Pimoroni Zero LiPo
PRODUCT ID: 3196
Description
Having a discrete, slick, and tidy power supply is always tricky when taking a project on the go...but get
ready to roam the earth worry free with the
Features: tiny little Pimoroni Zero LiPo! It aims to give you the most compact power supply possible for
all versions of Raspberry Pi.
You can either solder the 0.8mm thick PCB directly to the bottom of your GPIO header for a permanent
solution or solder on the provided 2x4 0.1" female header which will allow you to remove your Zero LiPo
at any time (but will block the GPIO pins).
It uses the TPS61232 Step-Up Boost Converter from Texas Instruments which offers up to 96% efficiency.
The board includes power on and battery low indicator LEDs. During shutdown (due to undervoltage or
external selection) the quiescent current is just 15uA sip.
Please note: This is not a charger, you will need a separate charger to keep your LiPo/LiIon batteries juiced
up! We recommend using our Micro Lipo to top up your battery.
Features:
o
o
o
o
o
o
o
o
o
0.8mm thick PCB
Shaped to sit as low as possible on the Raspberry Pi 3, 2, Zero, A+, B+
2-pole JST connector ideal for most LiPo/LiIon batteries
Power and low battery LED indicators
Supplies up to 1.5A continuous current
Low battery warning at 3.4V (assets GPIO #4 high)
Automatic shutdown at 3.0V to protect your battery
VBAT+, GND, and EN pins available to break out
15uA quiescent current
Kit includes: Zero LiPo, Rubber foot, 2x4 0.1" female header
Technical Details
For product support, replacement parts and warranty for Pimoroni products visit the Pimoroni forum or
contact Pimoroni directly.
Product Dimensions: 40.4mm x 22.2mm x 6.5mm / 1.6" x 0.9" x 0.3"
Product Weight: 2.6g / 0.1oz
Engineered in NYC Adafruit ® https://www.adafruit.com/product/3196 4‐11‐17
很抱歉,暂时无法提供与“3196”相匹配的价格&库存,您可以联系我们找货
