2791
2791
    ADAFRUIT
    适配器连接器 立体声耳机插孔,3.50mm(0.141",1/8") 至 端接块,3 位置 黑色,绿色
2791 数据手册
3.5mm (1/8") Stereo Audio Jack Terminal Block PRODUCT ID: 2791  Description One truth about working with audio is you always need the cable or adapter you don't have in your toolbox. That's why we love these terminal-block audio connectors so much. No soldering required! Use stranded or solid core wire and a small screw driver to create custom wiring jigs. This is the 3.5mm (1/8") Stereo Audio Jack Terminal Block. It's the most common size and style of audio connector, used in most headphones or basic audio connections you're looking to make. We also have a (matching) Stereo Audio Plug Terminal Block  Technical Details o o 37.3mm x 17.9mm x 12.1mm / 1.46" x .70" x 0.48" Weight: 7.5g                                 Engineered in NYC Adafruit ® https://www.adafruit.com/product/2791 6‐26‐17
很抱歉,暂时无法提供与“2791”相匹配的价格&库存,您可以联系我们找货
