3142
3142
    ADAFRUIT
    跳线 公头至公头,拉链式,40 芯 6.00"(152.40mm) 28AWG
3142 数据手册
Premium Male/Male Raw Jumper Wires - 40 x 6" (150mm) PRODUCT ID: 3142  Description Our Raw Male/Male Jumper Wires are perfect for making a custom jumper wire sets for wire harnesses or jumpering between headers on PCB's. These premium jumpers are a little over 6" (150mm) long and come in a 'strip' of 40 (4 pieces of each of the ten colors). The 0.1" raw sockets on either end are designed to be custom fitted with your choice of housing blocks to meet your prototyping needs. You can always pull the ribbon wires off to make individual jumpers, or keep them together to make neatly organized wire harnesses. If you're looking to set up an extending connection we suggest combining our F/F Raw jumpers with some extra-long break-away header pins. Add the pins to one end to turn the cables into female-male jumpers! Note: The length of the jumper wires is sometimes a bit longer than what is listed.  Technical Details o Each wire is 28 AWG (7 strands @ 36 AWG) Product Dimensions: 190.0mm x 55.2mm x 2.4mm / 7.5" x 2.2" x 0.1" Product Weight: 29.1g / 1.0oz        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3142”相匹配的价格&库存,您可以联系我们找货
