3283
3283
    ADAFRUIT
    IOT PHAT RASPB PI WIFI BTLE
3283 数据手册
Red Bear IoT pHAT for Raspberry Pi - WiFi + BTLE PRODUCT ID: 3283        Description So you've got your Pi 3 with its built-in wireless LAN and Bluetooth, but what about your Pi Zero? Say hello to the IoT pHAT from Red Bear! This Zero-size board provides WiFi (802.11bgn / 2.4GHz) and Bluetooth (v4.1 / BTLE) connectivity direct from the GPIO header. You don’t need to use a dongle plugged into the Pi Zero’s solitary data micro-USB port via a USB OTG adapter. Just snap it on top of a Raspberry Pi Zero (or really, any Raspberry Pi with a 2x20 connector)! The IoT pHAT provides a neat and convenient way to add WiFi and Bluetooth connectivity to your Pi Zero, while freeing up the USB data port. Using the same wireless radio chip as the Pi 3 results in reliable signal strength and quality via an on-board or optional external antenna. As with other pHATs, it works with all of the 40-pin Raspberry Pi variants - 2/B+/A+/Zero - but using it with the Pi Zero makes for a super-tiny package. Features: o o o o o o AMPAK AP6212A Wireless Module (Broadcom BCM43438 A1 chip inside)  WiFi (802.11bgn / 2.4GHz)  Bluetooth (4.1) and BLE support Single antenna for concurrent WiFi and Bluetooth operations  Onboard PCB antenna  External antenna connector  Antenna switch for extenal antenna 32 Kbit (4 KByte) EEPROM for DTOverlay configuration 40-pin connector  WiFi: SDIO v2.0 - up to 20 MHz clock rate  Bluetooth: UART (up to 4 Mbps) FCC/CE certified Pre-soldered with 40-pin female header, no assembly required! Pi Zero not included!  Technical Details For technical inquiries, please visit Red Bear's support forum. If you think you have a faulty unit, kindly open a support ticket and Red Bear staffs will follow up with you. Product Dimensions: 65.0mm x 30.0mm x 11.0mm / 2.6" x 1.2" x 0.4" Product Weight: 10.5g / 0.4oz                               Engineered in NYC Adafruit ® https://www.adafruit.com/product/3283 4‐12‐17
很抱歉,暂时无法提供与“3283”相匹配的价格&库存,您可以联系我们找货
