Kelvin Clip
PRODUCT ID: 3313
Description
Kelvin clips are used whenever you need to get a measurement right at the contact points of a circuit or
component. Even though these are grippy clips, each side of the clip is electrically insulated. So you can
use it to grab onto a part (as seen above) and perform measurements. These can also be used in circuit if
needed.
The clip is bare and comes with two jaw contacts that are screwed into each side of the plastic clip. No
wires are included, but you can easily solder to the clip jaws.
Technical Details
Product Dimensions: 51.5mm x 25.0mm x 12.4mm / 2.0" x 1.0" x 0.5"
Product Weight: 5.5g / 0.2oz
Engineered in NYC Adafruit ® https://www.adafruit.com/product/3313 5‐19‐17
很抱歉,暂时无法提供与“3313”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+22.021551+2.86273
