2975
2975
    ADAFRUIT
    基本元器件套件 元器件
2975 数据手册
    Adafruit Parts Pal PRODUCT ID: 2975       Description LEDs and passives and transistors and switches and op‐amps oh my! The Adafruit Parts Pal is the  ultimate companion for an entry‐level maker learning electronics. This kit is your friend whenever you  need to build up a project. It contains many of our most popular components and prototyping parts all  wrapped up in one parts pack so you can open up and dig right in.  Kit Contents:  Prototyping:  o o o o 1x ‐ Storage box with latch  1x ‐ Half‐size breadboard  20x ‐ Male/male jumper wires ‐ 3" (75mm)  10x ‐ Male/male jumper wires ‐ 6" (150mm)  LEDs:  o o o 5x ‐ 5mm Diffused green LEDs  5x ‐ 5mm Diffused red LEDs  1x ‐ 10mm Diffused Common‐Anode RGB LED  Capacitors:  o o o o o 10x ‐ 1.0uF Ceramic capacitors  10x ‐ 0.1uF Ceramic capacitors  10x ‐ 0.01uF Ceramic capacitors  5x ‐ 10uF 50V Electrolytic capacitors  5x ‐ 100uF 16V Electrolytic capacitors  Resistors:  o o o o 10x ‐ 560 ohm 5% axial resistors  10x ‐ 1K ohm 5% axial resistors  10x ‐ 10K ohm 5% axial resistors  10x ‐ 47K ohm 5% axial resistors  Semiconductors:  o o o o o o o o 5x ‐ 1N4001 Diodes  5x ‐ 1N4148 Signal Diodes  5x ‐ NPN Transistor PN2222 TO‐92  5x ‐ PNP Transistor PN2907 TO‐92  2x ‐ 5V 1.5A Linear voltage regulator ‐ 7805 TO‐220  1x ‐ 3.3V 800mA Linear voltage regulator ‐ LD1117‐3.3 TO‐220  1x ‐ TLC555 wide‐voltage range, low‐power 555 Timer  1x ‐ LM358 Dual operational Amplifier  Sensors:  o o o o o 1x ‐ Photocell  1x ‐ Thermistor (Breadboard version)  1x ‐ Vibration sensor switch  1x ‐ 10K Breadboard trim potentiometer  1x ‐ 1K Breadboard trim potentiometer  Mechanical:  o o o o o  1x ‐ Piezo buzzer  5x ‐ 6mm Tactile switches  3x ‐ SPDT slide switches  1x ‐ 40‐pin Break‐away male header strip  1x ‐ 40‐pin female header strip  Technical Details              Revision history  o As of July 20, 2016 we now include an LM358 dual opamp!  Datasheets:  o o o o o o o o TLC555  LM358  PN2222A  MPS2907A  LD1117  L7805CV  Eletrolytic Capacitor  Thermistor   Resistance at 25 degrees C: 10K +‐ 1%   B25/50 = 3950+‐ 1%   Thermal time constant
很抱歉,暂时无法提供与“2975”相匹配的价格&库存,您可以联系我们找货
