3.5 / 1.3mm or 3.8 / 1.1mm to 5.5 / 2.1mm DC
Jack Adapter Cable
PRODCT ID: 2788
Description
This convenient 3.8mm/1.3mm or 3.5mm/1.1mm or 1.3mm DC to 2.1mm DC adapter cable lets you
plug one of our solar panels into our optimized Solar Lithium Ion/Polymer charger!
2.1mm inner diameter (5.5mm outer diameter) is the most common type of DC plug, but you can use this
adapter for anything else that has a 1.1 or 1.3mm ID (3.5-3.8mm OD) DC jack! The adapter has little
springy parts inside so it can be used with 3.5mm to 3.8mm OD plugs.
Technical Details
Cable Length (end to end): ~165mm / 6.5"
Engineered in NYC Adafruit ® https://www.adafruit.com/product/2788 5‐17‐17
很抱歉,暂时无法提供与“2788”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+13.264461+1.71218
