3026
3026
    ADAFRUIT
    MAKE:BLUETOOTH BOOK PARTS PACK -
3026 数据手册
Make:Bluetooth Book Parts Pack - Book Not Included PRODUCT ID: 3026  Description Pickup a copy of Make: Bluetooth LE Projects for Arduino, RasPi, and Smartphones and then hit the ground running with these great bluetooth accessories. This pack DOES NOT include the book! (But you can pick it up in the Adafruit shop) This pack is perfect for somebody who is up for a little challenge and eager to dive further into the wonderful world of Bluetooth LE, and by picking up all of the parts in a pack you save 20%! This pack includes: o o o o o o o o o o o Bluefruit LE - Bluetooth Low Energy (BLE 4.0) - nRF8001 Breakout Adafruit BME280 I2C or SPI Temperature/Humidity/Pressure Sensor 9V DC 1000mA Regulated Switching Power Supply Half Size Breadboard Rotary Encoder & Extras Breadboard Friendly SPDT Slide Switch NeoPixel Ring - 16 x 5050 RGB LED w/ Integrated Drivers Lock-style Solenoid - 12VDC Premium Male/Male Jumper Wires - 20 x 3" Premium Male/Male Jumper Wires 20 x 6" Make: Bluetooth Parts Pack component bag including:  1x NPN Transistor PN2222  5x 10K 5% 1/4W Resistors  5x 220 ohm 5% 1/4W Resistors  5x 12mm Tactile Switch  5x Diffused 5mm Green LEDs  5x Diffused 5mm Red LEDs This kit will let you build just about all of the projects in the Make:Bluetooth book. You also will need an Arduino UNO or compatible like an Adafruit Metro. You will need to do some soldering and wiring, so be sure to check that you have a soldering iron, solder, hand tools, etc. This pack DOES NOT include the book! (But you can pick it up in the Adafruit shop)        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3026”相匹配的价格&库存,您可以联系我们找货
