2790
2790
    ADAFRUIT
    适配器连接器 立体声耳机插孔,3.50mm(0.141",1/8") 至 端接块,3 位置 黑色,绿色
2790 数据手册
3.5mm (1/8") Stereo Audio Plug Terminal Block PRODUCT ID: 2790  Description One truth about working with audio is you always need the cable or adapter you don't have in your toolbox. That's why we love these terminal-block audio connectors so much. No soldering required! Use stranded or solid core wire and a small screw driver to create custom wiring jigs. This is the 3.5mm (1/8") Stereo Audio Plug Terminal Block. It's the most common size and style of audio connector, used in most headphones or basic audio connections you're looking to make. We also have a (matching) Stereo Audio Jack Terminal Block!  Technical Details o o 42.2mm x 18.6mm x 12.7mm / 1.66" x 0.73" x 0.50" Weight: 8.5g                                 Engineered in NYC Adafruit ® https://www.adafruit.com/product/2790 6‐26‐17
很抱歉,暂时无法提供与“2790”相匹配的价格&库存,您可以联系我们找货
