Teensy 3.5 without headers
RODUCT ID: 3267
Description
The awesome new Teensy 3.5 is a small, breadboard-friendly development board designed by Paul
Stoffregen and PJRC. Teensy 3.5 brings a low-cost 32-bit ARM Cortex-M4 platform to hobbyists,
students and engineers, using an adapted version of the Arduino IDE (Teensyduino) or programming
directly in C language. Teensy 3.5 is an upgrade over 3.2, for when you need even more power!
Version 3.5 features a 32 bit 120 MHz ARM Cortex-M4 processor with floating point unit. All digital pins
are 5 volt tolerant. The unique specs for the 3.5 are:
o
o
o
o
o
o
120 MHz ARM Cortex-M4 with Floating Point Unit
512K Flash, 192K RAM, 4K EEPROM
Microcontroller Chip MK64FX512VMD12
1 CAN Bus Port
16 General Purpose DMA Channels
5 Volt Tolerance On All Digital I/O Pins
The latest in the line of very powerful, USB-capable microcontrollers, the Teensy 3.5 and 3.6 development
boards are faster, more capable, and bigger, putting even more pins on a solderless breadboard. Teensy 3.5
offers a little bit less in its features (MCU, RAM, Flash, clock and some peripherals) which makes it
slightly cheaper than Teensy 3.6. Teensy 3.5 has 5V tolerance on all digital I/O pins. Only Teensy 3.6 has a
USB High Speed (480 Mbit/sec) port accessed using 5 pins on the board.
Please note: Teensy 3 boards are not official Arduino-brand products. Although the Teensyduino IDE
has been adapted so that many Arduino projects will work with the Teensy, there will still be a lot of
libraries and shields that may not work with this device! If you're new to microcontrollers, we suggest
going with a classic Arduino UNO since all Arduino projects, examples and libraries will work with it.
More Specifications, Details & Features:
o
o
o
o
o
o
o
o
o
o
o
o
o
o
o
o
62 I/O Pins (42 breadboard friendly)
25 Analog Inputs to 2 ADCs with 13 bits resolution
2 Analog Outputs (DACs) with 12 bit resolution
20 PWM Outputs (Teensy 3.6 has 22 PWM)
USB Full Speed (12 Mbit/sec) Port
Ethernet mac, capable of full 100 Mbit/sec speed
Native (4 bit SDIO) micro SD card port
I2S Audio Port, 4 Channel Digital Audio Input & Output
14 Hardware Timers
Cryptographic Acceleration Unit
Random Number Generator
CRC Computation Unit
6 Serial Ports (2 with FIFO & Fast Baud Rates)
3 SPI Ports (1 with FIFO)
3 I2C Ports (Teensy 3.6 has a 4th I2C port)
Real Time Clock
Technical Details
Product Dimensions: 62.3mm x 18.0mm x 4.2mm / 2.5" x 0.7" x 0.2"
Product Weight: 4.8g / 0.2oz
o
o
Diagram (front) https://cdn-shop.adafruit.com/product-files/3267/3267_front.pdf
Diagram (back) https://cdn-shop.adafruit.com/product-files/3267/3267_back.pdf
Engineered in NYC Adafruit ® https://www.adafruit.com/product/3267 6‐28‐17
很抱歉,暂时无法提供与“3267”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+263.382071+34.07249
