DE-15 (DB-15) Female Socket to Terminal
Block Breakout PRODUCT ID: 3124
Description
Make your own custom DE‐15 cable or DE‐15 interface with ease, using this DE‐15 Socket to Terminal
Block Breakout. You get a nice solid PCB with an DE‐15 socket and two strips of terminal blocks that
you can use with stranded or solid core wire to quickly assemble your own wiring jigs.
Perfect for when you need a non‐standard wiring setup or interfacing to a device with a VGA interface
(that's what these connectors were used for the most).
Sometimes DE‐15 connectors are referred to as DB‐15. Technically that's the wrong name, but its so
ingrained that most people only know the connector as DB‐15.
Comes with one fully assembled breakout and a clip‐on housing.
Technical Details
Product Dimensions: 66.6mm x 33.4mm x 20.8mm / 2.6" x 1.3" x 0.8"
Product Weight: 30.4g / 1.1oz
https://www.adafruit.com/product/3124 7‐26‐17
很抱歉,暂时无法提供与“3124”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+39.330671+5.08960
