficiency at low current draw that drops do about 80%
at high current use. There's also a 3 mA quiescent current. Note that often times
the USB port voltage can droop too, and in addition you may have power losses
with any thin or low quality cables with high resistivity!
TECHNICAL DETAILS
Cable Length: approximately ~1.15m / ~45"
Weight: 34.6g
https://www.adafruit.com/product/2778/6‐24‐19
很抱歉,暂时无法提供与“2778”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+57.373831+7.42218
