AV (NTSC or PAL) to HDMI (720p or 1080p)
Video and Audio Adapter
PRODUCT ID: 3378
Description
Do you have an older electronic device that isn't compatible with your HDMI equipment? Here's an adapter
that will allow you to convert your older composite AV-output devices on modern TVs and monitors.
Perfect for reviving or re-using your older pieces of equipment that might not have an HDMI output (like
an old computer or game system).
This plug-and-play adapter takes 3-wire composite input: NTSC or PAL video on yellow, then left and
right audio on the red and white RCA connectors. The video is then converted to HDMI and piped out the
other side. Audio is added to the HDMI signal so you can use this with monitors or TVs that have built in
speakers. Or, grab the audio from the 3.5mm audio jack. You can select 720p or 1080p output by pressing
the little button on the side. Both video and audio are integrated into the HDMI output, providing an alldigital signal to maximize the fidelity of the audio and video.
Note that this converter doesn't magically clean up NTSC signals and make them 720p/1080p. NTSC/PAL
video is much lower resolution, about 480p! While the output is in that format the video itself will still have
the same quality and resolution as the input.
Features
o
o
o
o
o
Video and audio output in 1080p or 720p digital HDMI format
Supports input video formats PAL, NTSC, and SECAM
3.5mm stereo audio output signal (use when connecting to DVI TV and monitor)
No need to install drivers! The adapter is portable, flexible, plug and play
Package includes: Converter and DC 5V/1A power supply
Technical Details
o
o
Adapter body dimensions: 70mm x 76mm x 26mm
Power cable length: 48"
Engineered in NYC Adafruit ® https://www.adafruit.com/product/3378 4‐14‐17
很抱歉,暂时无法提供与“3378”相匹配的价格&库存,您可以联系我们找货
