3123
3123
    ADAFRUIT
    ADAPT DB9M TO TERM BLK 9POS BLK
3123 数据手册
DE-9 (DB-9) Male Plug to Terminal Block Breakout PRODUCT ID: 3123 Description Make your own custom DE-9 cable or DE-9 interface with ease, using this DE-9 Plug to Terminal Block Breakout. You get a nice solid PCB with an DE-9 socket and two strips of terminal blocks that you can use with stranded or solid core wire to quickly assemble your own wiring jigs. Perfect for when you need a non-standard wiring setup or interfacing to an older device with one of these connectors Sometimes DE-9 connectors are referred to as DB-9. Technically that's the wrong name, but its so ingrained that most people only know the connector as DB-9. Comes with one fully assembled breakout and a clip-on housing. Technical Details Product Dimensions: 51.7mm x 33.5mm x 20.5mm / 2.0" x 1.3" x 0.8" Product Weight: 22.3g / 0.8oz                               Engineered in NYC Adafruit ® https://www.adafruit.com/product/3123 6‐23‐17
很抱歉,暂时无法提供与“3123”相匹配的价格&库存,您可以联系我们找货
