2798
2798
    ADAFRUIT
    PARTICLE MAKER KIT WITH PHOTON
2798 数据手册
Particle Maker Kit with Photon PRODUCT ID: 2798  Description The Particle Maker Kit has just about everything you need to get started with your Particle Photon. It's the kind of no nonsense starter kit that's filled with all the components and accessories you need to build simple internet enabled projects and up your hacker level from zero to hardware hero. This kit also includes a pretty nifty carrying case that you can tidy up your projects with and keep displayed on your workbench. Kit includes: o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o Plastic case: 7" x 4.9" x 1.8" Photon w/ headers USB Micro B Cable Flex Antenna Mini Breadboard Proto-board Deluxe Jumper Wire Pack Male to female jumper wires x 10 Battery Holder - 4 x AA 12-pin Female Headers x 5 40-pin Male breakaway headers x 2 10nF Ceramic Capacitor x10 100nF Ceramic Capacitor x10 100 uF Electrolytic Capacitor x5 Red LED x5 Green LED x5 RGB LED IN4004 DIode x6 IR LED 220 Ohm Resistors x10 1K Ohm Resistors x10 10k Ohm Resistors x10 Photocells x2 10K Rotary Potentiometer DS18B20 Temp sensor Waterproof DS18B20 Temp Sensor w/ wires Piezo Buzzer Mini pushbuttons x3 SPDT Switch x2 SPDT Relay S9013 NPN Transistor PIR Sensor Pancake Vibration Motor Micro Servo Serial OLED Screen 0.96"        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“2798”相匹配的价格&库存,您可以联系我们找货
