3141
3141
    ADAFRUIT
    跳线 母头至母头,拉链式,40 芯 6.00"(152.40mm) 28AWG
3141 数据手册
Premium Female/Female Raw Custom Jumper Wires - 40 x 6" (150mm) PRODUCT ID: 3141 Description   Our Raw F/F Jumper Wires are perfect for making custom jumper wire sets for wire harnesses or jumpering between headers on PCB's. These premium jumpers are a little over 6" (150mm) long and come in a 'strip' of 40 (4 pieces of each of the ten colors). The 0.1" spacing raw sockets on either end made to be custom fitted with your choice of housing blocks to meet your prototyping needs. You can always pull the ribbon wires off to make individual jumpers, or keep them together to make neatly organized wire harnesses. We suggest picking up some extra-long break-away header pins as well, you can stick those into the sockets to turn the cables into female-male extension jumpers! Note: The length of the jumper wires is sometimes a bit longer than what is listed. Technical Details  o Each wire is 28 AWG (7 strands @ 36 AWG) Product Dimensions: 190.0mm x 55.2mm x 2.4mm / 7.5" x 2.2" x 0.1" Product Weight: 27.0g / 1.0oz                               Engineered in NYC Adafruit ® https://www.adafruit.com/product/3141 5‐5‐17
很抱歉,暂时无法提供与“3141”相匹配的价格&库存,您可以联系我们找货
