Adafruit RGB Matrix Featherwing Kit - For M0
and M4 Feathers
PRODUCT ID: 3036
https://www.adafruit.com/product/3036 - Slide1
https://www.adafruit.com/product/3036 - Slide9
DESCRIPTION
Ahoy! It's time to create a dazzling light up project with our new RGB Matrix FeatherWing.
Now you can quickly and easily create projects featuring your favorite 16 or 32-pixel tall
matrix boards. Using our RGB Matrix library is easy and works wonderfully with any of our
M0 or M4 based Feathers.
Please note: This wing is only tested/designed to work with the SAMD21 M0 and SAMD51 M4
Feathers. It's not for use with any other Feathers at this time. (Th at said, if you'd like to add
support, we'd be happy to take a pull request on the library repo)
This wing can be assembled in one of two ways. You can either solder in a 2x8 IDC shrouded
header on the top, then plug in the IDC cable that came with your matrix. This makes it easy
to stack on top of your Feather. Or, you can solder in the 2x10 socket header on
the bottom of the Wing, and then stack your Feather on top. That way you can plug it
directly into the back of the matrix *mind blown*
This FeatherWing will work great with any of our 16x32, 32x32 or 64x32 RGB matrices, and
is definitely the easiest way to glow and go.
Either way you decide to go, you can plug a 5V DC power pack into the 2.1mm DC jack. That
5V is polarity protected and then output on the other side to a 5.08mm terminal block. An
onboard regulator will provide 3.3V power to your Feather so you don't need a separate USB
or battery, this makes for a very compact build!
Each order comes with one FeatherWing PCB with surface mount parts attached, a 2x8 IDC
header, a 2x10 female socket, 2.1mm DC jack, 5.08mm terminal block, and some male
header. You may also want some Feather stacking headers or female headers depending on
how you plan to attach/stack your Feather.
TECHNICAL DETAILS
Product Dimensions: 51.0mm x 23.0mm x 4.0mm / 2.0" x 0.9" x 0.2"
Product Weight: 3.5g / 0.1oz
LEARN
Primary Guide: Adafruit RGB Matrix FeatherWing
Blast those pixels!
很抱歉,暂时无法提供与“3036”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+74.933221+9.68506
